non rigid tapping
14 years 2 months ago #23279 by clkeck1
non rigid tapping was created by clkeck1
My mill doesn't have a spindle encoder so i got a floating tap holder so i don't have to manually tap all the holes.
I set everything up tonight but when i went to write the program it looks like EMC doesn't support this. Am i missing something?
Cory
14 years 2 months ago #23280 by cmorley
Replied by cmorley on topic Re:non rigid tapping
hmm not that I have done this but
isn't a case of start the spindle,
feed at the pitch rate,
stop the spindle,
reverse the spindle
feed out at the pitch rate?
probably with some dell times to wait for the spindle to stop etc.
  • mhaberler
  • New Member
  • New Member
14 years 2 months ago #23282 by mhaberler
Replied by mhaberler on topic Re:non rigid tapping
Chris,
I got interested in that and had a long discussion on floating tap with Rob Harpham and some with Cradek on the issue.
I did an implementation of G84.1/G74.1 and the status is here: git.mah.priv.at/gitweb/emc2-dev.git/shortlog/refs/heads/g84-dev
I never integrated it into master because it does a bad sales job on my remapping work.. everything in it can be done with a new remapped G code except for this:
we agreed that on retract it is not a good idea to wait for the spindle-at-speed signal before beginning the retract move. So I adapted the SPINDLE_ON canon/nml message to carry an optional wait_for_atspeed flag, which defaults to true, and motion support to honour that.
I can surrect that patch and integrate it into master, if you drum up some support on the dev list.
- Michael
14 years 2 months ago #23283 by cncbasher
Replied by cncbasher on topic Re:non rigid tapping
i'd be interested in this Micheal ..
Dave
  • mhaberler
  • New Member
  • New Member
14 years 2 months ago #23290 by mhaberler
Cory
Cory,
you are not missing anything.
I suggest you add a feature request here: sourceforge.net/tracker/?group_id=6744&atid=356744
which will give me an excellent excuse to merge the relevant parts of the branch I mentioned below :laugh:
regards,
Michael
10 years 1 month ago - 10 years 1 month ago #80677 by terkaa
Replied by terkaa on topic Re:non rigid tapping
Should this still work with current master? I tried to create a ticket at sourceforge but did not have enough rights :evil:
Tero
Last edit: 10 years 1 month ago by terkaa.
Time to create page: 0.149 seconds
