Change Work Offsets from a hotkey
28 Apr 2023 23:39 #270145
by Vmax549
Change Work Offsets from a hotkey was created by Vmax549
IF anyone is interested in changing their work offsets (G54,G55,etc) from a hotkey. I will post the code to the toolbox.
There are 2 versions. One version uses the tenkey keypad section numbers 1-9 and the second version uses the keyboard numbers 1-9
It is design if you press ctrl_4 then it switches to G54 IF ctr_5 it switches to G55 etc etc >>>>>>>>>> IF Ctrl_1 it switches to g59.1 etc
I guess I could combine the functions into 1 so that either selection worked
( TP
( TP
- snowgoer540
- Thank you received: 750
30 Apr 2023 20:55 #270337
by snowgoer540
Replied by snowgoer540 on topic Change Work Offsets from a hotkey
I think whatever you're willing to share, someone may get use of later, even if they arent around currently to comment that they want it
01 May 2023 07:28 #270385
by Vmax549
Replied by Vmax549 on topic Change Work Offsets from a hotkey
I'll drop the combined code in the toolbox.
( TP
( TP
Moderators: cncbasher
Time to create page: 0.138 seconds
