Changing the default Jog Increment
07 Apr 2023 20:05 #268543
by Vmax549
Changing the default Jog Increment was created by Vmax549
Has anyone ran across the section of code where PathPilot sets the Default Jog increment to .0001 ?? I would really like to change that.
( TP
( TP
- Thank you received: 5946
07 Apr 2023 20:25 #268545
Replied by tommylight on topic Changing the default Jog Increment
LinuxCNC has those in the ini file, no idea if they are in Path Pilot there or not.
Should be, though.
Should be, though.
- snowgoer540
- Thank you received: 749
07 Apr 2023 20:48 #268549
by snowgoer540
If you are using a mill, it sets it in: /python/tormach_mill_ui.py
If you are using plasma, it sets it in: /python/tormach_plasma_ui.py
If you are using lathe, it sets it in: /python/tormach_lathe_ui.py
The line is common to all of them:
It doesnt matter if you use imperial or metric, left to right the four jog increments are 0, 1, 2, 3.
Change the value to whatever you want to be selected when you start PathPilot.
As always, backup before changes, and this will be wiped out with upgrades, etc.
Replied by snowgoer540 on topic Changing the default Jog Increment
( TP
self.hal['jog-gui-step-index'] = 0
08 Apr 2023 15:45 #268614
by Vmax549
Replied by Vmax549 on topic Changing the default Jog Increment
Thanks SNOW, I had search the UI file but used the wrong search words.
That did the trick
( TP
That did the trick
( TP
Moderators: cncbasher
Time to create page: 0.144 seconds
