Rounding corners
- Thank you received: 1466
21 Jul 2017 11:46 #96215
Replied by Todd Zuercher on topic Rounding corners
Which problem? The rouding corners? You still need to specify an appropriate G64Pn setting.
Or the slow downs at segment ends while milling your "curve"? You may need to specify a different G64Pn setting for that section of code as you may need more blending at these corners in order to maintain a constant speed and smooth out the kinks you've programed into that code.
- NikolayShopov
16 Nov 2017 07:34 #101878
by NikolayShopov
Replied by NikolayShopov on topic Rounding corners
i think the problem is from how i generate my g-code, and how i describe the roundings and and circles.
- NikolayShopov
16 Nov 2017 07:36 #101879
by NikolayShopov
Can someone give me advice for a free software for g-cod generating.Because my program is slef made (from my frined programer) .
- Thank you received: 4118
16 Nov 2017 09:27 #101883
Replied by rodw on topic Rounding corners
Why don't you try the freeware version of Sheetcam? There is a limit on the number of lines of code it will generate, but for small one off jobs, it will probably be enough. Other than that you could try Fusion 360 but I think making a POST for your machine might be harder.
The following user(s) said Thank You: NikolayShopov
