UnyTouch Touchscreen Driver Install
04 Nov 2021 04:09 #225196
by libbybapa
UnyTouch Touchscreen Driver Install was created by libbybapa
Hello, I recently acquired a Tormach 1100 S3. I have a UnyTouch U41-T190DS-SBL touchscreen monitor I would like to use with it. I have installed the touchscreen on a Windows machine and it works fine. I have never used any machine with Linux before. When hooked up to the PathPilot controller, I cannot get it to calibrate. When I enter ADMIN TOUCHSCREEN it enters the calibration screen correctly and allows me to select the first point. It does not accept the second point, although each time I touch the second point, it resets the timer so it is registering a touch. I assume it is a driver issue. I downloaded what I believe to be the correct Linux driver for the touchscreen but I have no idea how to get the driver installed on the PathPilot controller. Any assistance in how to proceed would be greatly appreciated.
06 Nov 2021 15:29 - 06 Nov 2021 15:30 #225504
by libbybapa
Replied by libbybapa on topic UnyTouch Touchscreen Driver Install
I did more experimenting and the cursor definitely responds to the touch movements but it is completely out of calibration, and apparently far enough out that the on-board PathPilot calibration is unsuccessful. I did more looking online and found where other people were successful with calibration of similar touchscreens but from what I saw those who were successful were using PathPilot 2.x.x. My machine is currently running PP 1.9.13, so I have ordered the updated version. I had planned to do the update anyway, so this just gave me added incentive to do it right away. I will report back when I get the update done and have a bit of time to do some further experimenting.
Last edit: 06 Nov 2021 15:30 by libbybapa.
09 Nov 2021 21:42 - 09 Nov 2021 21:43 #225880
by libbybapa
Just thought I would update this in case anyone runs into the same issue in the future. My upgrade to PathPilot 2 arrived today. I installed it and without doing anything other than running the on-board calibration (ADMIN TOUCHSCREEN), the touchscreen works perfectly!
Last edit: 09 Nov 2021 21:43 by libbybapa.
Moderators: cncbasher
