M19 spindle orientation on slant pro lathe
30 Mar 2024 17:16 #297221
by Sdubfid
M19 spindle orientation on slant pro lathe was created by Sdubfid
Is anyone able to make m19 spindle orientation work on the slant pro 15 lathe? The lathe has an encoder and I believe the mx machines use m19 to rotate the spindle for tool changes.
This would be a good feature for broaching on the lathe even if I need to lock the spindle after each rotation.
- gilesclement
13 Apr 2024 14:10 #298166
by gilesclement
Replied by gilesclement on topic M19 spindle orientation on slant pro lathe
I'm also curious about using M19 for broaching on a 3 axis mill running a servo spindle. Seems like it should work but not sure how to execute.
Moderators: cncbasher
