External Reset Button
- davidimurray
- Thank you received: 5
29 Aug 2021 19:31 #219119
by davidimurray
External Reset Button was created by davidimurray
My adventures with pathpilot continue - I am now trying to add an external button to do the on-screen reset. I am struggling to find what the correct pin is from the GUI to activate to get the reset conditon. Does anyone have any ideas?
Dave
Dave
29 Aug 2021 21:03 #219125
by smgvbest
Replied by smgvbest on topic External Reset Button
Thats in the HAL for your Mill/Lathe
here's from the MILL
# E stop
# P3 pin 15 gpio 003
# estop noise debounce
# use this line with a machine attached
net machine-ok-raw <= hm2_[HOSTMOT2](BOARD).0.gpio.003.in_not => debounce.0.3.in
# E stop
- davidimurray
30 Aug 2021 09:35 #219155
by davidimurray
Replied by davidimurray on topic External Reset Button
I've got that line hooked up to my E-stop button which seems to work correctly. But you then need to click the on-screen reset button to get the machine out of the Estop state - it is this reset I am trying to replicate with an external button.
The code below appears in the e-stop section
I've tried directly connecting my input pin from the 7i76e to estop-latch.0.reset and I can see the reset bit toggle and also the the ok-out bit change - but this doesn't clear the 'reset' condition in PP and the rest on-screen button continues to flash.
net estop estop-latch.0.ok-out => iocontrol.0.emc-enable-in => hm2_7i76e.0.7i76.0.0.output-07 => pwmgen.00.enable
net estop-reset iocontrol.0.user-request-enable => estop-latch.0.reset
- davidimurray
06 Sep 2021 20:01 #219786
by davidimurray
So far from all my research it looks like there is not the capability to setup a reset button without some Python work.
I've created a new Hal-Pin called ext-reset and linked this to my pushbutton. I can see that this is working in halshow
Apologises for the stupid question but I'm a noob to Python. how do I call the reset function? The function is setup asdo i just need :
Any help much appreciated
def on_reset_button_release_event(self, widget, data=none):
if self.hal['ext-reset'] ==1:
self.call_ui_hook('reset_button')
10 Sep 2021 00:10 #220090
by gerritv
Replied by gerritv on topic External Reset Button
I used this inside ui_common.py
self.enqueue_button_press_release(self.button_list)
when I was playing with the console modifications.
Gerrit
Gerrit
- davidimurray
13 Sep 2021 18:13 #220480
by davidimurray
That's brilliant - thanks for that gerrit - now have the external reset button working
The following user(s) said Thank You: gerritv
Moderators: cncbasher
Time to create page: 0.078 seconds
