ADMIN LOGLEVEL 0 1
30 Jul 2021 06:29 #216318
by Clive S
ADMIN LOGLEVEL 0 1 was created by Clive S
How can I get to use ADMIN LOGLEVEL 0 1 in PP 2.0
I have been asked to run this in the MDI
31 Jul 2021 21:43 #216506
by rafferty
Replied by rafferty on topic ADMIN LOGLEVEL 0 1
On v2.8.1 typing ADMIN LOGLEVEL in the MDI box show the current loglevels on the status page.
Typing ADMIN LOGLEVEL 0 1 reports linuxcnc loglevel changed to 0, hal loglevel changed to 1.
Also tried a few other values.
Same info is written to ~/gcode/pathpilotlog.txt, here's the relevant part with the time stamps removed:
Ken.
ADMIN LOGLEVEL [/home/operator/v2.8.1/python/ui_common.py:3737]
Current ADMIN LOGLEVEL for linuxcnc = 0x0 [/home/operator/v2.8.1/python/admincmd.py:994]
Switched to notebook page: alarms_fixed [/home/operator/v2.8.1/python/ui_common.py:6816]
Current ADMIN LOGLEVEL for hal = 0x0 [/home/operator/v2.8.1/python/admincmd.py:995]
Switched to notebook page: notebook_main_fixed [/home/operator/v2.8.1/python/ui_common.py:6816]
ADMIN LOGLEVEL 0 1 [/home/operator/v2.8.1/python/ui_common.py:3737]
ADMIN LOGLEVEL changed linuxcnc level from 0x0 to 0x0 [/home/operator/v2.8.1/python/admincmd.py:1016]
ADMIN LOGLEVEL changed hal level from 0x0 to 0x1 [/home/operator/v2.8.1/python/admincmd.py:1017]
Must take machine out of estop before jogging. [tormach_mill_ui.py:4348]
ADMIN LOGLEVEL 0 6 [/home/operator/v2.8.1/python/ui_common.py:3737]
ADMIN LOGLEVEL changed hal level from 0x1 to 0x6 [/home/operator/v2.8.1/python/admincmd.py:1017]
ADMIN LOGLEVEL 0X3 [/home/operator/v2.8.1/python/ui_common.py:3737]
Unrecognized ADMIN LOGLEVEL command. Try
ADMIN LOGLEVEL [value] [value]
where [value] is a hexadecimal value. [/home/operator/v2.8.1/python/admincmd.py:1021]
ADMIN LOGLEVEL 1 8 [/home/operator/v2.8.1/python/ui_common.py:3737]
ADMIN LOGLEVEL changed linuxcnc level from 0x0 to 0x1 [/home/operator/v2.8.1/python/admincmd.py:1016]
ADMIN LOGLEVEL changed hal level from 0x6 to 0x8 [/home/operator/v2.8.1/python/admincmd.py:1017]
Ken.
31 Jul 2021 22:01 #216511
by Clive S
Thanks for the reply.
My problem is that Pathpilot V 2 (on my system) does not accept the command ADMIN LOGLEVEL 0 1 in the MDI
Replied by Clive S on topic ADMIN LOGLEVEL 0 1
ADMIN LOGLEVEL [/home/operator/v2.8.1/python/ui_common.py:3737] Current ADMIN LOGLEVEL for linuxcnc = 0x0 [/home/operator/v2.8.1/python/admincmd.py:994] Switched to notebook page: alarms_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] Current ADMIN LOGLEVEL for hal = 0x0 [/home/operator/v2.8.1/python/admincmd.py:995] Switched to notebook page: notebook_main_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] Switched to notebook page: alarms_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] Switched to notebook page: notebook_main_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] ADMIN LOGLEVEL 0 1 [/home/operator/v2.8.1/python/ui_common.py:3737] ADMIN LOGLEVEL changed linuxcnc level from 0x0 to 0x0 [/home/operator/v2.8.1/python/admincmd.py:1016] Switched to notebook page: alarms_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] ADMIN LOGLEVEL changed hal level from 0x0 to 0x1 [/home/operator/v2.8.1/python/admincmd.py:1017] Switched to notebook page: notebook_main_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] Must take machine out of estop before jogging. [tormach_mill_ui.py:4348] Switched to notebook page: alarms_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] Switched to notebook page: notebook_main_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] ADMIN LOGLEVEL 0 6 [/home/operator/v2.8.1/python/ui_common.py:3737] ADMIN LOGLEVEL changed linuxcnc level from 0x0 to 0x0 [/home/operator/v2.8.1/python/admincmd.py:1016] Switched to notebook page: alarms_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] ADMIN LOGLEVEL changed hal level from 0x1 to 0x6 [/home/operator/v2.8.1/python/admincmd.py:1017] Switched to notebook page: notebook_main_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] ADMIN LOGLEVEL 0X3 [/home/operator/v2.8.1/python/ui_common.py:3737] Unrecognized ADMIN LOGLEVEL command. Try ADMIN LOGLEVEL [value] [value] where [value] is a hexadecimal value. [/home/operator/v2.8.1/python/admincmd.py:1021] Switched to notebook page: alarms_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] Switched to notebook page: notebook_main_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] ADMIN LOGLEVEL 1 8 [/home/operator/v2.8.1/python/ui_common.py:3737] ADMIN LOGLEVEL changed linuxcnc level from 0x0 to 0x1 [/home/operator/v2.8.1/python/admincmd.py:1016] Switched to notebook page: alarms_fixed [/home/operator/v2.8.1/python/ui_common.py:6816] ADMIN LOGLEVEL changed hal level from 0x6 to 0x8 [/home/operator/v2.8.1/python/admincmd.py:1017] Ken.
01 Aug 2021 08:01 #216585
by rafferty
OK, didn't realise V2 was literal.
Looking at admincmd.py, the ADMIN LOGLEVEL command arguments set debug levels, first is for linuxcnc, second if for HAL. Can't see how the linuxcnc argument is used (my python skills are woeful) but the second one I can follow.
In my 2.8.1 setup there is a HAL pin "tormach.debug-level", a u32. The second argument, a 1 in your case (can be any hex value) is written to this pin. I've verified this with halshow.
If this pin exists in your path pilotversion, you should be able to get the equivalent of ADMIN LOGLEVEL 0 1 (at least the 1 part) by manipulating the pin with halcmd,
In my setup the pin connects to zbotatc.debug-level and zbotschnozz.debug-level.
Moderators: cncbasher
Time to create page: 0.065 seconds
