Anilam 1100M to linux cnc
6 years 4 months ago #170854 by robf100
Hello, this is my first time installing linux cnc (6i25 and 7i77D to Anilam 1100M retrofit) and I'm have a little bit of trouble. I have all my axis figured out and wired up. Right now I am trying to get my spindle all wired and I am very lost at this point. Some sleep would help, but so would your opinion. I have a Saftronics PC3 VDF for spindle control (The VDF that yaskawa made a million of under different names) but I am lost on where the the wires match up to my 7i77D. Looking for help, the pins I am occupying on the VFD are pins 1, 2, two in pin 6, 8, 11, and FLT -B & -C. Those are all the pins that led to the original distribution board. imgur.com/gallery/khvM4PS
6 years 4 months ago #170857 by PCW
Replied by PCW on topic Anilam 1100M to linux cnc
1 FWD --> 7I77D field output
2 REV --> 7I77D field output
6 COM --> 7I77D field power common
8 FREQ REF --> 7I77D AOUT5
11 COM --> 7I77D AGND5
FLT-C --> 7I77D +field power
FLT-B --> 7I77D field input
6 years 4 months ago #170858 by tommylight
Mesa TB5 >>>>VFD
21 >>>>>>>>> 6
22 >>>>>>>>> 1
In case the spindle stays on, reverse the above 2 pins.
23 >>>>>>>>> 11
24 >>>>>>>>> 8
That is for forward only, in case you need reverse it is better to use two outputs from Mesa 7i77D and wire them to pins 1 and 2 on the VFD, but that would require wiring 7i77D ground to pin 6 on the VFD, so might be much better to use two relays for that.
The VFD manual says that the inputs 1 and 2 are optically isolated but it does not say that for the common pin 6. It should be isolated and that can be checked with a DVM/multimeter, but it is safer to use relays.
6 years 4 months ago #170982 by robf100
Replied by robf100 on topic Anilam 1100M to linux cnc
Thanks, I have forward all wired up with a relay this morning. Should be able to test here soon. What about FLT -B and -C? Wire them up to field power and one of the board inputs? I don't really comprehend what those two wires are for
6 years 4 months ago #170988 by tommylight
FLT = fault
That is a fault output from the drive to the Mesa board, so you can set that in hal to stop the machine and alert to what drive exactly caused the error.
6 years 4 months ago #171002 by robf100
Oh, makes sense. And would it be ok if I established a connection with you for simple questions? The mill is about 90% wired up and now I'm just stumbling through the finishing steps
Time to create page: 0.442 seconds
