Can I have multiple commands on one MDI line (Custom M101?)
- nick.smith
- Thank you received: 4
07 May 2023 12:01 #270852
by nick.smith
I'd like to be able to perform several commands at once from the MDI line.
Something like: G91 X1 ; G54 ; G90
More or less, I want a small .nc file ran, but all on one line, without having to actually manually open the .nc.
Can I get machine movement via M101, M102, etc.
07 May 2023 13:43 #270859
by Vmax549
Replied by Vmax549 on topic Can I have multiple commands on one MDI line (Custom M101?)
You can build a custom Mcode to run a function or you can build a Sub routine to run a function. The difference is the Mcode has to be built ahead of time as it compiles on startup and can be either Gcode based or Python script based.
The Sub can be built and called anytime .
( TP
( TP
- nick.smith
07 May 2023 17:38 #270874
by nick.smith
Replied by nick.smith on topic Can I have multiple commands on one MDI line (Custom M101?)
Thanks man. I have it by typing
O<TEST> CALL
I've wanted that ability for years.
Is that the best way to go about it?
O<TEST> CALL
07 May 2023 19:40 #270890
by Vmax549
That is as good as any.
( TP
( TP
Moderators: cncbasher
