Hypertherm Powermax65 Toolset
23 Sep 2020 08:35 #183432
Geez, I had one by that name
Replied by rodw on topic Hypertherm Powermax65 Toolset
Hi Guys, is there any chance that anyone has a similar Powermax65 toolset but for metric material thicknesses rather than gauge thicknesses that they are willing to share???
How about Powermax65SheetcamToolSet.tools.txt x 25.4
Sorry, I couldn't resist...
22 Feb 2021 01:42 #199669
by crowloy
Replied by crowloy on topic Hypertherm Powermax65 Toolset
Newer versions of sheetcam added a non-unique key to the toolset files. Notice the "Name_Edited=1" entry. This causes materialverter.py to use the "1" as the name of the sheet. I'm not sure how to fix this as it looks like the lines are read one after another. My quick solution was to search and remove that line from the file in it's entirety, but that's not ideal either. A proper fix would be to ignore the line completely. Maybe by using Name= instead of just Name.
AutoName=0
[Tool0]
Type=PlasmaTool
Name=40 Amp FineCut 26GA Mild Steel
Name_Edited=1
Comment=
Tool\ number=1
Kerf\ width=0.635
Plunge\ rate=3810
Pierce\ delay=0
Pause\ at\ end\ of\ cut=0
Wiggle\ length=9.999979999999999
Pierce\ height=3.81
Cut\ height=1.524
Pierce\ type=0
Feed\ rate=8255
Lead\ in=0
Lead\ out=0
Lead\ in\ type=0
Lead\ out\ type=0
CodeSnip=-1
Hole\ Size=0
Use\ leadin\ settings=0
22 Feb 2021 02:45 #199672
by phillc54
Replied by phillc54 on topic Hypertherm Powermax65 Toolset
Thanks for the report.
Time to create page: 0.145 seconds
