CNC Plasma cutters, DIY, building info and guide
- Mike_Eitel
- Thank you received: 185
02 Sep 2020 06:01 #180396
by Mike_Eitel
Replied by Mike_Eitel on topic CNC Plasma cutters, DIY, building info and guide
I have a plasma welder from them. As a beginner i gave them a mail... And very good reaction and support. Was impressed.
They also do some youtubes.. And some of them show their goods quite detailed described.
Mike
Mike
The following user(s) said Thank You: tommylight, dvn4life1972
12 Oct 2020 20:42 #185877
by shpatb
Replied by shpatb on topic CNC Plasma cutters, DIY, building info and guide
i own one of these plasmas , they are a great value for money.
wrote them for a defect on the torch as installed it wrong, got insta reply from them and i got my torch replaced immediately .
Also the 5 year warranty , and support from them is awesome.
so everyone considering to get a cheap but yet good quality and functional plasma you should really consider Stahlwerk .
regards,
Shpat
regards,
Shpat
- Topic Author
- Thank you received: 5984
12 Oct 2020 21:54 #185886
Replied by tommylight on topic CNC Plasma cutters, DIY, building info and guide
I did order a 100A one today for a client, hopefully it will be here next week so i can play with it.
Should be interesting.
www.stahlwerk-schweissgeraete.de/Plasma-cutter-CUT-100-P-IGBT
The following user(s) said Thank You: shpatb, dvn4life1972
18 Nov 2020 15:41 #189682
by paulsao
Replied by paulsao on topic CNC Plasma cutters, DIY, building info and guide
Hello community.
I wanted to see an alternative of a Hyprterm 45A plasma machine to a more economical one, obviously not Chinese and that can connect with my THCAD-10 table. Is it the only thing I need to build my plasma table?
- Topic Author
18 Nov 2020 18:13 #189702
Did you read the first few pages, there should be plenty of info on what you need.
The better question is, what you already have ?
18 Nov 2020 18:33 #189706
by paulsao
If I started reading that, and the materials I have are:
Hwin 20mm linear rails and hwin skates.
7i96 Mesa.
Thcad - 10.
Infrared sensors.
Nema 23 motor.
Driver Tb6600.
18 tooth pulleys.
and 15mm wide belts.
Intel nuc i3 pc with linux 2.8.
24v power supply.
3mm thick metal structure 2.6mx1.5m.
I read that the plasma must be low frequency so as not to interfere, I see that most have hypertherm plasma but I am looking for something cheaper and that I can connect to my card.
7i96 Mesa.
Thcad - 10.
Infrared sensors.
Nema 23 motor.
Driver Tb6600.
18 tooth pulleys.
24v power supply.
- Topic Author
18 Nov 2020 19:17 #189713
Nice !
You should use some reduction, it does work without it but not as smooth.
Plasma source can be any plasma that has pilot arc start, but non HF ones are easier to protect from EMI.
And yes the cheap ones will work, most of them not for long.
- Topic Author
14 May 2021 11:42 #208794
Added some more info about wiring and EMI, and changed the title a bit.
- Topic Author
07 Jul 2021 00:17 #213919
Added more info to the plasma source section (well post), types of pilot arc with short description on how they function, added the reed contact arcok link.
26 Jan 2022 19:01 #233208
by stefan63
Replied by stefan63 on topic CNC Plasma cutters, DIY, building info and guide
Hi! "some" time has passed so I would like to ask how did the Stahlwerk Cut 100 work out as a CNC plasma cutter power source?
Kind regards/Stefan
Kind regards/Stefan
Time to create page: 0.206 seconds
