PathPilot 2.0 with a standard parallel card
06 Jan 2022 02:02 #230921
by leedgtm
PathPilot 2.0 with a standard parallel card was created by leedgtm
3 questions. 1. If you have been using Pathpilot wit a standard parallel card, have you found it to be stable? 2. Is there something like Stepconf that allows you to set the pins, dir, step, pulses, etc? If they are hard coded, where are they? 3. Does the EStop pin need to be taken to ground or to plus 5V to send a reset to Tormach.
15 Jan 2022 04:06 #231856
by RandyJ
Replied by RandyJ on topic PathPilot 2.0 with a standard parallel card
It has been very stable for me. I have had a bit of lag in the screen XYZ numbers at time, but the output of the steps seems perfect.
To start looking around hit alt-left shift while PP is booting. Start a file manager in the operator folder. Files that will enlighten you are:
/operator/pathlilot.json (will point to first config file in configs)
/operator/tmc/configs/tormach_mill/ (ini and hal files for all models here)
Follow instructions from thread and add yours here. Gedit is a wonderful editor for these .ini and hal files.
To test your files open terminal and type in: ./operator_login
The configurations for the are in the /tmc/configs/tormach_mill
This will depend on your controller input type and mapping of pins. The sense can be inverted in software. On my Gecko540 is is shorted to ground. This produces a one on the input and the represents Estop_OK to the system.
Hope that gets you started.
Moderators: cncbasher
Time to create page: 0.064 seconds
