My Design8Studio logo cut in 18 ga steel
- Doug @ Design8Studio.com
- Topic Author
- Thank you received: 42
07 Feb 2023 00:41 #263884
by Doug @ Design8Studio.com
My Design8Studio logo cut in 18 ga steel was created by Doug @ Design8Studio.com
The following user(s) said Thank You: phillc54, tommylight
- Topic Author
08 Feb 2023 03:58 #264001
Replied by Doug @ Design8Studio.com on topic My Design8Studio logo cut in 18 ga steel
PART 2 - The Bends!
15 Feb 2023 00:17 #264536
by cakeslob
Replied by cakeslob on topic My Design8Studio logo cut in 18 ga steel
I almost broke my brain looking at that backwards pic, until i scrolled a bit more and saw it was backwards
is that a plasma specific thing to do it inverted?
- Topic Author
15 Feb 2023 00:21 #264537
The only downside to cutting it with the backside facing up was that the side facing the water tray gets a bit more dirt and slag, so its clean up is slightly more involved. But a few seconds with chipping off slag and a few seconds with a wire brush attached to my drill and the underside was clean and smooth ready to become the upper side again!
Sorry about that! And no, it's not a plasma thing, per se, I just simply extruded the wrong direction in Fusion 360, and did not catch it until later, and realized it would not make much difference if any, as I was going to be manually folding the box edges and would be sure to turn them the right way.I almost broke my brain looking at that backwards pic, until i scrolled a bit more and saw it was backwards
16 Feb 2023 10:20 #264606
Replied by rodw on topic My Design8Studio logo cut in 18 ga steel
You should be able to select the reverse side and create a sketch. don't add anything.Then in the tree, right click on the sketch and export DXF.
You also do this with sheetmetal. Flatten the part then follow the same steps.
Sheetcam then makes it trvial to cut the DXF.
- Topic Author
16 Feb 2023 10:22 #264607
Yes, I simply grabbed the wrong side of the sketch, and then later realized it would not make much difference and did not bother with correcting it!
Time to create page: 1.033 seconds
