How to replace subprograms?
01 Nov 2022 15:32 #255668 by daiman444
Hi all. It is known that "run from line" does not work in axis if there are subroutines in the code. It is also known that for the flame table to work, subroutines are needed to perform a number of actions (search for metal, burn, etc.). That is, it turns out some contradiction: it is impossible without subroutines and it is also necessary to "start from the line".
Hence the question if someone came across and was able to decide what and how to replace subroutines: how did you do it?
Plasmac not to offer. it doesn't work for a number of reasons.
Time to create page: 0.090 seconds
