How to add 80w laser diode to QtPlasmaC
15 May 2022 03:11 #242998
by aabtech
How to add 80w laser diode to QtPlasmaC was created by aabtech
Hi, I have a working QtPlasmaC with mesa 7i92+BOB and am planning to add 80W Laser Diode which will be like a double head system for cutting plastic and wood for metal sign can anyone help me.
- Thank you received: 5984
15 May 2022 13:56 #243016
Replied by tommylight on topic How to add 80w laser diode to QtPlasmaC
How?
Provide us with something, anything to go on.
15 May 2022 15:58 #243026
by aabtech
Replied by aabtech on topic How to add 80w laser diode to QtPlasmaC
Ok, adding a laser diode to your plasma touch for engraving and cutting.
15 May 2022 16:53 #243029
You are not helping yourself ...
What laser? 80W Diode laser is very expensive. Is it a CO2 laser?
What control signals does it need to work?
Do you intend to use them both at the same time or in the same job, or separate?
etc, etc.
Since you do not give use info, take some pictures or videos, or use smoke signals, but give us some info.
etc, etc.
- robertspark
- Thank you received: 216
15 May 2022 17:43 #243030
by robertspark
80w is not the output
it uses 2x7.5 laser diodes and a prism
use m62 and m63 to control it.
my plasma has a magnetic breakaway holder.... and I've got other devices I can attach to it (marker pen etc)
Replied by robertspark on topic How to add 80w laser diode to QtPlasmaC
- robertspark
15 May 2022 17:48 #243031
by robertspark
I went with an M50 but on its own frame
shop.atomstack.com/products/atomstack-a1...1GwLVREaAr6UEALw_wcB
with air assist. works really well
I use it to cut paper or card or wood templates..... saves wasting steel....
does gaskets too
does gaskets too
15 May 2022 18:32 #243036
Thank you.
New topic?
Now that is something i need for a local company, can you please share more info on what it can cut regarding gaskets?does gaskets too
Thank you.
New topic?
- robertspark
15 May 2022 19:15 #243041
by robertspark
will do. sep topic a bit later on as I'm out
16 May 2022 02:26 - 16 May 2022 02:29 #243063
by aabtech
Hi, tommylight the laser diode is a 80w and I want to add along side my QtPlasmaC if possible.
Last edit: 16 May 2022 02:29 by aabtech.
16 May 2022 11:46 #243076
It can be added as spindle 2 or spindle 3 in QtPlasmaC.
Time to create page: 0.275 seconds
