New Plasma build question
So Q1. if have built several routers that hold good accuracy. But with the plasma build, the gantry will be 1500mm long I am thinking of using 50x50x4 box section with this I have put 25Kg in the centre and it deflects 0.3mm is this acceptable for plasma or should I go for a better gantry construction? (I would not do this with a router)
Q2. I waant to fit a water table about 1250x650x!! how deep do I need to make it I was thinking 55-70mm ?
And no I am not using MDF for the gantry sides:woohoo: It will be 15mm ali and it will be taller. (How tall) ?
Thanks.
Q1: How heavy material are you planning on loading on the table? Are you going to use THC? I get the impression z flatness isn't terribly critical when you have THC constantly adjusting z anyway.
Q2: I'd like to know this too. I'm leaning toward 3" (~76mm) for my build. What ever winds up being convenient with materials I'll have on hand.
"And no I am not using MDF for the gantry sides"... Lol, I am for my plasma! At least until it can cut out it's own replacement parts.
Following.
I am building this as a hobby as it helps to keep my brain active as I am getting older:) so probably not more that 5 mm plate. Yes I will be using the Mesa THC not sure which one I need though with just a scratch start cut 40.
I have a router so its simple to make gantry sides out of MDF before I cut them for real. The router cuts ali fine.
- thefabricator03
- Thank you received: 531
Q2: I made my water tray 25mm below the bottom of my slats, I have used 100x6 Flat bar as the slats. For a hobby table you would be fine using 75x6 or even 65x6 and having a smaller gap under the slats.
Now I am a bit confused, I thought the water was to come just under the top of the slats and 65x6 I was thinking about 4 mm is this incorrect?
A lot of commercial tables use 3mm which is what I used (75 x3) I think I will replace them eventually with 50mm x 3 as its a bit high now. 75mm deep tray and 50mm slat would be fine.
It looks like a mini spaceship already!
Yes it was you ,Phill and Tommy etc. that got me started on this journey.
I have set the shelf for the water table tray to be 70mm from the top of the frame already so will have to go with that now.
I have used the 7i92 before on my last conversion (Novamill that's just been sold on) but this time I want to used the 7i96 but still unclear which THC to get 10 or 300 !!
- thefabricator03
I didn't realize that smaller tables used 3mm for the slats, How far are they spaced apart? How many supports do they need to stop them from warping?
- Thank you received: 5984
Scratch start will be a challenge, but I think firing the torch before probing could just make it work, but only with floating head and switch. This will also have the inheritable problem of short circuiting the output of the plasma cutter while probing and while that is required to make it start, doing that very often and for prolonged time might end up in burning the plasma if it does not have provisions for limiting the output current, that can be checked easily by opening the plasma and looking for a choke. Ohmic ( I do not like the term as it has nothing to do with the procedure not is being used for ) can not be used with scratch start as it will send all of the output voltage and power to the sensing equipment, rendering it "on fire ".
As for 10 or 300, in your case most probably the 300 since you do not have HF/HV start and most probably your plasma source does not have a built in divider.
