User Interfaces
PathPilot
Seperate Hotkey programing file.
Thank you received: 28
09 May 2023 21:25 #271065
by Vmax549
Does anyone have an idea on how to make PP process a seperate Hotkey programing file. The ldea is to crate a sperate file that contains the new hotkey scripts. THen have PP on load goto that FILE and load the contents into PP so it can be compiled with the rest of the Code. This would make adding Hotkeys much simpler to maintain.
In the Tormach_mill_ui in the section where hotkeys are generated (50ms loop)
####### Hotkeys for PP ********************************************************
step out to hotkey support file ( 'Hotkey_support_file') and load code from there
####### End Hotkey Loading ****************************************************
code
code
code
etc
etc
Just a thought , (
TP
User Interfaces
PathPilot
Time to create page: 0.058 seconds
