Dropped off a code snippet and it is wrong when saved
09 Apr 2023 20:06 #268707
by Vmax549
Dropped off a code snippet and it is wrong when saved was created by Vmax549
I just dropped off a new code snippet and it was correct until I saved then it deleted part of the code on one line. I then edited and the same thing happened. On the edit screen the code was correct until I saved it then part of one line is missing ???
( TP
( TP
- Thank you received: 5946
09 Apr 2023 20:39 #268711
Replied by tommylight on topic Dropped off a code snippet and it is wrong when saved
Use
[ code ]
Whatever code you want to post
[ / code ]
With no spaces.
But first, click on "source" on the top left side of the editor.
[ code ]
[ / code ]
With no spaces.
- snowgoer540
- Thank you received: 749
09 Apr 2023 21:29 #268715
by snowgoer540
Replied by snowgoer540 on topic Dropped off a code snippet and it is wrong when saved
The editor is kind of a colossal POS for editing posts and what not.
Like tommy said, I do it manually using the source and the code /code examples Tommy said.
The indentations will stay, but only on first posting, if you edit it, they go away. Also, if you edit it, everything goes to hell. So, I try my best to get it right the first time, so I dont suffer the editor. But it rarely goes as planned
09 Apr 2023 23:03 #268725
by Vmax549
Replied by Vmax549 on topic Dropped off a code snippet and it is wrong when saved
And here I thought moving to the Darkside was going to be uneventful
I will give it a try, ( TP
09 Apr 2023 23:07 #268726
by Vmax549
OK that fixed the problem . Another page to add to the" 999 things you need to know about LinuxCNC" manual
Thanks Guys, ( TP
Thanks Guys, ( TP
Moderators: cncbasher
Time to create page: 0.149 seconds
