Installing PathPilot 2.0 VM using VirtualBox
- snowgoer540
- Topic Author
- Thank you received: 746
05 Apr 2023 01:17 - 05 Apr 2023 01:20 #268306
by snowgoer540
Installing PathPilot 2.0 VM using VirtualBox was created by snowgoer540
Please see the attached guide.
Last edit: 05 Apr 2023 01:20 by snowgoer540.
07 May 2023 15:10 #270865
by gerritv
Replied by gerritv on topic Installing PathPilot 2.0 VM using VirtualBox
Excellent, I used a similar process to run PP in VMWare.
Gerrit
Gerrit
- snowgoer540
- Topic Author
10 Sep 2023 15:27 #280404
by snowgoer540
Replied by snowgoer540 on topic Installing PathPilot 2.0 VM using VirtualBox
I have recently been frustrated with mouse scrolling (that I don't remember having issue with previously). It would sometimes jump up a few lines, or erratically jiggle the text up and down.
Found a solution, which is to install "imwheel" so I thought I would share:
Run it:
Now you just need to add it to the startup applications:
Mint menu -> Startup Applications. Click "Add". For both "Name:" and "Command:" enter "imwheel". Click "Add".
This fix should now persist after restarting.
Credit (though the only thing to do was install imwheel): here
sudo apt-get install imwheel
Run it:
imwheel
The following user(s) said Thank You: tommylight, MarkoPolo
Moderators: cncbasher
Time to create page: 0.105 seconds
