Launch PP from desktop?
05 Nov 2021 20:54 #225427
by 93xshang
Launch PP from desktop? was created by 93xshang
Hey all, did some search but didnt find anything so thought i'd create a post and ask.
I'm doing some modification to the PP on my 1100M machine, specifically, adding functions to the UI. However, is there a way to launch PP from desktop after I finished editing the .py and .glade files? I'm now restarting the controller each time when i need to test out my modifications but there must be a better way..
07 Nov 2021 15:49 - 07 Nov 2021 15:51 #225559
by sharmstr
Replied by sharmstr on topic Launch PP from desktop?
I havent done this in awhile but from my simulator notes
From PP: crtl-alt-x to bring up terminal
In terminal type:
In System -> Preferences ->All Applications remove PP from start up applications.
Add desktop launcher: Right click on desktop -> create launcher -> give it a name and add this command
I do all my dev at my windows desktop using virtual box using PP in simulator mode. Once its ready for the machine, I'll upload and test there. Google it if you are interested. Lots of us are doing it this way.
In terminal type:
/usr/bin/mate-panel
mate-terminal -x bash -c "~/operator_login"
Last edit: 07 Nov 2021 15:51 by sharmstr.
10 Nov 2021 19:31 #226027
by 93xshang
Replied by 93xshang on topic Launch PP from desktop?
Thanks sharmstr.
The simulation mode is definitely something I should consider. I just haven't yet gotten the PP installation USB key from Tormach. Is it possible to burn a installation disk from the controller or is getting the USB the only way?
10 Nov 2021 19:42 #226029
by sharmstr
Hmmm. Good question. I definitely had the upgrade USB. Not sure how its done with machines that came standard with 2.0+
10 Nov 2021 20:14 #226034
by 93xshang
Cool. i know there's recovery section on the controller but not sure if I can burn it on to boot loader USB.. Maybe I'll just get a PP USB then
02 Dec 2021 01:45 #228167
by plewis
Replied by plewis on topic Launch PP from desktop?
Hello sharmstr,
I'm working with 93xshang on the same project. I'm very curious how did you install PP in virtualbox? I've created a config with a VHD and added the bootable usb as VHD but when I boot, it does not want to install (or perhaps is not seeing the other VHD). I'm trying to create an image now to mount as a DVD or floppy, but could really use some advice or instructions if possible please.
Thanks!
Thanks!
02 Dec 2021 01:50 #228168
by sharmstr
Here's a link to an old discussion where I explain what I had to do. Things may have changed since then: www.cnczone.com/forums/tormach-pathpilot...r-4.html#post2111468
15 Jan 2022 04:13 #231857
by RandyJ
Replied by RandyJ on topic Launch PP from desktop?
I have had good luck with holding alt-leftshift while booting to go to desktop when I want to edit files. After bringing up the terminal you can just type in:
./operator_login
This has worked for me. Up arrow in the term will repeat the PP launch. You might have to use it many times if adapting to other hardware:)
./operator_login
Moderators: cncbasher
Time to create page: 0.157 seconds
