edge start a possibility on thicker materials
28 Mar 2024 07:58 #296970
by Liborius
edge start a possibility on thicker materials was created by Liborius
Hello, I'm new here, I have a plasma cutter 1.5m x 3 meters, retrofit- qt plasmac ,Hypertherm 1650
I would like to ask what the procedure is for setting the edge start for thicker materials when cutting with plasma
excuse the english I'm using a translator
28 Mar 2024 09:09 #296972
Replied by rodw on topic edge start a possibility on thicker materials
Edge start does not need any special features.
You can also do a pierce only cycle that lets you pierce with old consumables, clean the dross and cut the sheet.
There is a new moving pierce feature that you may find helpful.
linuxcnc.org/docs/devel/html/plasma/qtpl...plasma:moving-pierce
28 Mar 2024 10:02 #296977
by Liborius
Replied by Liborius on topic edge start a possibility on thicker materials
thank you for the quick reply
I would like to ask if there is a possibility to ignite the arc on the edge of the sheet metal?
and the machine would continue to work
- Thank you received: 5962
28 Mar 2024 10:19 #296978
Replied by tommylight on topic edge start a possibility on thicker materials
Yes it is, position the torch center on the edge of material, press F9, wait for arc to transfer and cut to go through, click RUN. Be wary that the machine speed must be set to cut speed when doing this, otherwise machine will just rapid over material ... but this is fun to watch with all the sparksI would like to ask if there is a possibility to ignite the arc on the edge of the sheet metal?
The following user(s) said Thank You: caretech
28 Mar 2024 17:30 #297016
by Liborius
I'll try it and let you know how it works
qt plasmac is an excellent software, I've been using it for the second year and I'm still familiar with new functions, I use a camera - scanything, I also have a remote control, that's also great
I would like to contribute to the operation with some small financial amount, I just don't know where? or to whom?
The following user(s) said Thank You: tommylight, Clive S
31 Mar 2024 17:42 #297298
by Liborius
F9 doesn't work
the only way I was able to do it is to press start immediately, then pause and use the arrows to jog to the edge of the plate and start again
01 Apr 2024 03:08 #297325
In the settings tab, check "use keyboard shortcuts"
Time to create page: 0.098 seconds
