Simulator for QtPlasmaC
25 Aug 2021 05:04 - 04 Feb 2024 17:41 #218673
by phillc54
Simulator for QtPlasmaC was created by phillc54
It is possible to create a sim config from an existing table config provided that the table config was originally created by PnCconf or StepConf by doing the following:
1. Make a copy of the existing config.
2. Edit the [HAL] section of the copied .ini file so it looks like:
3. From the above .ini entries, edit </full/path/to> to be (be sure to change <user_name> to match your user name)
Run In Place Build:
Package Build:
4. Any HOME_SEARCH_VEL, HOME_LATCH_VEL, or HOME_FINAL_VEL settings that are negative will need to changed to positive (remove the negative sign).
You should now be able to run the sim config.
Note: If your config is a converted PlasmaC config then it may (or may not) work by commenting out or omitting the following two lines:
Also noteworthy:
The following parameters must be in the .ini file:
HOME
HOME_OFFSET
HOME_SEQUENCE
STEPGEN_MAXACCEL
STEP_SCALE
STEPLEN
STEPSPACE
DIRSETUP
DIRHOLD
HALUI = halui
TWOPASS = ON
HALFILE = </full/path/to>/sim_no_stepgen.tcl
HALFILE = qtplasmac_comp.hal
HALFILE = custom.hal
POSTGUI_HALFILE = </full/path/to>/sim_postgui.hal
Run In Place Build:
/home/<user_name>/linuxcnc-dev/configs/sim/qtplasmac
Package Build:
/usr/share/doc/linuxcnc/examples/sample-configs/sim/qtplasmac
POSTGUI_HALFILE = custom_postgui.hal
Also noteworthy:
HOME
HOME_OFFSET
HOME_SEQUENCE
STEPGEN_MAXACCEL
STEP_SCALE
STEPLEN
STEPSPACE
DIRSETUP
DIRHOLD
Last edit: 04 Feb 2024 17:41 by snowgoer540.
The following user(s) said Thank You: billykid, tommylight, robertspark, thefabricator03, snowgoer540, fernandosf
Time to create page: 0.594 seconds
