Error finishing read when plasma activated
07 Jul 2023 00:36 #274921
by Scooby
Error finishing read when plasma activated was created by Scooby
I am the final stages of commissioning my corexy plasma cutter controlled with a 7i96s. Today I finally got the touch off code working, so moved to firing up the plasma cutter. The M3 S1 gcode is switching the plasma cutter on (connected to outputs 4ab) - air blasts and the plasma momentarily appears before getting the error - hm/hm2_7i96s.0 :error finishing read! Iter=18747. I have also issued the M3 S1 with the plasma switched off, no error. Any ideas?
Thanks,
Mark
Thanks,
Mark
- Thank you received: 5984
07 Jul 2023 00:42 #274922
Replied by tommylight on topic Error finishing read when plasma activated
CoreXY plasma? Really?
Niceeeeeeeeee
But, you have issues with grounding and/or wiring, so stop firing the torch, something will go ...
This is a very short guide by Hypertherm
forum.linuxcnc.org/media/kunena/attachme...400r0_2021-03-28.pdf
But probably will need more reading and checking the wiring and shielding.
Niceeeeeeeeee
Time to create page: 0.123 seconds
