New design for a CNC engraver/etcher/scratcher ... ???
- Topic Author
- Online
- Thank you received: 5962
27 Aug 2022 20:47 #250595
New design for a CNC engraver/etcher/scratcher ... ??? was created by tommylight
What the tiiiiiit is this thing supposed to be named?
I am going with "scratcher" from now on, all it does is scratch the surface of granite or stone or glass or wood or...
So, i thought it would be nice to do a new design for these machines i keep making from time to time and since i had to learn FreeCAD again, i gave it a go, so here are the results of the Version 1 :
and Version 2 :
and Version 2 :
The following user(s) said Thank You: snowgoer540, itsme
- Topic Author
- Online
27 Aug 2022 21:05 - 12 Nov 2023 00:04 #250596
Replied by tommylight on topic New design for a CNC engraver/etcher/scratcher ... ???
For more info and videos
instagram @toma.3d and @toma.cnc
Attached is the full set of STL files in case anyone wants to build one, one part is compressed using 7Z and renamed to be able to upload, so remove ".txt" before unzipping it.
Edit:
Added the latest config as it has provisions for disabling PWM on ESC/Stop to prevent spindle from making a big hole on the material. Also "run from here" should work as is.
Edit:
Last edit: 12 Nov 2023 00:04 by tommylight. Reason: more info.
28 Aug 2022 01:51 #250599
by phillc54
Replied by phillc54 on topic New design for a CNC engraver/etcher/scratcher ... ???
That is cool Tommy, I like "scratcher".
- Topic Author
- Online
01 Sep 2022 21:58 #250950
- Topic Author
- Online
06 Sep 2022 22:46 #251362
- Topic Author
- Online
20 Sep 2022 00:20 #252372
Also finished this working occasionally on it
It has 4 motors on the Z axis so it probes 4 corners and adjusts each corner to make the table flat.
- Topic Author
- Online
28 Mar 2023 20:06 - 28 Mar 2023 20:08 #267727
Another video
youtube.com/shorts/mPyvLKJxuzI?feature=share
STL files are attached near the top, if anyone wants to build one.
Last edit: 28 Mar 2023 20:08 by tommylight. Reason: added link
11 Nov 2023 16:49 #285113
by santy
Replied by santy on topic New design for a CNC engraver/etcher/scratcher ... ???
Hey Tommy. I'm looking for some information on this post to help a friend build a similar machine.
I'm trying to understand the used mechanism to allow for harder/softer engraving. Are you using a faster motor speed for the darker areas? Or pressing harder with a Z axis movement? This is my main question in the proccess.
I managed to install dmap2gcode which is really helpful here!
- Topic Author
- Online
11 Nov 2023 22:00 #285136
The spindle and spindle motor are attached to the shaft of a 3 phase sensored servo motor from big photocopiers, they need 12-24V to work and a inverted PWM output from parallel port or Mesa board. Inverting is done using a single resistor and a transistor.
Inverting can be done by inverting the pin in hal, but that has the nasty habit of ramming the spindle in the table until LinuxCNC is started.
This.Or pressing harder with a Z axis movement?
11 Nov 2023 23:51 #285142
by santy
Oh, so Z axis only serves the purpose of probing the material. The rest is done via spindle output.
I assume the Z output from the Gcode signal is script-converted into a S1 - S1000 signal to drive the pwm out.
Can you post your files? Not sure how to handle the table flattening probe.
Thank you in advance.
Time to create page: 0.346 seconds
