Void Lock Kerf Crossing suggestion
Exactly, what I meant was "PlasmaC was designed to have its own internal kerf crossing"
Well when I nail it and its published as an opensource component, you can steal my code...
- Thank you received: 5934
As i said to a client after scraping 2 useless tables for robot welding, and thinking how to do the third:......................... on what I have obviously wasted my time on.
This was not a waste of time and money, we learned something, we learned what does NOT work !
Thanks but it would have been nice is if as I said before I had some testing and feedback done on what I have obviously wasted my time on.
I had a whole working plasma config that I wasted hundreds of hours of testing and experiments with Dewey's hpid component and his then experimental branch of external offsets that you worked out how to use. But I know a lot of that foundation work by others and myself found its way into Plasmac.
I did say at the time that I did not think you were following a workable kerf crossing algorithm... and did share my methodology and early code very early in the piece...
I think I have worked out how to turn the THC back on. I will save the torch voltage when the void hold kicks in and when it falls below that point, I'll trigger the off signal. I actually had code a bit like that in the component today but I deleted it.
The plots from today are by far the best void crossing ones I've captured so after looking at them, I think that approach will work. From what I can see, it naturally falls below that level but time will tell.. In my research I came across one system that just timed out and tried to enable the THC again
Ha Ha, thanks Tom but I don't even know if it doesn't work.
Most of how PlasmaC works is from the Toma config, just all wrapped up in one component.But I know a lot of that foundation work by others and myself found its way into Plasmac.
Yes, you were quite negative about it. I also recall you saying the same about my THC.I did say at the time that I did not think you were following a workable kerf crossing algorithm... and did share my methodology and early code very early in the piece...
I saw the light and let you do the coding but you failed me on the kerf crossing
I was never keen on the single component (Plasmac has 1373 lines). Its not really consistent with the Linuxcnc design which is based around small modular, discrete components. (eg. THCAD parsing, corner lock, kerf crossing, voltage sampling etc). While it might have taken a bit more effort in hal to tie it all together the modular approach would be much more maintainable.
That was not easy, for sure. That config has everything automated in hal, and just following what is going on there is a mess. I do not remember much of the work i have done at the beginning several years back, but i do remember when i made it work with Mesa and servo systems, i still have 3 or 4 pages of scribbles trying to follow joint command and joint feedback through it.
Since you two are bickering about it, i do recall writing here that the only way to do that properly is DV/DT. Or did i ?
As i see it, both of you ( and others ) did a magnificent job of making all this work properly and having features that most of the industrial plasma machines lack.
Again, i will point out that looking at a plasma machine while cutting it all seems very simple, but nothing related to plasma cutting is simple. Cutting metal like butter is no easy feat, and being able to build such a machine in a shed and have it work all day every day without a hiccup is only made possible by such persons as we have here, putting endless hours of work without expecting any reward for it. But it sure as hell is fun !
That is a great piece of HAL work Tom. I think it took me about a week to draw it out into a format I could understand.That was not easy, for sure. That config has everything automated in hal, and just following what is going on there is a mess. I do not remember much of the work i have done at the beginning several years back, but i do remember when i made it work with Mesa and servo systems, i still have 3 or 4 pages of scribbles trying to follow joint command and joint feedback through it.
I know I pushed hard to get some inclusions but then Islander261 had got Phill to do what he needed before me, now Stephan has pushed Phill on the RS485 not to mention Tommy in the background.
There is no doubt that plasma control is enormously complex and not well understood outside of a few major global manufacturers but it does kinda get you in. The knowledge in this forum is amazing, not to mention the flood of users trying to adopt Plasmac. The info we've published is by far the most comprehensive info about the process on the internet anywhere.
