External Coolant Controls
- davidimurray
- Thank you received: 5
15 Aug 2021 17:43 #217835
by davidimurray
External Coolant Controls was created by davidimurray
Hi All
After a hiatus, I'm back working on my new lathe. Having done some setup on the bench in Linuxcnc, I am now working on moving various functions into PP.
One thing I'm looking to do is add some external controls - in addition to the software controls. I can get either the external control, or the on-screen buttons to work. But not both together. Any help would be appreciated
Looking in the UI file - it appears PP looks at tormach.coolant-iocontrol
In the postgui file I have the following. The last two line are the original PP code. As shown, the code switches my coolant relay with the external switch but on-screen does not work. If I uncomment the original code - it complains about more than one pin being connected to the signal.
Any ideas would be much appreciated.
Dave
def on_coolant_button_release_event(self, widget, data=None):
# POSTGUI_HALFILE contains:
# net coolant-flood tormach.coolant => parport.0.pin-14-out
# net coolant-flood-io iocontrol.0.coolant-flood => tormach.coolant-iocontrol
# The UI code here watches tormach.coolant-iocontrol for changes from LinuxCNC.
# See the periodic handler for details
if not self.is_button_permitted(widget): return
self.window.set_focus(None)
# disable coolant lockout : if user commands coolant, do it immediately
self.coolant_lockout = 0
# use our tormach.coolant HAL pin to track actual coolant state
coolant_on = self.hal['coolant']
if not coolant_on:
self.hal['coolant'] = 1
else:
self.hal['coolant'] = 0
#coolant toggle section#
loadrt toggle2nist count=1
loadrt edge count=1
addf toggle2nist.0 servo-thread
addf edge.0 servo-thread
net coolant-flood <= iocontrol.0.coolant-flood
# Coolant switch
net flood-button <= hm2_7i76e.0.7i76.0.0.input-06 => edge.0.in
net button-edge <= edge.0.out => toggle2nist.0.in
net flood-on <= toggle2nist.0.on => halui.flood.on
net flood-off <= toggle2nist.0.off => halui.flood.off
net flood-control <= halui.flood.is-on => toggle2nist.0.is-on
#original tormach code below here
#net coolant-flood tormach.coolant
#net coolant-flood-io iocontrol.0.coolant-flood => tormach.coolant-iocont
Dave
15 Aug 2021 19:31 #217840
by nkp
Replied by nkp on topic External Coolant Controls
self.hal = hal.component("tormach")
self.hal.newpin("coolant", hal.HAL_BIT, hal.HAL_OUT)
self.hal.newpin("coolant-iocontrol", hal.HAL_BIT, hal.HAL_IN)
self.hal.newpin("coolant-tgbutton", hal.HAL_BIT, hal.HAL_IN) #nkp
# initial hal states:
self.prev_coolant_iocontrol = self.hal['coolant'] = 0
self.prev_coolant_tgbutton = 0 #nkp https://forum.linuxcnc.org/pathpilot/43326-external-coolant-controls
if self.prev_coolant_iocontrol != self.hal['coolant-iocontrol']:
if self.hal['coolant-iocontrol']:
else:
# current becomes previous
self.prev_coolant_iocontrol = self.hal['coolant-iocontrol']
# nkp https://forum.linuxcnc.org/pathpilot/43326-external-coolant-controls
if self.prev_coolant_tgbutton != self.hal['coolant-tgbutton']:
if self.hal['coolant-tgbutton']:
else:
self.prev_coolant_tgbutton = self.hal['coolant-tgbutton']
net tgb tormach.coolant-tgbutton
loadusr sim_pin tgb
16 Aug 2021 13:26 #217881
Replied by andypugh on topic External Coolant Controls
I use a 3-position switch and a mux component for this.
In the central "auto" position the mux passes through the iocontrol.0.coolant-flood signal.
Then the off input is simply setp to 0, and on to 1. So I can either leave the coolant under software control, or force it on or off.
(Note that this is done with a mux-generic component, that can be configured for bit-type signals.)
- davidimurray
16 Aug 2021 20:07 #217915
by davidimurray
Replied by davidimurray on topic External Coolant Controls
Thanks nkp - I tried for a few hours to get the code to work but I could not get it to switch with the external switch.
Andy - being cheeky would you have a sample of the code you use. I am a relative newbie to HAl and tried tonight to use mux-generic but think I confused myself!
Thanks both
Thanks both
16 Aug 2021 21:17 #217916
loadrt mux_generic config="bb4"
addf mux-gen.00 servo-thread
net coolant-off hm2_7i84.008a.input-25 => mux-gen.00.sel-bit-00
net coolant-on hm2_7i84.008a.input-26 => mux-gen.00.sel-bit-01
net coolant-flood mux-gen.00.out-bit => hm2_7i84.008a.output-08
net coolant-auto iocontrol.0.coolant-flood => mux-gen.00.in-bit-00
setp mux-gen.00.in-bit-01 0
setp mux-gen.00.in-bit-02 1
setp mux-gen.00.in-bit-03 0
- davidimurray
19 Aug 2021 20:16 #218176
by davidimurray
Thanks Andy
I've been having a play and can get the external switch working, but not with the onscreen button. After some work, I;ve got HALshow working. And looking at the pins tormach.coolant seems to be the one that changes with the onscreen button.
I've tried changing
to
net tormach.coolant => mux-gen.00.in-bit-00
but that doesn't work - any ideas much appreciated.
I've tried changing
to
19 Aug 2021 23:45 #218188
How doesn't it work? Is there an error message?but that doesn't work
- davidimurray
20 Aug 2021 11:28 #218230
by davidimurray
No error message. Pathpilot starts fine. When I toggle the on screen button, I can see tormach.coolant change states, but the output from the MUX does not change. If i use my external switch then the MUX output does change.
20 Aug 2021 11:31 #218231
What is the state of the mux select inputs in the "auto" position? perhaps toemach,coolant needs to go to in-bit-03
- davidimurray
20 Aug 2021 11:53 #218234
by davidimurray
I will have a play later when I get back from work and try changing the bit
Moderators: cncbasher
Time to create page: 0.132 seconds
