Pathpilot RPI
05 Sep 2021 14:04 #219671
by jbunch
Pathpilot RPI was created by jbunch
Will Pathpilot run on an RPI system?
Jim
Jim
05 Sep 2021 15:54 #219680
by smgvbest
Replied by smgvbest on topic Pathpilot RPI
It would not run natively. you would need the Source and build a RPI version.
The biggest issue is PP runs with a real time kernel and I do not think a RT Kernel is available for RPI. But I've not tracked it and do see a RPI forum here where you could get help there for the RPI part
That said.if you're not going to use any of PP modules. you copy everything but those. edit your hal files to remove them. edit to some python and you might get a working version. NOTE: this is not tested. just a thought
05 Sep 2021 19:39 #219693
Replied by PCW on topic Pathpilot RPI
There are certainly real time kernels for the RPI
LinuxCNC has been runnning on RPI3 and RPI4
for a few years already
Not sure how much of a challenge it would be to get the
PathPilot build/run environment put together on a RPI
though...
though...
05 Sep 2021 20:47 #219698
by jbunch
Replied by jbunch on topic Pathpilot RPI
Thank you for your replies.
I am not so worried about the Real time or Linux kernel for the RPI and installing LinucCNC.
I am more worried about the PathPilot portion and if any of it is compiled for x86 and would not run on the RPI.
If not x86 specific you should be able to find and move the PathPilot files to the new machine.
Or is the source available to recompile PathPilot?
Jim
Jim
05 Sep 2021 21:26 #219701
by Aaroncnc
Replied by Aaroncnc on topic Pathpilot RPI
The problem may actually be the open gl / mesa support.
Rpi4 dose not have full open gl support.
05 Sep 2021 22:48 #219705
by jbunch
Thank you for your reply.
I have purchased mesa 7c80 for this project. From going thru the threads it looks like most of the mesa hardware can be made to work. If not what would be recommended mesa hardware?
Jim
Jim
- Thank you received: 5944
05 Sep 2021 22:56 #219707
www.mesa3d.org/
Replied by tommylight on topic Pathpilot RPI
Aaroncnc was not refering to Mesa boards, he was refering to this:The problem may actually be the open gl / mesa support.
www.mesa3d.org/
05 Sep 2021 23:23 #219710
by Aaroncnc
That's correct sorry for the confusion.
I have had some troubles getting some control panels to run.
Some won't run at all other have non working screen elements.
It depends on what elements they used and how they are programmed.
I have thought about ordering a copy of pp to see if I could get it to run but have not had the time.
I got fed up enough the go deep into the axis gui and chage it to a dark theme and added more options widgets.
05 Sep 2021 23:38 #219711
Nothing to be sorry about, i just got the impression he took it as MesaNet .
Thank you for helping.
Now, what is that talk of dark Axis GUI????
That i want!
That i want!
06 Sep 2021 00:46 #219712
by Aaroncnc
Here is the thread I made about it for those interested in a dark theme and advanced color options for pyvcp widgets
forum.linuxcnc.org/22-pyvcp/42616-added-...pyvcp-widgets#209658
Moderators: cncbasher
Time to create page: 0.117 seconds
