Arduino running PathPilot ATC
23 Jan 2022 01:17 #232853
by Vmax549
Arduino running PathPilot ATC was created by Vmax549
Does anyone know the howsto to making an Arduino run the PathPilot ATC ??
( TP
( TP
23 Jan 2022 01:33 - 23 Jan 2022 01:37 #232855
by smgvbest
Replied by smgvbest on topic Arduino running PathPilot ATC
Do you mean a Real Tormach ATC? Lathe or Mill?
I know for the Lathe ATC, PPĀ Outputs a PWM signal that does 10% Tool1, 20% Tool2 thru 80% Tool8 then 90% No Tool
I haven't looked at the Mill one as much (or at all yet)
The ATC itself (Lathe) sends each tool as a induvial signal to the Lathe Control Board.
and is driven with a reversible drive circuit UVW
Last edit: 23 Jan 2022 01:37 by smgvbest.
23 Jan 2022 15:42 #232884
by Vmax549
Replied by Vmax549 on topic Arduino running PathPilot ATC
I was thinking about a MILL atc.. Mainly if there was a Arduino out there that could talk to PathPilot and really only do the carrosel rotations. I have plenty of unused I/O available from the 7i80 to 2work the rest of the ATC. That way I can use all of the facilities from PathPilot to run the act. IF if could fool PP into thinking there is an ATC and to load all the resources and make them active.. At one time I had PP running the atc stuff without an ATC card but can't remember now exactly how I did that. IF you check the atc box it tries to load it but cannot find it and reverts back to a normal mill screen.
Just a thought, ( TP
Moderators: cncbasher
Time to create page: 0.157 seconds
