Reboot Command
21 Nov 2023 00:14 #286119 by Cyber
Reboot Command was created by Cyber
How can I issue a reboot command to the mesa's card? any recommendations
21 Nov 2023 00:33 #286124 by snowgoer540
Replied by snowgoer540 on topic Reboot Command
What are you trying to achieve? If you are trying to reboot after updating the firmware that won’t work as it requires a power cycle.
The following user(s) said Thank You: Cyber
21 Nov 2023 00:37 #286125 by Cyber
Replied by Cyber on topic Reboot Command
Thank you for replying, I'm actually trying to write a script to remotely reboot a CNC machine
21 Nov 2023 01:06 - 21 Nov 2023 01:38 #286127 by snowgoer540
sudo shutdown -r now
Will reboot a machine.
Last edit: 21 Nov 2023 01:38 by snowgoer540. Reason: add sudo... oops
  • Moderator
  • Moderator
21 Nov 2023 01:30 #286130 by tommylight
Replied by tommylight on topic Reboot Command
So does
sudo reboot
and both require sudo and password, otherwise they do not work.
The following user(s) said Thank You: snowgoer540, Cyber
21 Nov 2023 01:39 #286132 by snowgoer540
So does
sudo reboot
Thank you for reminding me I forgot sudo...
On a PathPilot machine, this is not true. both sudo shutdown -r now and sudo reboot will work without being prompted for a password.
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
21 Nov 2023 10:08 #286155 by rodw
Replied by rodw on topic Reboot Command
That can be setup by placing a file in /etc/sudoers.d
With Linuxcnc's raspberry pi Bookworm installer, this was the default behaviour and we removed the feature. (by deleting the user's file)
I think this link explains how to do it. But what would I know I only undid it!
forums.bunsenlabs.org/viewtopic.php?id=5503
This was our script to remove the file created by the default installer.
rm -f /p2/etc/sudoers.d/010_${USERNAME}-nopasswd
21 Nov 2023 21:51 #286199 by snowgoer540
That’s good to know, I will likely do that on my plasma and VMs.  Typing the password is annoying.
Thanks for the heads up Rod.
Time to create page: 0.087 seconds
