Hypersensing used as a router touch plate
19 Aug 2023 08:55 #278447
by Hendrixx
Hypersensing used as a router touch plate was created by Hendrixx
could ohmic.comp be modified to be used as a routers touch probe
19 Aug 2023 09:35 #278450
Replied by rodw on topic Hypersensing used as a router touch plate
I think it could be. Use the included ohmic.comp component.You don't need a seperate power supply or any extra components
As you set the thresholds etc up, use halscope to see the voltages.
When you do your probing, probe towards the plate, then robe away slower until contact breaks and that will be your surface.
- Thank you received: 5984
19 Aug 2023 09:37 #278451
Replied by tommylight on topic Hypersensing used as a router touch plate
Probably yes, but the only thing i can think of is :
Why?
Why?
19 Aug 2023 17:24 #278480
by Hendrixx
Replied by Hendrixx on topic Hypersensing used as a router touch plate
because I built a table that has a router plasma and scribe using 2 z axis I was thinking would be nice to reclaim that input pin if I can do it in software in qt dragon the same way as qtplasmac, and as long as im probing conductive materials it should be a very accurate probe sensor
19 Aug 2023 17:27 #278481
OK, in that case i'll leave you in the competent hands of RodW, as i do not use ohmic probing, yet.
20 Aug 2023 01:52 #278514
You do need an encoder input to use hypersensing. So it may not be helpful. With plasma there is no need for an encoder so with firmware the encoder is split into 3 x encoder A
20 Aug 2023 09:55 #278534
by Hendrixx
I got it working. I used 7i96.dpl for the second encoder, same as my qtplasmac sensing circuit, instead of the connection to the torch its a connection to a electrically isolated touch plate i made out of resin and and a guage block . I used ohmic.comp's arc-on signal as my source, unlinked probe-in created a new signal probe in and sent it to the gui led and motion.probe-input. works really reallywell. what would be a good way of testing its accuracy without buying a bunch of different tool height setters
20 Aug 2023 09:57 - 20 Aug 2023 10:00 #278535
by Hendrixx
the hal files I used
Last edit: 20 Aug 2023 10:00 by Hendrixx. Reason: attached files in wrong place
20 Aug 2023 10:52 #278538
by Hendrixx
could this thread be moved over to qtvcp please
21 Aug 2023 07:53 #278590
Great work.
To test accuracy, try lifting the z axis by the diameter of a milling cutter or some known diameter cylinder and roll under it. Adjust to find the hysteresis and adjust for it.
But as I said, use G38.3 then G38.5 before zeroing.
Time to create page: 0.496 seconds
