Add LASER Cross on QtplasmaC
31 Mar 2024 21:10 #297306
by V34michel
Add LASER Cross on QtplasmaC was created by V34michel
Hi, I'm trying to add a laser cross in my QtPlasmaC configuration.
- I add : a Qt-laser.hal file with "net qtplasmac.laser_on => parport.0.pin-08-out" my laser is connected to P8 of my parport.0, (and light on with halrun test)
- I add : in QtPlasmaC.ini section [HAL] HALFILE = Qt-laser.hal
- I add : in QtPlasmaC.prefs section [BUTTONS] 8 Name = LASER and 8 Code = toggle-laser
When in Run QtplasmaC, powered it and homed the Laser button toggle correctly but the laser light doesn't
Can you help me to understand my mistake.
regards, Michel
regards, Michel
01 Apr 2024 00:44 #297316
by phillc54
Replied by phillc54 on topic Add LASER Cross on QtplasmaC
Have you set up the offsets for the laser with Peripheral Offsets?
linuxcnc.org/docs/devel/html/plasma/qtpl...l#peripheral-offsets
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#plasma:laser
01 Apr 2024 06:46 #297340
by Calysto
Replied by Calysto on topic Add LASER Cross on QtplasmaC
I think it should be qtplasmac.laser.on
see manual.
see manual.
Time to create page: 0.064 seconds
