LinuxCNC for SLA, DLP and mSLA/mLCD Printers
31 May 2020 02:51 #169473
by Bari
LinuxCNC for SLA, DLP and mSLA/mLCD Printers was created by Bari
LinuxCNC easily controls SLA 3D printers that use a galvo to control the laser position. It also can also control DLP and mSLA printers that use a raster device such as a DLP projector or LCD panel to cure liquid resins/photopolymers.
The DLP type shown below uses a 4K DLP projector to cure an entire XY print area in under 2 seconds. XY resolution is 3840 x 2160 pixels. The projector is focused at ~140um per pixel. XY area: 537.6mm x 302.4mm (21,14" x 11.89").
imgur.com/zvxoHUT
imgur.com/zKNtBAg
I'm using QTPYVCP with a widget to take SVG slices from sliced 3D models sent though Slic3r and synchronize them with Z-motion and other motors in the printer.
matrix.org/_matrix/media/r0/download/mat...ZtKczKAwdIQFMTMvXpbl
imgur.com/zvxoHUT
imgur.com/zKNtBAg
01 Jun 2020 08:15 #169628
by bbsr_5a
Replied by bbsr_5a on topic LinuxCNC for SLA, DLP and mSLA/mLCD Printers
nice job why did you double post on this printer
01 Jun 2020 15:53 #169682
by Bari
Replied by Bari on topic LinuxCNC for SLA, DLP and mSLA/mLCD Printers
A bit OT but, where is the other (2nd/double) post?
20 Sep 2020 20:45 #182956
by Bari
Should I make a LCNC SD card image with LCNC already configured to run a DLP/LCD printer using the Rpi4? I'm not sure how simple this has to be made for hobbyists to be able to use it.
- BeagleBrainz
- User is blocked
- Thank you received: 570
20 Sep 2020 23:15 #182987
by BeagleBrainz
Replied by BeagleBrainz on topic LinuxCNC for SLA, DLP and mSLA/mLCD Printers
It doesn't matter how simple you make it people will mess up.
Actually what would be interesting, if you have the time, is a description of the hardware and how you went about putting everything together.
Or if you have a blog or such a link.
Whilst not on my list of projects it sounds like a lot or work has gone into the printer and sounds as if it would be something quite interesting to have a read of.
Well done mate.
Well done mate.
21 Sep 2020 00:51 #183003
by Bari
I make them in all shapes and sizes. I usually use off the shelf automation parts but for the wide build plate area of the unit above I decided to build my own positioners.
imgur.com/QoVC0eR
1/2"-10 Acme screw with anti-lash nut. Screws and nuts are high precision overstock custom from Thompson. I just had to shorten them a bit for my application. ~300mm between the high precision Hiwin rails.
There is virtually no load on the build platform when printing since the cured resin is about the density of the uncured resin that it sits in.
imgur.com/QoVC0eR
- BeagleBrainz
- User is blocked
21 Sep 2020 02:08 #183021
by BeagleBrainz
Oh ok it's a commercial product. I thought it was just a one off home brew. No need to share your secrets then mate.
Still one hell of a job.
- Smitherman
23 Apr 2024 12:17 #298904
by Smitherman
Replied by Smitherman on topic LinuxCNC for SLA, DLP and mSLA/mLCD Printers
What a nice Project!
would Like to Work on Something similiar in the Future, is there a way to Talk to you directly?
