Knuth Numturn 360 lathe retrofit
- HalaszAttila
- Thank you received: 5
26 Oct 2016 21:17 #82120
by HalaszAttila
Knuth Numturn 360 lathe retrofit was created by HalaszAttila
Hello,
here is our newest retrofit with LinuxCNC control, with Mesa Electronics cards.
On machine we mounted new servo motors, make user friendly control panel, with gmoccapy gui, and ngcgui subroutines.
Best regards,
Halasz Attila.
Best regards,
Halasz Attila.
The following user(s) said Thank You: jtc
27 Oct 2016 07:25 #82130
by newbynobi
Replied by newbynobi on topic Knuth Numturn 360 lathe retrofit
I like the GUI
But feed is quiet slow.
Norbert
Norbert
- HalaszAttila
27 Oct 2016 07:31 #82132
by HalaszAttila
Replied by HalaszAttila on topic Knuth Numturn 360 lathe retrofit
I like too, more than Axis. With this side buttons really easy to use without mouse and keyboard.
A wait the next version with tool wear correction.
Where is the place to report problem with gmoccapy, to repair in next version?
Attila.
Attila.
27 Oct 2016 07:46 #82133
by newbynobi
Just post your wishes in the gmoccapy section, I have a long "to Do" list and will add your stuff to it
I am working on gmoccapy 2 (in master), as in future we need to support joint/axis stuff, and release 2 has this options.
Related to tool wear:
- there is an ongoing discussion on developer list, about the complete tool handling, I will wait for the result. But there is a "fanuc patch" hand that does work also with gmoccapy.
In master there is already a tooltable with wear offsets, but at the moment I have that one disabled in gmoccapy2
Norbert
Norbert
Time to create page: 0.273 seconds
