Button Function Touch_Z
03 May 2023 14:48 - 03 May 2023 22:31 #270571
by Vmax549
Button Function Touch_Z was created by Vmax549
I have a question about the coding for this. I have it working BUT it is ugly.
Is there a way to just link to the button instead of actually changing page to make it work. If you run just the Touch_z button code from the main page it errors saying it needs the Widget. Which mean it need to be on the same page as the button.. So I then pushed it to the page ran the button then switched back to the main page. I just wanted to clean it up if I could.
This programming is tough stuff for an old codger.
( TP
ui_misc.set_current_notebook_page_by_id(self.notebook, 'notebook_offsets_fixed')
ui_misc.set_current_notebook_page_by_id(self.offsets_notebook, 'tool_offsets_fixed')
self.enqueue_button_press_release(self.button_list['touch_z'])
ui_misc.set_current_notebook_page_by_id(self.notebook, 'notebook_main_fixed')
( TP
Last edit: 03 May 2023 22:31 by snowgoer540.
- snowgoer540
- Thank you received: 749
03 May 2023 22:40 #270592
by snowgoer540
Replied by snowgoer540 on topic Button Function Touch_Z
There's always more than one solution. So I'll give you two.
Your code emulates the button press through tormach's enqueue method. It emulates a mouse click on the button, so it needs to be on the right page to do that. Also, the code checks if it's allowed.
So options are:
1. call the function that does the work directly, after modifying it to not check if you're on the right page:
Before:
After:
Then call the function like this:
Of course you can chance Vmax549 to whatever you'd like, you're just passing it a bogus widget name for your check
2. Copy the code in that button check, and make a new function
Call the function like this:
That's 2 of probably 1000 ways to skin the proverbial cat. If you choose the new function route, you could probably pull some lines out that may not be necessary (like the focus grabs and releases, etc.), but I dont know without playing with it/looking at it harder.
So options are:
Before:
def on_touch_z_button_release_event(self, widget, data=None):
if not widget == 'Vmax549':
if not self.is_button_permitted(widget): return
valid, dro_val, error_msg = self.conversational.validate_z_touch_val(self.dro_list['touch_z_dro'])
if not valid:
self.error_handler.write(error_msg, ALARM_LEVEL_LOW)
return
ind = 2
# the G10 command wants values in mm if G21, but actual_postion and g5x_offsets are in machine units (in.)
# so we take the sup value and turn it into machine units, then send the offset command in g20/21 units
supplemental_offset = dro_val / self.get_axis_scale(ind)
tool_number = self.status.tool_in_spindle
# g10 doesn't like tool number = zero, and tool number will be -1 in some cases on startup
if tool_number < 1:
self.error_handler.write('Cannot set tool offset for tool zero. Please enter a valid tool number in the tool DRO before using Touch Z button', ALARM_LEVEL_MEDIUM)
return
z_offset = self.status.actual_position[ind] - self.status.g5x_offset[ind] - supplemental_offset
z_offset = z_offset * self.get_axis_scale(ind)
# can't use self.issue_tool_offset_command() here as this takes L10, other calls take L1
g10_command = "G10 L10 P%d Z%f" %(tool_number, dro_val)
self.issue_mdi(g10_command)
self.command.wait_complete()
self.issue_mdi("G43")
self.dro_list['touch_z_dro'].set_text(self.dro_long_format % dro_val)
self.set_image('touch_z_image', 'touch_z_green_led.png')
self.window.set_focus(None)
# kludge for asyncronous refresh of tool table, handled in periodic
self.tool_liststore_stale = 2
After:
if not valid:
return
ind = 2
if tool_number < 1:
return
self.on_touch_z_button_release_event('Vmax549')
def terrys_touch_z(self):
if not valid:
return
ind = 2
if tool_number < 1:
return
self.terrys_touch_z()
- snowgoer540
03 May 2023 22:42 #270593
by snowgoer540
Oops, the BEFORE for Option 1 should actually be this:
I'd edit it, but the editor here ... sucks.
if not valid:
return
ind = 2
if tool_number < 1:
return
04 May 2023 12:20 #270636
by Vmax549
Replied by Vmax549 on topic Button Function Touch_Z
WOW we are way down that rabbit hole now. Thanks Gary. That makes sense now.
( TP
( TP
Moderators: cncbasher
