- Hardware & Machines
- Plasma & Laser
- THC Seems to work, but not at the setpoint defined in material file?
- brian_cant_code
19 May 2023 00:45 #271638
by brian_cant_code
Hello everyone!
I'm using a THCAD2 with QT/PlasmaC. I've verified the voltage conversions are correct in my configuration and started to run with the THC active. I noticed that it's moving up/down (I see the THC become active and up/down indicators flip on an off) but never gets to my setpoint (78v). Furthermore, it seems to actually be controlling to 100v (which it seems to achieve quite well).
I'm using (I think) M190 Px to define the material parameters (configured in the GUI where I've set the voltage). Is this the wrong place to define the setpoint for the THC or is something else wrong?
Thank you!
Thank you!
19 May 2023 03:56 #271643
Replied by rodw on topic THC Seems to work, but not at the setpoint defined in material file?
Forget about your setpoint! Let the machine do its job for you.
With a good THC (like qtplasmac) we don't care about the actual voltage but we do care about the height of the torch so the arc is correctly positioned for the best cut. The voltage is a process control variable to monitor and control height. Generally we would enable auto sample so the actual voltage is sampled to set the setpoint after cutting commences
78 volts sonds too low anyway. 100-110 volts more realistic
If you want to lower the voltage, lower the torch but 20 volts could be a stretch.
- Thank you received: 5984
19 May 2023 10:54 #271662
Replied by tommylight on topic THC Seems to work, but not at the setpoint defined in material file?
I agree with Rod, stop chasing gremlins and 78 is to low.
Just do some sloped cuts, check cut quality and move on.
- brian_cant_code
19 May 2023 17:05 #271680
by brian_cant_code
Replied by brian_cant_code on topic THC Seems to work, but not at the setpoint defined in material file?
Thanks for the advice!
My 78 volt setpoint comes from the hypertherm cut tables for my consumables / material / supply, so maybe that's where I'm being led astray.
So if I understand correctly it doesn't use my setpoint from the material, but samples after a pierce and uses that voltage for THC? So to adjust my actual cut height I'd use the cut height parameter and not the voltage parameter?
My cuts are seemingly too high so I wanted to lower it, I'll take a look at the sampling settings to see if that's how it's configured for me and adjust accordingly. Thanks!
19 May 2023 19:40 #271686
A lot of your questions are answered in the Plasma Primer. Please read it
linuxcnc.org/docs/2.9/html/plasma/plasma-cnc-primer.html
- Plasma & Laser
Time to create page: 0.349 seconds
