Path pilot with 7i92tm and 7i77
- austin1366
25 Mar 2023 00:35 - 25 Mar 2023 00:38 #267437
by austin1366
Path pilot with 7i92tm and 7i77 was created by austin1366
About to start retrofiting another mill with analog dc servos to linux cnc and id like to use path pilot. I'm thinking id like to use
7I92TM Anything I/O Ethernet card 1x DB25 Male, 1x 26 pin header
and a
7I77 Analog servo interface plus I/O daughtercard - Sourcing output version.
Are these cards compatible with path pilot? Or there a better card combo i should be looking at to achieve this?
Thank You
Austin
Thank You
Austin
Last edit: 25 Mar 2023 00:38 by austin1366.
- Thank you received: 5949
25 Mar 2023 20:29 #267497
Replied by tommylight on topic Path pilot with 7i92tm and 7i77
Is there a way to check if any of the existing Tormach machines use that combo?
25 Mar 2023 21:43 #267502
Replied by PCW on topic Path pilot with 7i92tm and 7i77
Pretty sure a 7I92T[X] will be detected as a 7I92 which PathPilot supports
You will need to disable PathPilots re-flashing script and the hal/ini files
will have to be created by LinuxCNC tools with any PathPilot specific bits
copy-pasted froma stock PathPilot configuration file set,
- austin1366
27 Mar 2023 05:50 #267584
by austin1366
Replied by austin1366 on topic Path pilot with 7i92tm and 7i77
Wasn't sure if the 7i92tm showed up the same or not. But if needed i have a old 7i92 on another machine i can swap. Are yall thinking that the daughter card doesn't matter to pathpilot?
27 Mar 2023 15:36 #267612
The 7I92T should show up as a 7I92 to Path Pilot (It does to LinuxCNC)
Moderators: cncbasher
Time to create page: 0.217 seconds
