Debugging python code in remap.py, help
15 May 2023 00:13 #271378
by gerritv
Debugging python code in remap.py, help was created by gerritv
Hi
I am trying to debug some code in remap.py. Tried VSCode and WingIDE. Neither will breakpoint on code in remap.py except when it first gets loaded.
Anyone have hints on what works?
I tried adding PYTHON_TASK = 1 to the ini file but likely that is not implemented in this version of linuxcnc. I think this is supposed to keep the interpreter task visible as a process?
Gerrit
Gerrit
15 May 2023 00:29 #271379
by gerritv
Replied by gerritv on topic Debugging python code in remap.py, help
Of course as soon as I asked the question, I found a variable to set in wingdbstub.py
# (WINGDB_EMBEDDED environment variable)
kEmbedded = 1
Ref: wingware.com/doc/debug/debugging-embedded-code
kEmbedded = 1
15 May 2023 02:12 #271382
by Vmax549
Replied by Vmax549 on topic Debugging python code in remap.py, help
Are you trying to build a new tool change routine by remapping the M6 ?? If so there is an easy way to do that.
( TP
( TP
15 May 2023 10:21 #271390
by gerritv
Not so much new as adapting the router one to a gantry mill. I have an ER20 spindle. RapidChange is coming out with a rack to do tool changes. Much of what is in Tormach's remap for M6 stays the same.
Next big hurdle is Glade
Moderators: cncbasher
Time to create page: 0.173 seconds
