Customize "Go to sensor"
13 Apr 2024 15:56 - 13 Apr 2024 16:05 #298174
by tom_no
Customize "Go to sensor" was created by tom_no
Got an issue with the default "Go to sensor" button ignoring tool offsets (X and Y axis).
It is possible to customize the script behind the button, or is it all hard coded?
Edit: Running LinuxCNC 2.9.2 with QT Dragon HD and Probe Basic.
Last edit: 13 Apr 2024 16:05 by tom_no.
13 Apr 2024 23:47 #298209
Replied by cmorley on topic Customize "Go to sensor"
Its in the python handler file
In 2.9.2:
in 2.9.3:
In 2.9.2:
def btn_goto_sensor_clicked(self):
x = float(self.w.lineEdit_sensor_x.text())
y = float(self.w.lineEdit_sensor_y.text())
if not STATUS.is_metric_mode():
x = x / 25.4
y = y / 25.4
ACTION.CALL_MDI("G90")
ACTION.CALL_MDI_WAIT("G53 G0 Z0")
command = "G53 G0 X{:3.4f} Y{:3.4f}".format(x, y)
ACTION.CALL_MDI_WAIT(command, 10)
in 2.9.3:
def btn_goto_location_clicked(self):
dest = self.w.sender().property('location')
if dest == 'home':
x = float(self.w.lbl_home_x.text())
y = float(self.w.lbl_home_y.text())
elif dest == 'sensor':
else:
return
if STATUS.is_metric_mode():
x = INFO.convert_machine_to_metric(x)
y = INFO.convert_machine_to_metric(y)
else:
x = INFO.convert_machine_to_imperial(x)
y = INFO.convert_machine_to_imperial(y)
ACTION.CALL_MDI_WAIT(command, self.calc_mdi_move_wait_time(x,y))
The following user(s) said Thank You: tommylight, Pro_El
14 Apr 2024 19:37 #298251
by tom_no
Replied by tom_no on topic Customize "Go to sensor"
Thanks for the reply cmorley!
Can't see anything in the code that should make the scripts ignore tool offsets, so tried to dig a step deeper. Found that the tool offsets are ignored in G53 movements for machine coordinates, but not in G54, G55 user coordinate systems.
Is this a bug or a feature?
Is the solution to do the Go-to-sensor movement in one of the user coordinate systems for machines with multiple spindles?
15 Apr 2024 02:47 #298267
It's a feature.
linuxcnc.org/docs/devel/html/gcode/coord...ne-coordinate-system
You could use macro buttons to add your own button that calls arbitrary Gcode:
linuxcnc.org/docs/devel/html/gui/qtdragon.html#_macro_buttons
Time to create page: 0.193 seconds
