LinuxCNC Forum
Toggle Navigation
Remember Me
Log in
Forgot Login?
Sign up
Index
Recent Topics
Search
www.linuxcnc.org
Other Stuff
Show Your Stuff
Internal keyway on a CNC lathe
Start
Prev
1
Next
End
1
emcPT
Offline
Platinum Member
Thank you received: 95
09 Mar 2017 11:17
09 Mar 2017 11:19
#89245
by
emcPT
was created by
emcPT
Opening a keyway on a blind hole.
This operation is hard to make due to:
- Small bore size (11mm)
- Hole is blind
On a CNC lathe with a remaped gcode, I was able to open the keyway with a simple G code and a "hand made" tool.
Made 30 keyways like this.
Last edit: 09 Mar 2017 11:19 by
emcPT
The following user(s) said Thank You:
BigJohnT
Please
Log in
or
Create an account
to join the conversation.
Start
Prev
1
Next
End
1
Board Categories
LinuxCNC
- LinuxCNC Announcements
- General LinuxCNC Questions
- Installing LinuxCNC
- LinuxCNC Documents
Configuring LinuxCNC
- Configuration Tools
- - StepConf Wizard
- - PnCConf Wizard
- Basic Configuration
- Advanced Configuration
- - ClassicLadder
- - EtherCAT
- HAL
- - HAL Examples
User Interfaces
- AXIS
- Gmoccapy
- Plasmac
- pyVCP
- GladeVCP
- Other User Interfaces
- - PathPilot
- - QtPyVCP
- - Flex GUI
- Qtvcp
GCode and Part Programs
- G&M Codes
- O Codes (subroutines) and NGCGUI
- - Mill Library
- - Lathe Library
- - Plasma Library
- CAD CAM
- - Post Processors
- - - Fusion 360
- - - MasterCAM
- - - MecSoft
- - NativeCAM
Hardware & Machines
- Computers and Hardware
- Driver Boards
- CNC Machines
- - Milling Machines
- - Turning
- - Plasma & Laser
- Pick and Place
- Additive Manufacturing
Other Stuff
- Show Your Stuff
- Forum Questions
- User Exchange
- Off Topic and Test Posts
- - BeagleBone
International LinuxCNC Users
- Français
- Español
- Deutsch
- Other Languages
- - Russian
- - Polski
Other Stuff
Show Your Stuff
Time to create page: 0.264 seconds
Powered by
Kunena Forum
