A couple of errors during update 2.8.2-130-g87f66feaf
17 Jul 2022 22:57 #247602
by JohnnyCNC
Replied by JohnnyCNC on topic A couple of errors during update 2.8.2-130-g87f66feaf
I'll see what I can get when I get back to my machine. Earlier today I had it happen right after hitting the MDI button and running a G28. I had just done the home all which leaves the tool at the front left corner of the table. I then issued a G28 and it move the tool to center of the table when I do most work. At this point I could no longer put the machine back in manual or jog.
17 Jul 2022 23:14 #247605
by spumco
Replied by spumco on topic A couple of errors during update 2.8.2-130-g87f66feaf
I'm fiddling in a virtual machine now. If JohnnyCNC's examples aren't enough to reproduce, let me know and I'll fire up my real machine.
17 Jul 2022 23:32 #247609
by JohnnyCNC
17 Jul 2022 23:46 #247610
by dgarrett
Replied by dgarrett on topic A couple of errors during update 2.8.2-130-g87f66feaf
Repeating request:
@spumco :
1) post the output from:
$ linuxcnc_info
2) post a tar or zip file of the configuration directory
3) post details on the steps needed to produce the error
4) when the error occurs, execute (in a separate shell):
$ halcmd show pin|grep active
and post the result
Also
4) Please try to duplicate in an included distribution sim
config (qtdragon?) and post detailed steps to reproduce the error.
@spumco :
$ linuxcnc_info
and post the result
Also
18 Jul 2022 01:24 #247618
by spumco
Files attached, along with screenshot of error message.
LCNC 2.9 RIP, qtpyvcp (master), Probe Basic (py3)
Steps to reproduce:
Could not reproduce on included sim QtDragon_hd.
Steps to reproduce:
- Start machine & home all axis
- jogging works
- load ngc file
- switch back to manual mode - jogging works
- run ngc file using cycle start GUI button
- file completes
- select manual mode GUI button
- jogging works
- run ngc file again
- file completes
- attempt to jog => error message + jogging not responsive
- close error message
- jogging still not responsive
- select manual mode GUI button => error message + jogging not responsive
- select auto mode GUI button => error message + jogging not responsive
18 Jul 2022 02:15 - 18 Jul 2022 02:17 #247622
by dgarrett
@spumco
The ini file PBtestATC.ini contained in HAL_rev33_ATC.zip
uses:
[DISPLAY]
DISPLAY = probe_basic
The probe_basic executable is not part of the LinuxCNC
git tree or distribution and i don't have the time or
energy to build or test executables from outside projects.
Can you
1) reproduce problem using in-tree guis?
or better:
2) reproduce problem using an in-tree SIMULATION config
like qtdragon?
Ref: configs/sim/qtvcp_screens/qtdragon/qtdragon.ini
I have some ideas, but ... the hardware configs showing
the problem are complicated to test as they include
specific hardware (hm2_eth, vc-p4s) that i do not have
so simplifying to a sim config would be helpful.
Alternatively, making a modified config to test without
use of the vc-p4s component could help to isolate
the problem as it may be related to halui plus/minus
jogging implemented therein.
uses:
[DISPLAY]
Can you
or better:
like qtdragon?
Last edit: 18 Jul 2022 02:17 by dgarrett.
18 Jul 2022 03:15 #247626
by spumco
[don't blame for not wanting to delve in to edge-case GUI's]
I'm unable to reproduce the error in qtdragon or qtdragon_hd sims
I turned off the vc-p4s MPG component (commented out both HALFILE and POSTGUI_HALFILE) and the error is not occurring, regardless how many times I run an NGC file and switch back and forth between manual/auto modes.
I think that narrows it down, yes?
This wasn't an issue as of few months ago and I haven't changed anything in either of the vc-p4s hal files.
18 Jul 2022 03:29 #247627
by dgarrett
@spumco :
It appears you are running a self-built Run-in-place
install for the master branch at commit 8da3ed4f04 (Jun 9 2022)
I've made a test branch with a potential fix based
on the current master branch that you can test by
checking out and building the branch:
dgarr/master_testa
Example:
$ cd your_LinuxCNC_git_top_directory
$ git fetch
$ git checkout dgarr/master_testa
$ cd src
$ make && sudo make setuid
$ test_your_hardware_config
Please test and report
@johnnyCNC :
It appears you are running a deb install for the 2.8 branch
commit 87f66feaf (27 may 2022)
I've made a test branch dgarr/2.8testa based on current
2.8 branch that you can get from the buildbot as a 'scratch' deb
Instructions for using a scratch deb at:
buildbot.linuxcnc.org/
dgarr/master_testa
Example:
$ git fetch
$ cd src
@johnnyCNC :
18 Jul 2022 03:34 - 18 Jul 2022 03:38 #247628
by spumco
Minor hiccup on my end.
I have some changes to carousel.comp Andy gave me and I did a local halcompile to install them. How do I "commit my changes or stash them" before switching branches to your test?
Nevermind - internet to the rescue. Will report back after testing.
Last edit: 18 Jul 2022 03:38 by spumco.
18 Jul 2022 03:51 #247629
by dgarrett
@spumco :
Example 1) commit first:
$ cd top_directory
$ git branch | grep \* # show what branch you are on (master)
$ git diff # show what files you have changed
$ git add each_changed_file # add files for commit
$ git commit # make commit with message
$ git fetch # refresh
$ git checkout some_new_branch
Note: your git tree will not agree with master since you committed changes
For more info search the web or study:
$ git help commit
Example 2) stash
$ cd top_directory
$ git stash # stash in-tree changes
$ # when finished testing new branch:
$ git checkout master # (master)
$ git stash show # show what you stashed
$ git stash pop # restore stashed changes
Note: your git tree restored
$ git help stash
$ cd top_directory
$ git help commit
Example 2) stash
$ cd top_directory
$ git help stash
Time to create page: 0.260 seconds
