Starting Wizards up again??
10 Apr 2023 12:48 #268754
by Vmax549
Starting Wizards up again?? was created by Vmax549
Is anyone interested in getting Wizards up and running again ??? Do you have a favorite function the conversational pages do not cover and you would like to see as a wizard ??
( TP
( TP
- snowgoer540
- Thank you received: 750
10 Apr 2023 13:35 #268755
by snowgoer540
Replied by snowgoer540 on topic Starting Wizards up again??
I’m not sure I’m aware of these wizards you speak of?
10 Apr 2023 22:57 #268793
Replied by cmorley on topic Starting Wizards up again??
This one?
github.com/LinuxCNC/wizards
11 Apr 2023 02:29 #268800
by Vmax549
Replied by Vmax549 on topic Starting Wizards up again??
They were also know as Gcode Generators , Conversational Wizards. When called a window opens up and all the parameters to do the function are displayed. You then fill in the blanks and the Wizard will generate the Gcode program for you ready to run.
The advantage over having a Conversational section in the control is IF there is no function that you need, you are out of luck. With Wizards you can build it once and have it forever. Also you can share Wizards with others. If you need a special function to make life easier MAYBE someone has already made it.???
Conversational programming has been around for a long time now. Wizards just make it easier to have.
Just my Opinion, Your mileage may vary.
( TP
( TP
11 Apr 2023 02:46 #268802
by Vmax549
Here are some examples.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple...tors#Facing_Software.
Personally I do not do the drawing part I just program out the Gcode . You can see the pathways when you load it in PathPilot. That makes it simpler to create.
( TP
( TP
11 Apr 2023 04:34 #268804
These then:
github.com/LinuxCNC/simple-gcode-generators
Moderators: cncbasher
Time to create page: 0.240 seconds
