Emco PC Turn 55 retrofit
- The Feral Engineer
- Topic Author
- Thank you received: 22
08 Feb 2021 19:15 #198051
by The Feral Engineer
How would I check this?
Replied by The Feral Engineer on topic Emco PC Turn 55 retrofit
Those issues are not likely to be latency related, even 100s of usec of latency
have negligible effect on the step generation and the maximum step rate is
complete unrelated to latency with Mesa cards.
If you have poor latency (but good enough to avoid real time errors)
You do need to have the DPLL setup and enabled to be able to generate
clean step signals.
09 Feb 2021 23:24 #198220
You should have something like this in your hal file:
Note if the latency is really bad you may have to increase the time to 100 usec or so
because of baseline drift.
Replied by PCW on topic Emco PC Turn 55 retrofit
clean step signals.
# latch 50 usec before nominal read time:
setp hm2_7i76e.0.dpll.01.timer-us -50 # set timer 1 to 50 usec before read
setp hm2_7i76e.0.stepgen.timer-number 1 # use timer 1 as sample time reference for all stepgens
The following user(s) said Thank You: The Feral Engineer
- Topic Author
09 Feb 2021 23:43 - 09 Feb 2021 23:43 #198223
Thanks Peter
I'll check it out when I get back on the pi. I reconnected my laptop for my turret prove out. Pi is my endgame, but it's a pain in the rear with the keyboard and monitor sitting on top of the machine.
Last edit: 09 Feb 2021 23:43 by The Feral Engineer.
- Topic Author
18 Feb 2021 07:40 #199221
I set the pi back up, have it hooked to an asus touch screen and I've been able to do some playing. I did an isolcpus = 2,3 and I have a better servo-thread jitter result than not having any isolcpus (130000 vs 280000 if I load chromium and start playing youtube videos). I have my servo timing set to 140000 in my ini file and as long as I don't use wifi with the machine enabled, it seems to run pretty reliably. If I try to surf the web and jog the machine, it isn't happy about it at all, which is fine.
I haven't tried the DPLL thing yet, I actually came on here to read up on how to do it and figured I'd give an update on it.
30 Nov 2021 17:18 #228040
by gearshift
Replied by gearshift on topic Emco PC Turn 55 retrofit
Please I am begging you, my school has got one of these and we can’t index the turret, any help would be appreciated
- Topic Author
19 Apr 2022 05:58 #240629
Sorry, haven't been on this forum in a long time. Does your machine have the original software or has it been converted?
- calmissile
21 Feb 2023 18:12 #264973
by calmissile
Replied by calmissile on topic Emco PC Turn 55 retrofit
I am searching for a AC95 controller left over from a retrofit. If anyone has a spare laying around to sell please contact me.
calmissile at geeemail dot com
Thanks,
Doug
Thanks,
Doug
- Bluehawk11
21 Aug 2023 19:44 #278637
by Bluehawk11
Replied by Bluehawk11 on topic Emco PC Turn 55 retrofit
Hello,
i'm searching for help to make a retrofit of my PC Turn 55II from Emco. The Mesa7i76ED Board is not available and i have no idea wich Mesa board is equal to the 7i76ED.
Thanks,
Martin
Thanks,
Martin
- Thank you received: 5944
21 Aug 2023 20:09 #278638
Replied by tommylight on topic Emco PC Turn 55 retrofit
Nope, nothing there, yet.
Says "soon"...
7i96S
www.welectron.com/Mesa-Electronics-7i96S...thernet-Controller_1
eusurplus.com/index.php?route=product/pr...62_71&product_id=159
7i76E
www.welectron.com/Mesa-Electronics-7i76E...thernet-Controller_1
eusurplus.com/index.php?route=product/pr..._62_71&product_id=50
Says "soon"...
7i96S
7i76E
15 Jan 2024 20:24 #290792
by bazgazm
Replied by bazgazm on topic Emco PC Turn 55 retrofit
I have a Emco turn 105 with a very similar stepper driver (Y4A 031 011) which looks identical to the one you have. I'm having a very hard time finding documentation for this. It would be a huge help to me to know the pin out of the 16-pin connector. I know this is an older thread but if anyone knows...
