User Interfaces
PathPilot
Torrmach Path Pilot usb problem (SOLVED)
Thank you received: 475
15 Apr 2022 17:22 - 16 Apr 2022 13:29 #240329
by Clive S
Ok my hard drive went down I have the USB from Torrmach and and flashed another drive with it.
The problem is that when it it booting it pops and error say something like "check the ethernet cable between the pc and controller.
My machine is using a mesa 5i25 connected to the controller.
How can I get round this issue ?
(Solved) I was using the Tormach USB to flash another drive in a different PC to that of the PC on the Tormach
when I flashed with the USB with the drive in the Tormach PC it found the 5i25
(Solved)
Last edit: 16 Apr 2022 13:29 by
Clive S.
User Interfaces
PathPilot
Time to create page: 0.076 seconds
