checkcord3
22 Sep 2013 15:19 #39102
by Rick G
checkcord3 was created by Rick G
Helper sub to assign number to valid coordinate system for use with g code commands such as G10
Rick G
o<check_cord3> sub
(not_a_subfile)
; Assign number to valid coordinate system for use with g code commands such as G10
; edit Sept. 2013
#<Main_cord> = #1
#<Temp_cord> = #2
o<c550> if [#<Temp_cord> EQ 54]
#<_t:cord> = 1
o<c550> endif
o<c551> if [#<Temp_cord> EQ 55]
#<_t:cord> = 2
o<c551> endif
o<c552> if [#<Temp_cord> EQ 56]
#<_t:cord> = 3
o<c552> endif
o<c553> if [#<Temp_cord> EQ 57]
#<_t:cord> = 4
o<c553> endif
o<c554> if [#<Temp_cord> EQ 58]
#<_t:cord> = 5
o<c554> endif
o<c555> if [#<Temp_cord> EQ 59]
#<_t:cord> = 6
o<c555> endif
o<c556> if [#<Temp_cord> EQ 59.1]
#<_t:cord> = 7
o<c556> endif
o<c557> if [#<Temp_cord> EQ 59.2]
#<_t:cord> = 8
o<c557> endif
o<c558> if [#<Temp_cord> EQ 59.3]
#<_t:cord> = 9
o<c558> endif
o<b550> if [#<Main_cord> EQ 54]
#<_m:cord> = 1
o<b550> endif
o<b551> if [#<Main_cord> EQ 55]
#<_m:cord> = 2
o<b551> endif
o<b552> if [#<Main_cord> EQ 56]
#<_m:cord> = 3
o<b552> endif
o<b553> if [#<Main_cord> EQ 57]
#<_m:cord> = 4
o<b553> endif
o<b554> if [#<Main_cord> EQ 58]
#<_m:cord> = 5
o<b554> endif
o<b555> if [#<Main_cord> EQ 59]
#<_m:cord> = 6
o<b555> endif
o<b556> if [#<Main_cord> EQ 59.1]
#<_m:cord> = 7
o<b556> endif
o<b557> if [#<Main_cord> EQ 59.2]
#<_m:cord> = 8
o<b557> endif
o<b558> if [#<Main_cord> EQ 59.3]
#<_m:cord> = 9
o<b558> endif
o<check_cord3> endsub
Rick G
The following user(s) said Thank You: BigJohnT
Time to create page: 0.144 seconds
