LinuxCnc logo
22 Apr 2022 13:06 #240885
by Muecke
Replied by Muecke on topic LinuxCnc logo
-- en --
what is the name of the font?
I want to extend it, can't find the font.
-- de --
wie ist der Name der Schriftart?
Ich möchte es erweitern, kann die Schrift nicht finden.
-- de --
- robertspark
- Thank you received: 216
22 Apr 2022 17:19 #240898
by robertspark
22 Apr 2022 22:23 #240929
by Matt Hat
Replied by Matt Hat on topic LinuxCnc logo
Yes, it needs the ear protection. Not necessarily because of the fans in my intel3 dual core, but because of the spindle speed and the vibrations when cutting hard wood.
01 May 2022 09:57 #241784
by RNJFAB
Replied by RNJFAB on topic LinuxCnc logo
When will we have the LCNC Logo with a plasma torch ????
01 May 2022 09:59 #241785
by phillc54
Replied by phillc54 on topic LinuxCnc logo
11 May 2022 02:51 #242559
by XXCoder
Replied by XXCoder on topic LinuxCnc logo
I revisited the logo version I modified from other guy. I felt that I didn't do eyes well, and I really wanted to improve endmill. I had no time back then, but now? Plenty of time! So I recreated the logos again, this time with very good endmill (very realistic looking but 100% vector!) and corrected eyes. ZIP file is included with SVG.
Hope you guys like it!
11 May 2022 07:08 #242583
by Muecke
-- de --
der Bohrer sieht sehr gut aus!
Wenn ich das Bild verkleinere sind die Konturen vom Bohrer nicht mehr so gut zu erkennen.
Auf dem Alten Bild hat man das besser erkannt.
-- en --
the drill looks very good!
If I reduce the image, the contours of the drill are no longer so well visible.
On the old picture you can see it better.
-- en --
11 May 2022 07:59 #242587
by XXCoder
Ok I will play with stronger color gradients later
11 May 2022 08:59 #242595
by silopolis
Replied by silopolis on topic LinuxCnc logo
Indeed outline of the mill could be a little stronger... And IMHO, the ones of chips a little less
Also, the glasses leg could be a little thinner.
Posted a message in #linuxcnc-devel to ask devs what think about adding it to source tree...
About location in tree, logos are at repository root ATM, so make a PR there if you want to.
12 May 2022 05:13 #242729
by XXCoder
OKAY! I have taken in suggestions, and found original SVG! I was still meh on original, since while it is certainly better than remake I have been using, it still had problems.
So I decided to make sort of hybrid of both. Chip is slightly darker for contrast, Chip has more modern goggles. I have reshaped some of body and beak for better look.
The endmill now is lighter, and have strong black borders!
Left is old Chips, right is recreation. Middle is brand new one. As you can see, it is mostly same as left original.
Mascot with endmill.
The following user(s) said Thank You: Bari
Time to create page: 0.132 seconds
