My TOS MCV 1000 machining center Retrofit with Siemens 611
26 Jan 2024 13:32 #291655
by santy
Replied by santy on topic My TOS MCV 1000 machining center Retrofit with Siemens 611
Exactly, all you have said, makes a lot of sense. I have checked the manual and it makes sense too. I didn’t have 64 connected
When I have all others connected, I have a green light. The moment I connect 64, the green light disappears and no yellow light
27 Jan 2024 12:05 - 27 Jan 2024 12:07 #291744
by radom
Replied by radom on topic My TOS MCV 1000 machining center Retrofit with Siemens 611
sorry I had to look it up how I got my simodrive wired and I think I forgot about terminal 48 on the left side it also need to be connected to terminal 9,
there is a flowchart for start-up in the pdf I linked earlier
Last edit: 27 Jan 2024 12:07 by radom.
30 Jan 2024 13:33 #291980
by santy
Finally got the yellow light!!! The motor has moved. Besides 48 to 9, and 112 to 9, I forgot I should close the relay between NS1 and NS2. When you read the last pages of the manual you sent it all makes sense haha.
Now it’s time for tuning the analog/encoder scales and getting the spindle to run, which I assume will be harder.
Thank you!!
Thank you!!
