development of a qt version of ncam
08 Dec 2023 18:32 #287571
development of a qt version of ncam was created by cmorley
The following user(s) said Thank You: Roguish, phillc54, tommylight, ikkuh, BigDo, chrisfairbrothern, COFHAL, snowgoer540, MennilTossFlykune, Wieser and 2 other people also said thanks.
09 Dec 2023 18:38 #287705
Replied by andypugh on topic development of a qt version of ncam
While you are at it... Do you see a more elegant way to display the stock than a set of rapids that are in an optional block? That was an ingenious hack, but runs the risk of actually being run. (Unless I am misunderstanding something)
The following user(s) said Thank You: COFHAL
09 Dec 2023 19:44 #287711
Replied by cmorley on topic development of a qt version of ncam
I'm sure we could add magic comments to do it.
16 Dec 2023 20:24 #288365
Little more updates...
The following user(s) said Thank You: Roguish, phillc54, tommylight, Clive S, rodw, 0x2102, besriworld, chrisfairbrothern, COFHAL, snowgoer540 and 4 other people also said thanks.
05 Jan 2024 20:56 #289901
by Roguish
Replied by Roguish on topic development of a qt version of ncam
the previous version of NCAM would pop a warning at you if ya tried to run with the 'stock' lines on. and would not run, until ya turned them off.
No clue how it was handled inside, but it worked.
Caught and saved me a number of times......
Chris, NICE WORK.
Chris, NICE WORK.
The following user(s) said Thank You: robh
07 Jan 2024 17:00 #290115
by Roguish
Chris,
where is this? and how is it installed?????
thanks.
thanks.
07 Jan 2024 21:08 #290146
Currently not available -it's just on my system- I think it's still to rough for anyone to use.
It will install with linuxcnc - it will be part of it.
I'll push it pretty soon - I don't want to lose the work if my machine crashes
The following user(s) said Thank You: yeltrow, besriworld, ikkuh, chrisfairbrothern, Wieser, Unlogic
22 Jan 2024 11:47 #291337
by ikkuh
Replied by ikkuh on topic development of a qt version of ncam
I came across these:
github.com/LinuxCNC/simple-gcode-generators
23 Jan 2024 18:54 #291446
by Roguish
yup. those have been around for years. they pretty good.
24 Jan 2024 00:05 #291479
by blazini36
Replied by blazini36 on topic development of a qt version of ncam
Now that's handyI came across these:
Time to create page: 0.268 seconds
