Program cnc linux
1 year 1 month ago #334308 by bridges67
Program cnc linux was created by bridges67
I created a program in Fusion 360 and everything looks right on screen using the linux post, also looks right on linux cnc screen loaded program, a big but, it machines rotated and flipped when machined and it is just tracing letters and numbers ! please tell me why.
1 year 1 month ago #334314 by unknown
Replied by unknown on topic Program cnc linux
It's very hard to diagnose with the little information provided. At the very least a picture of what you are trying to machine and the gcode would be a good start.
I know you maybe very frustrated and maybe English is not your first language but you will have to provide more information.
Is this the only job you are having issues with ?
The following user(s) said Thank You: bridges67
1 year 1 month ago - 1 year 1 month ago #334344 by andypugh
Replied by andypugh on topic Program cnc linux
If the preview is correct, but the physical part is rotated and flipped, it may be that your axis directions are configured wrongly.
Jogging X+ should move the _tool_ to the right relative to the _work_
Jogging Y+ should move the tool away from the operator relative to the work.
Or, if you prefer:
Y+ = North
Y- = South
X+ = East
X- = West.
But everything describes the motion of the tool relative to the work, not the motion of the work relative to the world.
It can be confusing with moving-table machines, for example a standard bed mill will be table-left for X+.
Another possibility is that you have a rotation offset in the work coordinate system.
G10 L2 R0 in the MDI tab should fix that.
linuxcnc.org/docs/html/gcode/coordinates.html
Last edit: 1 year 1 month ago by andypugh.
1 year 1 month ago #334346 by bridges67
Replied by bridges67 on topic Program cnc linux
I tried to up load a jpg file but it kept saying didn't load.
1 year 1 month ago - 1 year 1 month ago #334347 by bridges67
% (5555) (SHOP SIGN CEDAR) (T1 D=0.0252 CR=0.015 TAPER=10DEG - ZMIN=-0.0394 - TAPERED MILL) N10 G90 G94 G17 G91.1 N15 G20 N20 G53 G0 Z0. (TRACE3) N25 T1 M6 N30 S5000 M3 N35 G17 G90 G94 N40 G54 N45 G64 P0.0004 Q0.0004 N50 G0 X-6.0683 Y3.7453 N55 G43 Z0.6 H1 N60 G0 Z0.1606 N65 G1 Z-0.0394 F13.123 N70 Y4.6203 F39.37 N75 X-5.8039 N80 X-5.6452 Y4.0235 N85 X-5.4882 Y4.6203 N90 X-5.2232 N95 Y3.7453 N100 X-5.3873 N105 Y4.4341 N110 X-5.561 Y3.7453 N115 X-5.7311 N120 X-5.9042 Y4.4341 N125 Y3.7453 N130 X-6.0683 N135 Z0.1606 N140 G0 Z0.2 N145 X-5.1367 N150 Z0.1606 N155 G1 Z-0.0394 F13.123 N160 X-4.7958 Y4.6203 F39.37 N165 X-4.609 N170 X-4.2587 Y3.7453 N175 X-4.4509 N180 X-4.5272 Y3.9441 N185 X-4.877 N190 X-4.9493 Y3.7453 N195 X-5.1367 N200 Z0.1606 N205 G0 Z0.2 N210 X-4.0903 Y3.8586 N215 Z0.1606 N220 G1 Z-0.0394 F13.123 N225 X-4.1097 Y3.8859 F39.37 N230 X-4.1222 Y3.9043 N235 X-4.1341 Y3.9229 N240 X-4.1452 Y3.9418 N245 X-4.1552 Y3.961 N250 X-4.1641 Y3.9807 N255 X-4.1716 Y4.0009 N260 X-4.1777 Y4.0215 N265 X-4.1826 Y4.0426 N270 X-4.1865 Y4.0641 N275 X-4.1894 Y4.0859 N280 X-4.1917 Y4.108 N285 X-4.1934 Y4.1302 N290 X-4.196 Y4.175 N295 X-4.1936 Y4.2216 N300 X-4.192 Y4.2446 N305 X-4.1898 Y4.2676 N310 X-4.1869 Y4.2902 N315 X-4.1831 Y4.3126 N320 X-4.1783 Y4.3346 N325 X-4.1722 Y4.3561 N330 X-4.1647 Y4.3772 N335 X-4.1558 Y4.3977 N340 X-4.1456 Y4.4178 N345 X-4.1343 Y4.4376 N350 X-4.1223 Y4.457 N355 X-4.1096 Y4.4763 N360 X-4.0832 Y4.5144 N365 X-4.051 Y4.5414 N370 X-4.0348 Y4.5544 N375 X-4.0183 Y4.5668 N380 X-4.0014 Y4.5785 N385 X-3.9842 Y4.5891 N390 X-3.9665 Y4.5987 N395 X-3.9481 Y4.6069 N400 X-3.9293 Y4.6136 N405 X-3.9099 Y4.6191 N410 X-3.89 Y4.6234 N415 X-3.8698 Y4.6269 N420 X-3.8492 Y4.6296 N425 X-3.8285 Y4.6318 N430 X-3.7865 Y4.6352 N435 X-3.7505 Y4.6327 N440 X-3.7326 Y4.6311 N445 X-3.7148 Y4.629 N450 X-3.6973 Y4.6264 N455 X-3.68 Y4.623 N460 X-3.6631 Y4.6188 N465 X-3.6465 Y4.6135 N470 X-3.6304 Y4.6071 N475 X-3.6147 Y4.5996 N480 X-3.5993 Y4.5912 N485 X-3.5842 Y4.582 N490 X-3.5694 Y4.5721 N495 X-3.5547 Y4.5618 N500 X-3.5257 Y4.5403 N505 X-3.5104 Y4.5225 N510 X-3.4957 Y4.5044 N515 X-3.4821 Y4.4856 N520 X-3.4758 Y4.4759 N525 X-3.4701 Y4.4659 N530 X-3.4648 Y4.4557 N535 X-3.4599 Y4.4452 N540 X-3.4512 Y4.4236 N545 X-3.4435 Y4.4015 N550 X-3.4362 Y4.3792 N555 X-3.6111 Y4.3374 N560 X-3.6158 Y4.3529 N565 X-3.6209 Y4.3681 N570 X-3.6269 Y4.3829 N575 X-3.6303 Y4.3899 N580 X-3.6341 Y4.3968 N585 X-3.6384 Y4.4034 N590 X-3.643 Y4.4098 N595 X-3.6532 Y4.4219 N600 X-3.6643 Y4.4335 N605 X-3.6758 Y4.4448 N610 X-3.6895 Y4.4536 N615 X-3.7033 Y4.4619 N620 X-3.7175 Y4.4692 N625 X-3.7248 Y4.4723 N630 X-3.7322 Y4.475 N635 X-3.7397 Y4.4772 N640 X-3.7474 Y4.4789 N645 X-3.7632 Y4.4815 N650 X-3.7793 Y4.4831 N655 X-3.7955 Y4.4842 N660 X-3.8182 Y4.482 N665 X-3.8405 Y4.4791 N670 X-3.8514 Y4.477 N675 X-3.862 Y4.4744 N680 X-3.8724 Y4.4712 N685 X-3.8825 Y4.4673 N690 X-3.8922 Y4.4626 N695 X-3.9015 Y4.457 N700 X-3.9106 Y4.4509 N705 X-3.9194 Y4.4443 N710 X-3.9366 Y4.4298 N715 X-3.9534 Y4.4144 N720 X-3.9685 Y4.3883 N725 X-3.9758 Y4.3752 N730 X-3.9826 Y4.362 N735 X-3.9889 Y4.3486 N740 X-3.9945 Y4.335 N745 X-3.9994 Y4.3212 N750 X-4.0033 Y4.3071 N755 X-4.0064 Y4.2927 N760 X-4.0088 Y4.2782 N765 X-4.0106 Y4.2635 N770 X-4.0119 Y4.2486 N775 X-4.0133 Y4.2185 N780 X-4.0139 Y4.1882 N785 X-4.0135 Y4.1567 N790 X-4.0122 Y4.1254 N795 X-4.011 Y4.1099 N800 X-4.0093 Y4.0946 N805 X-4.007 Y4.0794 N810 X-4.0039 Y4.0644 N815 X-4.0001 Y4.0497 N820 X-3.9954 Y4.0352 N825 X-3.9898 Y4.0209 N830 X-3.9835 Y4.0069 N835 X-3.9767 Y3.993 N840 X-3.9694 Y3.9792 N845 X-3.9543 Y3.9518 N850 X-3.9379 Y3.9364 N855 X-3.9211 Y3.9218 N860 X-3.9125 Y3.9151 N865 X-3.9036 Y3.909 N870 X-3.8944 Y3.9034 N875 X-3.8849 Y3.8987 N880 X-3.875 Y3.8947 N885 X-3.8648 Y3.8914 N890 X-3.8542 Y3.8888 N895 X-3.8435 Y3.8867 N900 X-3.8215 Y3.8836 N905 X-3.7991 Y3.8814 N910 X-3.7824 Y3.8828 N915 X-3.7659 Y3.8847 N920 X-3.7498 Y3.8877 N925 X-3.7419 Y3.8898 N930 X-3.7342 Y3.8923 N935 X-3.7268 Y3.8954 N940 X-3.7195 Y3.8989 N945 X-3.7053 Y3.9071 N950 X-3.6915 Y3.9163 N955 X-3.6779 Y3.9262 N960 X-3.6647 Y3.9415 N965 X-3.652 Y3.9572 N970 X-3.6461 Y3.9653 N975 X-3.6405 Y3.9735 N980 X-3.6353 Y3.982 N985 X-3.6306 Y3.9907 N990 X-3.6264 Y3.9998 N995 X-3.6226 Y4.0089 N1000 X-3.616 Y4.0279 N1005 X-3.6103 Y4.0473 N1010 X-3.6051 Y4.067 N1015 X-3.4338 Y4.0127 N1020 X-3.4438 Y3.9821 N1025 X-3.4546 Y3.952 N1030 X-3.4606 Y3.9373 N1035 X-3.467 Y3.9229 N1040 X-3.474 Y3.9088 N1045 X-3.4817 Y3.8952 N1050 X-3.4901 Y3.8821 N1055 X-3.4994 Y3.8694 N1060 X-3.5093 Y3.8572 N1065 X-3.5197 Y3.8453 N1070 X-3.5418 Y3.8223 N1075 X-3.5648 Y3.7999 N1080 X-3.5916 Y3.784 N1085 X-3.6188 Y3.769 N1090 X-3.6325 Y3.7622 N1095 X-3.6465 Y3.756 N1100 X-3.6606 Y3.7505 N1105 X-3.6751 Y3.7458 N1110 X-3.6898 Y3.742 N1115 X-3.7047 Y3.739 N1120 X-3.7198 Y3.7366 N1125 X-3.7351 Y3.7347 N1130 X-3.7661 Y3.7321 N1135 X-3.7973 Y3.7304 N1140 X-3.8378 Y3.734 N1145 X-3.8579 Y3.7363 N1150 X-3.8778 Y3.7391 N1155 X-3.8973 Y3.7426 N1160 X-3.9165 Y3.7469 N1165 X-3.9353 Y3.7524 N1170 X-3.9535 Y3.7591 N1175 X-3.9711 Y3.7672 N1180 X-3.9882 Y3.7765 N1185 X-4.0049 Y3.787 N1190 X-4.0211 Y3.7984 N1195 X-4.037 Y3.8105 N1200 X-4.0528 Y3.8232 N1205 X-4.0838 Y3.8495 N1210 X-4.0903 Y3.8586 N1215 Z0.1606 N1220 G0 Z0.2 N1225 X-3.2816 Y4.0703 N1230 Z0.1606 N1235 G1 Z-0.0394 F13.123 N1240 Y4.6203 F39.37 N1245 X-3.1049 N1250 Y4.2759 N1255 X-2.7587 N1260 Y4.6203 N1265 X-2.5821 N1270 Y3.7453 N1275 X-2.7587 N1280 Y4.1279 N1285 X-3.1049 N1290 Y3.7453 N1295 X-3.2816 N1300 Y4.0703 N1305 Z0.1606 N1310 G0 Z0.2 N1315 X-2.4048 Y3.7453 N1320 Z0.1606 N1325 G1 Z-0.0394 F13.123 N1330 Y4.6203 F39.37 N1335 X-2.2281 N1340 Y3.7453 N1345 X-2.4048 N1350 Z0.1606 N1355 G0 Z0.2 N1360 X-2.058 N1365 Z0.1606 N1370 G1 Z-0.0394 F13.123 N1375 Y4.6203 F39.37 N1380 X-1.8861 N1385 X-1.528 Y4.036 N1390 Y4.6203 N1395 X-1.3639 N1400 Y3.7453 N1405 X-1.5411 N1410 X-1.8939 Y4.3159 N1415 Y3.7453 N1420 X-2.058 N1425 Z0.1606 N1430 G0 Z0.2 N1435 X-2.0691 Y3.2542 N1440 Z0.1606 N1445 G1 Z-0.0394 F13.123 N1450 X-2.0482 Y3.2533 F39.37 N1455 X-2.0273 Y3.2518 N1460 X-2.0065 Y3.2494 N1465 X-1.9858 Y3.2461 N1470 X-1.9446 Y3.238 N1475 X-1.9261 Y3.2312 N1480 X-1.9079 Y3.2239 N1485 X-1.8902 Y3.2159 N1490 X-1.8816 Y3.2114 N1495 X-1.8733 Y3.2066 N1500 X-1.8651 Y3.2013 N1505 X-1.8572 Y3.1957 N1510 X-1.842 Y3.1836 N1515 X-1.8272 Y3.1707 N1520 X-1.8127 Y3.1574 N1525 X-1.7994 Y3.1414 N1530 X-1.7865 Y3.1251 N1535 X-1.7743 Y3.1084 N1540 X-1.7632 Y3.0911 N1545 X-1.7535 Y3.073 N1550 X-1.7448 Y3.0542 N1555 X-1.7368 Y3.035 N1560 X-1.7292 Y3.0156 N1565 X-1.7224 Y2.9903 N1570 X-1.7161 Y2.9648 N1575 X-1.7106 Y2.9392 N1580 X-1.7065 Y2.9135 N1585 X-1.7037 Y2.8875 N1590 X-1.702 Y2.8614 N1595 X-1.7005 Y2.8088 N1600 X-1.7021 Y2.7615 N1605 X-1.7037 Y2.738 N1610 X-1.7063 Y2.7146 N1615 X-1.7102 Y2.6914 N1620 X-1.7153 Y2.6684 N1625 X-1.7274 Y2.6226 N1630 X-1.7358 Y2.6013 N1635 X-1.7446 Y2.5802 N1640 X-1.7542 Y2.5596 N1645 X-1.7595 Y2.5495 N1650 X-1.7651 Y2.5397 N1655 X-1.7711 Y2.5301 N1660 X-1.7775 Y2.5208 N1665 X-1.7913 Y2.5028 N1670 X-1.806 Y2.4853 N1675 X-1.8211 Y2.468 N1680 X-1.8351 Y2.4566 N1685 X-1.8492 Y2.4455 N1690 X-1.8638 Y2.4352 N1695 X-1.879 Y2.4259 N1700 X-1.895 Y2.4179 N1705 X-1.9114 Y2.4108 N1710 X-1.9452 Y2.3982 N1715 X-1.9838 Y2.3895 N1720 X-2.0032 Y2.3859 N1725 X-2.0227 Y2.3832 N1730 X-2.0423 Y2.3815 N1735 X-2.062 Y2.3805 N1740 X-2.1016 Y2.3797 N1745 X-2.4341 N1750 Y3.2547 N1755 X-2.1112 N1760 X-2.0691 Y3.2542 N1765 Z0.1606 N1770 G0 Z0.2 N1775 X-2.2574 Y3.1067 N1780 Z0.1606 N1785 G1 Z-0.0394 F13.123 N1790 Y2.5271 F39.37 N1795 X-2.1255 N1800 X-2.0986 Y2.5273 N1805 X-2.0718 Y2.5284 N1810 X-2.0585 Y2.5295 N1815 X-2.0452 Y2.5312 N1820 X-2.0186 Y2.5355 N1825 X-1.9992 Y2.5416 N1830 X-1.9898 Y2.5451 N1835 X-1.9807 Y2.5492 N1840 X-1.972 Y2.5541 N1845 X-1.9636 Y2.5597 N1850 X-1.9473 Y2.5719 N1855 X-1.9318 Y2.5908 N1860 X-1.9248 Y2.6006 N1865 X-1.9187 Y2.611 N1870 X-1.9135 Y2.6219 N1875 X-1.9089 Y2.6331 N1880 X-1.9011 Y2.6563 N1885 X-1.8925 Y2.6959 N1890 X-1.8891 Y2.7158 N1895 X-1.8865 Y2.7358 N1900 X-1.8848 Y2.7559 N1905 X-1.8839 Y2.7761 N1910 X-1.8832 Y2.8166 N1915 X-1.8838 Y2.856 N1920 X-1.8847 Y2.8757 N1925 X-1.8863 Y2.8952 N1930 X-1.8889 Y2.9146 N1935 X-1.8924 Y2.934 N1940 X-1.9011 Y2.9724 N1945 X-1.91 Y2.9957 N1950 X-1.9151 Y3.007 N1955 X-1.9209 Y3.0179 N1960 X-1.9275 Y3.0283 N1965 X-1.935 Y3.0382 N1970 X-1.9512 Y3.0571 N1975 X-1.9696 Y3.0714 N1980 X-1.9792 Y3.0778 N1985 X-1.9892 Y3.0834 N1990 X-1.9997 Y3.088 N1995 X-2.0106 Y3.0919 N2000 X-2.033 Y3.0983 N2005 X-2.0691 Y3.1028 N2010 X-2.0871 Y3.1045 N2015 X-2.1053 Y3.1057 N2020 X-2.1416 Y3.1067 N2025 X-2.178 N2030 X-2.2574 N2035 Z0.1606 N2040 G0 Z0.2 N2045 X-1.5507 Y3.1047 N2050 Z0.1606 N2055 G1 Z-0.0394 F13.123 N2060 Y3.2547 F39.37 N2065 X-0.9019 N2070 Y3.1067 N2075 X-1.374 N2080 Y2.9127 N2085 X-0.9347 N2090 Y2.7653 N2095 X-1.374 N2100 Y2.5271 N2105 X-0.8852 N2110 Y2.3797 N2115 X-1.5507 N2120 Y3.1047 N2125 Z0.1606 N2130 G0 Z0.2 N2135 X-1.9114 Y1.6789 N2140 Z0.1606 N2145 G1 Z-0.0394 F13.123 N2150 X-1.9008 Y1.6725 F39.37 N2155 X-1.8909 Y1.6651 N2160 X-1.8815 Y1.6568 N2165 X-1.8638 Y1.639 N2170 X-1.8512 Y1.6194 N2175 X-1.8458 Y1.6094 N2180 X-1.8414 Y1.5989 N2185 X-1.8384 Y1.588 N2190 X-1.8364 Y1.5767 N2195 X-1.8342 Y1.5536 N2200 X-1.8352 Y1.5387 N2205 X-1.8361 Y1.5314 N2210 X-1.8374 Y1.5242 N2215 X-1.8393 Y1.5171 N2220 X-1.8417 Y1.5101 N2225 X-1.8473 Y1.4963 N2230 X-1.8551 Y1.4833 N2235 X-1.8594 Y1.477 N2240 X-1.864 Y1.4711 N2245 X-1.8691 Y1.4656 N2250 X-1.8745 Y1.4605 N2255 X-1.8861 Y1.4506 N2260 X-1.9049 Y1.4393 N2265 X-1.9145 Y1.4342 N2270 X-1.9244 Y1.4297 N2275 X-1.9346 Y1.4258 N2280 X-1.945 Y1.4225 N2285 X-1.9661 Y1.4167 N2290 X-1.9924 Y1.412 N2295 X-2.0188 Y1.408 N2300 X-2.0098 Y1.4176 N2305 X-2.0009 Y1.4233 N2310 X-1.9777 Y1.4196 N2315 X-1.9548 Y1.415 N2320 X-1.9435 Y1.412 N2325 X-1.9323 Y1.4086 N2330 X-1.9101 Y1.401 N2335 X-1.8932 Y1.3937 N2340 X-1.8769 Y1.3855 N2345 X-1.869 Y1.3809 N2350 X-1.8614 Y1.3758 N2355 X-1.8465 Y1.3651 N2360 X-1.8348 Y1.3544 N2365 X-1.8293 Y1.3488 N2370 X-1.8242 Y1.3429 N2375 X-1.8195 Y1.3366 N2380 X-1.8153 Y1.33 N2385 X-1.8074 Y1.3163 N2390 X-1.8018 Y1.3022 N2395 X-1.7994 Y1.295 N2400 X-1.7974 Y1.2877 N2405 X-1.7961 Y1.2803 N2410 X-1.7952 Y1.2728 N2415 X-1.7941 Y1.2576 N2420 X-1.7954 Y1.2445 N2425 X-1.7971 Y1.2316 N2430 X-1.7996 Y1.219 N2435 X-1.8014 Y1.2128 N2440 X-1.8035 Y1.2068 N2445 X-1.8088 Y1.1953 N2450 X-1.8155 Y1.1843 N2455 X-1.8229 Y1.1736 N2460 X-1.8308 Y1.1631 N2465 X-1.8535 Y1.1427 N2470 X-1.8653 Y1.1333 N2475 X-1.8778 Y1.1249 N2480 X-1.891 Y1.1177 N2485 X-1.9047 Y1.1114 N2490 X-1.9331 Y1.1001 N2495 X-1.9694 Y1.0905 N2500 X-1.9877 Y1.0864 N2505 X-2.0061 Y1.0832 N2510 X-2.0247 Y1.081 N2515 X-2.0434 Y1.0796 N2520 X-2.0809 Y1.0782 N2525 X-2.1043 Y1.0789 N2530 X-2.1276 Y1.0806 N2535 X-2.1508 Y1.0837 N2540 X-2.1738 Y1.0877 N2545 X-2.1921 Y1.0919 N2550 X-2.2101 Y1.097 N2555 X-2.219 Y1.1001 N2560 X-2.2276 Y1.1036 N2565 X-2.2447 Y1.1113 N2570 X-2.2595 Y1.1213 N2575 X-2.2665 Y1.1267 N2580 X-2.2732 Y1.1324 N2585 X-2.2793 Y1.1387 N2590 X-2.2851 Y1.1454 N2595 X-2.2959 Y1.1595 N2600 X-2.3035 Y1.1733 N2605 X-2.3067 Y1.1803 N2610 X-2.3094 Y1.1876 N2615 X-2.3114 Y1.195 N2620 X-2.3127 Y1.2026 N2625 X-2.3144 Y1.2183 N2630 X-2.3127 Y1.2345 N2635 X-2.3112 Y1.2424 N2640 X-2.3088 Y1.2499 N2645 X-2.3055 Y1.2571 N2650 X-2.3012 Y1.2638 N2655 X-2.2914 Y1.2769 N2660 X-2.2788 Y1.2869 N2665 X-2.2722 Y1.2912 N2670 X-2.2652 Y1.2946 N2675 X-2.2578 Y1.2971 N2680 X-2.2501 Y1.2986 N2685 X-2.2341 Y1.3004 N2690 X-2.2186 Y1.2989 N2695 X-2.2111 Y1.2975 N2700 X-2.204 Y1.2953 N2705 X-2.1972 Y1.2921 N2710 X-2.1907 Y1.2881 N2715 X-2.1784 Y1.2787 N2720 X-2.1691 Y1.2669 N2725 X-2.1652 Y1.2607 N2730 X-2.162 Y1.2542 N2735 X-2.1598 Y1.2473 N2740 X-2.1584 Y1.24 N2745 X-2.1568 Y1.2251 N2750 X-2.1574 Y1.2157 N2755 X-2.159 Y1.2066 N2760 X-2.1621 Y1.1979 N2765 X-2.1663 Y1.1895 N2770 X-2.173 Y1.1808 N2775 X-2.1805 Y1.1727 N2780 X-2.1889 Y1.1657 N2785 X-2.1979 Y1.1593 N2790 X-2.202 Y1.1569 N2795 X-2.2057 Y1.1541 N2800 X-2.2086 Y1.1506 N2805 X-2.2109 Y1.1465 N2810 X-2.2053 Y1.1372 N2815 X-2.2019 Y1.1333 N2820 X-2.1979 Y1.1301 N2825 X-2.1933 Y1.1276 N2830 X-2.1883 Y1.1256 N2835 X-2.1775 Y1.1223 N2840 X-2.1559 Y1.1171 N2845 X-2.1451 Y1.115 N2850 X-2.1342 Y1.1134 N2855 X-2.1232 Y1.1123 N2860 X-2.1121 Y1.1117 N2865 X-2.0899 Y1.1112 N2870 X-2.0756 Y1.1115 N2875 X-2.0614 Y1.1122 N2880 X-2.0474 Y1.1137 N2885 X-2.0339 Y1.1165 N2890 X-2.0273 Y1.1184 N2895 X-2.0209 Y1.1208 N2900 X-2.0084 Y1.1268 N2905 X-1.9962 Y1.1339 N2910 X-1.9842 Y1.1416 N2915 X-1.9755 Y1.1541 N2920 X-1.9674 Y1.1669 N2925 X-1.9638 Y1.1734 N2930 X-1.9606 Y1.18 N2935 X-1.9578 Y1.1868 N2940 X-1.9556 Y1.1938 N2945 X-1.9538 Y1.2009 N2950 X-1.9526 Y1.2081 N2955 X-1.9512 Y1.223 N2960 X-1.9508 Y1.2382 N2965 X-1.951 Y1.2536 N2970 X-1.952 Y1.2689 N2975 X-1.9534 Y1.2841 N2980 X-1.9556 Y1.299 N2985 X-1.959 Y1.3135 N2990 X-1.9612 Y1.3205 N2995 X-1.964 Y1.3274 N3000 X-1.9706 Y1.3408 N3005 X-1.9784 Y1.3537 N3010 X-1.9868 Y1.3664 N3015 X-1.9971 Y1.3737 N3020 X-2.0076 Y1.3806 N3025 X-2.0185 Y1.3865 N3030 X-2.0241 Y1.3889 N3035 X-2.0298 Y1.391 N3040 X-2.0417 Y1.394 N3045 X-2.054 Y1.3958 N3050 X-2.0665 Y1.3968 N3055 X-2.0793 Y1.3974 N3060 X-2.1071 Y1.3962 N3065 X-2.1349 Y1.3941 N3070 X-2.1474 Y1.3928 N3075 X-2.1599 Y1.3923 N3080 X-2.1662 Y1.3926 N3085 X-2.1723 Y1.3932 N3090 X-2.1778 Y1.3944 N3095 X-2.1826 Y1.3966 N3100 X-2.1846 Y1.3981 N3105 X-2.1863 Y1.4 N3110 X-2.1891 Y1.4046 N3115 X-2.1912 Y1.41 N3120 X-2.1929 Y1.4159 N3125 X-2.1908 Y1.4219 N3130 X-2.1883 Y1.4274 N3135 X-2.1851 Y1.4321 N3140 X-2.1832 Y1.4339 N3145 X-2.181 Y1.4354 N3150 X-2.1758 Y1.4374 N3155 X-2.1699 Y1.4385 N3160 X-2.1635 Y1.4389 N3165 X-2.1569 Y1.4391 N3170 X-2.1422 Y1.4379 N3175 X-2.1274 Y1.4364 N3180 X-2.103 Y1.4341 N3185 X-2.0784 Y1.4331 N3190 X-2.0638 Y1.4336 N3195 X-2.0566 Y1.4342 N3200 X-2.0494 Y1.4352 N3205 X-2.0424 Y1.4367 N3210 X-2.0355 Y1.4388 N3215 X-2.0219 Y1.4439 N3220 X-2.0121 Y1.4507 N3225 X-2.0076 Y1.4545 N3230 X-2.0036 Y1.4586 N3235 X-2.0001 Y1.4633 N3240 X-1.997 Y1.4683 N3245 X-1.9917 Y1.479 N3250 X-1.9871 Y1.4958 N3255 X-1.9852 Y1.5042 N3260 X-1.9838 Y1.5128 N3265 X-1.9824 Y1.53 N3270 X-1.9821 Y1.5475 N3275 X-1.9824 Y1.5587 N3280 X-1.983 Y1.5698 N3285 X-1.9844 Y1.5809 N3290 X-1.9862 Y1.592 N3295 X-1.9908 Y1.6103 N3300 X-1.994 Y1.6192 N3305 X-1.9976 Y1.628 N3310 X-2.0012 Y1.6349 N3315 X-2.0052 Y1.6415 N3320 X-2.01 Y1.6476 N3325 X-2.0152 Y1.6534 N3330 X-2.0238 Y1.6596 N3335 X-2.0325 Y1.6655 N3340 X-2.0416 Y1.6706 N3345 X-2.051 Y1.6745 N3350 X-2.0609 Y1.6771 N3355 X-2.0712 Y1.6787 N3360 X-2.0924 Y1.6801 N3365 X-2.1071 Y1.6797 N3370 X-2.1217 Y1.6785 N3375 X-2.1362 Y1.6762 N3380 X-2.1506 Y1.6732 N3385 X-2.1614 Y1.6702 N3390 X-2.172 Y1.6666 N3395 X-2.1821 Y1.6619 N3400 X-2.192 Y1.6564 N3405 X-2.1971 Y1.6529 N3410 X-2.2015 Y1.6489 N3415 X-2.2032 Y1.6465 N3420 X-2.2046 Y1.6439 N3425 X-2.2066 Y1.6382 N3430 X-2.2059 Y1.6347 N3435 X-2.204 Y1.6319 N3440 X-2.1978 Y1.6271 N3445 X-2.1911 Y1.623 N3450 X-2.1819 Y1.6179 N3455 X-2.1733 Y1.6121 N3460 X-2.1694 Y1.6087 N3465 X-2.1658 Y1.6049 N3470 X-2.159 Y1.5969 N3475 X-2.1544 Y1.5879 N3480 X-2.1525 Y1.5833 N3485 X-2.151 Y1.5785 N3490 X-2.1493 Y1.5687 N3495 X-2.1487 Y1.5586 N3500 X-2.1502 Y1.544 N3505 X-2.1516 Y1.5369 N3510 X-2.1538 Y1.5302 N3515 X-2.1569 Y1.5239 N3520 X-2.1608 Y1.5178 N3525 X-2.1699 Y1.5063 N3530 X-2.1816 Y1.4975 N3535 X-2.1877 Y1.4937 N3540 X-2.1941 Y1.4906 N3545 X-2.2009 Y1.4885 N3550 X-2.208 Y1.4871 N3555 X-2.2226 Y1.4856 N3560 X-2.2381 Y1.4873 N3565 X-2.2456 Y1.4889 N3570 X-2.2527 Y1.4912 N3575 X-2.2594 Y1.4945 N3580 X-2.2658 Y1.4987 N3585 X-2.278 Y1.5084 N3590 X-2.2875 Y1.5208 N3595 X-2.2916 Y1.5273 N3600 X-2.2949 Y1.534 N3605 X-2.2971 Y1.5412 N3610 X-2.2986 Y1.5487 N3615 X-2.3003 Y1.5642 N3620 X-2.2979 Y1.5859 N3625 X-2.2958 Y1.5963 N3630 X-2.2927 Y1.6064 N3635 X-2.2883 Y1.616 N3640 X-2.2828 Y1.6252 N3645 X-2.2702 Y1.6429 N3650 X-2.2518 Y1.6599 N3655 X-2.2422 Y1.6678 N3660 X-2.232 Y1.6748 N3665 X-2.2212 Y1.6809 N3670 X-2.21 Y1.6862 N3675 X-2.1868 Y1.6957 N3680 X-2.1573 Y1.7037 N3685 X-2.1425 Y1.7072 N3690 X-2.1276 Y1.7099 N3695 X-2.1125 Y1.7117 N3700 X-2.0974 Y1.7129 N3705 X-2.0668 Y1.7141 N3710 X-2.0359 Y1.7129 N3715 X-2.0206 Y1.7117 N3720 X-2.0053 Y1.7098 N3725 X-1.9902 Y1.707 N3730 X-1.9753 Y1.7034 N3735 X-1.9455 Y1.6948 N3740 X-1.9225 Y1.6846 N3745 X-1.9114 Y1.6789 N3750 Z0.1606 N3755 G0 Z0.2 N3760 X-1.692 Y1.3613 N3765 Z0.1606 N3770 G1 Z-0.0394 F13.123 N3775 X-1.3819 F39.37 N3780 Y1.2356 N3785 X-1.692 N3790 Y1.3613 N3795 Z0.1606 N3800 G0 Z0.2 N3805 X-1.2737 Y1.3142 N3810 Z0.1606 N3815 G1 Z-0.0394 F13.123 N3820 X-0.9153 Y1.7132 F39.37 N3825 X-0.8691 N3830 Y1.3196 N3835 X-0.7399 N3840 Y1.2348 N3845 X-0.8691 N3850 Y1.2111 N3855 X-0.8677 Y1.1927 N3860 X-0.8662 Y1.1839 N3865 X-0.8639 Y1.1753 N3870 X-0.8603 Y1.1673 N3875 X-0.8556 Y1.1597 N3880 X-0.8446 Y1.1451 N3885 X-0.8289 Y1.1346 N3890 X-0.8207 Y1.1302 N3895 X-0.8121 Y1.1269 N3900 X-0.8032 Y1.1247 N3905 X-0.794 Y1.1233 N3910 X-0.775 Y1.1221 N3915 X-0.7459 N3920 Y1.0891 N3925 X-1.1364 N3930 Y1.1221 N3935 X-1.1094 N3940 X-1.093 Y1.1226 N3945 X-1.0848 Y1.1232 N3950 X-1.0767 Y1.1242 N3955 X-1.0687 Y1.1257 N3960 X-1.0608 Y1.1277 N3965 X-1.0451 Y1.1326 N3970 X-1.0342 Y1.1385 N3975 X-1.029 Y1.1418 N3980 X-1.0243 Y1.1456 N3985 X-1.02 Y1.1499 N3990 X-1.0162 Y1.1547 N3995 X-1.0092 Y1.1649 N4000 X-1.0039 Y1.179 N4005 X-1.0017 Y1.1862 N4010 X-1.0001 Y1.1935 N4015 X-0.999 Y1.2008 N4020 X-0.9984 Y1.2083 N4025 X-0.9978 Y1.2234 N4030 Y1.2348 N4035 X-1.2737 N4040 Y1.3142 N4045 Z0.1606 N4050 G0 Z0.2 N4055 X-0.9978 Y1.5866 N4060 Z0.1606 N4065 G1 Z-0.0394 F13.123 N4070 X-1.2359 Y1.3187 F39.37 N4075 X-0.9978 N4080 Y1.5866 N4085 Z0.1606 N4090 G0 Z0.2 N4095 X-0.6733 Y1.5604 N4100 Z0.1606 N4105 G1 Z-0.0394 F13.123 N4110 X-0.6714 Y1.5729 F39.37 N4115 X-0.6684 Y1.585 N4120 X-0.664 Y1.5966 N4125 X-0.6586 Y1.608 N4130 X-0.6459 Y1.6301 N4135 X-0.6279 Y1.6498 N4140 X-0.6184 Y1.6589 N4145 X-0.6082 Y1.6672 N4150 X-0.5972 Y1.6743 N4155 X-0.5855 Y1.6807 N4160 X-0.5613 Y1.6919 N4165 X-0.53 Y1.7014 N4170 X-0.5143 Y1.7053 N4175 X-0.4984 Y1.7084 N4180 X-0.4823 Y1.7105 N4185 X-0.4661 Y1.7119 N4190 X-0.4334 Y1.7132 N4195 X-0.4088 Y1.7121 N4200 X-0.3844 Y1.7103 N4205 X-0.3724 Y1.7089 N4210 X-0.3606 Y1.707 N4215 X-0.3489 Y1.7045 N4220 X-0.3375 Y1.7013 N4225 X-0.3264 Y1.6974 N4230 X-0.3156 Y1.6926 N4235 X-0.305 Y1.6872 N4240 X-0.2946 Y1.6812 N4245 X-0.2743 Y1.6679 N4250 X-0.2543 Y1.6536 N4255 X-0.2458 Y1.6443 N4260 X-0.2381 Y1.6344 N4265 X-0.2317 Y1.6236 N4270 X-0.2261 Y1.6122 N4275 X-0.2217 Y1.6001 N4280 X-0.2182 Y1.5877 N4285 X-0.2163 Y1.5751 N4290 X-0.2154 Y1.5622 N4295 X-0.2163 Y1.548 N4300 X-0.2171 Y1.541 N4305 X-0.2184 Y1.5341 N4310 X-0.2203 Y1.5273 N4315 X-0.2226 Y1.5207 N4320 X-0.228 Y1.5075 N4325 X-0.2363 Y1.4946 N4330 X-0.2407 Y1.4884 N4335 X-0.2455 Y1.4825 N4340 X-0.2508 Y1.477 N4345 X-0.2564 Y1.4719 N4350 X-0.2682 Y1.462 N4355 X-0.2836 Y1.452 N4360 X-0.2915 Y1.4473 N4365 X-0.2996 Y1.4431 N4370 X-0.308 Y1.4395 N4375 X-0.3165 Y1.4363 N4380 X-0.334 Y1.4305 N4385 X-0.3058 Y1.421 N4390 X-0.2919 Y1.4156 N4395 X-0.2785 Y1.4095 N4400 X-0.2655 Y1.4025 N4405 X-0.2529 Y1.3947 N4410 X-0.2284 Y1.3776 N4415 X-0.2161 Y1.3655 N4420 X-0.2044 Y1.3531 N4425 X-0.1989 Y1.3466 N4430 X-0.1939 Y1.34 N4435 X-0.1894 Y1.3331 N4440 X-0.1854 Y1.326 N4445 X-0.182 Y1.3186 N4450 X-0.1792 Y1.3108 N4455 X-0.177 Y1.3029 N4460 X-0.1751 Y1.2947 N4465 X-0.1723 Y1.2778 N4470 X-0.1702 Y1.2607 N4475 X-0.1712 Y1.2455 N4480 X-0.172 Y1.2379 N4485 X-0.1733 Y1.2305 N4490 X-0.1751 Y1.2231 N4495 X-0.1773 Y1.2158 N4500 X-0.1824 Y1.2014 N4505 X-0.1905 Y1.1864 N4510 X-0.1949 Y1.1792 N4515 X-0.1998 Y1.1723 N4520 X-0.2052 Y1.1659 N4525 X-0.2111 Y1.1597 N4530 X-0.2234 Y1.1479 N4535 X-0.2485 Y1.1307 N4540 X-0.2611 Y1.1224 N4545 X-0.2739 Y1.1146 N4550 X-0.2869 Y1.1073 N4555 X-0.3001 Y1.1008 N4560 X-0.3136 Y1.0952 N4565 X-0.3275 Y1.0906 N4570 X-0.3417 Y1.0869 N4575 X-0.3562 Y1.084 N4580 X-0.3709 Y1.0819 N4585 X-0.3858 Y1.0802 N4590 X-0.4161 Y1.0783 N4595 X-0.4467 Y1.0773 N4600 X-0.476 Y1.0782 N4605 X-0.4905 Y1.079 N4610 X-0.5051 Y1.0803 N4615 X-0.5195 Y1.0821 N4620 X-0.5339 Y1.0844 N4625 X-0.5627 Y1.0899 N4630 X-0.5859 Y1.0962 N4635 X-0.5973 Y1.0997 N4640 X-0.6085 Y1.1039 N4645 X-0.6194 Y1.1087 N4650 X-0.63 Y1.1141 N4655 X-0.6509 Y1.126 N4660 X-0.663 Y1.1361 N4665 X-0.6745 Y1.1465 N4670 X-0.6799 Y1.1519 N4675 X-0.6848 Y1.1576 N4680 X-0.6893 Y1.1635 N4685 X-0.6932 Y1.1697 N4690 X-0.6966 Y1.1762 N4695 X-0.6994 Y1.1831 N4700 X-0.7017 Y1.1902 N4705 X-0.7035 Y1.1975 N4710 X-0.7064 Y1.2127 N4715 X-0.7086 Y1.2283 N4720 X-0.7074 Y1.2451 N4725 X-0.7063 Y1.2534 N4730 X-0.7045 Y1.2616 N4735 X-0.702 Y1.2695 N4740 X-0.6988 Y1.2772 N4745 X-0.6913 Y1.2923 N4750 X-0.6797 Y1.3072 N4755 X-0.6735 Y1.3142 N4760 X-0.6668 Y1.3208 N4765 X-0.6596 Y1.3268 N4770 X-0.6521 Y1.3324 N4775 X-0.6363 Y1.3428 N4780 X-0.6144 Y1.3541 N4785 X-0.6032 Y1.3594 N4790 X-0.5919 Y1.3641 N4795 X-0.5803 Y1.3682 N4800 X-0.5685 Y1.3719 N4805 X-0.5447 Y1.3784 N4810 X-0.5723 Y1.3889 N4815 X-0.5856 Y1.3949 N4820 X-0.5983 Y1.4018 N4825 X-0.6104 Y1.4098 N4830 X-0.6217 Y1.4189 N4835 X-0.6326 Y1.4287 N4840 X-0.6433 Y1.4389 N4845 X-0.6506 Y1.4498 N4850 X-0.6573 Y1.4609 N4855 X-0.6633 Y1.4722 N4860 X-0.668 Y1.484 N4865 X-0.6712 Y1.4963 N4870 X-0.6733 Y1.509 N4875 X-0.6745 Y1.5219 N4880 X-0.6754 Y1.535 N4885 X-0.6733 Y1.5604 N4890 Z0.1606 N4895 G0 Z0.2 N4900 X-0.5279 Y1.3534 N4905 Z0.1606 N4910 G1 Z-0.0394 F13.123 N4915 X-0.539 Y1.3451 F39.37 N4920 X-0.5495 Y1.3361 N4925 X-0.5597 Y1.3266 N4930 X-0.5677 Y1.3172 N4935 X-0.575 Y1.3072 N4940 X-0.5808 Y1.2964 N4945 X-0.5858 Y1.2851 N4950 X-0.5894 Y1.272 N4955 X-0.592 Y1.2587 N4960 X-0.5933 Y1.2453 N4965 X-0.5938 Y1.2317 N4970 X-0.5863 Y1.2023 N4975 X-0.582 Y1.1882 N4980 X-0.5771 Y1.1748 N4985 X-0.5714 Y1.1624 N4990 X-0.5682 Y1.1566 N4995 X-0.5646 Y1.1512 N5000 X-0.5608 Y1.1461 N5005 X-0.5566 Y1.1414 N5010 X-0.5521 Y1.1372 N5015 X-0.5472 Y1.1333 N5020 X-0.542 Y1.1298 N5025 X-0.5364 Y1.1268 N5030 X-0.5306 Y1.124 N5035 X-0.5244 Y1.1216 N5040 X-0.5114 Y1.1176 N5045 X-0.4975 Y1.1146 N5050 X-0.483 Y1.1124 N5055 X-0.4679 Y1.1108 N5060 X-0.4369 Y1.1086 N5065 X-0.4155 Y1.1095 N5070 X-0.4049 Y1.1104 N5075 X-0.3943 Y1.1118 N5080 X-0.3839 Y1.1138 N5085 X-0.3735 Y1.1164 N5090 X-0.353 Y1.1226 N5095 X-0.3372 Y1.1296 N5100 X-0.3295 Y1.1335 N5105 X-0.3222 Y1.1379 N5110 X-0.3153 Y1.1429 N5115 X-0.3088 Y1.1484 N5120 X-0.2963 Y1.1603 N5125 X-0.288 Y1.1721 N5130 X-0.2844 Y1.1783 N5135 X-0.2815 Y1.1846 N5140 X-0.2794 Y1.1913 N5145 X-0.278 Y1.1982 N5150 X-0.2762 Y1.2125 N5155 X-0.2778 Y1.227 N5160 X-0.2793 Y1.2339 N5165 X-0.2815 Y1.2405 N5170 X-0.2847 Y1.2467 N5175 X-0.2887 Y1.2525 N5180 X-0.2981 Y1.2636 N5185 X-0.3099 Y1.273 N5190 X-0.3222 Y1.2816 N5195 X-0.3424 Y1.2916 N5200 X-0.3628 Y1.3013 N5205 X-0.4043 Y1.3191 N5210 X-0.4344 Y1.3309 N5215 X-0.4585 Y1.3403 N5220 X-0.4692 Y1.3443 N5225 X-0.48 Y1.3479 N5230 X-0.5019 Y1.3553 N5235 X-0.5164 Y1.3612 N5240 X-0.5279 Y1.3534 N5245 Z0.1606 N5250 G0 Z0.2 N5255 X-0.4686 Y1.4832 N5260 Z0.1606 N5265 G1 Z-0.0394 F13.123 N5270 X-0.4482 Y1.4753 F39.37 N5275 X-0.4173 Y1.4643 N5280 X-0.3918 Y1.4563 N5285 X-0.3666 Y1.4476 N5290 X-0.3552 Y1.4578 N5295 X-0.3498 Y1.4631 N5300 X-0.3448 Y1.4688 N5305 X-0.3403 Y1.4749 N5310 X-0.3362 Y1.4813 N5315 X-0.3287 Y1.4946 N5320 X-0.3231 Y1.5105 N5325 X-0.3208 Y1.5185 N5330 X-0.319 Y1.5266 N5335 X-0.3178 Y1.5349 N5340 X-0.317 Y1.5432 N5345 X-0.3163 Y1.5601 N5350 X-0.3169 Y1.5726 N5355 X-0.3179 Y1.585 N5360 X-0.3198 Y1.597 N5365 X-0.3228 Y1.6087 N5370 X-0.3249 Y1.6142 N5375 X-0.3275 Y1.6197 N5380 X-0.3336 Y1.6301 N5385 X-0.3407 Y1.6402 N5390 X-0.3483 Y1.6502 N5395 X-0.3591 Y1.6574 N5400 X-0.3701 Y1.6641 N5405 X-0.3814 Y1.6699 N5410 X-0.3872 Y1.6723 N5415 X-0.3932 Y1.6742 N5420 X-0.4055 Y1.6771 N5425 X-0.4181 Y1.6787 N5430 X-0.4311 Y1.6796 N5435 X-0.4442 Y1.6801 N5440 X-0.4636 Y1.6794 N5445 X-0.4732 Y1.6787 N5450 X-0.4828 Y1.6775 N5455 X-0.4923 Y1.6757 N5460 X-0.5017 Y1.6735 N5465 X-0.5203 Y1.6681 N5470 X-0.534 Y1.6621 N5475 X-0.5407 Y1.6587 N5480 X-0.547 Y1.655 N5485 X-0.553 Y1.6506 N5490 X-0.5586 Y1.6458 N5495 X-0.5693 Y1.6354 N5500 X-0.5765 Y1.6242 N5505 X-0.5796 Y1.6184 N5510 X-0.582 Y1.6124 N5515 X-0.5837 Y1.6062 N5520 X-0.5849 Y1.5997 N5525 X-0.5861 Y1.5865 N5530 X-0.5856 Y1.5785 N5535 X-0.5845 Y1.5706 N5540 X-0.5824 Y1.5629 N5545 X-0.5796 Y1.5554 N5550 X-0.576 Y1.5487 N5555 X-0.572 Y1.5423 N5560 X-0.5672 Y1.5365 N5565 X-0.5619 Y1.5311 N5570 X-0.5506 Y1.5222 N5575 X-0.5386 Y1.5143 N5580 X-0.5089 Y1.5003 N5585 X-0.4788 Y1.4871 N5590 X-0.4686 Y1.4832 N5595 Z0.1606 N5600 G0 Z0.2 N5605 X-0.1129 Y1.4258 N5610 Z0.1606 N5615 G1 Z-0.0394 F13.123 N5620 X-0.1114 Y1.4423 F39.37 N5625 X-0.1091 Y1.4587 N5630 X-0.1058 Y1.4749 N5635 X-0.1017 Y1.4909 N5640 X-0.092 Y1.5228 N5645 X-0.0799 Y1.5498 N5650 X-0.0732 Y1.5629 N5655 X-0.0656 Y1.5754 N5660 X-0.057 Y1.5873 N5665 X-0.0476 Y1.5985 N5670 X-0.0272 Y1.62 N5675 X-0.0053 Y1.6414 N5680 X0.0061 Y1.6515 N5685 X0.018 Y1.6608 N5690 X0.0306 Y1.6691 N5695 X0.0438 Y1.6767 N5700 X0.0711 Y1.6905 N5705 X0.0986 Y1.7 N5710 X0.1125 Y1.7041 N5715 X0.1265 Y1.7074 N5720 X0.1408 Y1.7098 N5725 X0.1551 Y1.7114 N5730 X0.1842 Y1.7132 N5735 X0.2076 Y1.7119 N5740 X0.2192 Y1.7107 N5745 X0.2307 Y1.7088 N5750 X0.242 Y1.7061 N5755 X0.2531 Y1.7027 N5760 X0.2752 Y1.6948 N5765 X0.2941 Y1.6849 N5770 X0.3031 Y1.6795 N5775 X0.3117 Y1.6735 N5780 X0.3197 Y1.6668 N5785 X0.3273 Y1.6594 N5790 X0.3416 Y1.6438 N5795 X0.352 Y1.6274 N5800 X0.3564 Y1.619 N5805 X0.3601 Y1.6103 N5810 X0.3627 Y1.6013 N5815 X0.3645 Y1.5919 N5820 X0.3666 Y1.5727 N5825 X0.3649 Y1.5575 N5830 X0.3634 Y1.5501 N5835 X0.3612 Y1.543 N5840 X0.358 Y1.5363 N5845 X0.3541 Y1.5299 N5850 X0.3448 Y1.5176 N5855 X0.3328 Y1.5079 N5860 X0.3265 Y1.5038 N5865 X0.3198 Y1.5005 N5870 X0.3128 Y1.4981 N5875 X0.3054 Y1.4966 N5880 X0.29 Y1.495 N5885 X0.2747 Y1.4964 N5890 X0.2673 Y1.4978 N5895 X0.2601 Y1.4999 N5900 X0.2533 Y1.5029 N5905 X0.2469 Y1.5067 N5910 X0.2344 Y1.5157 N5915 X0.2249 Y1.5272 N5920 X0.2208 Y1.5332 N5925 X0.2176 Y1.5396 N5930 X0.2153 Y1.5464 N5935 X0.2138 Y1.5535 N5940 X0.2121 Y1.5683 N5945 X0.2129 Y1.5788 N5950 X0.2136 Y1.5839 N5955 X0.2147 Y1.5889 N5960 X0.2164 Y1.5937 N5965 X0.2185 Y1.5984 N5970 X0.2235 Y1.6076 N5975 X0.2308 Y1.6158 N5980 X0.2387 Y1.6233 N5985 X0.2477 Y1.6295 N5990 X0.2573 Y1.635 N5995 X0.2623 Y1.6375 N6000 X0.267 Y1.6404 N6005 X0.2711 Y1.644 N6010 X0.2746 Y1.6484 N6015 X0.2729 Y1.6525 N6020 X0.2705 Y1.6561 N6025 X0.2673 Y1.659 N6030 X0.2635 Y1.6616 N6035 X0.256 Y1.6659 N6040 X0.2482 Y1.6695 N6045 X0.2401 Y1.6723 N6050 X0.2318 Y1.6747 N6055 X0.2207 Y1.6771 N6060 X0.2095 Y1.6789 N6065 X0.1981 Y1.6798 N6070 X0.1868 Y1.6801 N6075 X0.171 Y1.6788 N6080 X0.1556 Y1.6769 N6085 X0.148 Y1.6756 N6090 X0.1407 Y1.6738 N6095 X0.1336 Y1.6716 N6100 X0.1267 Y1.6688 N6105 X0.1202 Y1.6655 N6110 X0.1139 Y1.6615 N6115 X0.1079 Y1.6571 N6120 X0.102 Y1.6522 N6125 X0.0908 Y1.6415 N6130 X0.0799 Y1.6302 N6135 X0.0711 Y1.6117 N6140 X0.0628 Y1.593 N6145 X0.0592 Y1.5836 N6150 X0.0559 Y1.574 N6155 X0.0531 Y1.5644 N6160 X0.0508 Y1.5546 N6165 X0.049 Y1.5447 N6170 X0.0476 Y1.5347 N6175 X0.0459 Y1.5145 N6180 X0.045 Y1.494 N6185 X0.0447 Y1.4734 N6190 Y1.393 N6195 X0.0325 N6200 X0.0479 Y1.411 N6205 X0.0557 Y1.4197 N6210 X0.0638 Y1.428 N6215 X0.0721 Y1.4358 N6220 X0.0808 Y1.4429 N6225 X0.0898 Y1.4493 N6230 X0.0994 Y1.4548 N6235 X0.1094 Y1.4593 N6240 X0.1199 Y1.463 N6245 X0.1308 Y1.4659 N6250 X0.142 Y1.4683 N6255 X0.1535 Y1.4701 N6260 X0.1651 Y1.4716 N6265 X0.1887 Y1.474 N6270 X0.2166 Y1.4721 N6275 X0.2303 Y1.4705 N6280 X0.2438 Y1.4679 N6285 X0.2571 Y1.4643 N6290 X0.2702 Y1.4597 N6295 X0.2959 Y1.449 N6300 X0.3185 Y1.4353 N6305 X0.3292 Y1.4278 N6310 X0.3393 Y1.4196 N6315 X0.3486 Y1.4106 N6320 X0.3573 Y1.4008 N6325 X0.3735 Y1.38 N6330 X0.3856 Y1.3574 N6335 X0.3908 Y1.3458 N6340 X0.395 Y1.3339 N6345 X0.398 Y1.3217 N6350 X0.4 Y1.3091 N6355 X0.4022 Y1.2835 N6360 X0.3997 Y1.2555 N6365 X0.3976 Y1.2418 N6370 X0.3943 Y1.2285 N6375 X0.3896 Y1.2155 N6380 X0.3838 Y1.2029 N6385 X0.3703 Y1.1782 N6390 X0.352 Y1.1555 N6395 X0.3422 Y1.1449 N6400 X0.3317 Y1.1351 N6405 X0.3203 Y1.1263 N6410 X0.3082 Y1.1184 N6415 X0.2828 Y1.1039 N6420 X0.2531 Y1.0925 N6425 X0.2381 Y1.0876 N6430 X0.2228 Y1.0837 N6435 X0.2073 Y1.081 N6440 X0.1916 Y1.0792 N6445 X0.1598 Y1.0773 N6450 X0.1338 Y1.0786 N6455 X0.121 Y1.0798 N6460 X0.1082 Y1.0816 N6465 X0.0956 Y1.0843 N6470 X0.0832 Y1.0877 N6475 X0.0584 Y1.0956 N6480 X0.0361 Y1.1061 N6485 X0.0252 Y1.1118 N6490 X0.0148 Y1.1181 N6495 X0.0047 Y1.125 N6500 X-0.005 Y1.1326 N6505 X-0.0237 Y1.1486 N6510 X-0.0377 Y1.1641 N6515 X-0.0444 Y1.1721 N6520 X-0.0508 Y1.1804 N6525 X-0.0567 Y1.1889 N6530 X-0.0622 Y1.1977 N6535 X-0.0728 Y1.2158 N6540 X-0.0824 Y1.2359 N6545 X-0.0869 Y1.2461 N6550 X-0.091 Y1.2564 N6555 X-0.0979 Y1.2776 N6560 X-0.1039 Y1.2991 N6565 X-0.1084 Y1.3222 N6570 X-0.1119 Y1.3455 N6575 X-0.1137 Y1.369 N6580 X-0.1145 Y1.3925 N6585 X-0.1129 Y1.4258 N6590 Z0.1606 N6595 G0 Z0.2 N6600 X0.0937 Y1.414 N6605 Z0.1606 N6610 G1 Z-0.0394 F13.123 N6615 X0.0875 Y1.4093 F39.37 N6620 X0.0817 Y1.4043 N6625 X0.0763 Y1.3988 N6630 X0.0716 Y1.3929 N6635 X0.0672 Y1.3866 N6640 X0.0593 Y1.3732 N6645 X0.0529 Y1.3568 N6650 X0.0502 Y1.3485 N6655 X0.048 Y1.3401 N6660 X0.0466 Y1.3315 N6665 X0.0457 Y1.3228 N6670 X0.0447 Y1.3052 N6675 Y1.251 N6680 X0.0453 Y1.2308 N6685 X0.0461 Y1.2208 N6690 X0.0472 Y1.2108 N6695 X0.049 Y1.201 N6700 X0.0514 Y1.1912 N6705 X0.0571 Y1.1719 N6710 X0.0637 Y1.1582 N6715 X0.0673 Y1.1516 N6720 X0.0715 Y1.1455 N6725 X0.0763 Y1.1399 N6730 X0.0817 Y1.1347 N6735 X0.0933 Y1.125 N6740 X0.107 Y1.1181 N6745 X0.114 Y1.1152 N6750 X0.1211 Y1.113 N6755 X0.1285 Y1.1114 N6760 X0.136 Y1.1105 N6765 X0.1513 Y1.1095 N6770 X0.1627 Y1.1105 N6775 X0.1738 Y1.112 N6780 X0.1845 Y1.1145 N6785 X0.1895 Y1.1162 N6790 X0.1943 Y1.1184 N6795 X0.1989 Y1.121 N6800 X0.2032 Y1.1241 N6805 X0.2113 Y1.1314 N6810 X0.2187 Y1.1398 N6815 X0.2259 Y1.1486 N6820 X0.2304 Y1.1568 N6825 X0.2342 Y1.1653 N6830 X0.2369 Y1.1742 N6835 X0.2391 Y1.1833 N6840 X0.2426 Y1.2106 N6845 X0.244 Y1.2244 N6850 X0.2449 Y1.2381 N6855 X0.2456 Y1.2657 N6860 Y1.2933 N6865 X0.2454 Y1.3128 N6870 X0.2444 Y1.3321 N6875 X0.242 Y1.3514 N6880 X0.2387 Y1.3706 N6885 X0.2342 Y1.3842 N6890 X0.2316 Y1.3909 N6895 X0.2286 Y1.3974 N6900 X0.2252 Y1.4036 N6905 X0.2213 Y1.4097 N6910 X0.213 Y1.4214 N6915 X0.2006 Y1.4279 N6920 X0.1942 Y1.4305 N6925 X0.1876 Y1.4324 N6930 X0.1808 Y1.4337 N6935 X0.1739 Y1.4344 N6940 X0.1598 Y1.4348 N6945 X0.144 Y1.4337 N6950 X0.1363 Y1.4327 N6955 X0.1287 Y1.431 N6960 X0.1213 Y1.4287 N6965 X0.114 Y1.4257 N6970 X0.0998 Y1.4187 N6975 X0.0937 Y1.414 N6980 Z0.1606 N6985 G0 Z0.2 N6990 X0.5088 Y1.311 N6995 Z0.1606 N7000 G1 Z-0.0394 F13.123 N7005 Y1.3613 F39.37 N7010 X0.8189 N7015 Y1.2356 N7020 X0.5088 N7025 Y1.311 N7030 Z0.1606 N7035 G0 Z0.2 N7040 X0.9386 Y1.2424 N7045 Z0.1606 N7050 G1 Z-0.0394 F13.123 N7055 X0.941 Y1.2499 F39.37 N7060 X0.9444 Y1.2571 N7065 X0.9486 Y1.2638 N7070 X0.9585 Y1.2769 N7075 X0.9711 Y1.2869 N7080 X0.9777 Y1.2912 N7085 X0.9846 Y1.2946 N7090 X0.992 Y1.2971 N7095 X0.9997 Y1.2986 N7100 X1.0157 Y1.3004 N7105 X1.0312 Y1.2989 N7110 X1.0387 Y1.2975 N7115 X1.0459 Y1.2953 N7120 X1.0526 Y1.2921 N7125 X1.0591 Y1.2881 N7130 X1.0715 Y1.2787 N7135 X1.0807 Y1.2669 N7140 X1.0846 Y1.2607 N7145 X1.0878 Y1.2542 N7150 X1.09 Y1.2473 N7155 X1.0915 Y1.24 N7160 X1.0931 Y1.2251 N7165 X1.0924 Y1.2157 N7170 X1.0908 Y1.2066 N7175 X1.0877 Y1.1979 N7180 X1.0836 Y1.1895 N7185 X1.0768 Y1.1808 N7190 X1.0694 Y1.1727 N7195 X1.0609 Y1.1657 N7200 X1.0519 Y1.1593 N7205 X1.0478 Y1.1569 N7210 X1.0441 Y1.1541 N7215 X1.0412 Y1.1506 N7220 X1.0389 Y1.1465 N7225 X1.0445 Y1.1372 N7230 X1.0479 Y1.1333 N7235 X1.0519 Y1.1301 N7240 X1.0566 Y1.1276 N7245 X1.0616 Y1.1256 N7250 X1.0723 Y1.1223 N7255 X1.0939 Y1.1171 N7260 X1.1047 Y1.115 N7265 X1.1157 Y1.1134 N7270 X1.1267 Y1.1123 N7275 X1.1377 Y1.1117 N7280 X1.1599 Y1.1112 N7285 X1.1743 Y1.1115 N7290 X1.1885 Y1.1122 N7295 X1.2024 Y1.1137 N7300 X1.2159 Y1.1165 N7305 X1.2225 Y1.1184 N7310 X1.229 Y1.1208 N7315 X1.2415 Y1.1268 N7320 X1.2536 Y1.1339 N7325 X1.2656 Y1.1416 N7330 X1.2743 Y1.1541 N7335 X1.2824 Y1.1669 N7340 X1.286 Y1.1734 N7345 X1.2893 Y1.18 N7350 X1.292 Y1.1868 N7355 X1.2943 Y1.1938 N7360 X1.296 Y1.2009 N7365 X1.2972 Y1.2081 N7370 X1.2987 Y1.223 N7375 X1.299 Y1.2382 N7380 X1.2989 Y1.2536 N7385 X1.2979 Y1.2689 N7390 X1.2964 Y1.2841 N7395 X1.2942 Y1.299 N7400 X1.2909 Y1.3135 N7405 X1.2886 Y1.3205 N7410 X1.2859 Y1.3274 N7415 X1.2792 Y1.3408 N7420 X1.2714 Y1.3537 N7425 X1.2631 Y1.3664 N7430 X1.2527 Y1.3737 N7435 X1.2422 Y1.3806 N7440 X1.2314 Y1.3865 N7445 X1.2258 Y1.3889 N7450 X1.22 Y1.391 N7455 X1.2081 Y1.394 N7460 X1.1959 Y1.3958 N7465 X1.1833 Y1.3968 N7470 X1.1706 Y1.3974 N7475 X1.1427 Y1.3962 N7480 X1.1149 Y1.3941 N7485 X1.1025 Y1.3928 N7490 X1.0899 Y1.3923 N7495 X1.0836 Y1.3926 N7500 X1.0776 Y1.3932 N7505 X1.072 Y1.3944 N7510 X1.0673 Y1.3966 N7515 X1.0653 Y1.3981 N7520 X1.0635 Y1.4 N7525 X1.0608 Y1.4046 N7530 X1.0587 Y1.41 N7535 X1.0569 Y1.4159 N7540 X1.059 Y1.4219 N7545 X1.0615 Y1.4274 N7550 X1.0647 Y1.4321 N7555 X1.0666 Y1.4339 N7560 X1.0689 Y1.4354 N7565 X1.074 Y1.4374 N7570 X1.0799 Y1.4385 N7575 X1.0863 Y1.4389 N7580 X1.0929 Y1.4391 N7585 X1.1077 Y1.4379 N7590 X1.1224 Y1.4364 N7595 X1.1469 Y1.4341 N7600 X1.1714 Y1.4331 N7605 X1.186 Y1.4336 N7610 X1.1932 Y1.4342 N7615 X1.2004 Y1.4352 N7620 X1.2074 Y1.4367 N7625 X1.2143 Y1.4388 N7630 X1.228 Y1.4439 N7635 X1.2377 Y1.4507 N7640 X1.2422 Y1.4545 N7645 X1.2463 Y1.4586 N7650 X1.2497 Y1.4633 N7655 X1.2528 Y1.4683 N7660 X1.2581 Y1.479 N7665 X1.2627 Y1.4958 N7670 X1.2646 Y1.5042 N7675 X1.266 Y1.5128 N7680 X1.2674 Y1.53 N7685 X1.2677 Y1.5475 N7690 X1.2668 Y1.5698 N7695 X1.2655 Y1.5809 N7700 X1.2637 Y1.592 N7705 X1.259 Y1.6103 N7710 X1.2558 Y1.6192 N7715 X1.2522 Y1.628 N7720 X1.2487 Y1.6349 N7725 X1.2447 Y1.6415 N7730 X1.2399 Y1.6476 N7735 X1.2346 Y1.6534 N7740 X1.226 Y1.6596 N7745 X1.2173 Y1.6655 N7750 X1.2083 Y1.6706 N7755 X1.1988 Y1.6745 N7760 X1.1889 Y1.6771 N7765 X1.1786 Y1.6787 N7770 X1.1574 Y1.6801 N7775 X1.1427 Y1.6797 N7780 X1.1281 Y1.6785 N7785 X1.1136 Y1.6762 N7790 X1.0992 Y1.6732 N7795 X1.0884 Y1.6702 N7800 X1.0778 Y1.6666 N7805 X1.0677 Y1.6619 N7810 X1.0578 Y1.6564 N7815 X1.0527 Y1.6529 N7820 X1.0483 Y1.6489 N7825 X1.0466 Y1.6465 N7830 X1.0452 Y1.6439 N7835 X1.0432 Y1.6382 N7840 X1.0439 Y1.6347 N7845 X1.0458 Y1.6319 N7850 X1.052 Y1.6271 N7855 X1.0587 Y1.623 N7860 X1.0679 Y1.6179 N7865 X1.0765 Y1.6121 N7870 X1.0804 Y1.6087 N7875 X1.084 Y1.6049 N7880 X1.0908 Y1.5969 N7885 X1.0954 Y1.5879 N7890 X1.0973 Y1.5833 N7895 X1.0989 Y1.5785 N7900 X1.1005 Y1.5687 N7905 X1.1012 Y1.5586 N7910 X1.0996 Y1.544 N7915 X1.0982 Y1.5369 N7920 X1.096 Y1.5302 N7925 X1.0929 Y1.5239 N7930 X1.089 Y1.5178 N7935 X1.0799 Y1.5063 N7940 X1.0682 Y1.4975 N7945 X1.0621 Y1.4937 N7950 X1.0557 Y1.4906 N7955 X1.0489 Y1.4885 N7960 X1.0419 Y1.4871 N7965 X1.0272 Y1.4856 N7970 X1.0117 Y1.4873 N7975 X1.0043 Y1.4889 N7980 X0.9971 Y1.4912 N7985 X0.9904 Y1.4945 N7990 X0.984 Y1.4987 N7995 X0.9718 Y1.5084 N8000 X0.9623 Y1.5208 N8005 X0.9582 Y1.5273 N8010 X0.955 Y1.534 N8015 X0.9527 Y1.5412 N8020 X0.9512 Y1.5487 N8025 X0.9495 Y1.5642 N8030 X0.9519 Y1.5859 N8035 X0.954 Y1.5963 N8040 X0.9572 Y1.6064 N8045 X0.9616 Y1.616 N8050 X0.967 Y1.6252 N8055 X0.9796 Y1.6429 N8060 X0.998 Y1.6599 N8065 X1.0076 Y1.6678 N8070 X1.0178 Y1.6748 N8075 X1.0286 Y1.6809 N8080 X1.0398 Y1.6862 N8085 X1.0631 Y1.6957 N8090 X1.0925 Y1.7037 N8095 X1.1073 Y1.7072 N8100 X1.1222 Y1.7099 N8105 X1.1373 Y1.7117 N8110 X1.1525 Y1.7129 N8115 X1.183 Y1.7141 N8120 X1.2139 Y1.7129 N8125 X1.2293 Y1.7117 N8130 X1.2445 Y1.7098 N8135 X1.2596 Y1.707 N8140 X1.2746 Y1.7034 N8145 X1.3043 Y1.6948 N8150 X1.3274 Y1.6846 N8155 X1.3385 Y1.6789 N8160 X1.349 Y1.6725 N8165 X1.359 Y1.6651 N8170 X1.3683 Y1.6568 N8175 X1.3861 Y1.639 N8180 X1.3987 Y1.6194 N8185 X1.4041 Y1.6094 N8190 X1.4084 Y1.5989 N8195 X1.4114 Y1.588 N8200 X1.4134 Y1.5767 N8205 X1.4156 Y1.5536 N8210 X1.4146 Y1.5387 N8215 X1.4138 Y1.5314 N8220 X1.4124 Y1.5242 N8225 X1.4105 Y1.5171 N8230 X1.4081 Y1.5101 N8235 X1.4025 Y1.4963 N8240 X1.3947 Y1.4833 N8245 X1.3905 Y1.477 N8250 X1.3858 Y1.4711 N8255 X1.3807 Y1.4656 N8260 X1.3753 Y1.4605 N8265 X1.3637 Y1.4506 N8270 X1.3449 Y1.4393 N8275 X1.3353 Y1.4342 N8280 X1.3254 Y1.4297 N8285 X1.3153 Y1.4258 N8290 X1.3049 Y1.4225 N8295 X1.2837 Y1.4167 N8300 X1.2574 Y1.412 N8305 X1.2311 Y1.408 N8310 X1.24 Y1.4176 N8315 X1.2489 Y1.4233 N8320 X1.2721 Y1.4196 N8325 X1.295 Y1.415 N8330 X1.3063 Y1.412 N8335 X1.3175 Y1.4086 N8340 X1.3397 Y1.401 N8345 X1.3566 Y1.3937 N8350 X1.373 Y1.3855 N8355 X1.3808 Y1.3809 N8360 X1.3884 Y1.3758 N8365 X1.4034 Y1.3651 N8370 X1.415 Y1.3544 N8375 X1.4205 Y1.3488 N8380 X1.4256 Y1.3429 N8385 X1.4303 Y1.3366 N8390 X1.4345 Y1.33 N8395 X1.4424 Y1.3163 N8400 X1.448 Y1.3022 N8405 X1.4505 Y1.295 N8410 X1.4524 Y1.2877 N8415 X1.4538 Y1.2803 N8420 X1.4547 Y1.2728 N8425 X1.4557 Y1.2576 N8430 X1.4544 Y1.2445 N8435 X1.4527 Y1.2316 N8440 X1.4502 Y1.219 N8445 X1.4485 Y1.2128 N8450 X1.4464 Y1.2068 N8455 X1.441 Y1.1953 N8460 X1.4344 Y1.1843 N8465 X1.4269 Y1.1736 N8470 X1.419 Y1.1631 N8475 X1.3963 Y1.1427 N8480 X1.3845 Y1.1333 N8485 X1.372 Y1.1249 N8490 X1.3588 Y1.1177 N8495 X1.3451 Y1.1114 N8500 X1.3167 Y1.1001 N8505 X1.2804 Y1.0905 N8510 X1.2621 Y1.0864 N8515 X1.2437 Y1.0832 N8520 X1.2251 Y1.081 N8525 X1.2065 Y1.0796 N8530 X1.1689 Y1.0782 N8535 X1.1455 Y1.0789 N8540 X1.1222 Y1.0806 N8545 X1.099 Y1.0837 N8550 X1.076 Y1.0877 N8555 X1.0577 Y1.0919 N8560 X1.0397 Y1.097 N8565 X1.0309 Y1.1001 N8570 X1.0222 Y1.1036 N8575 X1.0051 Y1.1113 N8580 X0.9904 Y1.1213 N8585 X0.9833 Y1.1267 N8590 X0.9766 Y1.1324 N8595 X0.9705 Y1.1387 N8600 X0.9647 Y1.1454 N8605 X0.9539 Y1.1595 N8610 X0.9464 Y1.1733 N8615 X0.9431 Y1.1803 N8620 X0.9404 Y1.1876 N8625 X0.9384 Y1.195 N8630 X0.9371 Y1.2026 N8635 X0.9354 Y1.2183 N8640 X0.9371 Y1.2345 N8645 X0.9386 Y1.2424 N8650 Z0.1606 N8655 G0 Z0.2 N8660 X1.4993 Y1.4705 N8665 Z0.1606 N8670 G1 Z-0.0394 F13.123 N8675 X1.4976 Y1.4798 F39.37 N8680 X1.4965 Y1.4893 N8685 X1.4952 Y1.5085 N8690 X1.4976 Y1.5364 N8695 X1.4997 Y1.55 N8700 X1.503 Y1.5633 N8705 X1.5076 Y1.5762 N8710 X1.5134 Y1.5888 N8715 X1.5268 Y1.6133 N8720 X1.5453 Y1.6358 N8725 X1.5551 Y1.6463 N8730 X1.5657 Y1.656 N8735 X1.5772 Y1.6646 N8740 X1.5893 Y1.6724 N8745 X1.6147 Y1.6866 N8750 X1.6446 Y1.6981 N8755 X1.6597 Y1.7029 N8760 X1.6751 Y1.7068 N8765 X1.6907 Y1.7095 N8770 X1.7065 Y1.7113 N8775 X1.7384 Y1.7132 N8780 X1.7572 Y1.7119 N8785 X1.7759 Y1.7102 N8790 X1.7943 Y1.7075 N8795 X1.8034 Y1.7057 N8800 X1.8123 Y1.7034 N8805 X1.8211 Y1.7007 N8810 X1.8298 Y1.6975 N8815 X1.8469 Y1.6901 N8820 X1.8637 Y1.6818 N8825 X1.8803 Y1.6729 N8830 X1.8954 Y1.6615 N8835 X1.9102 Y1.6497 N8840 X1.9242 Y1.6373 N8845 X1.9308 Y1.6307 N8850 X1.937 Y1.6239 N8855 X1.9429 Y1.6167 N8860 X1.9485 Y1.6093 N8865 X1.9589 Y1.5937 N8870 X1.9686 Y1.5775 N8875 X1.9779 Y1.561 N8880 X1.9856 Y1.5415 N8885 X1.9929 Y1.5219 N8890 X1.9993 Y1.5021 N8895 X2.0043 Y1.4821 N8900 X2.0078 Y1.4616 N8905 X2.01 Y1.4409 N8910 X2.0114 Y1.4201 N8915 X2.0123 Y1.3991 N8920 X2.0096 Y1.3659 N8925 X2.0079 Y1.3494 N8930 X2.0058 Y1.3331 N8935 X2.0031 Y1.317 N8940 X1.9998 Y1.3012 N8945 X1.9956 Y1.2857 N8950 X1.9904 Y1.2706 N8955 X1.9841 Y1.256 N8960 X1.9768 Y1.2417 N8965 X1.9687 Y1.2278 N8970 X1.9598 Y1.2142 N8975 X1.9503 Y1.2008 N8980 X1.9404 Y1.1875 N8985 X1.9198 Y1.1614 N8990 X1.8991 Y1.1426 N8995 X1.8884 Y1.1338 N9000 X1.8772 Y1.1257 N9005 X1.8655 Y1.1184 N9010 X1.8533 Y1.1118 N9015 X1.8281 Y1.0997 N9020 X1.8006 Y1.0903 N9025 X1.7867 Y1.0862 N9030 X1.7726 Y1.0829 N9035 X1.7584 Y1.0806 N9040 X1.744 Y1.0791 N9045 X1.7149 Y1.0773 N9050 X1.6949 Y1.0786 N9055 X1.6751 Y1.0805 N9060 X1.6653 Y1.0819 N9065 X1.6557 Y1.0837 N9070 X1.6463 Y1.086 N9075 X1.6371 Y1.0889 N9080 X1.6281 Y1.0924 N9085 X1.6194 Y1.0965 N9090 X1.6109 Y1.1012 N9095 X1.6025 Y1.1064 N9100 X1.5862 Y1.1176 N9105 X1.5702 Y1.1296 N9110 X1.562 Y1.1388 N9115 X1.5543 Y1.1481 N9120 X1.5473 Y1.1578 N9125 X1.5416 Y1.1681 N9130 X1.5393 Y1.1735 N9135 X1.5374 Y1.179 N9140 X1.5345 Y1.1905 N9145 X1.5325 Y1.2025 N9150 X1.5309 Y1.2146 N9155 X1.5324 Y1.2306 N9160 X1.5338 Y1.2384 N9165 X1.5361 Y1.2459 N9170 X1.5393 Y1.253 N9175 X1.5433 Y1.2598 N9180 X1.5528 Y1.2728 N9185 X1.5647 Y1.2827 N9190 X1.571 Y1.2869 N9195 X1.5776 Y1.2903 N9200 X1.5847 Y1.2927 N9205 X1.5921 Y1.2942 N9210 X1.6074 Y1.296 N9215 X1.623 Y1.2945 N9220 X1.6305 Y1.2931 N9225 X1.6378 Y1.291 N9230 X1.6446 Y1.2879 N9235 X1.6512 Y1.2841 N9240 X1.6639 Y1.275 N9245 X1.6736 Y1.2632 N9250 X1.6778 Y1.257 N9255 X1.6811 Y1.2505 N9260 X1.6834 Y1.2435 N9265 X1.6849 Y1.2362 N9270 X1.6866 Y1.221 N9275 X1.6858 Y1.2107 N9280 X1.6851 Y1.2057 N9285 X1.684 Y1.2008 N9290 X1.6824 Y1.196 N9295 X1.6804 Y1.1914 N9300 X1.6755 Y1.1823 N9305 X1.6673 Y1.1734 N9310 X1.6629 Y1.1692 N9315 X1.6582 Y1.1655 N9320 X1.648 Y1.1592 N9325 X1.6371 Y1.1537 N9330 X1.633 Y1.1514 N9335 X1.6294 Y1.1487 N9340 X1.6266 Y1.1452 N9345 X1.6247 Y1.141 N9350 X1.629 Y1.1337 N9355 X1.6316 Y1.1306 N9360 X1.6347 Y1.1279 N9365 X1.6382 Y1.1258 N9370 X1.6421 Y1.1239 N9375 X1.6502 Y1.1208 N9380 X1.6652 Y1.1161 N9385 X1.6728 Y1.1142 N9390 X1.6804 Y1.1126 N9395 X1.6959 Y1.111 N9400 X1.7116 Y1.1104 N9405 X1.7271 Y1.1118 N9410 X1.7422 Y1.1138 N9415 X1.7496 Y1.1152 N9420 X1.7568 Y1.117 N9425 X1.7638 Y1.1193 N9430 X1.7705 Y1.1221 N9435 X1.7769 Y1.1255 N9440 X1.7831 Y1.1294 N9445 X1.789 Y1.1339 N9450 X1.7947 Y1.1387 N9455 X1.8057 Y1.1493 N9460 X1.8164 Y1.1605 N9465 X1.8252 Y1.1781 N9470 X1.8335 Y1.1958 N9475 X1.8405 Y1.2139 N9480 X1.8433 Y1.2231 N9485 X1.8457 Y1.2324 N9490 X1.8475 Y1.2419 N9495 X1.849 Y1.2515 N9500 X1.8509 Y1.2709 N9505 X1.8518 Y1.2905 N9510 X1.8523 Y1.3103 N9515 Y1.3975 N9520 X1.8643 N9525 X1.8512 Y1.3799 N9530 X1.8443 Y1.3716 N9535 X1.8367 Y1.3638 N9540 X1.8285 Y1.3567 N9545 X1.8198 Y1.3503 N9550 X1.8014 Y1.3383 N9555 X1.7794 Y1.3294 N9560 X1.7683 Y1.3256 N9565 X1.7569 Y1.3227 N9570 X1.7454 Y1.3207 N9575 X1.7337 Y1.3195 N9580 X1.71 Y1.3183 N9585 X1.6888 Y1.3193 N9590 X1.6782 Y1.3203 N9595 X1.6678 Y1.3218 N9600 X1.6575 Y1.3239 N9605 X1.6473 Y1.3266 N9610 X1.627 Y1.3328 N9615 X1.6084 Y1.3408 N9620 X1.5994 Y1.3451 N9625 X1.5906 Y1.35 N9630 X1.5822 Y1.3553 N9635 X1.574 Y1.3612 N9640 X1.5581 Y1.3736 N9645 X1.5444 Y1.3872 N9650 X1.5379 Y1.3943 N9655 X1.5319 Y1.4017 N9660 X1.5263 Y1.4095 N9665 X1.5212 Y1.4176 N9670 X1.5118 Y1.4344 N9675 X1.5047 Y1.4523 N9680 X1.5017 Y1.4613 N9685 X1.4993 Y1.4705 N9690 Z0.1606 N9695 G0 Z0.2 N9700 X1.7995 Y1.3739 N9705 Z0.1606 N9710 G1 Z-0.0394 F13.123 N9715 X1.8082 Y1.3805 F39.37 N9720 X1.8167 Y1.3875 N9725 X1.8258 Y1.3984 N9730 X1.8299 Y1.4041 N9735 X1.8336 Y1.41 N9740 X1.8367 Y1.4163 N9745 X1.8394 Y1.4228 N9750 X1.844 Y1.4362 N9755 X1.8483 Y1.4561 N9760 X1.85 Y1.4662 N9765 X1.8513 Y1.4762 N9770 X1.8527 Y1.4965 N9775 X1.8531 Y1.5169 N9780 X1.8526 Y1.5407 N9785 X1.852 Y1.5526 N9790 X1.8509 Y1.5644 N9795 X1.8492 Y1.5762 N9800 X1.847 Y1.5879 N9805 X1.8416 Y1.6111 N9810 X1.8358 Y1.6262 N9815 X1.8325 Y1.6335 N9820 X1.8286 Y1.6403 N9825 X1.824 Y1.6468 N9830 X1.8188 Y1.6528 N9835 X1.8073 Y1.6641 N9840 X1.7937 Y1.6716 N9845 X1.7868 Y1.6748 N9850 X1.7796 Y1.6773 N9855 X1.7722 Y1.6789 N9860 X1.7646 Y1.68 N9865 X1.7491 Y1.681 N9870 X1.7377 Y1.6802 N9875 X1.7264 Y1.6789 N9880 X1.7156 Y1.6766 N9885 X1.7105 Y1.675 N9890 X1.7055 Y1.673 N9895 X1.7008 Y1.6706 N9900 X1.6964 Y1.6676 N9905 X1.688 Y1.6607 N9910 X1.6801 Y1.6526 N9915 X1.6726 Y1.644 N9920 X1.6682 Y1.635 N9925 X1.6643 Y1.6258 N9930 X1.6613 Y1.6163 N9935 X1.6589 Y1.6066 N9940 X1.6568 Y1.5945 N9945 X1.6555 Y1.5823 N9950 X1.6542 Y1.5621 N9955 X1.6534 Y1.5419 N9960 X1.6526 Y1.4934 N9965 X1.6528 Y1.4767 N9970 X1.6536 Y1.4599 N9975 X1.6552 Y1.4433 N9980 X1.6576 Y1.4267 N9985 X1.6619 Y1.408 N9990 X1.6678 Y1.3897 N9995 X1.675 Y1.3822 N10000 X1.6825 Y1.3751 N10005 X1.6903 Y1.3688 N10010 X1.6945 Y1.3661 N10015 X1.6988 Y1.3638 N10020 X1.708 Y1.3604 N10025 X1.7179 Y1.3581 N10030 X1.7281 Y1.3567 N10035 X1.7385 Y1.3557 N10040 X1.7495 Y1.3566 N10045 X1.7604 Y1.358 N10050 X1.7709 Y1.3601 N10055 X1.781 Y1.3634 N10060 X1.7905 Y1.368 N10065 X1.7995 Y1.3739 N10070 Z0.1606 N10075 G0 Z0.2 N10080 X2.1121 Y1.3513 N10085 Z0.1606 N10090 G1 Z-0.0394 F13.123 N10095 X2.4371 Y1.7132 F39.37 N10100 X2.4834 N10105 Y1.3196 N10110 X2.6126 N10115 Y1.2348 N10120 X2.4834 N10125 Y1.2111 N10130 X2.4848 Y1.1927 N10135 X2.4862 Y1.1839 N10140 X2.4886 Y1.1753 N10145 X2.4922 Y1.1673 N10150 X2.4968 Y1.1597 N10155 X2.5079 Y1.1451 N10160 X2.5236 Y1.1346 N10165 X2.5318 Y1.1302 N10170 X2.5403 Y1.1269 N10175 X2.5492 Y1.1247 N10180 X2.5585 Y1.1233 N10185 X2.5774 Y1.1221 N10190 X2.6066 N10195 Y1.0891 N10200 X2.216 N10205 Y1.1221 N10210 X2.2431 N10215 X2.2595 Y1.1226 N10220 X2.2677 Y1.1232 N10225 X2.2758 Y1.1242 N10230 X2.2838 Y1.1257 N10235 X2.2917 Y1.1277 N10240 X2.3073 Y1.1326 N10245 X2.3183 Y1.1385 N10250 X2.3234 Y1.1418 N10255 X2.3282 Y1.1456 N10260 X2.3324 Y1.1499 N10265 X2.3363 Y1.1547 N10270 X2.3432 Y1.1649 N10275 X2.3485 Y1.179 N10280 X2.3507 Y1.1862 N10285 X2.3524 Y1.1935 N10290 X2.3535 Y1.2008 N10295 X2.3541 Y1.2083 N10300 X2.3546 Y1.2234 N10305 Y1.2348 N10310 X2.0787 N10315 Y1.3142 N10320 X2.1121 Y1.3513 N10325 Z0.1606 N10330 G0 Z0.2 N10335 X2.3546 Y1.5866 N10340 Z0.1606 N10345 G1 Z-0.0394 F13.123 N10350 X2.1166 Y1.3187 F39.37 N10355 X2.3546 N10360 Y1.5866 N10365 Z0.1606 N10370 G0 Z0.2 N10375 X2.6792 Y1.5604 N10380 Z0.1606 N10385 G1 Z-0.0394 F13.123 N10390 X2.6811 Y1.5729 F39.37 N10395 X2.6841 Y1.585 N10400 X2.6884 Y1.5966 N10405 X2.6939 Y1.608 N10410 X2.7066 Y1.6301 N10415 X2.7245 Y1.6498 N10420 X2.7341 Y1.6589 N10425 X2.7443 Y1.6672 N10430 X2.7553 Y1.6743 N10435 X2.7669 Y1.6807 N10440 X2.7912 Y1.6919 N10445 X2.8224 Y1.7014 N10450 X2.8382 Y1.7053 N10455 X2.8541 Y1.7084 N10460 X2.8702 Y1.7105 N10465 X2.8864 Y1.7119 N10470 X2.919 Y1.7132 N10475 X2.9437 Y1.7121 N10480 X2.9681 Y1.7103 N10485 X2.9801 Y1.7089 N10490 X2.9919 Y1.707 N10495 X3.0036 Y1.7045 N10500 X3.0149 Y1.7013 N10505 X3.0261 Y1.6974 N10510 X3.0369 Y1.6926 N10515 X3.0475 Y1.6872 N10520 X3.0579 Y1.6812 N10525 X3.0782 Y1.6679 N10530 X3.0981 Y1.6536 N10535 X3.1067 Y1.6443 N10540 X3.1144 Y1.6344 N10545 X3.1208 Y1.6236 N10550 X3.1263 Y1.6122 N10555 X3.1308 Y1.6001 N10560 X3.1343 Y1.5877 N10565 X3.1362 Y1.5751 N10570 X3.1371 Y1.5622 N10575 X3.1362 Y1.548 N10580 X3.1353 Y1.541 N10585 X3.134 Y1.5341 N10590 X3.1322 Y1.5273 N10595 X3.1299 Y1.5207 N10600 X3.1244 Y1.5075 N10605 X3.1162 Y1.4946 N10610 X3.1118 Y1.4884 N10615 X3.1069 Y1.4825 N10620 X3.1017 Y1.477 N10625 X3.0961 Y1.4719 N10630 X3.0843 Y1.462 N10635 X3.0689 Y1.452 N10640 X3.061 Y1.4473 N10645 X3.0529 Y1.4431 N10650 X3.0445 Y1.4395 N10655 X3.0359 Y1.4363 N10660 X3.0184 Y1.4305 N10665 X3.0467 Y1.421 N10670 X3.0605 Y1.4156 N10675 X3.074 Y1.4095 N10680 X3.087 Y1.4025 N10685 X3.0996 Y1.3947 N10690 X3.124 Y1.3776 N10695 X3.1364 Y1.3655 N10700 X3.1481 Y1.3531 N10705 X3.1535 Y1.3466 N10710 X3.1586 Y1.34 N10715 X3.1631 Y1.3331 N10720 X3.1671 Y1.326 N10725 X3.1704 Y1.3186 N10730 X3.1732 Y1.3108 N10735 X3.1755 Y1.3029 N10740 X3.1774 Y1.2947 N10745 X3.1802 Y1.2778 N10750 X3.1823 Y1.2607 N10755 X3.1813 Y1.2455 N10760 X3.1805 Y1.2379 N10765 X3.1792 Y1.2305 N10770 X3.1774 Y1.2231 N10775 X3.1752 Y1.2158 N10780 X3.1701 Y1.2014 N10785 X3.162 Y1.1864 N10790 X3.1575 Y1.1792 N10795 X3.1527 Y1.1723 N10800 X3.1472 Y1.1659 N10805 X3.1414 Y1.1597 N10810 X3.129 Y1.1479 N10815 X3.104 Y1.1307 N10820 X3.0914 Y1.1224 N10825 X3.0786 Y1.1146 N10830 X3.0656 Y1.1073 N10835 X3.0524 Y1.1008 N10840 X3.0388 Y1.0952 N10845 X3.0249 Y1.0906 N10850 X3.0107 Y1.0869 N10855 X2.9963 Y1.084 N10860 X2.9815 Y1.0819 N10865 X2.9666 Y1.0802 N10870 X2.9363 Y1.0783 N10875 X2.9058 Y1.0773 N10880 X2.8765 Y1.0782 N10885 X2.8619 Y1.079 N10890 X2.8474 Y1.0803 N10895 X2.8329 Y1.0821 N10900 X2.8185 Y1.0844 N10905 X2.7898 Y1.0899 N10910 X2.7666 Y1.0962 N10915 X2.7552 Y1.0997 N10920 X2.744 Y1.1039 N10925 X2.7331 Y1.1087 N10930 X2.7224 Y1.1141 N10935 X2.7016 Y1.126 N10940 X2.6894 Y1.1361 N10945 X2.6779 Y1.1465 N10950 X2.6726 Y1.1519 N10955 X2.6677 Y1.1576 N10960 X2.6632 Y1.1635 N10965 X2.6592 Y1.1697 N10970 X2.6559 Y1.1762 N10975 X2.6531 Y1.1831 N10980 X2.6508 Y1.1902 N10985 X2.6489 Y1.1975 N10990 X2.6461 Y1.2127 N10995 X2.6439 Y1.2283 N11000 X2.6451 Y1.2451 N11005 X2.6462 Y1.2534 N11010 X2.648 Y1.2616 N11015 X2.6505 Y1.2695 N11020 X2.6537 Y1.2772 N11025 X2.6612 Y1.2923 N11030 X2.6728 Y1.3072 N11035 X2.679 Y1.3142 N11040 X2.6857 Y1.3208 N11045 X2.6928 Y1.3268 N11050 X2.7004 Y1.3324 N11055 X2.7162 Y1.3428 N11060 X2.7381 Y1.3541 N11065 X2.7493 Y1.3594 N11070 X2.7606 Y1.3641 N11075 X2.7722 Y1.3682 N11080 X2.784 Y1.3719 N11085 X2.8078 Y1.3784 N11090 X2.7802 Y1.3889 N11095 X2.7669 Y1.3949 N11100 X2.7541 Y1.4018 N11105 X2.7421 Y1.4098 N11110 X2.7307 Y1.4189 N11115 X2.7198 Y1.4287 N11120 X2.7091 Y1.4389 N11125 X2.7019 Y1.4498 N11130 X2.6951 Y1.4609 N11135 X2.6892 Y1.4722 N11140 X2.6845 Y1.484 N11145 X2.6813 Y1.4963 N11150 X2.6792 Y1.509 N11155 X2.6779 Y1.5219 N11160 X2.677 Y1.535 N11165 X2.6792 Y1.5604 N11170 Z0.1606 N11175 G0 Z0.2 N11180 X2.8246 Y1.3534 N11185 Z0.1606 N11190 G1 Z-0.0394 F13.123 N11195 X2.8134 Y1.3451 F39.37 N11200 X2.8029 Y1.3361 N11205 X2.7928 Y1.3266 N11210 X2.7847 Y1.3172 N11215 X2.7775 Y1.3072 N11220 X2.7716 Y1.2964 N11225 X2.7667 Y1.2851 N11230 X2.7631 Y1.272 N11235 X2.7604 Y1.2587 N11240 X2.7592 Y1.2453 N11245 X2.7587 Y1.2317 N11250 X2.7662 Y1.2023 N11255 X2.7705 Y1.1882 N11260 X2.7754 Y1.1748 N11265 X2.7811 Y1.1624 N11270 X2.7843 Y1.1566 N11275 X2.7878 Y1.1512 N11280 X2.7917 Y1.1461 N11285 X2.7958 Y1.1414 N11290 X2.8004 Y1.1372 N11295 X2.8053 Y1.1333 N11300 X2.8105 Y1.1298 N11305 X2.8161 Y1.1268 N11310 X2.8219 Y1.124 N11315 X2.828 Y1.1216 N11320 X2.8411 Y1.1176 N11325 X2.8549 Y1.1146 N11330 X2.8695 Y1.1124 N11335 X2.8845 Y1.1108 N11340 X2.9155 Y1.1086 N11345 X2.937 Y1.1095 N11350 X2.9476 Y1.1104 N11355 X2.9581 Y1.1118 N11360 X2.9686 Y1.1138 N11365 X2.9789 Y1.1164 N11370 X2.9995 Y1.1226 N11375 X3.0153 Y1.1296 N11380 X3.0229 Y1.1335 N11385 X3.0303 Y1.1379 N11390 X3.0372 Y1.1429 N11395 X3.0437 Y1.1484 N11400 X3.0562 Y1.1603 N11405 X3.0644 Y1.1721 N11410 X3.068 Y1.1783 N11415 X3.071 Y1.1846 N11420 X3.0731 Y1.1913 N11425 X3.0745 Y1.1982 N11430 X3.0762 Y1.2125 N11435 X3.0746 Y1.227 N11440 X3.0732 Y1.2339 N11445 X3.071 Y1.2405 N11450 X3.0678 Y1.2467 N11455 X3.0638 Y1.2525 N11460 X3.0544 Y1.2636 N11465 X3.0426 Y1.273 N11470 X3.0303 Y1.2816 N11475 X3.01 Y1.2916 N11480 X2.9896 Y1.3012 N11485 X2.9482 Y1.3191 N11490 X2.918 Y1.3309 N11495 X2.8939 Y1.3403 N11500 X2.8833 Y1.3443 N11505 X2.8725 Y1.3479 N11510 X2.8506 Y1.3553 N11515 X2.8361 Y1.3612 N11520 X2.8246 Y1.3534 N11525 Z0.1606 N11530 G0 Z0.2 N11535 X2.8838 Y1.4832 N11540 Z0.1606 N11545 G1 Z-0.0394 F13.123 N11550 X2.9043 Y1.4753 F39.37 N11555 X2.9352 Y1.4643 N11560 X2.9606 Y1.4563 N11565 X2.9859 Y1.4476 N11570 X2.9973 Y1.4578 N11575 X3.0027 Y1.4631 N11580 X3.0077 Y1.4688 N11585 X3.0122 Y1.4749 N11590 X3.0163 Y1.4813 N11595 X3.0238 Y1.4946 N11600 X3.0294 Y1.5105 N11605 X3.0317 Y1.5185 N11610 X3.0335 Y1.5266 N11615 X3.0347 Y1.5349 N11620 X3.0355 Y1.5432 N11625 X3.0362 Y1.5601 N11630 X3.0356 Y1.5726 N11635 X3.0345 Y1.585 N11640 X3.0327 Y1.597 N11645 X3.0296 Y1.6087 N11650 X3.0275 Y1.6142 N11655 X3.025 Y1.6197 N11660 X3.0189 Y1.6301 N11665 X3.0118 Y1.6402 N11670 X3.0042 Y1.6502 N11675 X2.9934 Y1.6574 N11680 X2.9824 Y1.6641 N11685 X2.9711 Y1.6699 N11690 X2.9653 Y1.6723 N11695 X2.9593 Y1.6742 N11700 X2.947 Y1.6771 N11705 X2.9343 Y1.6787 N11710 X2.9214 Y1.6796 N11715 X2.9083 Y1.6801 N11720 X2.8889 Y1.6794 N11725 X2.8793 Y1.6787 N11730 X2.8697 Y1.6775 N11735 X2.8602 Y1.6757 N11740 X2.8508 Y1.6735 N11745 X2.8322 Y1.6681 N11750 X2.8184 Y1.6621 N11755 X2.8118 Y1.6587 N11760 X2.8055 Y1.655 N11765 X2.7995 Y1.6506 N11770 X2.7939 Y1.6458 N11775 X2.7832 Y1.6354 N11780 X2.776 Y1.6242 N11785 X2.7729 Y1.6184 N11790 X2.7704 Y1.6124 N11795 X2.7687 Y1.6062 N11800 X2.7676 Y1.5997 N11805 X2.7664 Y1.5865 N11810 X2.7668 Y1.5785 N11815 X2.7679 Y1.5706 N11820 X2.7701 Y1.5629 N11825 X2.7729 Y1.5554 N11830 X2.7764 Y1.5487 N11835 X2.7804 Y1.5423 N11840 X2.7853 Y1.5365 N11845 X2.7906 Y1.5311 N11850 X2.8019 Y1.5222 N11855 X2.8139 Y1.5143 N11860 X2.8436 Y1.5003 N11865 X2.8736 Y1.4871 N11870 X2.8838 Y1.4832 N11875 Z0.1606 N11880 G0 Z0.2 N11885 X2.9044 Y0.423 N11890 Z0.1606 N11895 G1 Z-0.0394 F13.123 N11900 X2.9182 Y0.4217 F39.37 N11905 X2.9318 Y0.4197 N11910 X2.9452 Y0.4168 N11915 X2.9585 Y0.413 N11920 X2.9848 Y0.4043 N11925 X3.0069 Y0.3931 N11930 X3.0174 Y0.3869 N11935 X3.0274 Y0.38 N11940 X3.0367 Y0.3721 N11945 X3.0453 Y0.3635 N11950 X3.0617 Y0.3449 N11955 X3.0742 Y0.325 N11960 X3.0798 Y0.3148 N11965 X3.0846 Y0.3043 N11970 X3.0884 Y0.2934 N11975 X3.0914 Y0.2821 N11980 X3.0961 Y0.2591 N11985 X3.0988 Y0.2186 N11990 X3.1006 Y0.1781 N11995 X3.1011 Y0.1375 N12000 X3.101 Y0.0969 N12005 X3.1004 Y-0.0314 N12010 X3.1002 Y-0.0714 N12015 X3.0994 Y-0.1115 N12020 X3.0974 Y-0.1515 N12025 X3.0945 Y-0.1914 N12030 X3.0899 Y-0.2144 N12035 X3.0869 Y-0.2256 N12040 X3.0832 Y-0.2365 N12045 X3.0785 Y-0.247 N12050 X3.073 Y-0.2573 N12055 X3.0607 Y-0.2772 N12060 X3.0446 Y-0.2956 N12065 X3.036 Y-0.3042 N12070 X3.0268 Y-0.3121 N12075 X3.017 Y-0.3191 N12080 X3.0065 Y-0.3253 N12085 X2.9848 Y-0.3366 N12090 X2.9577 Y-0.3458 N12095 X2.944 Y-0.3496 N12100 X2.9302 Y-0.3526 N12105 X2.9162 Y-0.3546 N12110 X2.9021 Y-0.3558 N12115 X2.8735 Y-0.357 N12120 X2.8458 Y-0.3556 N12125 X2.832 Y-0.3543 N12130 X2.8184 Y-0.3523 N12135 X2.805 Y-0.3493 N12140 X2.7917 Y-0.3456 N12145 X2.7654 Y-0.3369 N12150 X2.7434 Y-0.3257 N12155 X2.7328 Y-0.3195 N12160 X2.7228 Y-0.3125 N12165 X2.7136 Y-0.3047 N12170 X2.7049 Y-0.296 N12175 X2.6885 Y-0.2775 N12180 X2.676 Y-0.2576 N12185 X2.6704 Y-0.2474 N12190 X2.6656 Y-0.2369 N12195 X2.6618 Y-0.2259 N12200 X2.6588 Y-0.2147 N12205 X2.6541 Y-0.1917 N12210 X2.6514 Y-0.1512 N12215 X2.6496 Y-0.1107 N12220 X2.6491 Y-0.0701 N12225 X2.6492 Y-0.0295 N12230 X2.6498 Y0.0988 N12235 X2.65 Y0.1389 N12240 X2.6508 Y0.1789 N12245 X2.6529 Y0.2189 N12250 X2.6558 Y0.2588 N12255 X2.6603 Y0.2818 N12260 X2.6633 Y0.293 N12265 X2.667 Y0.3039 N12270 X2.6717 Y0.3145 N12275 X2.6772 Y0.3247 N12280 X2.6895 Y0.3446 N12285 X2.7056 Y0.3631 N12290 X2.7142 Y0.3717 N12295 X2.7234 Y0.3795 N12300 X2.7332 Y0.3865 N12305 X2.7437 Y0.3928 N12310 X2.7655 Y0.4041 N12315 X2.7925 Y0.4132 N12320 X2.8062 Y0.417 N12325 X2.82 Y0.42 N12330 X2.834 Y0.422 N12335 X2.8482 Y0.4233 N12340 X2.8767 Y0.4245 N12345 X2.9044 Y0.423 N12350 Z0.1606 N12355 G0 Z0.2 N12360 X3.2864 Y-0.0305 N12365 Z0.1606 N12370 G1 Z-0.0394 F13.123 N12375 X3.2882 Y0.407 F39.37 N12380 X3.4263 Y0.4064 N12385 X3.4732 Y0.4062 N12390 X3.4966 Y0.4058 N12395 X3.52 Y0.4048 N12400 X3.5433 Y0.4032 N12405 X3.5666 Y0.4009 N12410 X3.6131 Y0.395 N12415 X3.625 Y0.391 N12420 X3.6367 Y0.3867 N12425 X3.6478 Y0.3816 N12430 X3.6582 Y0.3754 N12435 X3.6676 Y0.3679 N12440 X3.6763 Y0.3592 N12445 X3.6846 Y0.3499 N12450 X3.6926 Y0.3403 N12455 X3.7003 Y0.3237 N12460 X3.7075 Y0.3071 N12465 X3.7135 Y0.2901 N12470 X3.7159 Y0.2815 N12475 X3.7179 Y0.2728 N12480 X3.7206 Y0.2551 N12485 X3.722 Y0.237 N12490 X3.7226 Y0.2188 N12495 X3.7228 Y0.2005 N12500 X3.7225 Y0.1699 N12505 X3.7216 Y0.1548 N12510 X3.7197 Y0.1399 N12515 X3.7165 Y0.1253 N12520 X3.712 Y0.111 N12525 X3.7065 Y0.0969 N12530 X3.7006 Y0.0829 N12535 X3.6914 Y0.075 N12540 X3.682 Y0.0675 N12545 X3.6722 Y0.0611 N12550 X3.667 Y0.0584 N12555 X3.6617 Y0.0561 N12560 X3.6505 Y0.0526 N12565 X3.6389 Y0.0501 N12570 X3.6269 Y0.0484 N12575 X3.6147 Y0.0471 N12580 X3.6361 Y0.0412 N12585 X3.6465 Y0.0377 N12590 X3.6566 Y0.0335 N12595 X3.6661 Y0.0283 N12600 X3.6752 Y0.0222 N12605 X3.6924 Y0.0083 N12610 X3.7002 Y-0.0018 N12615 X3.7072 Y-0.0125 N12620 X3.7101 Y-0.0181 N12625 X3.7126 Y-0.024 N12630 X3.717 Y-0.036 N12635 X3.7197 Y-0.0637 N12640 X3.7213 Y-0.0914 N12645 X3.7216 Y-0.1192 N12650 X3.7214 Y-0.147 N12655 X3.7206 Y-0.3448 N12660 X3.5394 Y-0.344 N12665 X3.5405 Y-0.0948 N12670 X3.5407 Y-0.0757 N12675 X3.5405 Y-0.0663 N12680 X3.5398 Y-0.0569 N12685 X3.5386 Y-0.0476 N12690 X3.5366 Y-0.0384 N12695 X3.5313 Y-0.0202 N12700 X3.5203 Y-0.0125 N12705 X3.5145 Y-0.0095 N12710 X3.5083 Y-0.0074 N12715 X3.5019 Y-0.0062 N12720 X3.4952 Y-0.0057 N12725 X3.4815 Y-0.0056 N12730 X3.4801 Y-0.3438 N12735 X3.2851 Y-0.343 N12740 X3.2864 Y-0.0305 N12745 Z0.1606 N12750 G0 Z0.2 N12755 X3.4827 Y0.2779 N12760 Z0.1606 N12765 G1 Z-0.0394 F13.123 N12770 X3.482 Y0.1111 F39.37 N12775 X3.494 Y0.1113 N12780 X3.5058 Y0.1124 N12785 X3.5115 Y0.1137 N12790 X3.5171 Y0.1155 N12795 X3.5281 Y0.12 N12800 X3.5357 Y0.1334 N12805 X3.5386 Y0.1404 N12810 X3.5404 Y0.1476 N12815 X3.5414 Y0.1551 N12820 X3.5418 Y0.1628 N12825 X3.5416 Y0.1785 N12830 X3.5418 Y0.2197 N12835 X3.5416 Y0.2324 N12840 X3.5411 Y0.2386 N12845 X3.5401 Y0.2446 N12850 X3.5383 Y0.2504 N12855 X3.5357 Y0.2559 N12860 X3.5292 Y0.2666 N12865 X3.5184 Y0.2722 N12870 X3.5128 Y0.2745 N12875 X3.507 Y0.2761 N12880 X3.5011 Y0.2771 N12885 X3.495 Y0.2776 N12890 X3.4827 Y0.2779 N12895 Z0.1606 N12900 G0 Z0.2 N12905 X3.9119 Y0.2794 N12910 Z0.1606 N12915 G1 Z-0.0394 F13.123 N12920 X3.9124 Y0.4044 F39.37 N12925 X4.1074 Y0.4036 N12930 X4.1062 Y0.1123 N12935 X4.1943 Y0.4033 N12940 X4.3772 Y0.4025 N12945 X4.264 Y0.0643 N12950 X4.3848 Y-0.3475 N12955 X4.1833 Y-0.3467 N12960 X4.1056 Y-0.0249 N12965 X4.1043 Y-0.3464 N12970 X3.9093 Y-0.3456 N12975 X3.9119 Y0.2794 N12980 Z0.1606 N12985 G0 Z0.2 N12990 X2.9053 Y0.258 N12995 Z0.1606 N13000 G1 Z-0.0394 F13.123 N13005 X2.9041 Y0.2663 F39.37 N13010 X2.9009 Y0.2828 N13015 X2.8967 Y0.2893 N13020 X2.8943 Y0.292 N13025 X2.8916 Y0.2942 N13030 X2.8884 Y0.2956 N13035 X2.8848 Y0.2966 N13040 X2.8771 Y0.2975 N13045 X2.8702 Y0.2967 N13050 X2.8669 Y0.2959 N13055 X2.8638 Y0.2947 N13060 X2.861 Y0.293 N13065 X2.8585 Y0.2909 N13070 X2.8537 Y0.2858 N13075 X2.8489 Y0.2688 N13080 X2.8471 Y0.2602 N13085 X2.846 Y0.2515 N13090 X2.8451 Y0.2339 N13095 X2.8453 Y0.2161 N13100 X2.8438 Y-0.1341 N13105 X2.8436 Y-0.1544 N13110 X2.8441 Y-0.1746 N13115 X2.8447 Y-0.1847 N13120 X2.8458 Y-0.1947 N13125 X2.8488 Y-0.2147 N13130 X2.8531 Y-0.2216 N13135 X2.8555 Y-0.2244 N13140 X2.8584 Y-0.2267 N13145 X2.8618 Y-0.2282 N13150 X2.8655 Y-0.2292 N13155 X2.8736 Y-0.2301 N13160 X2.8822 Y-0.2289 N13165 X2.8861 Y-0.2278 N13170 X2.8896 Y-0.226 N13175 X2.8925 Y-0.2234 N13180 X2.895 Y-0.2202 N13185 X2.8991 Y-0.2126 N13190 X2.9023 Y-0.1918 N13195 X2.9036 Y-0.1814 N13200 X2.9044 Y-0.1709 N13205 X2.905 Y-0.1499 N13210 Y-0.1288 N13215 X2.9064 Y0.2159 N13220 X2.9066 Y0.2328 N13225 X2.906 Y0.2496 N13230 X2.9053 Y0.258 N13235 Z0.1606 N13240 G0 Z0.2 N13245 X2.487 Y0.2603 N13250 Z0.1606 N13255 G1 Z-0.0394 F13.123 N13260 X2.415 Y-0.3394 F39.37 N13265 X2.1715 Y-0.3384 N13270 X2.1546 Y-0.2404 N13275 X2.1466 Y-0.1913 N13280 X2.1391 Y-0.1422 N13285 X2.1323 Y-0.0929 N13290 X2.126 Y-0.0436 N13295 X2.1141 Y0.0552 N13300 X2.0868 Y-0.1415 N13305 X2.0581 Y-0.3379 N13310 X1.816 Y-0.3369 N13315 X1.7318 Y0.4134 N13320 X1.9213 Y0.4127 N13325 X1.9597 Y-0.1022 N13330 X1.9702 Y0.0268 N13335 X1.9761 Y0.0912 N13340 X1.9828 Y0.1556 N13345 X1.9903 Y0.2198 N13350 X1.9984 Y0.284 N13355 X2.0157 Y0.4123 N13360 X2.2182 Y0.4114 N13365 X2.229 Y0.2878 N13370 X2.2385 Y0.164 N13375 X2.2589 Y-0.1215 N13380 X2.2692 Y0.0121 N13385 X2.275 Y0.0788 N13390 X2.2816 Y0.1454 N13395 X2.2892 Y0.2119 N13400 X2.2975 Y0.2783 N13405 X2.3155 Y0.411 N13410 X2.5049 Y0.4102 N13415 X2.487 Y0.2603 N13420 Z0.1606 N13425 G0 Z0.2 N13430 X2.4976 Y-0.7469 N13435 Z0.1606 N13440 G1 Z-0.0394 F13.123 N13445 X2.5478 Y-0.7471 F39.37 N13450 X2.5447 Y-1.4971 N13455 X2.3738 Y-1.4964 N13460 X2.2737 Y-1.1551 N13465 X2.2723 Y-1.496 N13470 X2.1092 Y-1.4953 N13475 X2.1123 Y-0.7453 N13480 X2.2754 Y-0.746 N13485 X2.3833 Y-1.0842 N13490 X2.3847 Y-0.7465 N13495 X2.4976 Y-0.7469 N13500 Z0.1606 N13505 G0 Z0.2 N13510 X1.9142 Y-0.8822 N13515 Z0.1606 N13520 G1 Z-0.0394 F13.123 N13525 X1.9175 Y-0.8996 F39.37 N13530 X1.9199 Y-0.9172 N13535 X1.9214 Y-0.9348 N13540 X1.9222 Y-0.9526 N13545 X1.9226 Y-0.9882 N13550 X1.9225 Y-1.0206 N13555 X1.7275 Y-1.0198 N13560 X1.7277 Y-0.9517 N13565 X1.7279 Y-0.9315 N13570 X1.7275 Y-0.9112 N13575 X1.7267 Y-0.9012 N13580 X1.7256 Y-0.8911 N13585 X1.7225 Y-0.8711 N13590 X1.718 Y-0.8638 N13595 X1.7154 Y-0.8608 N13600 X1.7123 Y-0.8584 N13605 X1.7087 Y-0.8568 N13610 X1.7048 Y-0.8558 N13615 X1.6962 Y-0.8548 N13620 X1.6885 Y-0.8556 N13625 X1.6849 Y-0.8565 N13630 X1.6816 Y-0.8578 N13635 X1.6787 Y-0.8599 N13640 X1.6761 Y-0.8625 N13645 X1.6716 Y-0.8686 N13650 X1.6678 Y-0.8862 N13655 X1.6664 Y-0.895 N13660 X1.6654 Y-0.9039 N13665 X1.6647 Y-0.9219 N13670 X1.6648 Y-0.9399 N13675 X1.6633 Y-1.2999 N13680 X1.6632 Y-1.3167 N13685 X1.6639 Y-1.3334 N13690 X1.6647 Y-1.3417 N13695 X1.6661 Y-1.3499 N13700 X1.6695 Y-1.3664 N13705 X1.6741 Y-1.3734 N13710 X1.6767 Y-1.3763 N13715 X1.6797 Y-1.3787 N13720 X1.6832 Y-1.3803 N13725 X1.687 Y-1.3813 N13730 X1.6954 Y-1.3824 N13735 X1.7047 Y-1.3812 N13740 X1.709 Y-1.3801 N13745 X1.7129 Y-1.3782 N13750 X1.7163 Y-1.3756 N13755 X1.7192 Y-1.3723 N13760 X1.7244 Y-1.3645 N13765 X1.7285 Y-1.3472 N13770 X1.7302 Y-1.3385 N13775 X1.7313 Y-1.3297 N13780 X1.7323 Y-1.312 N13785 Y-1.2941 N13790 X1.7327 Y-1.2052 N13795 X1.6933 Y-1.205 N13800 X1.6938 Y-1.091 N13805 X1.9222 Y-1.092 N13810 X1.9205 Y-1.4946 N13815 X1.798 Y-1.494 N13820 X1.7801 Y-1.4402 N13825 X1.7699 Y-1.4555 N13830 X1.7644 Y-1.4628 N13835 X1.7584 Y-1.4696 N13840 X1.7518 Y-1.4758 N13845 X1.7447 Y-1.4815 N13850 X1.7296 Y-1.4921 N13855 X1.7125 Y-1.4997 N13860 X1.7038 Y-1.5029 N13865 X1.6949 Y-1.5054 N13870 X1.6859 Y-1.5071 N13875 X1.6766 Y-1.5082 N13880 X1.6579 Y-1.5092 N13885 X1.6339 Y-1.5073 N13890 X1.622 Y-1.5056 N13895 X1.6104 Y-1.5031 N13900 X1.5991 Y-1.4995 N13905 X1.5879 Y-1.4951 N13910 X1.566 Y-1.485 N13915 X1.5472 Y-1.4729 N13920 X1.5382 Y-1.4664 N13925 X1.5298 Y-1.4594 N13930 X1.522 Y-1.4517 N13935 X1.5147 Y-1.4433 N13940 X1.5011 Y-1.4256 N13945 X1.4915 Y-1.4081 N13950 X1.4872 Y-1.3992 N13955 X1.4834 Y-1.3901 N13960 X1.4803 Y-1.3807 N13965 X1.4778 Y-1.3712 N13970 X1.4736 Y-1.3516 N13975 X1.471 Y-1.3227 N13980 X1.4692 Y-1.2937 N13985 X1.4686 Y-1.2647 N13990 X1.4685 Y-1.2356 N13995 X1.4694 Y-1.0128 N14000 X1.4698 Y-0.9735 N14005 X1.4704 Y-0.9539 N14010 X1.4715 Y-0.9344 N14015 X1.4733 Y-0.9149 N14020 X1.4757 Y-0.8954 N14025 X1.4817 Y-0.8567 N14030 X1.487 Y-0.8434 N14035 X1.4927 Y-0.8303 N14040 X1.4993 Y-0.8179 N14045 X1.503 Y-0.812 N14050 X1.5071 Y-0.8064 N14055 X1.5162 Y-0.7959 N14060 X1.5264 Y-0.7861 N14065 X1.5373 Y-0.7768 N14070 X1.5485 Y-0.7678 N14075 X1.565 Y-0.7585 N14080 X1.5817 Y-0.7497 N14085 X1.5987 Y-0.7422 N14090 X1.6074 Y-0.739 N14095 X1.6162 Y-0.7363 N14100 X1.6252 Y-0.7341 N14105 X1.6343 Y-0.7324 N14110 X1.6529 Y-0.7301 N14115 X1.6717 Y-0.7287 N14120 X1.6907 Y-0.7278 N14125 X1.7094 Y-0.7287 N14130 X1.728 Y-0.73 N14135 X1.7463 Y-0.7322 N14140 X1.7643 Y-0.7358 N14145 X1.7732 Y-0.7381 N14150 X1.7819 Y-0.741 N14155 X1.7991 Y-0.7477 N14160 X1.816 Y-0.7554 N14165 X1.8327 Y-0.7636 N14170 X1.8445 Y-0.7719 N14175 X1.856 Y-0.7804 N14180 X1.8668 Y-0.7895 N14185 X1.8767 Y-0.7994 N14190 X1.8812 Y-0.8047 N14195 X1.8853 Y-0.8103 N14200 X1.8929 Y-0.8222 N14205 X1.8996 Y-0.8347 N14210 X1.9061 Y-0.8476 N14215 X1.9142 Y-0.8822 N14220 Z0.1606 N14225 G0 Z0.2 N14230 X1.2835 Y-1.0169 N14235 Z0.1606 N14240 G1 Z-0.0394 F13.123 N14245 X1.2815 Y-1.4919 F39.37 N14250 X1.0865 Y-1.4911 N14255 X1.0896 Y-0.7411 N14260 X1.2846 Y-0.7419 N14265 X1.2835 Y-1.0169 N14270 Z0.1606 N14275 G0 Z0.2 N14280 X0.8901 Y-0.8419 N14285 Z0.1606 N14290 G1 Z-0.0394 F13.123 N14295 X0.8935 Y-0.8576 F39.37 N14300 X0.8959 Y-0.8734 N14305 X0.8973 Y-0.8893 N14310 X0.898 Y-0.9054 N14315 X0.8982 Y-0.9377 N14320 X0.8981 Y-0.9673 N14325 X0.7169 Y-0.9666 N14330 X0.7172 Y-0.911 N14335 X0.7173 Y-0.8983 N14340 X0.7166 Y-0.8857 N14345 X0.7156 Y-0.8795 N14350 X0.7142 Y-0.8734 N14355 X0.7104 Y-0.8614 N14360 X0.7057 Y-0.8566 N14365 X0.7031 Y-0.8545 N14370 X0.7004 Y-0.853 N14375 X0.6973 Y-0.8519 N14380 X0.6941 Y-0.8513 N14385 X0.6873 Y-0.8506 N14390 X0.6793 Y-0.8517 N14395 X0.6755 Y-0.8526 N14400 X0.672 Y-0.8541 N14405 X0.6688 Y-0.8562 N14410 X0.6659 Y-0.8588 N14415 X0.6606 Y-0.8649 N14420 X0.6562 Y-0.8753 N14425 X0.6544 Y-0.8806 N14430 X0.6531 Y-0.886 N14435 X0.6518 Y-0.8971 N14440 X0.6514 Y-0.9084 N14445 X0.6517 Y-0.923 N14450 X0.6522 Y-0.9302 N14455 X0.6531 Y-0.9374 N14460 X0.6545 Y-0.9444 N14465 X0.6565 Y-0.9513 N14470 X0.6613 Y-0.965 N14475 X0.6729 Y-0.979 N14480 X0.6792 Y-0.9854 N14485 X0.6859 Y-0.9913 N14490 X0.6931 Y-0.9967 N14495 X0.7006 Y-1.0017 N14500 X0.7162 Y-1.0111 N14505 X0.7611 Y-1.0381 N14510 X0.7829 Y-1.0524 N14515 X0.804 Y-1.0675 N14520 X0.8143 Y-1.0754 N14525 X0.8242 Y-1.0837 N14530 X0.8434 Y-1.1013 N14535 X0.8617 Y-1.1197 N14540 X0.8798 Y-1.1386 N14545 X0.8883 Y-1.1576 N14550 X0.8962 Y-1.1768 N14555 X0.8997 Y-1.1864 N14560 X0.9028 Y-1.1962 N14565 X0.9055 Y-1.206 N14570 X0.9076 Y-1.216 N14575 X0.9093 Y-1.2261 N14580 X0.9106 Y-1.2363 N14585 X0.9121 Y-1.2569 N14590 X0.9128 Y-1.2777 N14595 X0.9129 Y-1.2986 N14600 X0.9123 Y-1.3289 N14605 X0.9113 Y-1.3439 N14610 X0.9096 Y-1.3588 N14615 X0.9068 Y-1.3735 N14620 X0.903 Y-1.388 N14625 X0.8937 Y-1.4167 N14630 X0.8866 Y-1.4269 N14635 X0.8793 Y-1.4368 N14640 X0.8714 Y-1.446 N14645 X0.8627 Y-1.4544 N14650 X0.8531 Y-1.4617 N14655 X0.8428 Y-1.4683 N14660 X0.8209 Y-1.4801 N14665 X0.7906 Y-1.4913 N14670 X0.7753 Y-1.496 N14675 X0.7598 Y-1.4997 N14680 X0.744 Y-1.5022 N14685 X0.728 Y-1.5037 N14690 X0.6957 Y-1.5052 N14695 X0.661 Y-1.5033 N14700 X0.6439 Y-1.5014 N14705 X0.627 Y-1.4984 N14710 X0.6105 Y-1.494 N14715 X0.5942 Y-1.4884 N14720 X0.5782 Y-1.4819 N14725 X0.5622 Y-1.475 N14730 X0.5506 Y-1.468 N14735 X0.5393 Y-1.4606 N14740 X0.5287 Y-1.4526 N14745 X0.519 Y-1.4438 N14750 X0.5146 Y-1.4389 N14755 X0.5105 Y-1.4338 N14760 X0.5031 Y-1.4228 N14765 X0.4964 Y-1.4112 N14770 X0.49 Y-1.3992 N14775 X0.4819 Y-1.3672 N14780 X0.4786 Y-1.3511 N14785 X0.4762 Y-1.3349 N14790 X0.4747 Y-1.3185 N14795 X0.4739 Y-1.3021 N14800 X0.4734 Y-1.269 N14805 X0.4736 Y-1.2199 N14810 X0.6547 Y-1.2206 N14815 X0.6544 Y-1.3119 N14820 X0.6542 Y-1.3258 N14825 X0.6551 Y-1.3395 N14830 X0.6561 Y-1.3463 N14835 X0.6577 Y-1.353 N14840 X0.6618 Y-1.3661 N14845 X0.6673 Y-1.3717 N14850 X0.6703 Y-1.374 N14855 X0.6736 Y-1.3758 N14860 X0.6771 Y-1.377 N14865 X0.6809 Y-1.3777 N14870 X0.6888 Y-1.3783 N14875 X0.6976 Y-1.3772 N14880 X0.7017 Y-1.3763 N14885 X0.7055 Y-1.3747 N14890 X0.7089 Y-1.3725 N14895 X0.7121 Y-1.3697 N14900 X0.7179 Y-1.3631 N14905 X0.7225 Y-1.3523 N14910 X0.7243 Y-1.3468 N14915 X0.7257 Y-1.3411 N14920 X0.7271 Y-1.3296 N14925 X0.7275 Y-1.3178 N14930 X0.7276 Y-1.295 N14935 X0.7269 Y-1.2838 N14940 X0.7255 Y-1.2728 N14945 X0.723 Y-1.262 N14950 X0.7193 Y-1.2515 N14955 X0.7148 Y-1.2412 N14960 X0.7098 Y-1.2311 N14965 X0.6884 Y-1.2123 N14970 X0.6773 Y-1.2033 N14975 X0.666 Y-1.1946 N14980 X0.6427 Y-1.1783 N14985 X0.6189 Y-1.1626 N14990 X0.5941 Y-1.146 N14995 X0.5697 Y-1.129 N15000 X0.5459 Y-1.111 N15005 X0.5228 Y-1.0922 N15010 X0.5107 Y-1.0787 N15015 X0.5051 Y-1.0716 N15020 X0.5 Y-1.0642 N15025 X0.4955 Y-1.0565 N15030 X0.4914 Y-1.0484 N15035 X0.4839 Y-1.0319 N15040 X0.4768 Y-1.0078 N15045 X0.4739 Y-0.9957 N15050 X0.4717 Y-0.9835 N15055 X0.4703 Y-0.9711 N15060 X0.4694 Y-0.9587 N15065 X0.4688 Y-0.9336 N15070 X0.4695 Y-0.9011 N15075 X0.4706 Y-0.8851 N15080 X0.4727 Y-0.8692 N15085 X0.4759 Y-0.8535 N15090 X0.4803 Y-0.8381 N15095 X0.4856 Y-0.8228 N15100 X0.4913 Y-0.8077 N15105 X0.5056 Y-0.7881 N15110 X0.5133 Y-0.7791 N15115 X0.5219 Y-0.7709 N15120 X0.5313 Y-0.7636 N15125 X0.5414 Y-0.7572 N15130 X0.5627 Y-0.7457 N15135 X0.5915 Y-0.7357 N15140 X0.606 Y-0.7315 N15145 X0.6208 Y-0.7283 N15150 X0.6357 Y-0.7262 N15155 X0.6509 Y-0.7249 N15160 X0.6814 Y-0.7237 N15165 X0.7146 Y-0.7252 N15170 X0.7311 Y-0.7268 N15175 X0.7474 Y-0.7293 N15180 X0.7635 Y-0.7329 N15185 X0.7794 Y-0.7376 N15190 X0.8107 Y-0.7488 N15195 X0.8322 Y-0.7601 N15200 X0.8423 Y-0.7665 N15205 X0.8517 Y-0.7736 N15210 X0.8601 Y-0.7818 N15215 X0.8677 Y-0.791 N15220 X0.8747 Y-0.8008 N15225 X0.8814 Y-0.8109 N15230 X0.8901 Y-0.8419 N15235 Z0.1606 N15240 G0 Z0.2 N15245 X0.3029 Y-0.888 N15250 Z0.1606 N15255 G1 Z-0.0394 F13.123 N15260 X0.1728 Y-0.8874 F39.37 N15265 X0.1722 Y-1.0296 N15270 X0.294 Y-1.0301 N15275 X0.2934 Y-1.1728 N15280 X0.1716 Y-1.1723 N15285 X0.1709 Y-1.3372 N15290 X0.3141 Y-1.3378 N15295 X0.3134 Y-1.4879 N15300 X-0.0247 Y-1.4865 N15305 X-0.0216 Y-0.7365 N15310 X0.3036 Y-0.7379 N15315 X0.3029 Y-0.888 N15320 Z0.1606 N15325 G0 Z0.2 N15330 X-0.2261 Y-0.822 N15335 Z0.1606 N15340 G1 Z-0.0394 F13.123 N15345 X-0.2224 Y-0.8305 F39.37 N15350 X-0.2194 Y-0.8393 N15355 X-0.2146 Y-0.8573 N15360 X-0.2112 Y-0.893 N15365 X-0.21 Y-0.9108 N15370 X-0.2091 Y-0.9287 N15375 X-0.2085 Y-0.9645 N15380 X-0.2087 Y-1.0003 N15385 X-0.2098 Y-1.2629 N15390 X-0.2099 Y-1.2969 N15395 X-0.2103 Y-1.3138 N15400 X-0.2111 Y-1.3308 N15405 X-0.2125 Y-1.3476 N15410 X-0.2146 Y-1.3644 N15415 X-0.2198 Y-1.3979 N15420 X-0.2253 Y-1.413 N15425 X-0.2285 Y-1.4203 N15430 X-0.2323 Y-1.4272 N15435 X-0.2368 Y-1.4336 N15440 X-0.2419 Y-1.4396 N15445 X-0.2532 Y-1.4511 N15450 X-0.2667 Y-1.4601 N15455 X-0.2736 Y-1.4642 N15460 X-0.2808 Y-1.4678 N15465 X-0.2883 Y-1.4708 N15470 X-0.2959 Y-1.4734 N15475 X-0.3116 Y-1.4777 N15480 X-0.3377 Y-1.4814 N15485 X-0.3507 Y-1.4828 N15490 X-0.3638 Y-1.4839 N15495 X-0.3901 Y-1.4848 N15500 X-0.4164 Y-1.4849 N15505 X-0.6623 Y-1.4839 N15510 X-0.6593 Y-0.7339 N15515 X-0.5133 Y-0.7345 N15520 X-0.4653 Y-0.7347 N15525 X-0.4413 Y-0.7353 N15530 X-0.4174 Y-0.7364 N15535 X-0.3935 Y-0.7384 N15540 X-0.3697 Y-0.7411 N15545 X-0.3223 Y-0.7483 N15550 X-0.3012 Y-0.7551 N15555 X-0.291 Y-0.7592 N15560 X-0.2812 Y-0.764 N15565 X-0.272 Y-0.7698 N15570 X-0.2633 Y-0.7765 N15575 X-0.2467 Y-0.7912 N15580 X-0.2355 Y-0.8062 N15585 X-0.2305 Y-0.814 N15590 X-0.2261 Y-0.822 N15595 Z0.1606 N15600 G0 Z0.2 N15605 X-0.4648 Y-0.863 N15610 Z0.1606 N15615 G1 Z-0.0394 F13.123 N15620 X-0.4668 Y-1.3564 F39.37 N15625 X-0.4522 Y-1.3563 N15630 X-0.4452 Y-1.3557 N15635 X-0.4384 Y-1.3543 N15640 X-0.432 Y-1.352 N15645 X-0.426 Y-1.3485 N15650 X-0.4204 Y-1.3443 N15655 X-0.4148 Y-1.3397 N15660 X-0.4091 Y-1.3171 N15665 X-0.407 Y-1.3058 N15670 X-0.4056 Y-1.2943 N15675 X-0.4049 Y-1.2827 N15680 X-0.4046 Y-1.2711 N15685 X-0.4047 Y-1.2478 N15690 X-0.4035 Y-0.9564 N15695 X-0.4034 Y-0.94 N15700 X-0.4037 Y-0.9236 N15705 X-0.4048 Y-0.9073 N15710 X-0.4065 Y-0.8911 N15715 X-0.4086 Y-0.8847 N15720 X-0.4116 Y-0.8789 N15725 X-0.4136 Y-0.8764 N15730 X-0.416 Y-0.8741 N15735 X-0.4212 Y-0.8699 N15740 X-0.4318 Y-0.8664 N15745 X-0.4371 Y-0.865 N15750 X-0.4425 Y-0.864 N15755 X-0.4536 Y-0.8631 N15760 X-0.4648 Y-0.863 N15765 Z0.1606 N15770 G0 Z0.2 N15775 X-0.4667 Y-0.3275 N15780 Z0.1606 N15785 G1 Z-0.0394 F13.123 N15790 X-0.504 Y-0.3273 F39.37 N15795 X-0.5139 Y-0.1925 N15800 X-0.5837 Y-0.1922 N15805 X-0.596 Y-0.327 N15810 X-0.7976 Y-0.3261 N15815 X-0.695 Y0.4235 N15820 X-0.4131 Y0.4223 N15825 X-0.3047 Y-0.3282 N15830 X-0.4667 Y-0.3275 N15835 Z0.1606 N15840 G0 Z0.2 N15845 X-0.241 Y0.4216 N15850 Z0.1606 N15855 G1 Z-0.0394 F13.123 N15860 X0.1852 Y0.4198 F39.37 N15865 X0.1846 Y0.2697 N15870 X0.0688 Y0.2702 N15875 X0.0663 Y-0.3297 N15880 X-0.1287 Y-0.3289 N15885 X-0.1263 Y0.271 N15890 X-0.2416 Y0.2715 N15895 X-0.241 Y0.4216 N15900 Z0.1606 N15905 G0 Z0.2 N15910 X0.3429 Y0.4192 N15915 Z0.1606 N15920 G1 Z-0.0394 F13.123 N15925 X0.5379 Y0.4184 F39.37 N15930 X0.5368 Y0.1502 N15935 X0.5952 Y0.1499 N15940 X0.5963 Y0.4181 N15945 X0.7913 Y0.4173 N15950 X0.7882 Y-0.3327 N15955 X0.5932 Y-0.3319 N15960 X0.5945 Y-0.0169 N15965 X0.5361 Y-0.0166 N15970 X0.5348 Y-0.3316 N15975 X0.3398 Y-0.3308 N15980 X0.3429 Y0.4192 N15985 Z0.1606 N15990 G0 Z0.2 N15995 X0.9828 Y0.4165 N16000 Z0.1606 N16005 G1 Z-0.0394 F13.123 N16010 X1.308 Y0.4152 F39.37 N16015 X1.3074 Y0.2651 N16020 X1.1772 Y0.2656 N16025 X1.1766 Y0.1234 N16030 X1.2985 Y0.1229 N16035 X1.2979 Y-0.0198 N16040 X1.1761 Y-0.0193 N16045 X1.1754 Y-0.1842 N16050 X1.3185 Y-0.1848 N16055 X1.3179 Y-0.3349 N16060 X0.9797 Y-0.3335 N16065 X0.9828 Y0.4165 N16070 Z0.1606 N16075 G0 Z0.2 N16080 X-0.5469 Y0.2556 N16085 Z0.1606 N16090 G1 Z-0.0394 F13.123 N16095 X-0.558 Y0.1771 F39.37 N16100 X-0.5684 Y0.0984 N16105 X-0.5775 Y0.0197 N16110 X-0.5856 Y-0.0592 N16115 X-0.5185 Y-0.0595 N16120 X-0.5266 Y0.0192 N16125 X-0.5341 Y0.0979 N16130 X-0.5407 Y0.1767 N16135 X-0.5469 Y0.2556 N16140 Z0.1606 N16145 G0 Z0.2 N16150 X-0.9368 Y-0.1755 N16155 Z0.1606 N16160 G1 Z-0.0394 F13.123 N16165 X-0.9375 Y-0.3255 F39.37 N16170 X-1.2511 Y-0.3243 N16175 X-1.248 Y0.4257 N16180 X-1.053 Y0.4249 N16185 X-1.0554 Y-0.175 N16190 X-0.9368 Y-0.1755 N16195 Z0.1606 N16200 G0 Z0.2 N16205 X-1.813 Y0.2086 N16210 Z0.1606 N16215 G1 Z-0.0394 F13.123 N16220 X-1.8109 Y0.2008 F39.37 N16225 X-1.8078 Y0.1847 N16230 X-1.8058 Y0.1682 N16235 X-1.8045 Y0.1515 N16240 X-1.8067 Y0.1324 N16245 X-1.8096 Y0.1137 N16250 X-1.8115 Y0.1045 N16255 X-1.8138 Y0.0955 N16260 X-1.8167 Y0.0867 N16265 X-1.8201 Y0.0782 N16270 X-1.8241 Y0.0699 N16275 X-1.8287 Y0.0619 N16280 X-1.8337 Y0.0541 N16285 X-1.8392 Y0.0465 N16290 X-1.851 Y0.0316 N16295 X-1.8634 Y0.0169 N16300 X-1.7978 Y-0.1027 N16305 X-1.6955 Y-0.0375 N16310 X-1.696 Y-0.164 N16315 X-1.7483 Y-0.1971 N16320 X-1.6834 Y-0.3225 N16325 X-1.8567 Y-0.3218 N16330 X-1.879 Y-0.28 N16335 X-1.8982 Y-0.2915 N16340 X-1.9176 Y-0.3024 N16345 X-1.9373 Y-0.3123 N16350 X-1.9474 Y-0.3166 N16355 X-1.9576 Y-0.3206 N16360 X-1.9679 Y-0.3239 N16365 X-1.9785 Y-0.3268 N16370 X-1.9892 Y-0.3291 N16375 X-2. Y-0.3311 N16380 X-2.022 Y-0.3342 N16385 X-2.0442 Y-0.3367 N16390 X-2.0622 Y-0.3352 N16395 X-2.08 Y-0.3331 N16400 X-2.0887 Y-0.3315 N16405 X-2.0972 Y-0.3296 N16410 X-2.1054 Y-0.3271 N16415 X-2.1134 Y-0.3241 N16420 X-2.1211 Y-0.3204 N16425 X-2.1286 Y-0.3161 N16430 X-2.1358 Y-0.3113 N16435 X-2.1427 Y-0.306 N16440 X-2.1563 Y-0.2944 N16445 X-2.1694 Y-0.282 N16450 X-2.1792 Y-0.2671 N16455 X-2.1883 Y-0.252 N16460 X-2.1964 Y-0.2365 N16465 X-2.1998 Y-0.2286 N16470 X-2.2027 Y-0.2205 N16475 X-2.2052 Y-0.2122 N16480 X-2.2071 Y-0.2038 N16485 X-2.2099 Y-0.1866 N16490 X-2.2117 Y-0.169 N16495 X-2.2129 Y-0.1512 N16500 X-2.2115 Y-0.1257 N16505 X-2.21 Y-0.1133 N16510 X-2.2074 Y-0.1011 N16515 X-2.2036 Y-0.0892 N16520 X-2.1986 Y-0.0778 N16525 X-2.1928 Y-0.0665 N16530 X-2.1866 Y-0.0554 N16535 X-2.1697 Y-0.0377 N16540 X-2.1608 Y-0.0295 N16545 X-2.1514 Y-0.0221 N16550 X-2.1412 Y-0.0156 N16555 X-2.1306 Y-0.0097 N16560 X-2.1085 Y0.0008 N16565 X-2.1245 Y0.0154 N16570 X-2.1396 Y0.0304 N16575 X-2.1466 Y0.0382 N16580 X-2.153 Y0.0463 N16585 X-2.1588 Y0.0547 N16590 X-2.1638 Y0.0636 N16595 X-2.168 Y0.0728 N16600 X-2.1714 Y0.0824 N16605 X-2.1742 Y0.0924 N16610 X-2.1764 Y0.1026 N16615 X-2.1796 Y0.1237 N16620 X-2.182 Y0.1452 N16625 X-2.1804 Y0.1631 N16630 X-2.1782 Y0.1807 N16635 X-2.1766 Y0.1893 N16640 X-2.1747 Y0.1978 N16645 X-2.1723 Y0.206 N16650 X-2.1693 Y0.214 N16655 X-2.1657 Y0.2218 N16660 X-2.1615 Y0.2293 N16665 X-2.1568 Y0.2366 N16670 X-2.1517 Y0.2437 N16675 X-2.1405 Y0.2574 N16680 X-2.1287 Y0.2709 N16685 X-2.1123 Y0.282 N16690 X-2.0956 Y0.2924 N16695 X-2.0871 Y0.2971 N16700 X-2.0784 Y0.3013 N16705 X-2.0696 Y0.3051 N16710 X-2.0605 Y0.3082 N16715 X-2.0513 Y0.3108 N16720 X-2.0419 Y0.3128 N16725 X-2.0226 Y0.3155 N16730 X-2.0029 Y0.3171 N16735 X-1.9831 Y0.3181 N16740 X-1.9649 Y0.3169 N16745 X-1.9469 Y0.3151 N16750 X-1.9294 Y0.3122 N16755 X-1.9209 Y0.3101 N16760 X-1.9126 Y0.3075 N16765 X-1.9044 Y0.3044 N16770 X-1.8965 Y0.3006 N16775 X-1.8888 Y0.2964 N16780 X-1.8813 Y0.2917 N16785 X-1.8665 Y0.2816 N16790 X-1.8519 Y0.2707 N16795 X-1.8414 Y0.2577 N16800 X-1.8314 Y0.2444 N16805 X-1.8268 Y0.2376 N16810 X-1.8226 Y0.2306 N16815 X-1.8189 Y0.2235 N16820 X-1.8157 Y0.2162 N16825 X-1.813 Y0.2086 N16830 Z0.1606 N16835 G0 Z0.2 N16840 X-1.9488 Y-0.1849 N16845 Z0.1606 N16850 G1 Z-0.0394 F13.123 N16855 X-2.0028 Y-0.0937 F39.37 N16860 X-2.0166 Y-0.1082 N16865 X-2.0227 Y-0.1158 N16870 X-2.0278 Y-0.124 N16875 X-2.0316 Y-0.1327 N16880 X-2.0343 Y-0.1421 N16885 X-2.0363 Y-0.1518 N16890 X-2.0378 Y-0.1616 N16895 X-2.0374 Y-0.1722 N16900 X-2.0369 Y-0.1774 N16905 X-2.0359 Y-0.1825 N16910 X-2.0343 Y-0.1873 N16915 X-2.0322 Y-0.1921 N16920 X-2.0271 Y-0.2013 N16925 X-2.0203 Y-0.2072 N16930 X-2.0166 Y-0.2097 N16935 X-2.0127 Y-0.2117 N16940 X-2.0086 Y-0.213 N16945 X-2.0042 Y-0.2138 N16950 X-1.9951 Y-0.2146 N16955 X-1.9811 Y-0.2125 N16960 X-1.9742 Y-0.2109 N16965 X-1.9676 Y-0.2087 N16970 X-1.9612 Y-0.2058 N16975 X-1.955 Y-0.2025 N16980 X-1.9428 Y-0.1951 N16985 X-1.9488 Y-0.1849 N16990 Z0.1606 N16995 G0 Z0.2 N17000 X-1.984 Y0.0952 N17005 Z0.1606 N17010 G1 Z-0.0394 F13.123 N17015 X-1.9715 Y0.1131 F39.37 N17020 X-1.9659 Y0.1224 N17025 X-1.9612 Y0.132 N17030 X-1.9577 Y0.142 N17035 X-1.9551 Y0.1524 N17040 X-1.9517 Y0.1739 N17045 X-1.9524 Y0.1818 N17050 X-1.9539 Y0.1894 N17055 X-1.957 Y0.1966 N17060 X-1.9608 Y0.2035 N17065 X-1.9661 Y0.2093 N17070 X-1.9689 Y0.2117 N17075 X-1.972 Y0.2137 N17080 X-1.9754 Y0.2151 N17085 X-1.979 Y0.216 N17090 X-1.9867 Y0.2171 N17095 X-1.9934 Y0.2165 N17100 X-1.9966 Y0.2158 N17105 X-1.9996 Y0.2148 N17110 X-2.0024 Y0.2134 N17115 X-2.005 Y0.2115 N17120 X-2.0099 Y0.207 N17125 X-2.0137 Y0.1997 N17130 X-2.0153 Y0.196 N17135 X-2.0164 Y0.1922 N17140 X-2.0176 Y0.1842 N17145 X-2.0179 Y0.176 N17150 X-2.0166 Y0.1647 N17155 X-2.0149 Y0.1535 N17160 X-2.0125 Y0.1427 N17165 X-2.0088 Y0.1324 N17170 X-2.0039 Y0.1226 N17175 X-1.9978 Y0.1132 N17180 X-1.984 Y0.0952 N17185 Z0.1606 N17190 G0 Z0.2 N17195 X-2.6317 Y-0.1685 N17200 Z0.1606 N17205 G1 Z-0.0394 F13.123 N17210 X-2.6323 Y-0.3186 F39.37 N17215 X-2.9459 Y-0.3173 N17220 X-2.9428 Y0.4327 N17225 X-2.7478 Y0.4319 N17230 X-2.7503 Y-0.168 N17235 X-2.6317 Y-0.1685 N17240 Z0.1606 N17245 G0 Z0.2 N17250 X-3.2219 Y0.4339 N17255 Z0.1606 N17260 G1 Z-0.0394 F13.123 N17265 X-3.2243 Y-0.166 F39.37 N17270 X-3.1058 Y-0.1665 N17275 X-3.1064 Y-0.3166 N17280 X-3.42 Y-0.3153 N17285 X-3.4169 Y0.4347 N17290 X-3.2219 Y0.4339 N17295 Z0.1606 N17300 G0 Z0.2 N17305 X-3.6084 Y0.4355 N17310 Z0.1606 N17315 G1 Z-0.0394 F13.123 N17320 X-3.6115 Y-0.3145 F39.37 N17325 X-3.8065 Y-0.3137 N17330 X-3.8034 Y0.4363 N17335 X-3.6084 Y0.4355 N17340 Z0.1606 N17345 G0 Z0.2 N17350 X-3.9949 Y0.4371 N17355 Z0.1606 N17360 G1 Z-0.0394 F13.123 N17365 X-3.998 Y-0.3129 F39.37 N17370 X-4.1685 Y-0.3122 N17375 X-4.1667 Y0.1941 N17380 X-4.2366 Y-0.3119 N17385 X-4.3575 Y-0.3114 N17390 X-4.427 Y0.1836 N17395 X-4.4293 Y-0.3111 N17400 X-4.5998 Y-0.3104 N17405 X-4.5967 Y0.4396 N17410 X-4.3443 Y0.4385 N17415 X-4.3324 Y0.3589 N17420 X-4.3219 Y0.279 N17425 X-4.2949 Y0.0881 N17430 X-4.2487 Y0.4381 N17435 X-3.9949 Y0.4371 N17440 Z0.1606 N17445 G0 Z0.2 N17450 X-3.4072 Y1.1296 N17455 Z0.1606 N17460 G1 Z-0.0394 F13.123 N17465 X-3.4154 Y1.1388 F39.37 N17470 X-3.4231 Y1.1481 N17475 X-3.43 Y1.1578 N17480 X-3.4358 Y1.1681 N17485 X-3.4381 Y1.1735 N17490 X-3.44 Y1.179 N17495 X-3.4429 Y1.1905 N17500 X-3.4449 Y1.2025 N17505 X-3.4465 Y1.2146 N17510 X-3.445 Y1.2306 N17515 X-3.4435 Y1.2384 N17520 X-3.4413 Y1.2459 N17525 X-3.4381 Y1.253 N17530 X-3.4341 Y1.2598 N17535 X-3.4246 Y1.2728 N17540 X-3.4127 Y1.2827 N17545 X-3.4064 Y1.2869 N17550 X-3.3998 Y1.2903 N17555 X-3.3927 Y1.2927 N17560 X-3.3853 Y1.2942 N17565 X-3.3699 Y1.296 N17570 X-3.3544 Y1.2945 N17575 X-3.3469 Y1.2931 N17580 X-3.3396 Y1.291 N17585 X-3.3327 Y1.2879 N17590 X-3.3261 Y1.2841 N17595 X-3.3135 Y1.275 N17600 X-3.3037 Y1.2632 N17605 X-3.2996 Y1.257 N17610 X-3.2963 Y1.2505 N17615 X-3.294 Y1.2435 N17620 X-3.2925 Y1.2362 N17625 X-3.2908 Y1.221 N17630 X-3.2915 Y1.2107 N17635 X-3.2922 Y1.2057 N17640 X-3.2934 Y1.2008 N17645 X-3.295 Y1.196 N17650 X-3.297 Y1.1914 N17655 X-3.3019 Y1.1823 N17660 X-3.3101 Y1.1734 N17665 X-3.3145 Y1.1692 N17670 X-3.3192 Y1.1655 N17675 X-3.3294 Y1.1592 N17680 X-3.3403 Y1.1537 N17685 X-3.3444 Y1.1514 N17690 X-3.348 Y1.1487 N17695 X-3.3507 Y1.1452 N17700 X-3.3527 Y1.141 N17705 X-3.3484 Y1.1337 N17710 X-3.3458 Y1.1306 N17715 X-3.3427 Y1.1279 N17720 X-3.3392 Y1.1258 N17725 X-3.3353 Y1.1239 N17730 X-3.3272 Y1.1208 N17735 X-3.3122 Y1.1161 N17740 X-3.3046 Y1.1142 N17745 X-3.297 Y1.1126 N17750 X-3.2815 Y1.111 N17755 X-3.2658 Y1.1104 N17760 X-3.2503 Y1.1118 N17765 X-3.2352 Y1.1138 N17770 X-3.2278 Y1.1152 N17775 X-3.2206 Y1.117 N17780 X-3.2136 Y1.1193 N17785 X-3.2069 Y1.1221 N17790 X-3.2005 Y1.1255 N17795 X-3.1943 Y1.1294 N17800 X-3.1884 Y1.1339 N17805 X-3.1827 Y1.1387 N17810 X-3.1717 Y1.1493 N17815 X-3.161 Y1.1605 N17820 X-3.1522 Y1.1781 N17825 X-3.1439 Y1.1958 N17830 X-3.1369 Y1.2139 N17835 X-3.1341 Y1.2231 N17840 X-3.1317 Y1.2324 N17845 X-3.1298 Y1.2419 N17850 X-3.1284 Y1.2515 N17855 X-3.1265 Y1.2709 N17860 X-3.1256 Y1.2905 N17865 X-3.1251 Y1.3103 N17870 Y1.3975 N17875 X-3.1131 N17880 X-3.1261 Y1.3799 N17885 X-3.1331 Y1.3716 N17890 X-3.1407 Y1.3638 N17895 X-3.1488 Y1.3567 N17900 X-3.1576 Y1.3503 N17905 X-3.176 Y1.3383 N17910 X-3.198 Y1.3294 N17915 X-3.2091 Y1.3256 N17920 X-3.2204 Y1.3227 N17925 X-3.232 Y1.3207 N17930 X-3.2437 Y1.3195 N17935 X-3.2674 Y1.3183 N17940 X-3.2886 Y1.3193 N17945 X-3.2991 Y1.3203 N17950 X-3.3096 Y1.3218 N17955 X-3.3199 Y1.3239 N17960 X-3.3301 Y1.3266 N17965 X-3.3504 Y1.3328 N17970 X-3.3689 Y1.3408 N17975 X-3.378 Y1.3451 N17980 X-3.3868 Y1.35 N17985 X-3.3952 Y1.3553 N17990 X-3.4034 Y1.3612 N17995 X-3.4193 Y1.3736 N18000 X-3.433 Y1.3872 N18005 X-3.4395 Y1.3943 N18010 X-3.4455 Y1.4017 N18015 X-3.451 Y1.4095 N18020 X-3.4561 Y1.4176 N18025 X-3.4656 Y1.4344 N18030 X-3.4727 Y1.4523 N18035 X-3.4757 Y1.4613 N18040 X-3.4781 Y1.4705 N18045 X-3.4798 Y1.4798 N18050 X-3.4809 Y1.4893 N18055 X-3.4822 Y1.5085 N18060 X-3.4798 Y1.5364 N18065 X-3.4777 Y1.55 N18070 X-3.4744 Y1.5633 N18075 X-3.4698 Y1.5762 N18080 X-3.464 Y1.5888 N18085 X-3.4506 Y1.6133 N18090 X-3.4321 Y1.6358 N18095 X-3.4222 Y1.6463 N18100 X-3.4117 Y1.656 N18105 X-3.4002 Y1.6646 N18110 X-3.3881 Y1.6724 N18115 X-3.3627 Y1.6866 N18120 X-3.3328 Y1.6981 N18125 X-3.3177 Y1.7029 N18130 X-3.3023 Y1.7068 N18135 X-3.2867 Y1.7095 N18140 X-3.2709 Y1.7113 N18145 X-3.239 Y1.7132 N18150 X-3.2201 Y1.7119 N18155 X-3.2015 Y1.7102 N18160 X-3.183 Y1.7075 N18165 X-3.174 Y1.7057 N18170 X-3.165 Y1.7034 N18175 X-3.1562 Y1.7007 N18180 X-3.1476 Y1.6975 N18185 X-3.1305 Y1.6901 N18190 X-3.1137 Y1.6818 N18195 X-3.0971 Y1.6729 N18200 X-3.0819 Y1.6615 N18205 X-3.0672 Y1.6497 N18210 X-3.0532 Y1.6373 N18215 X-3.0466 Y1.6307 N18220 X-3.0404 Y1.6239 N18225 X-3.0345 Y1.6167 N18230 X-3.0289 Y1.6093 N18235 X-3.0185 Y1.5937 N18240 X-3.0088 Y1.5775 N18245 X-2.9995 Y1.561 N18250 X-2.9918 Y1.5415 N18255 X-2.9845 Y1.5219 N18260 X-2.9781 Y1.5021 N18265 X-2.9731 Y1.4821 N18270 X-2.9696 Y1.4616 N18275 X-2.9674 Y1.4409 N18280 X-2.966 Y1.4201 N18285 X-2.965 Y1.3991 N18290 X-2.9678 Y1.3659 N18295 X-2.9695 Y1.3494 N18300 X-2.9716 Y1.3331 N18305 X-2.9743 Y1.317 N18310 X-2.9776 Y1.3012 N18315 X-2.9818 Y1.2857 N18320 X-2.987 Y1.2706 N18325 X-2.9933 Y1.256 N18330 X-3.0006 Y1.2417 N18335 X-3.0087 Y1.2278 N18340 X-3.0176 Y1.2142 N18345 X-3.0271 Y1.2008 N18350 X-3.037 Y1.1875 N18355 X-3.0576 Y1.1614 N18360 X-3.0782 Y1.1426 N18365 X-3.089 Y1.1338 N18370 X-3.1002 Y1.1257 N18375 X-3.1119 Y1.1184 N18380 X-3.1241 Y1.1118 N18385 X-3.1493 Y1.0997 N18390 X-3.1768 Y1.0903 N18395 X-3.1907 Y1.0862 N18400 X-3.2048 Y1.0829 N18405 X-3.219 Y1.0806 N18410 X-3.2334 Y1.0791 N18415 X-3.2624 Y1.0773 N18420 X-3.2825 Y1.0786 N18425 X-3.3023 Y1.0805 N18430 X-3.3121 Y1.0819 N18435 X-3.3217 Y1.0837 N18440 X-3.3311 Y1.086 N18445 X-3.3403 Y1.0889 N18450 X-3.3492 Y1.0924 N18455 X-3.358 Y1.0965 N18460 X-3.3665 Y1.1012 N18465 X-3.3748 Y1.1063 N18470 X-3.3912 Y1.1176 N18475 X-3.4072 Y1.1296 N18480 Z0.1606 N18485 G0 Z0.2 N18490 X-3.1779 Y1.3739 N18495 Z0.1606 N18500 G1 Z-0.0394 F13.123 N18505 X-3.1692 Y1.3805 F39.37 N18510 X-3.1606 Y1.3875 N18515 X-3.1516 Y1.3984 N18520 X-3.1474 Y1.4041 N18525 X-3.1438 Y1.41 N18530 X-3.1407 Y1.4163 N18535 X-3.138 Y1.4228 N18540 X-3.1334 Y1.4362 N18545 X-3.1291 Y1.4561 N18550 X-3.1274 Y1.4662 N18555 X-3.126 Y1.4762 N18560 X-3.1247 Y1.4965 N18565 X-3.1242 Y1.5169 N18570 X-3.1248 Y1.5407 N18575 X-3.1254 Y1.5526 N18580 X-3.1265 Y1.5644 N18585 X-3.1282 Y1.5762 N18590 X-3.1304 Y1.5879 N18595 X-3.1358 Y1.6111 N18600 X-3.1415 Y1.6262 N18605 X-3.1449 Y1.6335 N18610 X-3.1488 Y1.6403 N18615 X-3.1534 Y1.6468 N18620 X-3.1586 Y1.6528 N18625 X-3.1701 Y1.6641 N18630 X-3.1836 Y1.6716 N18635 X-3.1906 Y1.6748 N18640 X-3.1977 Y1.6773 N18645 X-3.2051 Y1.6789 N18650 X-3.2127 Y1.68 N18655 X-3.2282 Y1.681 N18660 X-3.2397 Y1.6802 N18665 X-3.251 Y1.6789 N18670 X-3.2618 Y1.6766 N18675 X-3.2669 Y1.675 N18680 X-3.2718 Y1.673 N18685 X-3.2765 Y1.6706 N18690 X-3.281 Y1.6676 N18695 X-3.2894 Y1.6607 N18700 X-3.2972 Y1.6526 N18705 X-3.3048 Y1.644 N18710 X-3.3092 Y1.635 N18715 X-3.3131 Y1.6258 N18720 X-3.3161 Y1.6163 N18725 X-3.3185 Y1.6066 N18730 X-3.3206 Y1.5945 N18735 X-3.3218 Y1.5823 N18740 X-3.3232 Y1.5621 N18745 X-3.324 Y1.5419 N18750 X-3.3247 Y1.4934 N18755 X-3.3245 Y1.4767 N18760 X-3.3238 Y1.4599 N18765 X-3.3221 Y1.4433 N18770 X-3.3198 Y1.4267 N18775 X-3.3155 Y1.408 N18780 X-3.3096 Y1.3897 N18785 X-3.3023 Y1.3822 N18790 X-3.2949 Y1.3751 N18795 X-3.287 Y1.3688 N18800 X-3.2829 Y1.3661 N18805 X-3.2786 Y1.3638 N18810 X-3.2693 Y1.3604 N18815 X-3.2595 Y1.3581 N18820 X-3.2493 Y1.3567 N18825 X-3.2389 Y1.3557 N18830 X-3.2279 Y1.3566 N18835 X-3.217 Y1.358 N18840 X-3.2065 Y1.3601 N18845 X-3.1964 Y1.3634 N18850 X-3.1869 Y1.368 N18855 X-3.1779 Y1.3739 N18860 Z0.1606 N18865 G0 Z0.2 N18870 X-2.8606 Y1.6425 N18875 Z0.1606 N18880 G1 Z-0.0394 F13.123 N18885 X-2.8355 Y1.644 F39.37 N18890 X-2.8104 Y1.6459 N18895 X-2.7855 Y1.6487 N18900 X-2.7606 Y1.652 N18905 X-2.7416 Y1.6554 N18910 X-2.7227 Y1.6594 N18915 X-2.7041 Y1.6644 N18920 X-2.6856 Y1.6701 N18925 X-2.6666 Y1.6774 N18930 X-2.6478 Y1.6852 N18935 X-2.6294 Y1.694 N18940 X-2.6112 Y1.7032 N18945 X-2.571 N18950 Y1.2158 N18955 X-2.5672 Y1.1947 N18960 X-2.5649 Y1.1845 N18965 X-2.5622 Y1.1748 N18970 X-2.5589 Y1.1657 N18975 X-2.5549 Y1.1573 N18980 X-2.55 Y1.1499 N18985 X-2.5441 Y1.1435 N18990 X-2.5371 Y1.1382 N18995 X-2.5292 Y1.1339 N19000 X-2.5205 Y1.1305 N19005 X-2.511 Y1.1278 N19010 X-2.5011 Y1.1257 N19015 X-2.4907 Y1.124 N19020 X-2.4693 Y1.1212 N19025 X-2.4034 N19030 Y1.0882 N19035 X-2.8772 N19040 Y1.1212 N19045 X-2.8071 N19050 X-2.7854 Y1.1222 N19055 X-2.7748 Y1.1235 N19060 X-2.7646 Y1.1259 N19065 X-2.7548 Y1.1295 N19070 X-2.7455 Y1.1344 N19075 X-2.7364 Y1.1402 N19080 X-2.7275 Y1.1464 N19085 X-2.7214 Y1.1559 N19090 X-2.7158 Y1.1655 N19095 X-2.711 Y1.1755 N19100 X-2.7075 Y1.1858 N19105 X-2.7053 Y1.1966 N19110 X-2.704 Y1.2076 N19115 X-2.7032 Y1.2303 N19120 Y1.4961 N19125 X-2.7033 Y1.5109 N19130 X-2.7039 Y1.5257 N19135 X-2.7054 Y1.5404 N19140 X-2.7077 Y1.555 N19145 X-2.7105 Y1.5633 N19150 X-2.7142 Y1.5711 N19155 X-2.7192 Y1.578 N19160 X-2.725 Y1.5845 N19165 X-2.7342 Y1.5908 N19170 X-2.7434 Y1.5966 N19175 X-2.753 Y1.6017 N19180 X-2.7629 Y1.6055 N19185 X-2.7734 Y1.608 N19190 X-2.7841 Y1.6094 N19195 X-2.8062 Y1.6107 N19200 X-2.8606 N19205 Y1.6425 N19210 Z0.1606 N19215 G0 Z0.2 N19220 X-2.6321 Y-0.7128 N19225 Z0.1606 N19230 G1 Z-0.0394 F13.123 N19235 X-2.6178 Y-0.7115 F39.37 N19240 X-2.5889 Y-0.7102 N19245 X-2.5703 Y-0.711 N19250 X-2.5518 Y-0.7122 N19255 X-2.5334 Y-0.7143 N19260 X-2.5155 Y-0.7176 N19265 X-2.5066 Y-0.7198 N19270 X-2.4979 Y-0.7225 N19275 X-2.4806 Y-0.7289 N19280 X-2.4637 Y-0.7362 N19285 X-2.4468 Y-0.7441 N19290 X-2.4349 Y-0.7522 N19295 X-2.4234 Y-0.7605 N19300 X-2.4125 Y-0.7695 N19305 X-2.4026 Y-0.7793 N19310 X-2.3982 Y-0.7846 N19315 X-2.394 Y-0.7902 N19320 X-2.3866 Y-0.8021 N19325 X-2.3798 Y-0.8146 N19330 X-2.3735 Y-0.8274 N19335 X-2.3649 Y-0.8656 N19340 X-2.3615 Y-0.8848 N19345 X-2.359 Y-0.9041 N19350 X-2.3575 Y-0.9235 N19355 X-2.3568 Y-0.943 N19360 X-2.3565 Y-0.9822 N19365 X-2.3568 Y-1.0535 N19370 X-2.5518 Y-1.0527 N19375 X-2.5513 Y-0.9223 N19380 X-2.5511 Y-0.9044 N19385 X-2.5517 Y-0.8866 N19390 X-2.5525 Y-0.8777 N19395 X-2.5538 Y-0.8689 N19400 X-2.5573 Y-0.8513 N19405 X-2.5625 Y-0.8448 N19410 X-2.5654 Y-0.842 N19415 X-2.5686 Y-0.84 N19420 X-2.5723 Y-0.8386 N19425 X-2.5763 Y-0.8378 N19430 X-2.5848 Y-0.8371 N19435 X-2.5945 Y-0.838 N19440 X-2.599 Y-0.8389 N19445 X-2.6031 Y-0.8405 N19450 X-2.6067 Y-0.843 N19455 X-2.6099 Y-0.8463 N19460 X-2.6154 Y-0.8541 N19465 X-2.6191 Y-0.8724 N19470 X-2.6204 Y-0.8816 N19475 X-2.6214 Y-0.8909 N19480 X-2.6222 Y-0.9095 N19485 Y-0.9282 N19490 X-2.6236 Y-1.2766 N19495 X-2.6238 Y-1.2946 N19500 X-2.6231 Y-1.3125 N19505 X-2.6222 Y-1.3215 N19510 X-2.6209 Y-1.3303 N19515 X-2.6175 Y-1.348 N19520 X-2.6123 Y-1.3556 N19525 X-2.6093 Y-1.3587 N19530 X-2.6058 Y-1.3612 N19535 X-2.6019 Y-1.3628 N19540 X-2.5976 Y-1.3638 N19545 X-2.5883 Y-1.3648 N19550 X-2.5793 Y-1.3638 N19555 X-2.575 Y-1.3628 N19560 X-2.5712 Y-1.3612 N19565 X-2.5678 Y-1.3587 N19570 X-2.5649 Y-1.3556 N19575 X-2.5598 Y-1.3482 N19580 X-2.5559 Y-1.3288 N19585 X-2.5545 Y-1.319 N19590 X-2.5535 Y-1.3092 N19595 X-2.5527 Y-1.2895 N19600 Y-1.2697 N19605 X-2.5524 Y-1.1754 N19610 X-2.3573 Y-1.1762 N19615 X-2.3574 Y-1.2055 N19620 X-2.3579 Y-1.2472 N19625 X-2.3586 Y-1.268 N19630 X-2.3601 Y-1.2887 N19635 X-2.3626 Y-1.3093 N19640 X-2.366 Y-1.3298 N19645 X-2.3746 Y-1.3706 N19650 X-2.3809 Y-1.3835 N19655 X-2.3877 Y-1.3961 N19660 X-2.3952 Y-1.4081 N19665 X-2.3993 Y-1.4138 N19670 X-2.4038 Y-1.4192 N19675 X-2.4136 Y-1.4293 N19680 X-2.4244 Y-1.4385 N19685 X-2.4359 Y-1.4472 N19690 X-2.4477 Y-1.4556 N19695 X-2.464 Y-1.4639 N19700 X-2.4805 Y-1.4718 N19705 X-2.4972 Y-1.4786 N19710 X-2.5057 Y-1.4814 N19715 X-2.5144 Y-1.4838 N19720 X-2.5231 Y-1.4858 N19725 X-2.532 Y-1.4874 N19730 X-2.55 Y-1.4896 N19735 X-2.5682 Y-1.4909 N19740 X-2.5865 Y-1.4917 N19745 X-2.6049 Y-1.491 N19750 X-2.6233 Y-1.4898 N19755 X-2.6414 Y-1.4879 N19760 X-2.6592 Y-1.4849 N19765 X-2.668 Y-1.4828 N19770 X-2.6767 Y-1.4803 N19775 X-2.6939 Y-1.4743 N19780 X-2.7109 Y-1.4674 N19785 X-2.7277 Y-1.4601 N19790 X-2.7399 Y-1.4519 N19795 X-2.7518 Y-1.4434 N19800 X-2.7629 Y-1.4342 N19805 X-2.768 Y-1.4293 N19810 X-2.7728 Y-1.424 N19815 X-2.7772 Y-1.4185 N19820 X-2.7813 Y-1.4127 N19825 X-2.7885 Y-1.4003 N19830 X-2.795 Y-1.3872 N19835 X-2.801 Y-1.3738 N19840 X-2.8097 Y-1.333 N19845 X-2.8132 Y-1.3125 N19850 X-2.8157 Y-1.2919 N19855 X-2.8173 Y-1.2712 N19860 X-2.8181 Y-1.2504 N19865 X-2.8184 Y-1.2086 N19870 X-2.8175 Y-0.9895 N19875 X-2.8172 Y-0.959 N19880 X-2.8163 Y-0.9286 N19885 X-2.8143 Y-0.8982 N19890 X-2.8114 Y-0.8679 N19895 X-2.8065 Y-0.847 N19900 X-2.8034 Y-0.8368 N19905 X-2.7996 Y-0.8269 N19910 X-2.795 Y-0.8173 N19915 X-2.7897 Y-0.8081 N19920 X-2.778 Y-0.79 N19925 X-2.7615 Y-0.7718 N19930 X-2.7528 Y-0.7633 N19935 X-2.7436 Y-0.7555 N19940 X-2.7336 Y-0.7487 N19945 X-2.7231 Y-0.7425 N19950 X-2.7013 Y-0.7313 N19955 X-2.674 Y-0.7219 N19960 X-2.6602 Y-0.7179 N19965 X-2.6462 Y-0.7148 N19970 X-2.6321 Y-0.7128 N19975 Z0.1606 N19980 G0 Z0.2 N19985 X-2.1658 Y-1.0842 N19990 Z0.1606 N19995 G1 Z-0.0394 F13.123 N20000 X-2.1171 Y-0.7279 F39.37 N20005 X-1.8352 Y-0.729 N20010 X-1.7267 Y-1.4795 N20015 X-1.9261 Y-1.4787 N20020 X-1.936 Y-1.3438 N20025 X-2.0057 Y-1.3435 N20030 X-2.018 Y-1.4783 N20035 X-2.2196 Y-1.4775 N20040 X-2.1658 Y-1.0842 N20045 Z0.1606 N20050 G0 Z0.2 N20055 X-1.9689 Y-0.8957 N20060 Z0.1606 N20065 G1 Z-0.0394 F13.123 N20070 X-1.98 Y-0.9743 F39.37 N20075 X-1.9904 Y-1.0529 N20080 X-1.9995 Y-1.1317 N20085 X-2.0077 Y-1.2106 N20090 X-1.9405 Y-1.2109 N20095 X-1.9486 Y-1.1322 N20100 X-1.9561 Y-1.0534 N20105 X-1.9628 Y-0.9746 N20110 X-1.9689 Y-0.8957 N20115 Z0.1606 N20120 G0 Z0.2 N20125 X-1.5793 Y-1.2176 N20130 Z0.1606 N20135 G1 Z-0.0394 F13.123 N20140 X-1.5773 Y-0.7301 F39.37 N20145 X-1.4314 Y-0.7307 N20150 X-1.3834 Y-0.7309 N20155 X-1.3594 Y-0.7315 N20160 X-1.3355 Y-0.7327 N20165 X-1.3116 Y-0.7346 N20170 X-1.2878 Y-0.7374 N20175 X-1.2404 Y-0.7445 N20180 X-1.2192 Y-0.7514 N20185 X-1.209 Y-0.7554 N20190 X-1.1993 Y-0.7602 N20195 X-1.1901 Y-0.766 N20200 X-1.1814 Y-0.7727 N20205 X-1.1648 Y-0.7874 N20210 X-1.1536 Y-0.8024 N20215 X-1.1485 Y-0.8102 N20220 X-1.1441 Y-0.8182 N20225 X-1.1405 Y-0.8267 N20230 X-1.1375 Y-0.8355 N20235 X-1.1326 Y-0.8535 N20240 X-1.1293 Y-0.8892 N20245 X-1.128 Y-0.907 N20250 X-1.1272 Y-0.9249 N20255 X-1.1266 Y-0.9607 N20260 X-1.1267 Y-0.9965 N20265 X-1.1278 Y-1.2591 N20270 X-1.1279 Y-1.2931 N20275 X-1.1284 Y-1.3101 N20280 X-1.1292 Y-1.327 N20285 X-1.1306 Y-1.3438 N20290 X-1.1326 Y-1.3606 N20295 X-1.1379 Y-1.3941 N20300 X-1.1434 Y-1.4092 N20305 X-1.1466 Y-1.4165 N20310 X-1.1504 Y-1.4234 N20315 X-1.1549 Y-1.4298 N20320 X-1.16 Y-1.4358 N20325 X-1.1712 Y-1.4473 N20330 X-1.1847 Y-1.4563 N20335 X-1.1917 Y-1.4604 N20340 X-1.1989 Y-1.464 N20345 X-1.2063 Y-1.467 N20350 X-1.214 Y-1.4696 N20355 X-1.2297 Y-1.4739 N20360 X-1.2557 Y-1.4776 N20365 X-1.2688 Y-1.479 N20370 X-1.2819 Y-1.4801 N20375 X-1.3081 Y-1.481 N20380 X-1.3344 Y-1.4811 N20385 X-1.5804 Y-1.4801 N20390 X-1.5793 Y-1.2176 N20395 Z0.1606 N20400 G0 Z0.2 N20405 X-1.3828 Y-0.8592 N20410 Z0.1606 N20415 G1 Z-0.0394 F13.123 N20420 X-1.3849 Y-1.3526 F39.37 N20425 X-1.3703 Y-1.3525 N20430 X-1.3632 Y-1.3519 N20435 X-1.3565 Y-1.3505 N20440 X-1.3501 Y-1.3482 N20445 X-1.3441 Y-1.3447 N20450 X-1.3384 Y-1.3405 N20455 X-1.3329 Y-1.3359 N20460 X-1.3272 Y-1.3134 N20465 X-1.3251 Y-1.302 N20470 X-1.3237 Y-1.2905 N20475 X-1.3229 Y-1.279 N20480 X-1.3226 Y-1.2673 N20485 X-1.3228 Y-1.244 N20490 X-1.3216 Y-0.9526 N20495 X-1.3215 Y-0.9362 N20500 X-1.3217 Y-0.9199 N20505 X-1.3228 Y-0.9035 N20510 X-1.3246 Y-0.8873 N20515 X-1.3267 Y-0.8809 N20520 X-1.3296 Y-0.8751 N20525 X-1.3317 Y-0.8726 N20530 X-1.334 Y-0.8703 N20535 X-1.3393 Y-0.8661 N20540 X-1.3498 Y-0.8626 N20545 X-1.3552 Y-0.8612 N20550 X-1.3606 Y-0.8602 N20555 X-1.3716 Y-0.8593 N20560 X-1.3828 Y-0.8592 N20565 Z0.1606 N20570 G0 Z0.2 N20575 X-1.4286 Y-2.0457 N20580 Z0.1606 N20585 G1 Z-0.0394 F13.123 N20590 X-1.4356 Y-2.0663 F39.37 N20595 X-1.4469 N20600 X-1.4674 Y-2.0714 N20605 X-1.4877 Y-2.077 N20610 X-1.5075 Y-2.0837 N20615 X-1.5171 Y-2.0876 N20620 X-1.5267 Y-2.0919 N20625 X-1.5453 Y-2.1015 N20630 X-1.5634 Y-2.1121 N20635 X-1.5991 Y-2.1349 N20640 X-1.6897 Y-2.1906 N20645 X-1.6342 Y-2.3631 N20650 X-1.6301 Y-2.3746 N20655 X-1.6278 Y-2.3802 N20660 X-1.625 Y-2.3855 N20665 X-1.6218 Y-2.3905 N20670 X-1.6181 Y-2.3952 N20675 X-1.6098 Y-2.4041 N20680 X-1.6001 Y-2.4097 N20685 X-1.595 Y-2.4121 N20690 X-1.5899 Y-2.4139 N20695 X-1.5845 Y-2.4151 N20700 X-1.579 Y-2.4158 N20705 X-1.5677 Y-2.4165 N20710 X-1.5547 N20715 X-1.5621 Y-2.4382 N20720 X-1.8088 N20725 X-1.8014 Y-2.4165 N20730 X-1.7836 N20735 X-1.7681 Y-2.4167 N20740 X-1.7607 Y-2.416 N20745 X-1.7537 Y-2.4145 N20750 X-1.7472 Y-2.4119 N20755 X-1.7413 Y-2.4079 N20760 X-1.7358 Y-2.4029 N20765 X-1.7305 Y-2.3975 N20770 X-1.7299 Y-2.3939 N20775 X-1.73 Y-2.3902 N20780 X-1.7324 Y-2.3685 N20785 X-1.7726 Y-2.2425 N20790 X-1.879 Y-2.3115 N20795 X-1.893 Y-2.3527 N20800 X-1.8968 Y-2.3649 N20805 X-1.8981 Y-2.371 N20810 X-1.8988 Y-2.377 N20815 X-1.8986 Y-2.383 N20820 X-1.8975 Y-2.3891 N20825 X-1.8937 Y-2.401 N20830 X-1.8846 Y-2.4086 N20835 X-1.8798 Y-2.4117 N20840 X-1.8746 Y-2.4139 N20845 X-1.8691 Y-2.4153 N20850 X-1.8633 Y-2.4161 N20855 X-1.8512 Y-2.4165 N20860 X-1.8342 N20865 X-1.8416 Y-2.4382 N20870 X-2.0939 N20875 X-2.0865 Y-2.4165 N20880 X-2.0703 N20885 X-2.056 Y-2.4156 N20890 X-2.0489 Y-2.4146 N20895 X-2.0421 Y-2.4131 N20900 X-2.0354 Y-2.4108 N20905 X-2.029 Y-2.4079 N20910 X-2.0164 Y-2.4009 N20915 X-2.0058 Y-2.3906 N20920 X-2.001 Y-2.3852 N20925 X-1.9967 Y-2.3793 N20930 X-1.9931 Y-2.373 N20935 X-1.9899 Y-2.3665 N20940 X-1.9843 Y-2.3527 N20945 X-1.9088 Y-2.1307 N20950 X-1.905 Y-2.1185 N20955 X-1.9037 Y-2.1124 N20960 X-1.903 Y-2.1063 N20965 X-1.9032 Y-2.1002 N20970 X-1.9043 Y-2.0942 N20975 X-1.9081 Y-2.0821 N20980 X-1.9173 Y-2.0744 N20985 X-1.9222 Y-2.0712 N20990 X-1.9275 Y-2.0689 N20995 X-1.9331 Y-2.0675 N21000 X-1.939 Y-2.0668 N21005 X-1.9512 Y-2.0663 N21010 X-1.968 N21015 X-1.961 Y-2.0457 N21020 X-1.7081 N21025 X-1.7151 Y-2.0663 N21030 X-1.7321 N21035 X-1.7463 Y-2.0673 N21040 X-1.7532 Y-2.0683 N21045 X-1.76 Y-2.0699 N21050 X-1.7665 Y-2.0722 N21055 X-1.7728 Y-2.0751 N21060 X-1.7851 Y-2.082 N21065 X-1.7958 Y-2.0924 N21070 X-1.8007 Y-2.0979 N21075 X-1.805 Y-2.1038 N21080 X-1.8087 Y-2.1102 N21085 X-1.8119 Y-2.1168 N21090 X-1.8175 Y-2.1307 N21095 X-1.8721 Y-2.2912 N21100 X-1.652 Y-2.1477 N21105 X-1.6362 Y-2.137 N21110 X-1.6287 Y-2.1311 N21115 X-1.6214 Y-2.1249 N21120 X-1.6176 Y-2.1205 N21125 X-1.6143 Y-2.1159 N21130 X-1.6116 Y-2.1109 N21135 X-1.6094 Y-2.1056 N21140 X-1.6078 Y-2.0978 N21145 X-1.6075 Y-2.094 N21150 X-1.6078 Y-2.0903 N21155 X-1.6089 Y-2.0869 N21160 X-1.6107 Y-2.0836 N21165 X-1.6154 Y-2.0772 N21170 X-1.6246 Y-2.0719 N21175 X-1.6294 Y-2.0698 N21180 X-1.6343 Y-2.0682 N21185 X-1.6395 Y-2.0672 N21190 X-1.6447 Y-2.0667 N21195 X-1.6555 Y-2.0663 N21200 X-1.67 N21205 X-1.663 Y-2.0457 N21210 X-1.4286 N21215 Z0.1606 N21220 G0 Z0.2 N21225 X-2.0839 Y-2.1018 N21230 Z0.1606 N21235 G1 Z-0.0394 F13.123 N21240 X-2.0824 Y-2.1061 F39.37 N21245 X-2.08 Y-2.1153 N21250 X-2.0798 Y-2.1239 N21255 X-2.0802 Y-2.1325 N21260 X-2.0818 Y-2.1409 N21265 X-2.0841 Y-2.1493 N21270 X-2.0903 Y-2.1613 N21275 X-2.0968 Y-2.1729 N21280 X-2.1042 Y-2.1838 N21285 X-2.1083 Y-2.1889 N21290 X-2.1127 Y-2.1936 N21295 X-2.1174 Y-2.198 N21300 X-2.1225 Y-2.2022 N21305 X-2.1333 Y-2.2098 N21310 X-2.1448 Y-2.2167 N21315 X-2.1566 Y-2.2234 N21320 X-2.1694 Y-2.2285 N21325 X-2.1824 Y-2.2331 N21330 X-2.1957 Y-2.2368 N21335 X-2.2091 Y-2.2401 N21340 X-2.2394 Y-2.246 N21345 X-2.2546 Y-2.2481 N21350 X-2.27 Y-2.2498 N21355 X-2.3008 Y-2.2511 N21360 X-2.3317 Y-2.2514 N21365 X-2.3292 Y-2.2441 N21370 X-2.3151 Y-2.2553 N21375 X-2.3002 Y-2.2655 N21380 X-2.2856 Y-2.2739 N21385 X-2.2703 Y-2.281 N21390 X-2.2512 Y-2.2876 N21395 X-2.2316 Y-2.2929 N21400 X-2.2263 Y-2.3097 N21405 X-2.2198 Y-2.3288 N21410 X-2.2151 Y-2.3431 N21415 X-2.2081 Y-2.3633 N21420 X-2.1999 Y-2.3831 N21425 X-2.1941 Y-2.3947 N21430 X-2.1906 Y-2.4002 N21435 X-2.1866 Y-2.4054 N21440 X-2.1763 Y-2.4109 N21445 X-2.171 Y-2.4131 N21450 X-2.1655 Y-2.4147 N21455 X-2.1599 Y-2.4157 N21460 X-2.1541 Y-2.4162 N21465 X-2.1423 Y-2.4165 N21470 X-2.1259 N21475 X-2.1332 Y-2.4382 N21480 X-2.2849 N21485 X-2.3533 Y-2.2514 N21490 X-2.4303 N21495 X-2.4648 Y-2.3527 N21500 X-2.4685 Y-2.3648 N21505 X-2.4699 Y-2.3709 N21510 X-2.4706 Y-2.377 N21515 X-2.4704 Y-2.383 N21520 X-2.4694 Y-2.389 N21525 X-2.4657 Y-2.401 N21530 X-2.4565 Y-2.4087 N21535 X-2.4517 Y-2.4117 N21540 X-2.4464 Y-2.414 N21545 X-2.4409 Y-2.4154 N21550 X-2.435 Y-2.4161 N21555 X-2.4229 Y-2.4165 N21560 X-2.4059 N21565 X-2.4133 Y-2.4382 N21570 X-2.6654 N21575 X-2.658 Y-2.4165 N21580 X-2.6421 N21585 X-2.6278 Y-2.4156 N21590 X-2.6208 Y-2.4147 N21595 X-2.614 Y-2.4132 N21600 X-2.6074 Y-2.4109 N21605 X-2.601 Y-2.408 N21610 X-2.5885 Y-2.4011 N21615 X-2.578 Y-2.3907 N21620 X-2.5732 Y-2.3852 N21625 X-2.5689 Y-2.3794 N21630 X-2.5653 Y-2.3731 N21635 X-2.5621 Y-2.3665 N21640 X-2.5566 Y-2.3527 N21645 X-2.4811 Y-2.1307 N21650 X-2.4773 Y-2.1185 N21655 X-2.4759 Y-2.1125 N21660 X-2.4752 Y-2.1064 N21665 X-2.4754 Y-2.1003 N21670 X-2.4764 Y-2.0943 N21675 X-2.48 Y-2.0823 N21680 X-2.4893 Y-2.0746 N21685 X-2.4942 Y-2.0716 N21690 X-2.4995 Y-2.0694 N21695 X-2.5051 Y-2.068 N21700 X-2.511 Y-2.0673 N21705 X-2.5232 Y-2.0669 N21710 X-2.5391 N21715 X-2.5319 Y-2.0457 N21720 X-2.2307 N21725 X-2.2071 Y-2.0461 N21730 X-2.1836 Y-2.0473 N21735 X-2.1719 Y-2.0486 N21740 X-2.1602 Y-2.0504 N21745 X-2.137 Y-2.0547 N21750 X-2.1247 Y-2.0587 N21755 X-2.1189 Y-2.0612 N21760 X-2.1137 Y-2.0643 N21765 X-2.1091 Y-2.0683 N21770 X-2.1052 Y-2.073 N21775 X-2.0986 Y-2.0839 N21780 X-2.0917 Y-2.0905 N21785 X-2.0887 Y-2.094 N21790 X-2.086 Y-2.0977 N21795 X-2.0839 Y-2.1018 N21800 Z0.1606 N21805 G0 Z0.2 N21810 X-2.3545 Y-2.2303 N21815 Z0.1606 N21820 G1 Z-0.0394 F13.123 N21825 X-2.3202 F39.37 N21830 X-2.304 Y-2.2298 N21835 X-2.2879 Y-2.2284 N21840 X-2.2721 Y-2.2255 N21845 X-2.2564 Y-2.2214 N21850 X-2.2443 Y-2.2165 N21855 X-2.2385 Y-2.2138 N21860 X-2.2329 Y-2.2107 N21865 X-2.2276 Y-2.2071 N21870 X-2.2225 Y-2.2032 N21875 X-2.2127 Y-2.1947 N21880 X-2.2041 Y-2.1841 N21885 X-2.2002 Y-2.1787 N21890 X-2.1966 Y-2.173 N21895 X-2.1934 Y-2.167 N21900 X-2.1906 Y-2.1609 N21905 X-2.1856 Y-2.1482 N21910 X-2.1841 Y-2.1287 N21915 X-2.1838 Y-2.1194 N21920 X-2.1841 Y-2.1105 N21925 X-2.1851 Y-2.1023 N21930 X-2.1871 Y-2.0949 N21935 X-2.1886 Y-2.0915 N21940 X-2.1903 Y-2.0884 N21945 X-2.1924 Y-2.0856 N21950 X-2.1948 Y-2.0831 N21955 X-2.2006 Y-2.0787 N21960 X-2.2074 Y-2.0753 N21965 X-2.2153 Y-2.0727 N21970 X-2.2239 Y-2.0708 N21975 X-2.2331 Y-2.0694 N21980 X-2.2428 Y-2.0683 N21985 X-2.263 Y-2.0669 N21990 X-2.3676 N21995 X-2.4231 Y-2.2303 N22000 X-2.3545 N22005 Z0.1606 N22010 G0 Z0.2 N22015 X-2.6567 Y-2.2073 N22020 Z0.1606 N22025 G1 Z-0.0394 F13.123 N22030 X-2.6582 Y-2.2162 F39.37 N22035 X-2.6602 Y-2.2251 N22040 X-2.6651 Y-2.2428 N22045 X-2.6774 Y-2.2709 N22050 X-2.6843 Y-2.2845 N22055 X-2.6921 Y-2.2976 N22060 X-2.7009 Y-2.31 N22065 X-2.7105 Y-2.3219 N22070 X-2.7311 Y-2.3447 N22075 X-2.7562 Y-2.3667 N22080 X-2.7691 Y-2.3771 N22085 X-2.7826 Y-2.3867 N22090 X-2.7966 Y-2.3955 N22095 X-2.8111 Y-2.4035 N22100 X-2.841 Y-2.4184 N22105 X-2.8717 Y-2.4296 N22110 X-2.8872 Y-2.4345 N22115 X-2.9028 Y-2.4385 N22120 X-2.9188 Y-2.4413 N22125 X-2.9349 Y-2.4432 N22130 X-2.9675 Y-2.4455 N22135 X-2.9895 Y-2.4445 N22140 X-3.0005 Y-2.4435 N22145 X-3.0113 Y-2.442 N22150 X-3.022 Y-2.4398 N22155 X-3.0326 Y-2.4369 N22160 X-3.0536 Y-2.4302 N22165 X-3.0707 Y-2.4219 N22170 X-3.0789 Y-2.4173 N22175 X-3.0868 Y-2.4122 N22180 X-3.0941 Y-2.4065 N22185 X-3.1011 Y-2.4002 N22190 X-3.1144 Y-2.3867 N22195 X-3.1247 Y-2.3716 N22200 X-3.1294 Y-2.3639 N22205 X-3.1333 Y-2.3558 N22210 X-3.1365 Y-2.3474 N22215 X-3.1391 Y-2.3388 N22220 X-3.1432 Y-2.321 N22225 X-3.1444 Y-2.3009 N22230 Y-2.2909 N22235 X-3.1437 Y-2.2811 N22240 X-3.1422 Y-2.2712 N22245 X-3.1401 Y-2.2615 N22250 X-3.1347 Y-2.2421 N22255 X-3.1223 Y-2.214 N22260 X-3.1154 Y-2.2004 N22265 X-3.1076 Y-2.1874 N22270 X-3.0988 Y-2.175 N22275 X-3.0891 Y-2.1632 N22280 X-3.0685 Y-2.1404 N22285 X-3.0433 Y-2.1183 N22290 X-3.0303 Y-2.1078 N22295 X-3.0168 Y-2.098 N22300 X-3.0027 Y-2.0891 N22305 X-2.9882 Y-2.081 N22310 X-2.9583 Y-2.0658 N22315 X-2.9281 Y-2.0544 N22320 X-2.9129 Y-2.0495 N22325 X-2.8975 Y-2.0455 N22330 X-2.8818 Y-2.0426 N22335 X-2.8659 Y-2.0406 N22340 X-2.8339 Y-2.0382 N22345 X-2.8097 Y-2.0393 N22350 X-2.7977 Y-2.0404 N22355 X-2.7859 Y-2.0421 N22360 X-2.7742 Y-2.0447 N22365 X-2.7627 Y-2.048 N22370 X-2.7398 Y-2.0558 N22375 X-2.7218 Y-2.0655 N22380 X-2.7133 Y-2.0708 N22385 X-2.7052 Y-2.0768 N22390 X-2.6978 Y-2.0836 N22395 X-2.691 Y-2.091 N22400 X-2.6782 Y-2.1069 N22405 X-2.67 Y-2.1219 N22410 X-2.6663 Y-2.1296 N22415 X-2.6633 Y-2.1375 N22420 X-2.6608 Y-2.1456 N22425 X-2.659 Y-2.1539 N22430 X-2.6561 Y-2.1708 N22435 X-2.6557 Y-2.1891 N22440 X-2.6559 Y-2.1982 N22445 X-2.6567 Y-2.2073 N22450 Z0.1606 N22455 G0 Z0.2 N22460 X-2.834 Y-2.0594 N22465 Z0.1606 N22470 G1 Z-0.0394 F13.123 N22475 X-2.846 Y-2.0601 F39.37 N22480 X-2.8579 Y-2.0615 N22485 X-2.8696 Y-2.0641 N22490 X-2.8812 Y-2.0675 N22495 X-2.8926 Y-2.0721 N22500 X-2.9036 Y-2.0774 N22505 X-2.9141 Y-2.0837 N22510 X-2.9242 Y-2.0907 N22515 X-2.935 Y-2.0998 N22520 X-2.9455 Y-2.1093 N22525 X-2.9552 Y-2.1195 N22530 X-2.9646 Y-2.1301 N22535 X-2.9741 Y-2.1423 N22540 X-2.983 Y-2.1549 N22545 X-2.9912 Y-2.1679 N22550 X-2.999 Y-2.1813 N22555 X-3.0065 Y-2.1963 N22560 X-3.0136 Y-2.2115 N22565 X-3.0198 Y-2.227 N22570 X-3.0256 Y-2.2428 N22575 X-3.0313 Y-2.2612 N22580 X-3.0362 Y-2.2799 N22585 X-3.0397 Y-2.2988 N22590 X-3.0421 Y-2.318 N22595 X-3.0426 Y-2.3326 N22600 X-3.042 Y-2.3471 N22605 X-3.041 Y-2.3542 N22610 X-3.0395 Y-2.3614 N22615 X-3.0359 Y-2.3755 N22620 X-3.0311 Y-2.3862 N22625 X-3.0283 Y-2.3912 N22630 X-3.0252 Y-2.396 N22635 X-3.0215 Y-2.4004 N22640 X-3.0174 Y-2.4044 N22645 X-3.0084 Y-2.4119 N22650 X-2.9973 Y-2.4174 N22655 X-2.9917 Y-2.4198 N22660 X-2.9858 Y-2.4216 N22665 X-2.9799 Y-2.4228 N22670 X-2.9738 Y-2.4236 N22675 X-2.9614 Y-2.4243 N22680 X-2.9417 Y-2.4224 N22685 X-2.932 Y-2.4209 N22690 X-2.9226 Y-2.4186 N22695 X-2.9134 Y-2.4153 N22700 X-2.9045 Y-2.4114 N22705 X-2.8869 Y-2.4023 N22710 X-2.8682 Y-2.3888 N22715 X-2.8593 Y-2.3816 N22720 X-2.8509 Y-2.3739 N22725 X-2.843 Y-2.3656 N22730 X-2.8355 Y-2.3569 N22735 X-2.8212 Y-2.3388 N22740 X-2.8064 Y-2.3151 N22745 X-2.7994 Y-2.3031 N22750 X-2.793 Y-2.2908 N22755 X-2.7871 Y-2.2782 N22760 X-2.7818 Y-2.2654 N22765 X-2.7719 Y-2.2393 N22770 X-2.7666 Y-2.2221 N22775 X-2.7621 Y-2.2048 N22780 X-2.759 Y-2.1872 N22785 X-2.7567 Y-2.1695 N22790 X-2.7561 Y-2.1552 N22795 X-2.7565 Y-2.141 N22800 X-2.7574 Y-2.134 N22805 X-2.7586 Y-2.127 N22810 X-2.7619 Y-2.1131 N22815 X-2.7663 Y-2.1023 N22820 X-2.7689 Y-2.0971 N22825 X-2.7718 Y-2.0922 N22830 X-2.7753 Y-2.0876 N22835 X-2.7791 Y-2.0832 N22840 X-2.7875 Y-2.0751 N22845 X-2.7924 Y-2.0716 N22850 X-2.7974 Y-2.0685 N22855 X-2.8083 Y-2.0638 N22860 X-2.8146 Y-2.062 N22865 X-2.8209 Y-2.0605 N22870 X-2.8274 Y-2.0597 N22875 X-2.834 Y-2.0594 N22880 Z0.1606 N22885 G0 Z0.2 N22890 X-3.1172 Y-2.0457 N22895 Z0.1606 N22900 G1 Z-0.0394 F13.123 N22905 X-3.1243 Y-2.0665 F39.37 N22910 X-3.1394 Y-2.068 N22915 X-3.1469 Y-2.0694 N22920 X-3.1542 Y-2.0713 N22925 X-3.1665 Y-2.0766 N22930 X-3.1781 Y-2.0832 N22935 X-3.1938 Y-2.0952 N22940 X-3.2012 Y-2.1015 N22945 X-3.2083 Y-2.1083 N22950 X-3.215 Y-2.1154 N22955 X-3.2214 Y-2.1229 N22960 X-3.2335 Y-2.1385 N22965 X-3.4595 Y-2.4466 N22970 X-3.4776 N22975 X-3.4815 Y-2.1627 N22980 X-3.6874 Y-2.4466 N22985 X-3.706 N22990 X-3.7136 Y-2.141 N22995 X-3.7141 Y-2.1262 N23000 X-3.7146 Y-2.1189 N23005 X-3.7157 Y-2.1116 N23010 X-3.7173 Y-2.1045 N23015 X-3.7195 Y-2.0976 N23020 X-3.725 Y-2.0839 N23025 X-3.732 Y-2.0764 N23030 X-3.7358 Y-2.0732 N23035 X-3.7399 Y-2.0707 N23040 X-3.7445 Y-2.0691 N23045 X-3.7493 Y-2.068 N23050 X-3.7595 Y-2.0669 N23055 X-3.7747 N23060 X-3.7675 Y-2.0457 N23065 X-3.558 N23070 X-3.5643 Y-2.0668 N23075 X-3.5744 Y-2.067 N23080 X-3.5844 Y-2.0677 N23085 X-3.5942 Y-2.0696 N23090 X-3.6039 Y-2.0723 N23095 X-3.6086 Y-2.0751 N23100 X-3.6127 Y-2.0784 N23105 X-3.6158 Y-2.0827 N23110 X-3.6183 Y-2.0876 N23115 X-3.6214 Y-2.0996 N23120 X-3.6225 Y-2.1119 N23125 X-3.6217 Y-2.3327 N23130 X-3.4859 Y-2.1445 N23135 X-3.4866 Y-2.1255 N23140 X-3.489 Y-2.1067 N23145 X-3.4906 Y-2.1008 N23150 X-3.4925 Y-2.0952 N23155 X-3.4952 Y-2.0899 N23160 X-3.4983 Y-2.0847 N23165 X-3.5012 Y-2.0804 N23170 X-3.5045 Y-2.0765 N23175 X-3.5085 Y-2.0733 N23180 X-3.5129 Y-2.0706 N23185 X-3.5196 Y-2.0687 N23190 X-3.5265 Y-2.0675 N23195 X-3.5335 Y-2.067 N23200 X-3.5405 Y-2.0669 N23205 X-3.5333 Y-2.0457 N23210 X-3.3151 N23215 X-3.3223 Y-2.0669 N23220 X-3.3382 N23225 X-3.3477 Y-2.0672 N23230 X-3.357 Y-2.0683 N23235 X-3.3661 Y-2.0707 N23240 X-3.375 Y-2.074 N23245 X-3.381 Y-2.0777 N23250 X-3.3862 Y-2.0821 N23255 X-3.3884 Y-2.0847 N23260 X-3.3902 Y-2.0876 N23265 X-3.3934 Y-2.0938 N23270 X-3.3958 Y-2.1037 N23275 X-3.3963 Y-2.1138 N23280 X-3.3942 Y-2.3327 N23285 X-3.2511 Y-2.1316 N23290 X-3.2423 Y-2.1178 N23295 X-3.2386 Y-2.1104 N23300 X-3.2354 Y-2.1029 N23305 X-3.2337 Y-2.0956 N23310 X-3.2333 Y-2.0921 N23315 X-3.2335 Y-2.0887 N23320 X-3.2345 Y-2.0855 N23325 X-3.2361 Y-2.0825 N23330 X-3.2406 Y-2.0766 N23335 X-3.2519 Y-2.0717 N23340 X-3.2576 Y-2.0698 N23345 X-3.2635 Y-2.0684 N23350 X-3.2757 Y-2.0671 N23355 X-3.288 Y-2.0668 N23360 X-3.2817 Y-2.0457 N23365 X-3.1172 N23370 Z0.1606 N23375 G0 Z0.2 N23380 X-3.9978 N23385 Z0.1606 N23390 G1 Z-0.0394 F13.123 N23395 X-4.0518 Y-2.2044 F39.37 N23400 X-4.0701 N23405 X-4.069 Y-2.1739 N23410 X-4.0693 Y-2.1587 N23415 X-4.0702 Y-2.1434 N23420 X-4.0718 Y-2.1341 N23425 X-4.074 Y-2.1249 N23430 X-4.0772 Y-2.116 N23435 X-4.0809 Y-2.1072 N23440 X-4.0853 Y-2.0995 N23445 X-4.0904 Y-2.0923 N23450 X-4.0967 Y-2.0862 N23455 X-4.1038 Y-2.0808 N23460 X-4.1226 Y-2.0745 N23465 X-4.1321 Y-2.0718 N23470 X-4.1417 Y-2.0698 N23475 X-4.1515 Y-2.0684 N23480 X-4.1613 Y-2.0676 N23485 X-4.1811 Y-2.0669 N23490 X-4.2504 N23495 X-4.3082 Y-2.237 N23500 X-4.2939 N23505 X-4.2826 Y-2.2354 N23510 X-4.2716 Y-2.2335 N23515 X-4.2609 Y-2.2308 N23520 X-4.2507 Y-2.2268 N23525 X-4.2411 Y-2.2215 N23530 X-4.232 Y-2.2152 N23535 X-4.2146 Y-2.2007 N23540 X-4.2049 Y-2.1902 N23545 X-4.1957 Y-2.1793 N23550 X-4.1876 Y-2.1676 N23555 X-4.18 Y-2.1555 N23560 X-4.1695 Y-2.136 N23565 X-4.16 Y-2.1161 N23570 X-4.1396 N23575 X-4.2285 Y-2.3774 N23580 X-4.2487 N23585 X-4.2454 Y-2.3565 N23590 X-4.2428 Y-2.3353 N23595 X-4.2421 Y-2.3212 N23600 X-4.243 Y-2.3072 N23605 X-4.2456 Y-2.296 N23610 X-4.2496 Y-2.2853 N23615 X-4.2548 Y-2.2786 N23620 X-4.2603 Y-2.2724 N23625 X-4.2662 Y-2.2671 N23630 X-4.2694 Y-2.2649 N23635 X-4.2729 Y-2.263 N23640 X-4.2803 Y-2.2604 N23645 X-4.2883 Y-2.2589 N23650 X-4.2967 Y-2.258 N23655 X-4.3052 Y-2.2576 N23660 X-4.3152 N23665 X-4.3695 Y-2.4171 N23670 X-4.3126 N23675 X-4.2873 Y-2.4162 N23680 X-4.2747 Y-2.4149 N23685 X-4.2622 Y-2.4132 N23690 X-4.2513 Y-2.411 N23695 X-4.2405 Y-2.4085 N23700 X-4.2299 Y-2.4051 N23705 X-4.2194 Y-2.4014 N23710 X-4.2093 Y-2.3968 N23715 X-4.1994 Y-2.3919 N23720 X-4.1898 Y-2.3864 N23725 X-4.1804 Y-2.3805 N23730 X-4.1642 Y-2.3686 N23735 X-4.1564 Y-2.3623 N23740 X-4.1489 Y-2.3557 N23745 X-4.1417 Y-2.3487 N23750 X-4.1349 Y-2.3413 N23755 X-4.1219 Y-2.326 N23760 X-4.1024 Y-2.2986 N23765 X-4.0843 Y-2.2702 N23770 X-4.0641 N23775 X-4.1212 Y-2.4382 N23780 X-4.5474 N23785 X-4.541 Y-2.4171 N23790 X-4.5251 N23795 X-4.5102 Y-2.4147 N23800 X-4.4958 Y-2.4116 N23805 X-4.489 Y-2.4096 N23810 X-4.4825 Y-2.4071 N23815 X-4.4765 Y-2.404 N23820 X-4.4709 Y-2.4003 N23825 X-4.4658 Y-2.3959 N23830 X-4.4612 Y-2.3909 N23835 X-4.457 Y-2.3853 N23840 X-4.4531 Y-2.3793 N23845 X-4.446 Y-2.3664 N23850 X-4.4394 Y-2.3527 N23855 X-4.3639 Y-2.1307 N23860 X-4.3601 Y-2.1185 N23865 X-4.3587 Y-2.1125 N23870 X-4.358 Y-2.1064 N23875 X-4.3581 Y-2.1003 N23880 X-4.3592 Y-2.0943 N23885 X-4.3628 Y-2.0823 N23890 X-4.3721 Y-2.0746 N23895 X-4.377 Y-2.0716 N23900 X-4.3823 Y-2.0694 N23905 X-4.3879 Y-2.068 N23910 X-4.3938 Y-2.0673 N23915 X-4.406 Y-2.0669 N23920 X-4.4219 N23925 X-4.4147 Y-2.0457 N23930 X-3.9978 N23935 Z0.1606 N23940 G0 Z0.2 N23945 X-4.4405 N23950 Z0.1606 N23955 G1 Z-0.0394 F13.123 N23960 X-4.4477 Y-2.0669 F39.37 N23965 X-4.4574 N23970 X-4.4756 Y-2.0688 N23975 X-4.4844 Y-2.0704 N23980 X-4.493 Y-2.0729 N23985 X-4.5011 Y-2.0765 N23990 X-4.5089 Y-2.0809 N23995 X-4.524 Y-2.0913 N24000 X-4.5385 Y-2.1073 N24005 X-4.5452 Y-2.1156 N24010 X-4.5511 Y-2.1245 N24015 X-4.5562 Y-2.1338 N24020 X-4.5607 Y-2.1436 N24025 X-4.5686 Y-2.1637 N24030 X-4.6633 Y-2.4421 N24035 X-4.6805 N24040 X-4.8864 Y-2.1037 N24045 X-4.9616 Y-2.3248 N24050 X-4.9656 Y-2.3372 N24055 X-4.9688 Y-2.3497 N24060 X-4.9707 Y-2.3624 N24065 X-4.9715 Y-2.3754 N24070 X-4.9698 Y-2.3842 N24075 X-4.9687 Y-2.3884 N24080 X-4.967 Y-2.3924 N24085 X-4.9647 Y-2.3961 N24090 X-4.962 Y-2.3996 N24095 X-4.9559 Y-2.4061 N24100 X-4.9492 Y-2.4094 N24105 X-4.9422 Y-2.4119 N24110 X-4.935 Y-2.4134 N24115 X-4.9276 Y-2.4145 N24120 X-4.9097 Y-2.4164 N24125 X-4.8917 Y-2.4173 N24130 X-4.8988 Y-2.4382 N24135 X-5.1092 N24140 X-5.1021 Y-2.4174 N24145 X-5.0878 Y-2.4163 N24150 X-5.0735 Y-2.4145 N24155 X-5.0596 Y-2.4112 N24160 X-5.0459 Y-2.407 N24165 X-5.0361 Y-2.4022 N24170 X-5.0269 Y-2.3966 N24175 X-5.0186 Y-2.3896 N24180 X-5.0109 Y-2.3818 N24185 X-5.0039 Y-2.3721 N24190 X-4.9976 Y-2.3619 N24195 X-4.9925 Y-2.3511 N24200 X-4.9881 Y-2.3398 N24205 X-4.9148 Y-2.1241 N24210 X-4.9126 Y-2.1165 N24215 X-4.9112 Y-2.1089 N24220 X-4.9113 Y-2.1011 N24225 X-4.9123 Y-2.0933 N24230 X-4.9152 Y-2.0872 N24235 X-4.9188 Y-2.0818 N24240 X-4.9237 Y-2.0775 N24245 X-4.9294 Y-2.0739 N24250 X-4.9381 Y-2.0706 N24255 X-4.947 Y-2.0683 N24260 X-4.9562 Y-2.0672 N24265 X-4.9656 Y-2.0669 N24270 X-4.9761 N24275 X-4.9689 Y-2.0457 N24280 X-4.8077 N24285 X-4.6439 Y-2.3205 N24290 X-4.5899 Y-2.1616 N24295 X-4.5862 Y-2.1494 N24300 X-4.5835 Y-2.137 N24305 X-4.5828 Y-2.1307 N24310 X-4.5825 Y-2.1244 N24315 X-4.5826 Y-2.1116 N24320 X-4.5848 Y-2.102 N24325 X-4.5862 Y-2.0974 N24330 X-4.5882 Y-2.0931 N24335 X-4.5908 Y-2.0891 N24340 X-4.5939 Y-2.0853 N24345 X-4.6009 Y-2.0784 N24350 X-4.608 Y-2.0738 N24355 X-4.616 Y-2.0708 N24360 X-4.6318 Y-2.068 N24365 X-4.6477 Y-2.0665 N24370 X-4.6407 Y-2.0457 N24375 X-4.4405 N24380 Z0.1606 N24385 G0 Z0.2 N24390 X-5.0111 N24395 Z0.1606 N24400 G1 Z-0.0394 F13.123 N24405 X-5.0183 Y-2.0669 F39.37 N24410 X-5.0348 N24415 X-5.0489 Y-2.0678 N24420 X-5.0559 Y-2.0687 N24425 X-5.0626 Y-2.0702 N24430 X-5.0692 Y-2.0724 N24435 X-5.0755 Y-2.0753 N24440 X-5.0879 Y-2.0822 N24445 X-5.0984 Y-2.0926 N24450 X-5.1032 Y-2.0981 N24455 X-5.1074 Y-2.104 N24460 X-5.111 Y-2.1103 N24465 X-5.1142 Y-2.1169 N24470 X-5.1197 Y-2.1307 N24475 X-5.1952 Y-2.3527 N24480 X-5.199 Y-2.3649 N24485 X-5.2004 Y-2.371 N24490 X-5.2011 Y-2.377 N24495 X-5.2009 Y-2.3831 N24500 X-5.1999 Y-2.3891 N24505 X-5.1963 Y-2.4011 N24510 X-5.1872 Y-2.4087 N24515 X-5.1823 Y-2.4118 N24520 X-5.1771 Y-2.414 N24525 X-5.1715 Y-2.4154 N24530 X-5.1657 Y-2.4161 N24535 X-5.1537 Y-2.4165 N24540 X-5.1372 N24545 X-5.1446 Y-2.4382 N24550 X-5.3961 N24555 X-5.3887 Y-2.4165 N24560 X-5.3725 N24565 X-5.3582 Y-2.4156 N24570 X-5.3512 Y-2.4147 N24575 X-5.3444 Y-2.4132 N24580 X-5.3378 Y-2.4109 N24585 X-5.3314 Y-2.408 N24590 X-5.3189 Y-2.4011 N24595 X-5.3084 Y-2.3907 N24600 X-5.3036 Y-2.3852 N24605 X-5.2993 Y-2.3794 N24610 X-5.2957 Y-2.3731 N24615 X-5.2926 Y-2.3665 N24620 X-5.287 Y-2.3527 N24625 X-5.2772 Y-2.3238 N24630 X-5.2688 Y-2.2992 N24635 X-5.2569 Y-2.264 N24640 X-5.2089 Y-2.1229 N24645 X-5.2065 Y-2.1096 N24650 X-5.2059 Y-2.1028 N24655 Y-2.096 N24660 X-5.2065 Y-2.0918 N24665 X-5.2077 Y-2.0877 N24670 X-5.2097 Y-2.084 N24675 X-5.2122 Y-2.0805 N24680 X-5.2213 Y-2.0738 N24685 X-5.2261 Y-2.0711 N24690 X-5.2312 Y-2.0691 N24695 X-5.2366 Y-2.0679 N24700 X-5.2421 Y-2.0673 N24705 X-5.2536 Y-2.0669 N24710 X-5.2698 N24715 X-5.2626 Y-2.0457 N24720 X-5.0111 N24725 Z0.1606 N24730 G0 Z0.2 N24735 X-5.4334 Y-2.4165 N24740 Z0.1606 N24745 G1 Z-0.0394 F13.123 N24750 X-5.4407 Y-2.4382 F39.37 N24755 X-5.6904 N24760 X-5.6831 Y-2.4165 N24765 X-5.6696 N24770 X-5.6553 Y-2.4156 N24775 X-5.6483 Y-2.4147 N24780 X-5.6415 Y-2.4132 N24785 X-5.6348 Y-2.4109 N24790 X-5.6284 Y-2.408 N24795 X-5.6159 Y-2.401 N24800 X-5.6054 Y-2.3907 N24805 X-5.6006 Y-2.3852 N24810 X-5.5963 Y-2.3793 N24815 X-5.5927 Y-2.3731 N24820 X-5.5896 Y-2.3664 N24825 X-5.5841 Y-2.3527 N24830 X-5.5491 Y-2.2498 N24835 X-5.7431 N24840 X-5.7781 Y-2.3527 N24845 X-5.7819 Y-2.3649 N24850 X-5.7832 Y-2.3709 N24855 X-5.7839 Y-2.377 N24860 X-5.7837 Y-2.383 N24865 X-5.7826 Y-2.389 N24870 X-5.7788 Y-2.401 N24875 X-5.7696 Y-2.4086 N24880 X-5.7648 Y-2.4117 N24885 X-5.7596 Y-2.4139 N24890 X-5.7541 Y-2.4153 N24895 X-5.7483 Y-2.4161 N24900 X-5.7362 Y-2.4165 N24905 X-5.7219 N24910 X-5.7293 Y-2.4382 N24915 X-5.9806 N24920 X-5.9732 Y-2.4165 N24925 X-5.9554 N24930 X-5.9411 Y-2.4156 N24935 X-5.9341 Y-2.4147 N24940 X-5.9273 Y-2.4132 N24945 X-5.9207 Y-2.4109 N24950 X-5.9143 Y-2.408 N24955 X-5.9018 Y-2.4011 N24960 X-5.8913 Y-2.3907 N24965 X-5.8865 Y-2.3852 N24970 X-5.8822 Y-2.3793 N24975 X-5.8786 Y-2.373 N24980 X-5.8754 Y-2.3664 N24985 X-5.8699 Y-2.3527 N24990 X-5.8575 Y-2.3161 N24995 X-5.8387 Y-2.2609 N25000 X-5.8112 Y-2.18 N25005 X-5.7913 Y-2.1216 N25010 X-5.7892 Y-2.1087 N25015 X-5.7888 Y-2.0957 N25020 X-5.7895 Y-2.0915 N25025 X-5.7906 Y-2.0875 N25030 X-5.7926 Y-2.0839 N25035 X-5.7951 Y-2.0805 N25040 X-5.8043 Y-2.0738 N25045 X-5.809 Y-2.0711 N25050 X-5.8141 Y-2.0691 N25055 X-5.8194 Y-2.0679 N25060 X-5.825 Y-2.0673 N25065 X-5.8365 Y-2.0669 N25070 X-5.8551 N25075 X-5.848 Y-2.0457 N25080 X-5.5958 N25085 X-5.603 Y-2.0669 N25090 X-5.6173 N25095 X-5.6315 Y-2.0678 N25100 X-5.6385 Y-2.0687 N25105 X-5.6453 Y-2.0703 N25110 X-5.6519 Y-2.0725 N25115 X-5.6582 Y-2.0754 N25120 X-5.6707 Y-2.0823 N25125 X-5.6812 Y-2.0927 N25130 X-5.686 Y-2.0982 N25135 X-5.6902 Y-2.104 N25140 X-5.6939 Y-2.1103 N25145 X-5.697 Y-2.1169 N25150 X-5.7026 Y-2.1307 N25155 X-5.7355 Y-2.2275 N25160 X-5.5415 N25165 X-5.5085 Y-2.1307 N25170 X-5.5047 Y-2.1185 N25175 X-5.5033 Y-2.1124 N25180 X-5.5026 Y-2.1064 N25185 X-5.5028 Y-2.1003 N25190 X-5.5038 Y-2.0943 N25195 X-5.5074 Y-2.0823 N25200 X-5.5167 Y-2.0746 N25205 X-5.5217 Y-2.0716 N25210 X-5.5269 Y-2.0694 N25215 X-5.5326 Y-2.068 N25220 X-5.5385 Y-2.0673 N25225 X-5.5507 Y-2.0669 N25230 X-5.5641 N25235 X-5.5569 Y-2.0457 N25240 X-5.3073 N25245 X-5.3144 Y-2.0669 N25250 X-5.3315 N25255 X-5.3457 Y-2.0678 N25260 X-5.3526 Y-2.0688 N25265 X-5.3594 Y-2.0703 N25270 X-5.3659 Y-2.0725 N25275 X-5.3723 Y-2.0754 N25280 X-5.3847 Y-2.0823 N25285 X-5.3953 Y-2.0927 N25290 X-5.4001 Y-2.0982 N25295 X-5.4043 Y-2.104 N25300 X-5.408 Y-2.1103 N25305 X-5.4111 Y-2.1169 N25310 X-5.4167 Y-2.1307 N25315 X-5.4922 Y-2.3527 N25320 X-5.496 Y-2.3649 N25325 X-5.4973 Y-2.371 N25330 X-5.498 Y-2.377 N25335 X-5.4978 Y-2.383 N25340 X-5.4967 Y-2.3891 N25345 X-5.4929 Y-2.401 N25350 X-5.4838 Y-2.4086 N25355 X-5.479 Y-2.4117 N25360 X-5.4738 Y-2.4139 N25365 X-5.4682 Y-2.4153 N25370 X-5.4624 Y-2.4161 N25375 X-5.4504 Y-2.4165 N25380 X-5.4334 N25385 Z0.1606 N25390 G0 Z0.2 N25395 X-6.0276 Y-2.3586 N25400 Z0.1606 N25405 G1 Z-0.0394 F13.123 N25410 X-6.0446 Y-2.3746 F39.37 N25415 X-6.0645 Y-2.3895 N25420 X-6.0847 Y-2.4037 N25425 X-6.095 Y-2.4103 N25430 X-6.1055 Y-2.4164 N25435 X-6.1162 Y-2.422 N25440 X-6.1272 Y-2.4269 N25445 X-6.1385 Y-2.431 N25450 X-6.15 Y-2.4345 N25455 X-6.1617 Y-2.4373 N25460 X-6.1737 Y-2.4397 N25465 X-6.1981 Y-2.4433 N25470 X-6.2228 Y-2.446 N25475 X-6.2498 Y-2.4442 N25480 X-6.263 Y-2.4425 N25485 X-6.276 Y-2.4397 N25490 X-6.2886 Y-2.4357 N25495 X-6.3009 Y-2.4305 N25500 X-6.325 Y-2.4183 N25505 X-6.3438 Y-2.403 N25510 X-6.3524 Y-2.3948 N25515 X-6.3601 Y-2.3859 N25520 X-6.3666 Y-2.3761 N25525 X-6.3722 Y-2.3655 N25530 X-6.3817 Y-2.3433 N25535 X-6.3843 Y-2.3304 N25540 X-6.3864 Y-2.3175 N25545 X-6.3877 Y-2.3047 N25550 X-6.3878 Y-2.2919 N25555 X-6.3866 Y-2.2792 N25560 X-6.3842 Y-2.2665 N25565 X-6.3776 Y-2.2411 N25570 X-6.3707 Y-2.2241 N25575 X-6.3629 Y-2.2075 N25580 X-6.3536 Y-2.1917 N25585 X-6.3434 Y-2.1763 N25590 X-6.3308 Y-2.1602 N25595 X-6.3175 Y-2.1447 N25600 X-6.3031 Y-2.1303 N25605 X-6.288 Y-2.1164 N25610 X-6.2727 Y-2.1043 N25615 X-6.2568 Y-2.093 N25620 X-6.2485 Y-2.0879 N25625 X-6.24 Y-2.0832 N25630 X-6.2226 Y-2.0744 N25635 X-6.1938 Y-2.0597 N25640 X-6.1791 Y-2.0533 N25645 X-6.1641 Y-2.048 N25650 X-6.1487 Y-2.0441 N25655 X-6.1329 Y-2.0415 N25660 X-6.1169 Y-2.0397 N25665 X-6.1007 Y-2.0382 N25670 X-6.0821 Y-2.0391 N25675 X-6.0637 Y-2.0418 N25680 X-6.0556 Y-2.0438 N25685 X-6.0477 Y-2.0463 N25690 X-6.0401 Y-2.0496 N25695 X-6.0327 Y-2.0533 N25700 X-6.0255 Y-2.0579 N25705 X-6.0185 Y-2.0629 N25710 X-6.0057 Y-2.0742 N25715 X-6.0015 Y-2.078 N25720 X-5.997 Y-2.0814 N25725 X-5.992 Y-2.0837 N25730 X-5.9865 Y-2.0853 N25735 X-5.9696 Y-2.0784 N25740 X-5.9617 Y-2.0742 N25745 X-5.9541 Y-2.0692 N25750 X-5.947 Y-2.0636 N25755 X-5.9402 Y-2.0575 N25760 X-5.9269 Y-2.0446 N25765 X-5.909 N25770 X-5.967 Y-2.2392 N25775 X-5.9863 N25780 X-5.9846 Y-2.2211 N25785 X-5.9837 Y-2.203 N25790 X-5.9844 Y-2.1895 N25795 X-5.9861 Y-2.1762 N25800 X-5.9894 Y-2.1596 N25805 X-5.9915 Y-2.1515 N25810 X-5.9939 Y-2.1435 N25815 X-5.9968 Y-2.1357 N25820 X-6.0002 Y-2.128 N25825 X-6.0076 Y-2.113 N25830 X-6.0159 Y-2.1009 N25835 X-6.0204 Y-2.0952 N25840 X-6.0252 Y-2.0899 N25845 X-6.0304 Y-2.085 N25850 X-6.0361 Y-2.0806 N25855 X-6.048 Y-2.0722 N25860 X-6.0612 Y-2.0662 N25865 X-6.0679 Y-2.0637 N25870 X-6.0747 Y-2.0616 N25875 X-6.0817 Y-2.0602 N25880 X-6.0887 Y-2.0593 N25885 X-6.1032 Y-2.0583 N25890 X-6.1204 Y-2.0597 N25895 X-6.1289 Y-2.061 N25900 X-6.1371 Y-2.0629 N25905 X-6.1452 Y-2.0657 N25910 X-6.153 Y-2.0692 N25915 X-6.1682 Y-2.0774 N25920 X-6.1842 Y-2.0904 N25925 X-6.1917 Y-2.0973 N25930 X-6.1987 Y-2.1047 N25935 X-6.2052 Y-2.1126 N25940 X-6.2113 Y-2.1209 N25945 X-6.2227 Y-2.1381 N25950 X-6.2367 Y-2.164 N25955 X-6.2433 Y-2.1772 N25960 X-6.2495 Y-2.1905 N25965 X-6.2552 Y-2.2041 N25970 X-6.2605 Y-2.2178 N25975 X-6.2705 Y-2.2455 N25980 X-6.2809 Y-2.2788 N25985 X-6.2853 Y-2.2956 N25990 X-6.2893 Y-2.3126 N25995 X-6.2914 Y-2.3245 N26000 X-6.293 Y-2.3366 N26005 X-6.2936 Y-2.3486 N26010 X-6.2935 Y-2.3608 N26015 X-6.2922 Y-2.3702 N26020 X-6.2902 Y-2.3793 N26025 X-6.2872 Y-2.3882 N26030 X-6.2835 Y-2.3969 N26035 X-6.2772 Y-2.4031 N26040 X-6.2704 Y-2.4085 N26045 X-6.2628 Y-2.4129 N26050 X-6.2548 Y-2.4167 N26055 X-6.2437 Y-2.4204 N26060 X-6.2325 Y-2.4231 N26065 X-6.221 Y-2.4244 N26070 X-6.2093 Y-2.4249 N26075 X-6.1968 Y-2.4244 N26080 X-6.1844 Y-2.4233 N26085 X-6.1721 Y-2.4212 N26090 X-6.1599 Y-2.4186 N26095 X-6.1474 Y-2.4148 N26100 X-6.135 Y-2.4106 N26105 X-6.1231 Y-2.4054 N26110 X-6.1113 Y-2.3997 N26115 X-6.0993 Y-2.3929 N26120 X-6.0875 Y-2.3856 N26125 X-6.0763 Y-2.3776 N26130 X-6.0653 Y-2.3692 N26135 X-6.0484 Y-2.3542 N26140 X-6.0328 Y-2.3379 N26145 X-6.0156 Y-2.3159 N26150 X-5.9998 Y-2.2929 N26155 X-5.9803 N26160 X-5.9875 Y-2.3055 N26165 X-5.9951 Y-2.3178 N26170 X-6.0033 Y-2.3298 N26175 X-6.0119 Y-2.3414 N26180 X-6.0276 Y-2.3586 N26185 Z0.1606 N26190 G0 Z0.2 N26195 X-6.4896 Y-2.4165 N26200 Z0.1606 N26205 G1 Z-0.0394 F13.123 N26210 X-6.497 Y-2.4382 F39.37 N26215 X-6.7298 N26220 X-6.7224 Y-2.4165 N26225 X-6.688 N26230 X-6.6804 Y-2.4164 N26235 X-6.6729 Y-2.4157 N26240 X-6.6656 Y-2.4141 N26245 X-6.6584 Y-2.4118 N26250 X-6.6543 Y-2.4093 N26255 X-6.6507 Y-2.4062 N26260 X-6.648 Y-2.4024 N26265 X-6.6458 Y-2.398 N26270 X-6.6441 Y-2.3897 N26275 X-6.6438 Y-2.3811 N26280 X-6.6453 Y-2.3616 N26285 X-6.6476 Y-2.3422 N26290 X-6.6481 Y-2.3371 N26295 X-6.6492 Y-2.3294 N26300 X-6.6504 Y-2.3185 N26305 X-6.8042 N26310 X-6.8219 Y-2.3404 N26315 X-6.8267 Y-2.3476 N26320 X-6.8311 Y-2.355 N26325 X-6.8349 Y-2.3627 N26330 X-6.8382 Y-2.3707 N26335 X-6.8396 Y-2.3762 N26340 X-6.8405 Y-2.3817 N26345 X-6.8403 Y-2.3873 N26350 X-6.8396 Y-2.393 N26355 X-6.8378 Y-2.3981 N26360 X-6.8354 Y-2.4028 N26365 X-6.8319 Y-2.4068 N26370 X-6.8278 Y-2.4104 N26375 X-6.8236 Y-2.413 N26380 X-6.8189 Y-2.4147 N26385 X-6.8089 Y-2.4162 N26390 X-6.7988 Y-2.4169 N26395 X-6.806 Y-2.4382 N26400 X-6.9728 N26405 X-6.9656 Y-2.4172 N26410 X-6.9492 Y-2.4149 N26415 X-6.9412 Y-2.4131 N26420 X-6.9332 Y-2.4109 N26425 X-6.9202 Y-2.4051 N26430 X-6.9079 Y-2.398 N26435 X-6.8848 Y-2.38 N26440 X-6.8737 Y-2.3704 N26445 X-6.8631 Y-2.3603 N26450 X-6.8531 Y-2.3497 N26455 X-6.8435 Y-2.3386 N26460 X-6.825 Y-2.3157 N26465 X-6.6081 Y-2.0382 N26470 X-6.5907 N26475 X-6.5511 Y-2.379 N26480 X-6.5478 Y-2.3894 N26485 X-6.5431 Y-2.3992 N26490 X-6.5403 Y-2.4033 N26495 X-6.5371 Y-2.407 N26500 X-6.5333 Y-2.4099 N26505 X-6.529 Y-2.4125 N26510 X-6.5233 Y-2.4144 N26515 X-6.5175 Y-2.4157 N26520 X-6.5116 Y-2.4163 N26525 X-6.5056 Y-2.4165 N26530 X-6.4896 N26535 Z0.1606 N26540 G0 Z0.2 N26545 X-6.6674 Y-2.1387 N26550 Z0.1606 N26555 G1 Z-0.0394 F13.123 N26560 X-6.7904 Y-2.2974 F39.37 N26565 X-6.6506 N26570 X-6.6674 Y-2.1387 N26575 Z0.1606 N26580 G0 Z0.2 N26585 X-6.8736 Y-2.0669 N26590 Z0.1606 N26595 G1 Z-0.0394 F13.123 N26600 X-6.8933 F39.37 N26605 X-6.9076 Y-2.0678 N26610 X-6.9145 Y-2.0687 N26615 X-6.9213 Y-2.0703 N26620 X-6.9279 Y-2.0725 N26625 X-6.9343 Y-2.0754 N26630 X-6.9467 Y-2.0823 N26635 X-6.9572 Y-2.0927 N26640 X-6.962 Y-2.0982 N26645 X-6.9663 Y-2.104 N26650 X-6.9699 Y-2.1103 N26655 X-6.973 Y-2.1169 N26660 X-6.9785 Y-2.1307 N26665 X-7.0541 Y-2.3527 N26670 X-7.0578 Y-2.3649 N26675 X-7.0592 Y-2.3709 N26680 X-7.0599 Y-2.377 N26685 X-7.0597 Y-2.383 N26690 X-7.0587 Y-2.389 N26695 X-7.055 Y-2.401 N26700 X-7.0459 Y-2.4087 N26705 X-7.041 Y-2.4117 N26710 X-7.0357 Y-2.414 N26715 X-7.0302 Y-2.4154 N26720 X-7.0244 Y-2.4161 N26725 X-7.0123 Y-2.4165 N26730 X-6.9925 N26735 X-6.9999 Y-2.4382 N26740 X-7.258 N26745 X-7.2506 Y-2.4165 N26750 X-7.2286 N26755 X-7.2144 Y-2.4156 N26760 X-7.2074 Y-2.4147 N26765 X-7.2006 Y-2.4131 N26770 X-7.1941 Y-2.4109 N26775 X-7.1877 Y-2.408 N26780 X-7.1753 Y-2.4011 N26785 X-7.1648 Y-2.3907 N26790 X-7.16 Y-2.3852 N26795 X-7.1557 Y-2.3794 N26800 X-7.1521 Y-2.3731 N26805 X-7.1489 Y-2.3665 N26810 X-7.1434 Y-2.3527 N26815 X-7.057 Y-2.0988 N26820 X-7.0489 N26825 X-7.3281 Y-2.4382 N26830 X-7.3446 N26835 X-7.3953 Y-2.0999 N26840 X-7.387 N26845 X-7.4688 Y-2.3404 N26850 X-7.4718 Y-2.3505 N26855 X-7.4739 Y-2.3606 N26860 X-7.4743 Y-2.3657 N26865 Y-2.3709 N26870 X-7.4737 Y-2.3813 N26875 X-7.471 Y-2.389 N26880 X-7.4694 Y-2.3927 N26885 X-7.4673 Y-2.396 N26890 X-7.4648 Y-2.399 N26895 X-7.4619 Y-2.4018 N26900 X-7.4555 Y-2.4068 N26905 X-7.4445 Y-2.4113 N26910 X-7.4389 Y-2.4132 N26915 X-7.4332 Y-2.4146 N26920 X-7.4215 Y-2.4162 N26925 X-7.4096 Y-2.4168 N26930 X-7.4169 Y-2.4382 N26935 X-7.6073 N26940 X-7.5999 Y-2.4165 N26945 X-7.5906 N26950 X-7.5742 Y-2.415 N26955 X-7.5662 Y-2.4137 N26960 X-7.5585 Y-2.4117 N26965 X-7.5511 Y-2.4088 N26970 X-7.5439 Y-2.4051 N26975 X-7.5298 Y-2.3966 N26980 X-7.5175 Y-2.385 N26985 X-7.5118 Y-2.3788 N26990 X-7.5067 Y-2.3722 N26995 X-7.5024 Y-2.3652 N27000 X-7.4986 Y-2.3577 N27005 X-7.4919 Y-2.3421 N27010 X-7.42 Y-2.1307 N27015 X-7.4162 Y-2.1185 N27020 X-7.4148 Y-2.1125 N27025 X-7.4141 Y-2.1064 N27030 X-7.4143 Y-2.1003 N27035 X-7.4153 Y-2.0943 N27040 X-7.4189 Y-2.0823 N27045 X-7.4281 Y-2.0746 N27050 X-7.4331 Y-2.0716 N27055 X-7.4384 Y-2.0694 N27060 X-7.444 Y-2.068 N27065 X-7.4499 Y-2.0673 N27070 X-7.4621 Y-2.0669 N27075 X-7.481 N27080 X-7.4738 Y-2.0457 N27085 X-7.3052 N27090 X-7.2645 Y-2.3376 N27095 X-7.0263 Y-2.0457 N27100 X-6.8664 N27105 X-6.8736 Y-2.0669 N27110 Z0.1606 N27115 G0 Z0.2 N27120 X-5.7739 Y-3.1632 N27125 Z0.1606 N27130 G1 Z-0.0394 F13.123 N27135 X-5.655 F39.37 N27140 X-5.5689 Y-3.6443 N27145 X-5.4639 Y-3.1632 N27150 X-5.3258 N27155 X-5.225 Y-3.6524 N27160 X-5.1365 Y-3.1632 N27165 X-5.02 N27170 X-5.1594 Y-3.8632 N27175 X-5.2828 N27180 X-5.3974 Y-3.3397 N27185 X-5.5111 Y-3.8632 N27190 X-5.6363 N27195 X-5.7739 Y-3.1632 N27200 Z0.1606 N27205 G0 Z0.2 N27210 X-4.8908 Y-3.6607 N27215 Z0.1606 N27220 G1 Z-0.0394 F13.123 N27225 X-4.8952 Y-3.6436 F39.37 N27230 X-4.8987 Y-3.6261 N27235 X-4.9014 Y-3.6084 N27240 X-4.9035 Y-3.5905 N27245 X-4.9051 Y-3.5724 N27250 X-4.9063 Y-3.5542 N27255 X-4.908 Y-3.5175 N27260 X-4.9072 Y-3.491 N27265 X-4.906 Y-3.4646 N27270 X-4.9039 Y-3.4384 N27275 X-4.9023 Y-3.4254 N27280 X-4.9004 Y-3.4124 N27285 X-4.8979 Y-3.3996 N27290 X-4.895 Y-3.3868 N27295 X-4.8879 Y-3.3615 N27300 X-4.8797 Y-3.3365 N27305 X-4.8709 Y-3.3115 N27310 X-4.8619 Y-3.2939 N27315 X-4.8525 Y-3.2767 N27320 X-4.8423 Y-3.26 N27325 X-4.8369 Y-3.252 N27330 X-4.8311 Y-3.2443 N27335 X-4.8249 Y-3.2369 N27340 X-4.8183 Y-3.2298 N27345 X-4.8043 Y-3.2162 N27350 X-4.7895 Y-3.2034 N27355 X-4.7743 Y-3.1909 N27360 X-4.7573 Y-3.1819 N27365 X-4.7402 Y-3.1735 N27370 X-4.7228 Y-3.1661 N27375 X-4.7139 Y-3.1629 N27380 X-4.705 Y-3.1603 N27385 X-4.6958 Y-3.1581 N27390 X-4.6866 Y-3.1563 N27395 X-4.6678 Y-3.1538 N27400 X-4.6487 Y-3.1523 N27405 X-4.6296 Y-3.1513 N27410 X-4.6004 Y-3.1544 N27415 X-4.586 Y-3.1563 N27420 X-4.5717 Y-3.1586 N27425 X-4.5578 Y-3.1614 N27430 X-4.5441 Y-3.1649 N27435 X-4.5309 Y-3.1693 N27440 X-4.5181 Y-3.1747 N27445 X-4.5058 Y-3.1811 N27450 X-4.4939 Y-3.1884 N27455 X-4.4825 Y-3.1967 N27460 X-4.4713 Y-3.2056 N27465 X-4.4605 Y-3.215 N27470 X-4.4498 Y-3.2249 N27475 X-4.4288 Y-3.2454 N27480 X-4.4103 Y-3.2761 N27485 X-4.4014 Y-3.2916 N27490 X-4.393 Y-3.3073 N27495 X-4.3851 Y-3.3231 N27500 X-4.378 Y-3.3391 N27505 X-4.3719 Y-3.3555 N27510 X-4.3668 Y-3.3721 N27515 X-4.3626 Y-3.3891 N27520 X-4.3594 Y-3.4063 N27525 X-4.3569 Y-3.4238 N27530 X-4.355 Y-3.4415 N27535 X-4.3526 Y-3.4772 N27540 X-4.3512 Y-3.5132 N27545 X-4.3528 Y-3.5503 N27550 X-4.354 Y-3.5687 N27555 X-4.3555 Y-3.587 N27560 X-4.3576 Y-3.6051 N27565 X-4.3602 Y-3.623 N27570 X-4.3637 Y-3.6407 N27575 X-4.3681 Y-3.6581 N27580 X-4.3736 Y-3.6752 N27585 X-4.3801 Y-3.6919 N27590 X-4.3876 Y-3.7083 N27595 X-4.3958 Y-3.7245 N27600 X-4.4046 Y-3.7405 N27605 X-4.4139 Y-3.7563 N27610 X-4.4333 Y-3.7878 N27615 X-4.4539 Y-3.8072 N27620 X-4.4644 Y-3.8166 N27625 X-4.475 Y-3.8255 N27630 X-4.4859 Y-3.8339 N27635 X-4.4972 Y-3.8416 N27640 X-4.5088 Y-3.8485 N27645 X-4.5208 Y-3.8544 N27650 X-4.5333 Y-3.8593 N27655 X-4.5462 Y-3.8633 N27660 X-4.5595 Y-3.8665 N27665 X-4.573 Y-3.869 N27670 X-4.5869 Y-3.871 N27675 X-4.6008 Y-3.8726 N27680 X-4.6291 Y-3.8752 N27685 X-4.6574 Y-3.8727 N27690 X-4.6714 Y-3.8711 N27695 X-4.6853 Y-3.8692 N27700 X-4.6989 Y-3.8667 N27705 X-4.7122 Y-3.8636 N27710 X-4.7252 Y-3.8597 N27715 X-4.7377 Y-3.8548 N27720 X-4.7498 Y-3.849 N27725 X-4.7615 Y-3.8422 N27730 X-4.7728 Y-3.8345 N27735 X-4.7837 Y-3.8262 N27740 X-4.7945 Y-3.8173 N27745 X-4.805 Y-3.808 N27750 X-4.8258 Y-3.7887 N27755 X-4.8451 Y-3.7577 N27760 X-4.8544 Y-3.7421 N27765 X-4.8631 Y-3.7263 N27770 X-4.8714 Y-3.7103 N27775 X-4.8788 Y-3.6941 N27780 X-4.8853 Y-3.6776 N27785 X-4.8908 Y-3.6607 N27790 Z0.1606 N27795 G0 Z0.2 N27800 X-4.7886 Y-3.5127 N27805 Z0.1606 N27810 G1 Z-0.0394 F13.123 N27815 X-4.788 Y-3.5368 F39.37 N27820 X-4.7867 Y-3.5607 N27825 X-4.7843 Y-3.5843 N27830 X-4.7824 Y-3.5959 N27835 X-4.78 Y-3.6073 N27840 X-4.777 Y-3.6186 N27845 X-4.7734 Y-3.6297 N27850 X-4.7692 Y-3.6407 N27855 X-4.7644 Y-3.6515 N27860 X-4.7539 Y-3.6728 N27865 X-4.7427 Y-3.694 N27870 X-4.7311 Y-3.7066 N27875 X-4.7192 Y-3.7187 N27880 X-4.7131 Y-3.7243 N27885 X-4.7067 Y-3.7294 N27890 X-4.7 Y-3.7341 N27895 X-4.6931 Y-3.7383 N27900 X-4.6859 Y-3.7418 N27905 X-4.6783 Y-3.7447 N27910 X-4.6705 Y-3.7471 N27915 X-4.6624 Y-3.7491 N27920 X-4.6458 Y-3.7521 N27925 X-4.6289 Y-3.7544 N27930 X-4.612 Y-3.7521 N27935 X-4.5954 Y-3.7492 N27940 X-4.5874 Y-3.7473 N27945 X-4.5796 Y-3.7449 N27950 X-4.572 Y-3.742 N27955 X-4.5648 Y-3.7386 N27960 X-4.5579 Y-3.7345 N27965 X-4.5513 Y-3.7298 N27970 X-4.545 Y-3.7247 N27975 X-4.5388 Y-3.7191 N27980 X-4.527 Y-3.7071 N27985 X-4.5155 Y-3.6944 N27990 X-4.5044 Y-3.6729 N27995 X-4.494 Y-3.6512 N28000 X-4.4893 Y-3.6401 N28005 X-4.4852 Y-3.629 N28010 X-4.4816 Y-3.6177 N28015 X-4.4787 Y-3.6062 N28020 X-4.4763 Y-3.5946 N28025 X-4.4745 Y-3.5828 N28030 X-4.4722 Y-3.5589 N28035 X-4.4711 Y-3.5347 N28040 X-4.4706 Y-3.5104 N28045 X-4.4711 Y-3.4865 N28050 X-4.4721 Y-3.4629 N28055 X-4.4744 Y-3.4395 N28060 X-4.4761 Y-3.428 N28065 X-4.4784 Y-3.4166 N28070 X-4.4813 Y-3.4054 N28075 X-4.4847 Y-3.3943 N28080 X-4.4888 Y-3.3834 N28085 X-4.4933 Y-3.3727 N28090 X-4.5034 Y-3.3514 N28095 X-4.5143 Y-3.3303 N28100 X-4.526 Y-3.3178 N28105 X-4.538 Y-3.306 N28110 X-4.5442 Y-3.3005 N28115 X-4.5507 Y-3.2954 N28120 X-4.5574 Y-3.2909 N28125 X-4.5643 Y-3.2869 N28130 X-4.5717 Y-3.2836 N28135 X-4.5793 Y-3.2808 N28140 X-4.5871 Y-3.2786 N28145 X-4.5952 Y-3.2768 N28150 X-4.6119 Y-3.2741 N28155 X-4.6289 Y-3.2721 N28160 X-4.6459 Y-3.2741 N28165 X-4.6627 Y-3.2769 N28170 X-4.6708 Y-3.2787 N28175 X-4.6787 Y-3.281 N28180 X-4.6864 Y-3.2838 N28185 X-4.6937 Y-3.2871 N28190 X-4.7007 Y-3.2911 N28195 X-4.7075 Y-3.2957 N28200 X-4.714 Y-3.3008 N28205 X-4.7203 Y-3.3063 N28210 X-4.7324 Y-3.3182 N28215 X-4.7441 Y-3.3308 N28220 X-4.7552 Y-3.3521 N28225 X-4.7655 Y-3.3736 N28230 X-4.7701 Y-3.3844 N28235 X-4.7742 Y-3.3955 N28240 X-4.7777 Y-3.4066 N28245 X-4.7806 Y-3.418 N28250 X-4.7829 Y-3.4295 N28255 X-4.7847 Y-3.4411 N28260 X-4.787 Y-3.4647 N28265 X-4.7881 Y-3.4887 N28270 X-4.7886 Y-3.5127 N28275 Z0.1606 N28280 G0 Z0.2 N28285 X-4.1833 Y-3.5132 N28290 Z0.1606 N28295 G1 Z-0.0394 F13.123 N28300 Y-3.1632 F39.37 N28305 X-3.9393 N28310 X-3.9052 Y-3.1636 N28315 X-3.8882 Y-3.1644 N28320 X-3.8714 Y-3.1661 N28325 X-3.8547 Y-3.1688 N28330 X-3.8383 Y-3.1726 N28335 X-3.8056 Y-3.1821 N28340 X-3.7855 Y-3.1947 N28345 X-3.7761 Y-3.2017 N28350 X-3.7675 Y-3.2095 N28355 X-3.7597 Y-3.2181 N28360 X-3.7527 Y-3.2275 N28365 X-3.7397 Y-3.2475 N28370 X-3.7283 Y-3.2742 N28375 X-3.7235 Y-3.2877 N28380 X-3.7197 Y-3.3016 N28385 X-3.7171 Y-3.3156 N28390 X-3.7155 Y-3.33 N28395 X-3.7139 Y-3.359 N28400 X-3.7148 Y-3.3768 N28405 X-3.7162 Y-3.3944 N28410 X-3.7186 Y-3.4117 N28415 X-3.7203 Y-3.4202 N28420 X-3.7224 Y-3.4286 N28425 X-3.725 Y-3.4368 N28430 X-3.7282 Y-3.4449 N28435 X-3.7356 Y-3.4606 N28440 X-3.7442 Y-3.476 N28445 X-3.7533 Y-3.4913 N28450 X-3.7651 Y-3.5031 N28455 X-3.7771 Y-3.5144 N28460 X-3.7897 Y-3.5246 N28465 X-3.7964 Y-3.5292 N28470 X-3.8033 Y-3.5334 N28475 X-3.8104 Y-3.537 N28480 X-3.8178 Y-3.5403 N28485 X-3.8332 Y-3.5457 N28490 X-3.8491 Y-3.5502 N28495 X-3.8653 Y-3.5543 N28500 X-3.8484 Y-3.5674 N28505 X-3.8402 Y-3.5742 N28510 X-3.8323 Y-3.5813 N28515 X-3.8248 Y-3.5888 N28520 X-3.8176 Y-3.5966 N28525 X-3.8037 Y-3.6128 N28530 X-3.7855 Y-3.6403 N28535 X-3.7767 Y-3.6542 N28540 X-3.7683 Y-3.6684 N28545 X-3.7525 Y-3.6973 N28550 X-3.7373 Y-3.7267 N28555 X-3.6676 Y-3.8632 N28560 X-3.8059 N28565 X-3.8897 Y-3.7109 N28570 X-3.9041 Y-3.6845 N28575 X-3.919 Y-3.6583 N28580 X-3.9347 Y-3.6327 N28585 X-3.9513 Y-3.6075 N28590 X-3.9587 Y-3.5989 N28595 X-3.9667 Y-3.591 N28600 X-3.9711 Y-3.5876 N28605 X-3.9758 Y-3.5845 N28610 X-3.9856 Y-3.5789 N28615 X-3.9999 Y-3.5749 N28620 X-4.0071 Y-3.5734 N28625 X-4.0143 Y-3.5722 N28630 X-4.0291 Y-3.5712 N28635 X-4.0439 Y-3.571 N28640 X-4.0678 N28645 Y-3.8632 N28650 X-4.1833 N28655 Y-3.5132 N28660 Z0.1606 N28665 G0 Z0.2 N28670 X-4.0678 Y-3.4593 N28675 Z0.1606 N28680 G1 Z-0.0394 F13.123 N28685 X-3.9818 F39.37 N28690 X-3.9566 Y-3.4594 N28695 X-3.9314 Y-3.4586 N28700 X-3.9189 Y-3.4577 N28705 X-3.9064 Y-3.4562 N28710 X-3.8815 Y-3.4523 N28715 X-3.8711 Y-3.4475 N28720 X-3.8662 Y-3.4448 N28725 X-3.8616 Y-3.4415 N28730 X-3.8575 Y-3.4378 N28735 X-3.8537 Y-3.4335 N28740 X-3.8467 Y-3.4244 N28745 X-3.8405 Y-3.4111 N28750 X-3.838 Y-3.4044 N28755 X-3.836 Y-3.3975 N28760 X-3.8348 Y-3.3904 N28765 X-3.834 Y-3.3832 N28770 X-3.8333 Y-3.3685 N28775 X-3.834 Y-3.3544 N28780 X-3.8348 Y-3.3475 N28785 X-3.8361 Y-3.3407 N28790 X-3.838 Y-3.334 N28795 X-3.8406 Y-3.3275 N28800 X-3.8467 Y-3.3148 N28805 X-3.8541 Y-3.3057 N28810 X-3.8581 Y-3.3015 N28815 X-3.8624 Y-3.2977 N28820 X-3.8671 Y-3.2945 N28825 X-3.8722 Y-3.2917 N28830 X-3.883 Y-3.2869 N28835 X-3.9064 Y-3.2838 N28840 X-3.9181 Y-3.2827 N28845 X-3.9298 Y-3.2819 N28850 X-3.9534 Y-3.2815 N28855 X-3.977 Y-3.2816 N28860 X-4.0678 N28865 Y-3.4593 N28870 Z0.1606 N28875 G0 Z0.2 N28880 X-3.5269 Y-3.4632 N28885 Z0.1606 N28890 G1 Z-0.0394 F13.123 N28895 Y-3.1632 F39.37 N28900 X-3.4114 N28905 Y-3.4748 N28910 X-3.1767 Y-3.1632 N28915 X-3.0206 N28920 X-3.237 Y-3.4361 N28925 X-3.0091 Y-3.8632 N28930 X-3.1591 N28935 X-3.3174 Y-3.5343 N28940 X-3.4114 Y-3.6517 N28945 Y-3.8632 N28950 X-3.5269 N28955 Y-3.4632 N28960 Z0.1606 N28965 G0 Z0.2 N28970 X-2.8763 Y-3.8632 N28975 Z0.1606 N28980 G1 Z-0.0394 F13.123 N28985 Y-3.1632 F39.37 N28990 X-2.7608 N28995 Y-3.8632 N29000 X-2.8763 N29005 Z0.1606 N29010 G0 Z0.2 N29015 X-2.5719 N29020 Z0.1606 N29025 G1 Z-0.0394 F13.123 N29030 Y-3.1632 F39.37 N29035 X-2.4592 N29040 X-2.2243 Y-3.6307 N29045 Y-3.1632 N29050 X-2.1164 N29055 Y-3.8632 N29060 X-2.2329 N29065 X-2.464 Y-3.4067 N29070 Y-3.8632 N29075 X-2.5719 N29080 Z0.1606 N29085 G0 Z0.2 N29090 X-1.9164 Y-3.6607 N29095 Z0.1606 N29100 G1 Z-0.0394 F13.123 N29105 X-1.9235 Y-3.6367 F39.37 N29110 X-1.9265 Y-3.6246 N29115 X-1.929 Y-3.6124 N29120 X-1.9311 Y-3.6001 N29125 X-1.9328 Y-3.5877 N29130 X-1.9351 Y-3.5627 N29135 X-1.9365 Y-3.5375 N29140 X-1.9375 Y-3.5123 N29145 X-1.9366 Y-3.4868 N29150 X-1.9352 Y-3.4614 N29155 X-1.9329 Y-3.4362 N29160 X-1.9312 Y-3.4237 N29165 X-1.9291 Y-3.4112 N29170 X-1.9265 Y-3.3989 N29175 X-1.9235 Y-3.3867 N29180 X-1.9162 Y-3.3625 N29185 X-1.9079 Y-3.3385 N29190 X-1.899 Y-3.3146 N29195 X-1.8896 Y-3.2967 N29200 X-1.8799 Y-3.2792 N29205 X-1.8693 Y-3.2622 N29210 X-1.8636 Y-3.2541 N29215 X-1.8576 Y-3.2462 N29220 X-1.8513 Y-3.2387 N29225 X-1.8445 Y-3.2314 N29230 X-1.8301 Y-3.2176 N29235 X-1.8149 Y-3.2046 N29240 X-1.7992 Y-3.1919 N29245 X-1.7821 Y-3.1827 N29250 X-1.7647 Y-3.1741 N29255 X-1.747 Y-3.1666 N29260 X-1.7381 Y-3.1634 N29265 X-1.7289 Y-3.1606 N29270 X-1.7197 Y-3.1584 N29275 X-1.7103 Y-3.1566 N29280 X-1.6912 Y-3.154 N29285 X-1.6719 Y-3.1524 N29290 X-1.6524 Y-3.1513 N29295 X-1.6301 Y-3.1525 N29300 X-1.608 Y-3.1544 N29305 X-1.5971 Y-3.1557 N29310 X-1.5863 Y-3.1575 N29315 X-1.5757 Y-3.1598 N29320 X-1.5653 Y-3.1626 N29325 X-1.5551 Y-3.1661 N29330 X-1.5451 Y-3.1703 N29335 X-1.5353 Y-3.175 N29340 X-1.5256 Y-3.1801 N29345 X-1.5066 Y-3.1915 N29350 X-1.4879 Y-3.2036 N29355 X-1.4729 Y-3.22 N29360 X-1.4585 Y-3.2369 N29365 X-1.4518 Y-3.2455 N29370 X-1.4455 Y-3.2544 N29375 X-1.4397 Y-3.2636 N29380 X-1.4345 Y-3.2731 N29385 X-1.4299 Y-3.2829 N29390 X-1.4259 Y-3.2929 N29395 X-1.4223 Y-3.3033 N29400 X-1.4191 Y-3.3138 N29405 X-1.4134 Y-3.3353 N29410 X-1.4084 Y-3.3571 N29415 X-1.523 Y-3.3833 N29420 X-1.5303 Y-3.36 N29425 X-1.5346 Y-3.3488 N29430 X-1.5399 Y-3.3381 N29435 X-1.5463 Y-3.3281 N29440 X-1.5538 Y-3.3186 N29445 X-1.5703 Y-3.3007 N29450 X-1.589 Y-3.2885 N29455 X-1.5987 Y-3.2832 N29460 X-1.6087 Y-3.279 N29465 X-1.6192 Y-3.2761 N29470 X-1.6301 Y-3.2742 N29475 X-1.6524 Y-3.2721 N29480 X-1.6699 Y-3.274 N29485 X-1.6871 Y-3.2766 N29490 X-1.6955 Y-3.2783 N29495 X-1.7037 Y-3.2805 N29500 X-1.7116 Y-3.2832 N29505 X-1.7193 Y-3.2864 N29510 X-1.7266 Y-3.2903 N29515 X-1.7337 Y-3.2949 N29520 X-1.7405 Y-3.2999 N29525 X-1.7471 Y-3.3053 N29530 X-1.7598 Y-3.3171 N29535 X-1.7723 Y-3.3296 N29540 X-1.7836 Y-3.35 N29545 X-1.7941 Y-3.3706 N29550 X-1.7988 Y-3.381 N29555 X-1.803 Y-3.3916 N29560 X-1.8067 Y-3.4023 N29565 X-1.8097 Y-3.4133 N29570 X-1.812 Y-3.4244 N29575 X-1.8139 Y-3.4356 N29580 X-1.8163 Y-3.4585 N29585 X-1.8175 Y-3.4817 N29590 X-1.8181 Y-3.5051 N29595 X-1.8174 Y-3.5307 N29600 X-1.816 Y-3.5561 N29605 X-1.8148 Y-3.5686 N29610 X-1.8133 Y-3.5811 N29615 X-1.8112 Y-3.5934 N29620 X-1.8086 Y-3.6056 N29625 X-1.8054 Y-3.6176 N29630 X-1.8014 Y-3.6294 N29635 X-1.7969 Y-3.641 N29640 X-1.7918 Y-3.6525 N29645 X-1.7805 Y-3.6751 N29650 X-1.7684 Y-3.6975 N29655 X-1.7567 Y-3.7099 N29660 X-1.7446 Y-3.7217 N29665 X-1.7383 Y-3.727 N29670 X-1.7318 Y-3.732 N29675 X-1.7251 Y-3.7365 N29680 X-1.7181 Y-3.7403 N29685 X-1.7107 Y-3.7436 N29690 X-1.703 Y-3.7462 N29695 X-1.6951 Y-3.7483 N29700 X-1.687 Y-3.75 N29705 X-1.6704 Y-3.7525 N29710 X-1.6534 Y-3.7544 N29715 X-1.6352 Y-3.7529 N29720 X-1.6262 Y-3.7517 N29725 X-1.6174 Y-3.75 N29730 X-1.6086 Y-3.7477 N29735 X-1.6 Y-3.7449 N29740 X-1.5829 Y-3.7384 N29745 X-1.5653 Y-3.7295 N29750 X-1.5567 Y-3.7248 N29755 X-1.5484 Y-3.7196 N29760 X-1.5404 Y-3.7139 N29765 X-1.5327 Y-3.7078 N29770 X-1.5178 Y-3.6949 N29775 Y-3.6063 N29780 X-1.6505 N29785 Y-3.4879 N29790 X-1.4008 N29795 Y-3.7668 N29800 X-1.4246 Y-3.7899 N29805 X-1.437 Y-3.8008 N29810 X-1.4501 Y-3.8107 N29815 X-1.4639 Y-3.8197 N29820 X-1.4782 Y-3.828 N29825 X-1.5077 Y-3.8432 N29830 X-1.5413 Y-3.8564 N29835 X-1.5583 Y-3.8621 N29840 X-1.5755 Y-3.8668 N29845 X-1.593 Y-3.8702 N29850 X-1.6108 Y-3.8724 N29855 X-1.6467 Y-3.8752 N29860 X-1.6666 Y-3.8739 N29865 X-1.6863 Y-3.8722 N29870 X-1.7057 Y-3.8695 N29875 X-1.7153 Y-3.8676 N29880 X-1.7248 Y-3.8653 N29885 X-1.7341 Y-3.8624 N29890 X-1.7432 Y-3.8591 N29895 X-1.7613 Y-3.8514 N29900 X-1.779 Y-3.8427 N29905 X-1.7966 Y-3.8334 N29910 X-1.8129 Y-3.8206 N29915 X-1.8287 Y-3.8074 N29920 X-1.8436 Y-3.7934 N29925 X-1.8506 Y-3.7861 N29930 X-1.8571 Y-3.7784 N29935 X-1.8633 Y-3.7704 N29940 X-1.8692 Y-3.7621 N29945 X-1.88 Y-3.7447 N29950 X-1.8899 Y-3.7267 N29955 X-1.8995 Y-3.7083 N29960 X-1.9082 Y-3.6846 N29965 X-1.9164 Y-3.6607 N29970 Z0.1606 N29975 G0 Z0.2 N29980 X-0.9189 Y-3.6007 N29985 Z0.1606 N29990 G1 Z-0.0394 F13.123 N29995 Y-3.1632 F39.37 N30000 X-0.7456 N30005 X-0.6412 Y-3.6412 N30010 X-0.5377 Y-3.1632 N30015 X-0.3636 N30020 Y-3.8632 N30025 X-0.4715 N30030 Y-3.3117 N30035 X-0.5859 Y-3.8632 N30040 X-0.6974 N30045 X-0.811 Y-3.3117 N30050 Y-3.8632 N30055 X-0.9189 N30060 Y-3.6007 N30065 Z0.1606 N30070 G0 Z0.2 N30075 X-0.231 Y-3.8632 N30080 Z0.1606 N30085 G1 Z-0.0394 F13.123 N30090 X-0.0075 Y-3.1632 F39.37 N30095 X0.1152 N30100 X0.3453 Y-3.8632 N30105 X0.2197 N30110 X0.1694 Y-3.7047 N30115 X-0.0604 N30120 X-0.1078 Y-3.8632 N30125 X-0.231 N30130 Z0.1606 N30135 G0 Z0.2 N30140 X0.4841 N30145 Z0.1606 N30150 G1 Z-0.0394 F13.123 N30155 Y-3.1632 F39.37 N30160 X0.5967 N30165 X0.8317 Y-3.6307 N30170 Y-3.1632 N30175 X0.9396 N30180 Y-3.8632 N30185 X0.8231 N30190 X0.592 Y-3.4067 N30195 Y-3.8632 N30200 X0.4841 N30205 Z0.1606 N30210 G0 Z0.2 N30215 X0.1321 Y-3.5863 N30220 Z0.1606 N30225 G1 Z-0.0394 F13.123 N30230 X0.0528 Y-3.3265 F39.37 N30235 X-0.0249 Y-3.5863 N30240 X0.1321 N30245 Z0.1606 N30250 G0 Z0.2 N30255 X1.1361 Y-3.412 N30260 Z0.1606 N30265 G1 Z-0.0394 F13.123 N30270 X1.1156 Y-3.2816 F39.37 N30275 Y-3.1632 N30280 X1.2354 N30285 Y-3.2816 N30290 X1.2173 Y-3.412 N30295 X1.1361 N30300 Z0.1606 N30305 G0 Z0.2 N30310 X1.4 Y-3.3824 N30315 Z0.1606 N30320 G1 Z-0.0394 F13.123 N30325 X1.3986 Y-3.3706 F39.37 N30330 X1.3971 Y-3.3469 N30335 X1.399 Y-3.3199 N30340 X1.4007 Y-3.3067 N30345 X1.4033 Y-3.2936 N30350 X1.4071 Y-3.2809 N30355 X1.4119 Y-3.2684 N30360 X1.4231 Y-3.2438 N30365 X1.4375 Y-3.2229 N30370 X1.4454 Y-3.213 N30375 X1.4539 Y-3.2039 N30380 X1.4633 Y-3.1957 N30385 X1.4735 Y-3.1882 N30390 X1.495 Y-3.1747 N30395 X1.5223 Y-3.1641 N30400 X1.5361 Y-3.1597 N30405 X1.5501 Y-3.1563 N30410 X1.5644 Y-3.154 N30415 X1.5789 Y-3.1526 N30420 X1.6082 Y-3.1513 N30425 X1.63 Y-3.1525 N30430 X1.6515 Y-3.1544 N30435 X1.6621 Y-3.1559 N30440 X1.6726 Y-3.1577 N30445 X1.6828 Y-3.1601 N30450 X1.6929 Y-3.1631 N30455 X1.7027 Y-3.1668 N30460 X1.7122 Y-3.1711 N30465 X1.7215 Y-3.176 N30470 X1.7307 Y-3.1815 N30475 X1.7486 Y-3.1934 N30480 X1.7662 Y-3.2062 N30485 X1.7796 Y-3.2235 N30490 X1.7922 Y-3.2411 N30495 X1.7979 Y-3.2501 N30500 X1.8032 Y-3.2593 N30505 X1.8079 Y-3.2688 N30510 X1.8119 Y-3.2785 N30515 X1.8152 Y-3.2885 N30520 X1.8179 Y-3.2988 N30525 X1.8201 Y-3.3092 N30530 X1.8218 Y-3.3198 N30535 X1.8245 Y-3.3414 N30540 X1.8264 Y-3.3633 N30545 X1.7103 Y-3.3695 N30550 X1.7066 Y-3.3478 N30555 X1.7041 Y-3.3372 N30560 X1.7007 Y-3.3271 N30565 X1.6961 Y-3.3174 N30570 X1.6905 Y-3.3082 N30575 X1.6841 Y-3.2994 N30580 X1.6774 Y-3.2907 N30585 X1.6609 Y-3.2804 N30590 X1.6524 Y-3.2761 N30595 X1.6435 Y-3.2729 N30600 X1.6343 Y-3.2707 N30605 X1.6248 Y-3.2694 N30610 X1.6053 Y-3.2683 N30615 X1.5861 Y-3.2692 N30620 X1.5767 Y-3.2703 N30625 X1.5675 Y-3.2721 N30630 X1.5586 Y-3.275 N30635 X1.55 Y-3.2787 N30640 X1.5332 Y-3.2878 N30645 X1.5228 Y-3.2978 N30650 X1.5183 Y-3.3032 N30655 X1.5146 Y-3.309 N30660 X1.5119 Y-3.3153 N30665 X1.5101 Y-3.3221 N30670 X1.5079 Y-3.3363 N30675 X1.5098 Y-3.3502 N30680 X1.5114 Y-3.3568 N30685 X1.5138 Y-3.363 N30690 X1.5172 Y-3.3688 N30695 X1.5213 Y-3.3742 N30700 X1.5309 Y-3.3844 N30705 X1.5558 Y-3.3985 N30710 X1.5686 Y-3.4048 N30715 X1.5817 Y-3.4104 N30720 X1.5951 Y-3.4152 N30725 X1.6088 Y-3.4196 N30730 X1.6364 Y-3.4273 N30735 X1.6694 Y-3.4374 N30740 X1.6857 Y-3.4429 N30745 X1.7017 Y-3.449 N30750 X1.7174 Y-3.456 N30755 X1.7327 Y-3.4637 N30760 X1.7627 Y-3.4806 N30765 X1.7808 Y-3.4959 N30770 X1.7893 Y-3.5041 N30775 X1.7971 Y-3.5127 N30780 X1.8041 Y-3.5221 N30785 X1.8105 Y-3.532 N30790 X1.8221 Y-3.5527 N30795 X1.8313 Y-3.5787 N30800 X1.8352 Y-3.5918 N30805 X1.8382 Y-3.6051 N30810 X1.8402 Y-3.6186 N30815 X1.8414 Y-3.6323 N30820 X1.8426 Y-3.6599 N30825 X1.841 Y-3.681 N30830 X1.8386 Y-3.7019 N30835 X1.837 Y-3.7122 N30840 X1.835 Y-3.7223 N30845 X1.8324 Y-3.7322 N30850 X1.8293 Y-3.7419 N30855 X1.8255 Y-3.7514 N30860 X1.821 Y-3.7606 N30865 X1.8161 Y-3.7697 N30870 X1.8107 Y-3.7786 N30875 X1.799 Y-3.796 N30880 X1.7865 Y-3.8131 N30885 X1.7673 Y-3.828 N30890 X1.7477 Y-3.8419 N30895 X1.7376 Y-3.8482 N30900 X1.7273 Y-3.8538 N30905 X1.7167 Y-3.8588 N30910 X1.7059 Y-3.8629 N30915 X1.6947 Y-3.8661 N30920 X1.6832 Y-3.8687 N30925 X1.6715 Y-3.8707 N30930 X1.6597 Y-3.8722 N30935 X1.6355 Y-3.8741 N30940 X1.611 Y-3.8752 N30945 X1.5863 Y-3.8704 N30950 X1.5619 Y-3.8653 N30955 X1.5382 Y-3.8596 N30960 X1.5267 Y-3.8563 N30965 X1.5155 Y-3.8528 N30970 X1.5046 Y-3.849 N30975 X1.494 Y-3.8447 N30980 X1.4839 Y-3.8401 N30985 X1.4742 Y-3.835 N30990 X1.465 Y-3.8294 N30995 X1.4563 Y-3.8232 N31000 X1.4483 Y-3.8165 N31005 X1.4408 Y-3.8091 N31010 X1.4339 Y-3.8012 N31015 X1.4275 Y-3.7926 N31020 X1.4217 Y-3.7836 N31025 X1.4163 Y-3.774 N31030 X1.4114 Y-3.764 N31035 X1.4069 Y-3.7536 N31040 X1.4028 Y-3.7428 N31045 X1.399 Y-3.7317 N31050 X1.3922 Y-3.7086 N31055 X1.3864 Y-3.6846 N31060 X1.3811 Y-3.6599 N31065 X1.3761 Y-3.635 N31070 X1.4893 Y-3.6216 N31075 X1.4951 Y-3.6483 N31080 X1.4984 Y-3.6612 N31085 X1.5021 Y-3.6738 N31090 X1.5064 Y-3.6857 N31095 X1.5114 Y-3.6968 N31100 X1.5174 Y-3.7071 N31105 X1.5244 Y-3.7163 N31110 X1.5283 Y-3.7205 N31115 X1.5325 Y-3.7244 N31120 X1.5371 Y-3.7279 N31125 X1.5419 Y-3.7312 N31130 X1.5524 Y-3.7369 N31135 X1.5637 Y-3.7418 N31140 X1.5757 Y-3.7459 N31145 X1.5883 Y-3.7495 N31150 X1.6144 Y-3.7558 N31155 X1.6369 Y-3.7542 N31160 X1.6478 Y-3.7526 N31165 X1.6584 Y-3.7499 N31170 X1.6685 Y-3.7459 N31175 X1.6782 Y-3.7407 N31180 X1.6877 Y-3.7347 N31185 X1.697 Y-3.7283 N31190 X1.7097 Y-3.7136 N31195 X1.7151 Y-3.7059 N31200 X1.7195 Y-3.6977 N31205 X1.7226 Y-3.6889 N31210 X1.7247 Y-3.6796 N31215 X1.7271 Y-3.6603 N31220 X1.7264 Y-3.6497 N31225 X1.7257 Y-3.6444 N31230 X1.7247 Y-3.6393 N31235 X1.7232 Y-3.6343 N31240 X1.7212 Y-3.6294 N31245 X1.7166 Y-3.6198 N31250 X1.7099 Y-3.6114 N31255 X1.7063 Y-3.6074 N31260 X1.7025 Y-3.6038 N31265 X1.6939 Y-3.5977 N31270 X1.6846 Y-3.5923 N31275 X1.659 Y-3.5821 N31280 X1.6331 Y-3.5728 N31285 X1.6069 Y-3.5643 N31290 X1.5805 Y-3.5563 N31295 X1.552 Y-3.5472 N31300 X1.5379 Y-3.5421 N31305 X1.5242 Y-3.5365 N31310 X1.5108 Y-3.5302 N31315 X1.4977 Y-3.5231 N31320 X1.4721 Y-3.5077 N31325 X1.4555 Y-3.4927 N31330 X1.4478 Y-3.4849 N31335 X1.4406 Y-3.4765 N31340 X1.4341 Y-3.4676 N31345 X1.4282 Y-3.4582 N31350 X1.4174 Y-3.4387 N31355 X1.4088 Y-3.4166 N31360 X1.4051 Y-3.4054 N31365 X1.4021 Y-3.394 N31370 X1.4 Y-3.3824 N31375 Z0.1606 N31380 G0 Z0.2 N31385 X2.3173 Y-3.6382 N31390 Z0.1606 N31395 G1 Z-0.0394 F13.123 N31400 Y-3.1632 F39.37 N31405 X2.7108 N31410 Y-3.2816 N31415 X2.4329 N31420 Y-3.4473 N31425 X2.6735 N31430 Y-3.5657 N31435 X2.4329 N31440 Y-3.8632 N31445 X2.3173 N31450 Y-3.6382 N31455 Z0.1606 N31460 G0 Z0.2 N31465 X2.8834 Y-3.8632 N31470 Z0.1606 N31475 G1 Z-0.0394 F13.123 N31480 Y-3.1632 F39.37 N31485 X3.1274 N31490 X3.1616 Y-3.1636 N31495 X3.1785 Y-3.1644 N31500 X3.1953 Y-3.1661 N31505 X3.212 Y-3.1688 N31510 X3.2285 Y-3.1726 N31515 X3.2611 Y-3.1821 N31520 X3.2812 Y-3.1947 N31525 X3.2906 Y-3.2017 N31530 X3.2993 Y-3.2095 N31535 X3.307 Y-3.2181 N31540 X3.3141 Y-3.2275 N31545 X3.327 Y-3.2475 N31550 X3.3385 Y-3.2742 N31555 X3.3433 Y-3.2877 N31560 X3.3471 Y-3.3016 N31565 X3.3496 Y-3.3156 N31570 X3.3512 Y-3.33 N31575 X3.3528 Y-3.359 N31580 X3.3519 Y-3.3768 N31585 X3.3506 Y-3.3944 N31590 X3.3482 Y-3.4117 N31595 X3.3465 Y-3.4202 N31600 X3.3443 Y-3.4286 N31605 X3.3417 Y-3.4368 N31610 X3.3386 Y-3.4449 N31615 X3.3311 Y-3.4606 N31620 X3.3226 Y-3.476 N31625 X3.3134 Y-3.4913 N31630 X3.3017 Y-3.5031 N31635 X3.2896 Y-3.5144 N31640 X3.277 Y-3.5246 N31645 X3.2704 Y-3.5292 N31650 X3.2635 Y-3.5334 N31655 X3.2563 Y-3.537 N31660 X3.2489 Y-3.5403 N31665 X3.2336 Y-3.5457 N31670 X3.2176 Y-3.5502 N31675 X3.2015 Y-3.5543 N31680 X3.2183 Y-3.5674 N31685 X3.2265 Y-3.5742 N31690 X3.2344 Y-3.5813 N31695 X3.2419 Y-3.5888 N31700 X3.2491 Y-3.5966 N31705 X3.263 Y-3.6128 N31710 X3.2813 Y-3.6403 N31715 X3.2901 Y-3.6542 N31720 X3.2985 Y-3.6684 N31725 X3.3143 Y-3.6973 N31730 X3.3294 Y-3.7267 N31735 X3.3991 Y-3.8632 N31740 X3.2609 N31745 X3.177 Y-3.7109 N31750 X3.1626 Y-3.6845 N31755 X3.1478 Y-3.6583 N31760 X3.132 Y-3.6327 N31765 X3.1155 Y-3.6075 N31770 X3.1081 Y-3.5989 N31775 X3.1001 Y-3.591 N31780 X3.0957 Y-3.5876 N31785 X3.091 Y-3.5845 N31790 X3.0811 Y-3.5789 N31795 X3.0669 Y-3.5749 N31800 X3.0597 Y-3.5734 N31805 X3.0524 Y-3.5722 N31810 X3.0377 Y-3.5712 N31815 X3.0229 Y-3.571 N31820 X2.999 N31825 Y-3.8632 N31830 X2.8834 N31835 Z0.1606 N31840 G0 Z0.2 N31845 X2.999 Y-3.4593 N31850 Z0.1606 N31855 G1 Z-0.0394 F13.123 N31860 X3.0849 F39.37 N31865 X3.1102 Y-3.4594 N31870 X3.1353 Y-3.4586 N31875 X3.1479 Y-3.4577 N31880 X3.1603 Y-3.4562 N31885 X3.1852 Y-3.4523 N31890 X3.1957 Y-3.4475 N31895 X3.2006 Y-3.4448 N31900 X3.2051 Y-3.4415 N31905 X3.2093 Y-3.4378 N31910 X3.2131 Y-3.4335 N31915 X3.2201 Y-3.4244 N31920 X3.2262 Y-3.4111 N31925 X3.2288 Y-3.4044 N31930 X3.2307 Y-3.3975 N31935 X3.232 Y-3.3904 N31940 X3.2328 Y-3.3832 N31945 X3.2334 Y-3.3685 N31950 X3.2327 Y-3.3544 N31955 X3.232 Y-3.3475 N31960 X3.2307 Y-3.3407 N31965 X3.2287 Y-3.334 N31970 X3.2262 Y-3.3275 N31975 X3.2201 Y-3.3148 N31980 X3.2127 Y-3.3057 N31985 X3.2087 Y-3.3015 N31990 X3.2043 Y-3.2977 N31995 X3.1996 Y-3.2945 N32000 X3.1945 Y-3.2917 N32005 X3.1838 Y-3.2869 N32010 X3.1604 Y-3.2838 N32015 X3.1487 Y-3.2827 N32020 X3.1369 Y-3.2819 N32025 X3.1133 Y-3.2815 N32030 X3.0897 Y-3.2816 N32035 X2.999 N32040 Y-3.4593 N32045 Z0.1606 N32050 G0 Z0.2 N32055 X3.535 Y-3.4632 N32060 Z0.1606 N32065 G1 Z-0.0394 F13.123 N32070 Y-3.1632 F39.37 N32075 X3.6506 N32080 Y-3.8632 N32085 X3.535 N32090 Y-3.4632 N32095 Z0.1606 N32100 G0 Z0.2 N32105 X3.8385 Y-3.8632 N32110 Z0.1606 N32115 G1 Z-0.0394 F13.123 N32120 Y-3.1632 F39.37 N32125 X4.2644 N32130 Y-3.2816 N32135 X3.9541 N32140 Y-3.4368 N32145 X4.2425 N32150 Y-3.5548 N32155 X3.9541 N32160 Y-3.7448 N32165 X4.275 N32170 Y-3.8632 N32175 X3.8385 N32180 Z0.1606 N32185 G0 Z0.2 N32190 X4.4509 N32195 Z0.1606 N32200 G1 Z-0.0394 F13.123 N32205 Y-3.1632 F39.37 N32210 X4.5636 N32215 X4.7985 Y-3.6307 N32220 Y-3.1632 N32225 X4.9065 N32230 Y-3.8632 N32235 X4.79 N32240 X4.5589 Y-3.4067 N32245 Y-3.8632 N32250 X4.4509 N32255 Z0.1606 N32260 G0 Z0.2 N32265 X5.1044 N32270 Z0.1606 N32275 G1 Z-0.0394 F13.123 N32280 Y-3.1632 F39.37 N32285 X5.3157 N32290 X5.3466 Y-3.1638 N32295 X5.362 Y-3.1647 N32300 X5.3772 Y-3.1663 N32305 X5.3922 Y-3.1689 N32310 X5.4071 Y-3.1724 N32315 X5.4367 Y-3.1811 N32320 X5.458 Y-3.1931 N32325 X5.4682 Y-3.1996 N32330 X5.4778 Y-3.2068 N32335 X5.4869 Y-3.2148 N32340 X5.4955 Y-3.2233 N32345 X5.5118 Y-3.2415 N32350 X5.5291 Y-3.2672 N32355 X5.5371 Y-3.2804 N32360 X5.5443 Y-3.294 N32365 X5.5504 Y-3.308 N32370 X5.5559 Y-3.3224 N32375 X5.5657 Y-3.3518 N32380 X5.5747 Y-3.3935 N32385 X5.5784 Y-3.4144 N32390 X5.5813 Y-3.4354 N32395 X5.5831 Y-3.4565 N32400 X5.5843 Y-3.4778 N32405 X5.5853 Y-3.5204 N32410 X5.5841 Y-3.5604 N32415 X5.5828 Y-3.5803 N32420 X5.5808 Y-3.6001 N32425 X5.5778 Y-3.6197 N32430 X5.5739 Y-3.6393 N32435 X5.5648 Y-3.6782 N32440 X5.5551 Y-3.7064 N32445 X5.5497 Y-3.7203 N32450 X5.5437 Y-3.7338 N32455 X5.5369 Y-3.7469 N32460 X5.5293 Y-3.7596 N32465 X5.5128 Y-3.7844 N32470 X5.4962 Y-3.8023 N32475 X5.4875 Y-3.8108 N32480 X5.4783 Y-3.8185 N32485 X5.4685 Y-3.8255 N32490 X5.4581 Y-3.8318 N32495 X5.4367 Y-3.8434 N32500 X5.4088 Y-3.8525 N32505 X5.3946 Y-3.8563 N32510 X5.3804 Y-3.8592 N32515 X5.3659 Y-3.8611 N32520 X5.3514 Y-3.8622 N32525 X5.322 Y-3.8632 N32530 X5.1044 N32535 Z0.1606 N32540 G0 Z0.2 N32545 X5.22 Y-3.2816 N32550 Z0.1606 N32555 G1 Z-0.0394 F13.123 N32560 Y-3.7448 F39.37 N32565 X5.3069 N32570 X5.3275 Y-3.7446 N32575 X5.3377 Y-3.7441 N32580 X5.3479 Y-3.7432 N32585 X5.358 Y-3.7417 N32590 X5.368 Y-3.7396 N32595 X5.3878 Y-3.7343 N32600 X5.3996 Y-3.7283 N32605 X5.4052 Y-3.725 N32610 X5.4105 Y-3.7212 N32615 X5.4155 Y-3.717 N32620 X5.4201 Y-3.7124 N32625 X5.4289 Y-3.7026 N32630 X5.4379 Y-3.6868 N32635 X5.4419 Y-3.6787 N32640 X5.4454 Y-3.6704 N32645 X5.4484 Y-3.6619 N32650 X5.451 Y-3.6532 N32655 X5.4554 Y-3.6356 N32660 X5.4604 Y-3.6056 N32665 X5.4624 Y-3.5906 N32670 X5.4639 Y-3.5755 N32675 X5.4649 Y-3.5604 N32680 X5.4654 Y-3.5453 N32685 X5.4659 Y-3.5149 N32690 X5.4655 Y-3.484 N32695 X5.4649 Y-3.4686 N32700 X5.4639 Y-3.4533 N32705 X5.4624 Y-3.438 N32710 X5.4603 Y-3.4227 N32715 X5.4552 Y-3.3923 N32720 X5.4497 Y-3.3733 N32725 X5.4465 Y-3.364 N32730 X5.4427 Y-3.3549 N32735 X5.4382 Y-3.3463 N32740 X5.4331 Y-3.3379 N32745 X5.4217 Y-3.3217 N32750 X5.4098 Y-3.3103 N32755 X5.4035 Y-3.3051 N32760 X5.3968 Y-3.3005 N32765 X5.3897 Y-3.2966 N32770 X5.3822 Y-3.2933 N32775 X5.3666 Y-3.2878 N32780 X5.3432 Y-3.2845 N32785 X5.3315 Y-3.2832 N32790 X5.3197 Y-3.2824 N32795 X5.2961 Y-3.2816 N32800 X5.22 N32805 Z0.1606 N32810 G0 Z0.2 N32815 X5.2059 Y-2.4382 N32820 Z0.1606 N32825 G1 Z-0.0394 F13.123 N32830 X4.9544 F39.37 N32835 X4.9617 Y-2.4165 N32840 X4.978 N32845 X4.9922 Y-2.4156 N32850 X4.9992 Y-2.4147 N32855 X5.0061 Y-2.4132 N32860 X5.0126 Y-2.4109 N32865 X5.0191 Y-2.408 N32870 X5.0315 Y-2.4011 N32875 X5.0422 Y-2.3905 N32880 X5.047 Y-2.3849 N32885 X5.0513 Y-2.379 N32890 X5.055 Y-2.3726 N32895 X5.0581 Y-2.3659 N32900 X5.0637 Y-2.3519 N32905 X5.0761 Y-2.3256 N32910 X5.0814 Y-2.3131 N32915 X5.0861 Y-2.3004 N32920 X5.0985 Y-2.2641 N32925 X5.1098 Y-2.2292 N32930 X5.1208 Y-2.1943 N32935 X5.131 Y-2.1592 N32940 X5.1407 Y-2.1238 N32945 X5.1437 Y-2.1101 N32950 X5.1444 Y-2.1031 N32955 X5.1446 Y-2.096 N32960 X5.1439 Y-2.0918 N32965 X5.1428 Y-2.0877 N32970 X5.1407 Y-2.084 N32975 X5.1382 Y-2.0805 N32980 X5.1291 Y-2.0738 N32985 X5.1243 Y-2.0711 N32990 X5.1192 Y-2.0691 N32995 X5.1139 Y-2.0679 N33000 X5.1083 Y-2.0673 N33005 X5.0969 Y-2.0669 N33010 X5.0807 N33015 X5.0879 Y-2.0457 N33020 X5.3394 N33025 X5.3322 Y-2.0669 N33030 X5.3157 N33035 X5.3015 Y-2.0678 N33040 X5.2946 Y-2.0687 N33045 X5.2878 Y-2.0702 N33050 X5.2813 Y-2.0724 N33055 X5.2749 Y-2.0753 N33060 X5.2626 Y-2.0822 N33065 X5.252 Y-2.0926 N33070 X5.2472 Y-2.0981 N33075 X5.243 Y-2.104 N33080 X5.2394 Y-2.1103 N33085 X5.2363 Y-2.1169 N33090 X5.2308 Y-2.1307 N33095 X5.1553 Y-2.3527 N33100 X5.1515 Y-2.3649 N33105 X5.1501 Y-2.371 N33110 X5.1494 Y-2.377 N33115 X5.1495 Y-2.3831 N33120 X5.1506 Y-2.3891 N33125 X5.1542 Y-2.4011 N33130 X5.1633 Y-2.4087 N33135 X5.1681 Y-2.4118 N33140 X5.1733 Y-2.414 N33145 X5.1789 Y-2.4154 N33150 X5.1847 Y-2.4161 N33155 X5.1968 Y-2.4165 N33160 X5.2133 N33165 X5.2059 Y-2.4382 N33170 Z0.1606 N33175 G0 Z0.2 N33180 X4.9183 Y-2.4165 N33185 Z0.1606 N33190 G1 Z-0.0394 F13.123 N33195 X4.9109 Y-2.4382 F39.37 N33200 X4.6781 N33205 X4.6856 Y-2.4165 N33210 X4.72 N33215 X4.7276 Y-2.4164 N33220 X4.735 Y-2.4157 N33225 X4.7423 Y-2.4141 N33230 X4.7495 Y-2.4118 N33235 X4.7536 Y-2.4093 N33240 X4.7572 Y-2.4062 N33245 X4.76 Y-2.4024 N33250 X4.7621 Y-2.398 N33255 X4.7638 Y-2.3897 N33260 X4.7641 Y-2.3811 N33265 X4.7626 Y-2.3616 N33270 X4.7604 Y-2.3422 N33275 X4.7598 Y-2.3371 N33280 X4.7587 Y-2.3294 N33285 X4.7575 Y-2.3185 N33290 X4.6038 N33295 X4.5861 Y-2.3404 N33300 X4.5813 Y-2.3476 N33305 X4.5769 Y-2.355 N33310 X4.5731 Y-2.3627 N33315 X4.5697 Y-2.3707 N33320 X4.5683 Y-2.3762 N33325 X4.5675 Y-2.3817 N33330 X4.5676 Y-2.3873 N33335 X4.5683 Y-2.393 N33340 X4.5701 Y-2.3981 N33345 X4.5725 Y-2.4028 N33350 X4.576 Y-2.4068 N33355 X4.5801 Y-2.4104 N33360 X4.5844 Y-2.413 N33365 X4.589 Y-2.4147 N33370 X4.599 Y-2.4162 N33375 X4.6091 Y-2.4169 N33380 X4.6019 Y-2.4382 N33385 X4.4352 N33390 X4.4423 Y-2.4172 N33395 X4.4587 Y-2.4149 N33400 X4.4667 Y-2.4131 N33405 X4.4747 Y-2.4109 N33410 X4.4877 Y-2.4051 N33415 X4.5 Y-2.398 N33420 X4.5232 Y-2.38 N33425 X4.5343 Y-2.3704 N33430 X4.5448 Y-2.3603 N33435 X4.5548 Y-2.3497 N33440 X4.5644 Y-2.3386 N33445 X4.5829 Y-2.3157 N33450 X4.7998 Y-2.0382 N33455 X4.8173 N33460 X4.8568 Y-2.379 N33465 X4.8602 Y-2.3894 N33470 X4.8648 Y-2.3992 N33475 X4.8676 Y-2.4033 N33480 X4.8708 Y-2.407 N33485 X4.8746 Y-2.4099 N33490 X4.8789 Y-2.4125 N33495 X4.8846 Y-2.4144 N33500 X4.8904 Y-2.4157 N33505 X4.8964 Y-2.4163 N33510 X4.9024 Y-2.4165 N33515 X4.9183 N33520 Z0.1606 N33525 G0 Z0.2 N33530 X4.7405 Y-2.1387 N33535 Z0.1606 N33540 G1 Z-0.0394 F13.123 N33545 X4.6176 Y-2.2974 F39.37 N33550 X4.7573 N33555 X4.7405 Y-2.1387 N33560 Z0.1606 N33565 G0 Z0.2 N33570 X4.5343 Y-2.0669 N33575 Z0.1606 N33580 G1 Z-0.0394 F13.123 N33585 X4.5146 F39.37 N33590 X4.5004 Y-2.0678 N33595 X4.4934 Y-2.0687 N33600 X4.4866 Y-2.0703 N33605 X4.48 Y-2.0725 N33610 X4.4737 Y-2.0754 N33615 X4.4613 Y-2.0823 N33620 X4.4507 Y-2.0927 N33625 X4.4459 Y-2.0982 N33630 X4.4417 Y-2.104 N33635 X4.4381 Y-2.1103 N33640 X4.4349 Y-2.1169 N33645 X4.4294 Y-2.1307 N33650 X4.3539 Y-2.3527 N33655 X4.3501 Y-2.3649 N33660 X4.3487 Y-2.3709 N33665 X4.3481 Y-2.377 N33670 X4.3482 Y-2.383 N33675 X4.3493 Y-2.389 N33680 X4.353 Y-2.401 N33685 X4.3621 Y-2.4087 N33690 X4.367 Y-2.4117 N33695 X4.3722 Y-2.414 N33700 X4.3777 Y-2.4154 N33705 X4.3836 Y-2.4161 N33710 X4.3957 Y-2.4165 N33715 X4.4154 N33720 X4.408 Y-2.4382 N33725 X4.15 N33730 X4.1574 Y-2.4165 N33735 X4.1793 N33740 X4.1935 Y-2.4156 N33745 X4.2005 Y-2.4147 N33750 X4.2073 Y-2.4131 N33755 X4.2139 Y-2.4109 N33760 X4.2202 Y-2.408 N33765 X4.2326 Y-2.4011 N33770 X4.2431 Y-2.3907 N33775 X4.248 Y-2.3852 N33780 X4.2522 Y-2.3794 N33785 X4.2559 Y-2.3731 N33790 X4.259 Y-2.3665 N33795 X4.2645 Y-2.3527 N33800 X4.3509 Y-2.0988 N33805 X4.3591 N33810 X4.0798 Y-2.4382 N33815 X4.0633 N33820 X4.0126 Y-2.0999 N33825 X4.0209 N33830 X3.9391 Y-2.3404 N33835 X3.9361 Y-2.3505 N33840 X3.934 Y-2.3606 N33845 X3.9336 Y-2.3657 N33850 Y-2.3709 N33855 X3.9343 Y-2.3813 N33860 X3.9369 Y-2.389 N33865 X3.9386 Y-2.3927 N33870 X3.9406 Y-2.396 N33875 X3.9431 Y-2.399 N33880 X3.946 Y-2.4018 N33885 X3.9524 Y-2.4068 N33890 X3.9634 Y-2.4113 N33895 X3.969 Y-2.4132 N33900 X3.9747 Y-2.4146 N33905 X3.9864 Y-2.4162 N33910 X3.9983 Y-2.4168 N33915 X3.991 Y-2.4382 N33920 X3.8006 N33925 X3.808 Y-2.4165 N33930 X3.8174 N33935 X3.8337 Y-2.415 N33940 X3.8417 Y-2.4137 N33945 X3.8494 Y-2.4117 N33950 X3.8569 Y-2.4088 N33955 X3.8641 Y-2.4051 N33960 X3.8781 Y-2.3966 N33965 X3.8904 Y-2.385 N33970 X3.8961 Y-2.3788 N33975 X3.9012 Y-2.3722 N33980 X3.9056 Y-2.3652 N33985 X3.9094 Y-2.3577 N33990 X3.916 Y-2.3421 N33995 X3.9879 Y-2.1307 N34000 X3.9917 Y-2.1185 N34005 X3.9931 Y-2.1125 N34010 X3.9938 Y-2.1064 N34015 X3.9937 Y-2.1003 N34020 X3.9926 Y-2.0943 N34025 X3.9891 Y-2.0823 N34030 X3.9798 Y-2.0746 N34035 X3.9748 Y-2.0716 N34040 X3.9696 Y-2.0694 N34045 X3.9639 Y-2.068 N34050 X3.9581 Y-2.0673 N34055 X3.9459 Y-2.0669 N34060 X3.9269 N34065 X3.9341 Y-2.0457 N34070 X4.1027 N34075 X4.1434 Y-2.3376 N34080 X4.3817 Y-2.0457 N34085 X4.5415 N34090 X4.5343 Y-2.0669 N34095 Z0.1606 N34100 G0 Z0.2 N34105 X3.8265 Y-2.048 N34110 Z0.1606 N34115 G1 Z-0.0394 F13.123 N34120 X3.7696 Y-2.2236 F39.37 N34125 X3.7506 N34130 X3.7509 Y-2.1984 N34135 X3.7497 Y-2.1731 N34140 X3.7475 Y-2.159 N34145 X3.7437 Y-2.1451 N34150 X3.7357 Y-2.127 N34155 X3.7311 Y-2.1184 N34160 X3.7258 Y-2.1103 N34165 X3.7196 Y-2.1028 N34170 X3.7127 Y-2.0959 N34175 X3.6977 Y-2.083 N34180 X3.6804 Y-2.0736 N34185 X3.6716 Y-2.0696 N34190 X3.6625 Y-2.0664 N34195 X3.6532 Y-2.0641 N34200 X3.6435 Y-2.0627 N34205 X3.6239 Y-2.0611 N34210 X3.6125 Y-2.0618 N34215 X3.6012 Y-2.0632 N34220 X3.5901 Y-2.0657 N34225 X3.5791 Y-2.0689 N34230 X3.5683 Y-2.0729 N34235 X3.5577 Y-2.0775 N34240 X3.5478 Y-2.0832 N34245 X3.5381 Y-2.0895 N34250 X3.5231 Y-2.1027 N34255 X3.5159 Y-2.1097 N34260 X3.5092 Y-2.117 N34265 X3.503 Y-2.1247 N34270 X3.4972 Y-2.1328 N34275 X3.4862 Y-2.1496 N34280 X3.4733 Y-2.1741 N34285 X3.4671 Y-2.1865 N34290 X3.4614 Y-2.1991 N34295 X3.4512 Y-2.2248 N34300 X3.4418 Y-2.2508 N34305 X3.4359 Y-2.2694 N34310 X3.4307 Y-2.2883 N34315 X3.427 Y-2.304 N34320 X3.4241 Y-2.3199 N34325 X3.4224 Y-2.3336 N34330 X3.4215 Y-2.3474 N34335 Y-2.3589 N34340 X3.4229 Y-2.3703 N34345 X3.4269 Y-2.3819 N34350 X3.4297 Y-2.3873 N34355 X3.4329 Y-2.3926 N34360 X3.4368 Y-2.3977 N34365 X3.4411 Y-2.4024 N34370 X3.4459 Y-2.4065 N34375 X3.451 Y-2.4103 N34380 X3.4571 Y-2.4138 N34385 X3.4634 Y-2.417 N34390 X3.47 Y-2.4194 N34395 X3.4768 Y-2.4214 N34400 X3.4926 Y-2.4241 N34405 X3.5087 Y-2.4249 N34410 X3.5205 Y-2.4244 N34415 X3.5323 Y-2.4234 N34420 X3.5439 Y-2.4215 N34425 X3.5555 Y-2.4192 N34430 X3.5667 Y-2.4162 N34435 X3.5776 Y-2.4128 N34440 X3.5883 Y-2.4084 N34445 X3.5987 Y-2.4036 N34450 X3.611 Y-2.3949 N34455 X3.6166 Y-2.3902 N34460 X3.6217 Y-2.385 N34465 X3.626 Y-2.3792 N34470 X3.6297 Y-2.3729 N34475 X3.6362 Y-2.3594 N34480 X3.6429 Y-2.3398 N34485 X3.6456 Y-2.3263 N34490 X3.6467 Y-2.3198 N34495 X3.6474 Y-2.3135 N34500 X3.6476 Y-2.3076 N34505 X3.6471 Y-2.3021 N34510 X3.6459 Y-2.2971 N34515 X3.6438 Y-2.2928 N34520 X3.6408 Y-2.2891 N34525 X3.6368 Y-2.286 N34530 X3.632 Y-2.2835 N34535 X3.6266 Y-2.2814 N34540 X3.6206 Y-2.2798 N34545 X3.6142 Y-2.2783 N34550 X3.6008 Y-2.2759 N34555 X3.5622 N34560 X3.5694 Y-2.2548 N34565 X3.8417 N34570 X3.8345 Y-2.2759 N34575 X3.8199 N34580 X3.8057 Y-2.2769 N34585 X3.7988 Y-2.2778 N34590 X3.792 Y-2.2793 N34595 X3.7854 Y-2.2816 N34600 X3.779 Y-2.2845 N34605 X3.7666 Y-2.2914 N34610 X3.7561 Y-2.3017 N34615 X3.7513 Y-2.3072 N34620 X3.7471 Y-2.3131 N34625 X3.7434 Y-2.3194 N34630 X3.7403 Y-2.326 N34635 X3.7348 Y-2.3398 N34640 X3.7024 Y-2.4349 N34645 X3.6842 N34650 X3.6808 Y-2.4304 N34655 X3.6771 Y-2.4262 N34660 X3.6728 Y-2.4225 N34665 X3.6682 Y-2.4193 N34670 X3.6635 Y-2.4176 N34675 X3.6587 Y-2.4165 N34680 X3.6488 Y-2.4158 N34685 X3.6379 Y-2.4163 N34690 X3.6272 Y-2.418 N34695 X3.6116 Y-2.4223 N34700 X3.5963 Y-2.4277 N34705 X3.5699 Y-2.4357 N34710 X3.5431 Y-2.4422 N34715 X3.5318 Y-2.4439 N34720 X3.5205 Y-2.4452 N34725 X3.4977 Y-2.446 N34730 X3.4755 Y-2.4451 N34735 X3.4645 Y-2.4442 N34740 X3.4536 Y-2.4427 N34745 X3.4429 Y-2.4405 N34750 X3.4322 Y-2.4378 N34755 X3.411 Y-2.4313 N34760 X3.3942 Y-2.4234 N34765 X3.3861 Y-2.419 N34770 X3.3784 Y-2.4141 N34775 X3.3711 Y-2.4085 N34780 X3.3643 Y-2.4024 N34785 X3.3513 Y-2.3891 N34790 X3.3413 Y-2.3744 N34795 X3.3369 Y-2.3668 N34800 X3.3332 Y-2.3589 N34805 X3.3302 Y-2.3506 N34810 X3.3278 Y-2.3421 N34815 X3.3242 Y-2.3247 N34820 X3.3234 Y-2.3044 N34825 X3.3236 Y-2.2943 N34830 X3.3244 Y-2.2842 N34835 X3.3261 Y-2.2743 N34840 X3.3284 Y-2.2644 N34845 X3.3339 Y-2.2448 N34850 X3.339 Y-2.2316 N34855 X3.3446 Y-2.2186 N34860 X3.3511 Y-2.2061 N34865 X3.3581 Y-2.1938 N34870 X3.366 Y-2.1815 N34875 X3.3745 Y-2.1696 N34880 X3.3836 Y-2.1582 N34885 X3.3932 Y-2.1471 N34890 X3.4039 Y-2.1362 N34895 X3.415 Y-2.1257 N34900 X3.4266 Y-2.1158 N34905 X3.4386 Y-2.1062 N34910 X3.4531 Y-2.0961 N34915 X3.4679 Y-2.0866 N34920 X3.4833 Y-2.0779 N34925 X3.4991 Y-2.0698 N34930 X3.5145 Y-2.063 N34935 X3.5301 Y-2.0568 N34940 X3.5461 Y-2.0516 N34945 X3.5623 Y-2.0469 N34950 X3.5774 Y-2.0436 N34955 X3.5926 Y-2.0409 N34960 X3.6079 Y-2.0395 N34965 X3.6233 Y-2.0388 N34970 X3.6371 Y-2.0393 N34975 X3.6508 Y-2.0406 N34980 X3.6643 Y-2.043 N34985 X3.6778 Y-2.0462 N34990 X3.6915 Y-2.051 N34995 X3.7049 Y-2.0564 N35000 X3.7178 Y-2.0629 N35005 X3.7305 Y-2.0699 N35010 X3.737 Y-2.0739 N35015 X3.7437 Y-2.0773 N35020 X3.7507 Y-2.0798 N35025 X3.7581 Y-2.0816 N35030 X3.7632 Y-2.0808 N35035 X3.7681 Y-2.0794 N35040 X3.7727 Y-2.0772 N35045 X3.7771 Y-2.0746 N35050 X3.7852 Y-2.0685 N35055 X3.793 Y-2.062 N35060 X3.8077 Y-2.048 N35065 X3.8265 N35070 Z0.1606 N35075 G0 Z0.2 N35080 X3.2714 Y-2.1539 N35085 Z0.1606 N35090 G1 Z-0.0394 F13.123 N35095 X3.2733 Y-2.1772 F39.37 N35100 X3.2735 Y-2.1888 N35105 X3.2729 Y-2.2003 N35110 X3.2713 Y-2.2117 N35115 X3.2688 Y-2.2231 N35120 X3.2627 Y-2.2457 N35125 X3.2514 Y-2.273 N35130 X3.2452 Y-2.2863 N35135 X3.2383 Y-2.2992 N35140 X3.2305 Y-2.3116 N35145 X3.2221 Y-2.3236 N35150 X3.2041 Y-2.3471 N35155 X3.1854 Y-2.3671 N35160 X3.1757 Y-2.3766 N35165 X3.1655 Y-2.3856 N35170 X3.1547 Y-2.3939 N35175 X3.1435 Y-2.4015 N35180 X3.1201 Y-2.4158 N35185 X3.0994 Y-2.4249 N35190 X3.0888 Y-2.4289 N35195 X3.0781 Y-2.4322 N35200 X3.0672 Y-2.4346 N35205 X3.0561 Y-2.4362 N35210 X3.0335 Y-2.4382 N35215 X3.0225 Y-2.4377 N35220 X3.0172 Y-2.437 N35225 X3.0121 Y-2.4357 N35230 X3.0073 Y-2.4336 N35235 X3.0029 Y-2.4307 N35240 X2.9945 Y-2.4237 N35245 X2.9907 Y-2.4145 N35250 X2.9893 Y-2.4098 N35255 X2.9888 Y-2.4051 N35260 X2.9889 Y-2.4003 N35265 X2.9897 Y-2.3955 N35270 X2.9923 Y-2.3857 N35275 X2.9957 Y-2.3777 N35280 X2.9995 Y-2.3699 N35285 X3.0041 Y-2.3625 N35290 X3.009 Y-2.3553 N35295 X3. Y-2.3681 N35300 X2.9906 Y-2.3805 N35305 X2.9801 Y-2.3921 N35310 X2.969 Y-2.4031 N35315 X2.9591 Y-2.4109 N35320 X2.9489 Y-2.4182 N35325 X2.9382 Y-2.4248 N35330 X2.9272 Y-2.4308 N35335 X2.9195 Y-2.4338 N35340 X2.9116 Y-2.4362 N35345 X2.9035 Y-2.4375 N35350 X2.8953 Y-2.4382 N35355 X2.8861 Y-2.4371 N35360 X2.8818 Y-2.4361 N35365 X2.8779 Y-2.4344 N35370 X2.8744 Y-2.432 N35375 X2.8713 Y-2.4289 N35380 X2.8657 Y-2.4216 N35385 X2.8628 Y-2.4096 N35390 X2.8621 Y-2.4035 N35395 Y-2.3975 N35400 X2.8629 Y-2.3915 N35405 X2.8642 Y-2.3855 N35410 X2.8679 Y-2.3735 N35415 X2.8761 Y-2.3533 N35420 X2.8806 Y-2.3433 N35425 X2.8855 Y-2.3336 N35430 X2.8909 Y-2.3242 N35435 X2.8966 Y-2.315 N35440 X2.9088 Y-2.2968 N35445 X2.9229 Y-2.2788 N35450 X2.9377 Y-2.2614 N35455 X2.9456 Y-2.2532 N35460 X2.9538 Y-2.2453 N35465 X2.9707 Y-2.2299 N35470 X2.987 Y-2.2171 N35475 X3.0038 Y-2.205 N35480 X3.0214 Y-2.1943 N35485 X3.0396 Y-2.1844 N35490 X3.0486 Y-2.1804 N35495 X3.0578 Y-2.1771 N35500 X3.0674 Y-2.1751 N35505 X3.0772 Y-2.1741 N35510 X3.0844 Y-2.1746 N35515 X3.0878 Y-2.1753 N35520 X3.0911 Y-2.1763 N35525 X3.0941 Y-2.1779 N35530 X3.0969 Y-2.1799 N35535 X3.1022 Y-2.1848 N35540 X3.105 Y-2.1922 N35545 X3.1059 Y-2.196 N35550 X3.1062 Y-2.1998 N35555 X3.1059 Y-2.2036 N35560 X3.1051 Y-2.2075 N35565 X3.1028 Y-2.2152 N35570 X3.1163 Y-2.1838 N35575 X3.1913 Y-2.1813 N35580 X3.0842 Y-2.3534 N35585 X3.0727 Y-2.3724 N35590 X3.0678 Y-2.3823 N35595 X3.0633 Y-2.3925 N35600 X3.0625 Y-2.3953 N35605 X3.0623 Y-2.3981 N35610 X3.0629 Y-2.4008 N35615 X3.064 Y-2.4034 N35620 X3.066 Y-2.4055 N35625 X3.0682 Y-2.4069 N35630 X3.0709 Y-2.4076 N35635 X3.0737 Y-2.4079 N35640 X3.087 Y-2.4051 N35645 X3.0935 Y-2.4032 N35650 X3.0998 Y-2.4009 N35655 X3.112 Y-2.3949 N35660 X3.1238 Y-2.3881 N35665 X3.1419 Y-2.3758 N35670 X3.1507 Y-2.3693 N35675 X3.159 Y-2.3623 N35680 X3.167 Y-2.3548 N35685 X3.1746 Y-2.347 N35690 X3.1892 Y-2.3306 N35695 X3.2031 Y-2.312 N35700 X3.2097 Y-2.3024 N35705 X3.2157 Y-2.2926 N35710 X3.2212 Y-2.2824 N35715 X3.226 Y-2.2718 N35720 X3.2349 Y-2.2503 N35725 X3.2391 Y-2.2355 N35730 X3.2427 Y-2.2208 N35735 X3.2451 Y-2.2062 N35740 X3.2456 Y-2.1989 N35745 X3.2457 Y-2.1917 N35750 X3.2451 Y-2.1845 N35755 X3.2439 Y-2.1773 N35760 X3.2422 Y-2.1702 N35765 X3.2401 Y-2.1632 N35770 X3.2348 Y-2.1491 N35775 X3.2288 Y-2.1351 N35780 X3.2184 Y-2.1244 N35785 X3.2076 Y-2.1144 N35790 X3.202 Y-2.1099 N35795 X3.1962 Y-2.1058 N35800 X3.1901 Y-2.1022 N35805 X3.1838 Y-2.0992 N35810 X3.1772 Y-2.0968 N35815 X3.1703 Y-2.0949 N35820 X3.1561 Y-2.0923 N35825 X3.1413 Y-2.0909 N35830 X3.1263 Y-2.09 N35835 X3.0939 Y-2.0925 N35840 X3.078 Y-2.0946 N35845 X3.0622 Y-2.0977 N35850 X3.0468 Y-2.1021 N35855 X3.0316 Y-2.1074 N35860 X3.0015 Y-2.1196 N35865 X2.9707 Y-2.1372 N35870 X2.9558 Y-2.1467 N35875 X2.9416 Y-2.157 N35880 X2.9281 Y-2.1683 N35885 X2.9152 Y-2.1804 N35890 X2.8904 Y-2.2058 N35895 X2.8683 Y-2.2338 N35900 X2.858 Y-2.2482 N35905 X2.8485 Y-2.2631 N35910 X2.8401 Y-2.2785 N35915 X2.8325 Y-2.2945 N35920 X2.8187 Y-2.3274 N35925 X2.8134 Y-2.3459 N35930 X2.8089 Y-2.3644 N35935 X2.8071 Y-2.3737 N35940 X2.8058 Y-2.3829 N35945 X2.8051 Y-2.392 N35950 X2.805 Y-2.4011 N35955 X2.8056 Y-2.4101 N35960 X2.807 Y-2.4191 N35965 X2.8091 Y-2.4281 N35970 X2.8118 Y-2.437 N35975 X2.8183 Y-2.4547 N35980 X2.8257 Y-2.4724 N35985 X2.8383 Y-2.4856 N35990 X2.8514 Y-2.4979 N35995 X2.8581 Y-2.5035 N36000 X2.8652 Y-2.5086 N36005 X2.8725 Y-2.5131 N36010 X2.8802 Y-2.5168 N36015 X2.8882 Y-2.5199 N36020 X2.8965 Y-2.5223 N36025 X2.9051 Y-2.5242 N36030 X2.9138 Y-2.5256 N36035 X2.9319 Y-2.5275 N36040 X2.9502 Y-2.5287 N36045 X2.9689 Y-2.5273 N36050 X2.9876 Y-2.5254 N36055 X3.0059 Y-2.5226 N36060 X3.0239 Y-2.5185 N36065 X3.0416 Y-2.5128 N36070 X3.0588 Y-2.5059 N36075 X3.0759 Y-2.4982 N36080 X3.0928 Y-2.49 N36085 X3.1098 Y-2.4792 N36090 X3.1266 Y-2.468 N36095 X3.1427 Y-2.4563 N36100 X3.1581 Y-2.4436 N36105 X3.1724 Y-2.4297 N36110 X3.1858 Y-2.4149 N36115 X3.1987 Y-2.3994 N36120 X3.2113 Y-2.3837 N36125 X3.2374 N36130 X3.2228 Y-2.4026 N36135 X3.2078 Y-2.4211 N36140 X3.1922 Y-2.439 N36145 X3.184 Y-2.4476 N36150 X3.1756 Y-2.4558 N36155 X3.1669 Y-2.4637 N36160 X3.1578 Y-2.4713 N36165 X3.1389 Y-2.4856 N36170 X3.1193 Y-2.4991 N36175 X3.0994 Y-2.5123 N36180 X3.0806 Y-2.5213 N36185 X3.0616 Y-2.5299 N36190 X3.0424 Y-2.5375 N36195 X3.0327 Y-2.5408 N36200 X3.0229 Y-2.5436 N36205 X3.0129 Y-2.5461 N36210 X3.0029 Y-2.5481 N36215 X2.9825 Y-2.5511 N36220 X2.9618 Y-2.5531 N36225 X2.941 Y-2.5546 N36230 X2.9192 Y-2.5532 N36235 X2.8977 Y-2.5509 N36240 X2.8873 Y-2.5492 N36245 X2.8771 Y-2.5469 N36250 X2.8672 Y-2.5441 N36255 X2.8576 Y-2.5404 N36260 X2.8485 Y-2.536 N36265 X2.8398 Y-2.5307 N36270 X2.8314 Y-2.5246 N36275 X2.8233 Y-2.518 N36280 X2.8154 Y-2.5108 N36285 X2.8077 Y-2.5033 N36290 X2.7926 Y-2.4876 N36295 X2.7837 Y-2.467 N36300 X2.7758 Y-2.4464 N36305 X2.7726 Y-2.436 N36310 X2.77 Y-2.4255 N36315 X2.7683 Y-2.415 N36320 X2.7674 Y-2.4044 N36325 Y-2.3938 N36330 X2.7682 Y-2.3831 N36335 X2.7696 Y-2.3723 N36340 X2.7716 Y-2.3615 N36345 X2.7768 Y-2.3398 N36350 X2.7829 Y-2.3181 N36355 X2.7978 Y-2.2826 N36360 X2.8061 Y-2.2654 N36365 X2.8153 Y-2.2487 N36370 X2.8256 Y-2.2327 N36375 X2.8369 Y-2.2172 N36380 X2.8609 Y-2.1872 N36385 X2.889 Y-2.1595 N36390 X2.9035 Y-2.1465 N36395 X2.9188 Y-2.1343 N36400 X2.9349 Y-2.1233 N36405 X2.9517 Y-2.1132 N36410 X2.9864 Y-2.0946 N36415 X3.0211 Y-2.0812 N36420 X3.0387 Y-2.0754 N36425 X3.0565 Y-2.0706 N36430 X3.0746 Y-2.0672 N36435 X3.0929 Y-2.0649 N36440 X3.13 Y-2.0622 N36445 X3.1554 Y-2.0635 N36450 X3.168 Y-2.0649 N36455 X3.1802 Y-2.0672 N36460 X3.1922 Y-2.0707 N36465 X3.2039 Y-2.0753 N36470 X3.2268 Y-2.0863 N36475 X3.2351 Y-2.093 N36480 X3.243 Y-2.0999 N36485 X3.2502 Y-2.1072 N36490 X3.2564 Y-2.1152 N36495 X3.2614 Y-2.1241 N36500 X3.2653 Y-2.1337 N36505 X3.2685 Y-2.1437 N36510 X3.2714 Y-2.1539 N36515 Z0.1606 N36520 G0 Z0.2 N36525 X3.0782 Y-2.2067 N36530 Z0.1606 N36535 G1 Z-0.0394 F13.123 N36540 X3.0766 Y-2.2053 F39.37 N36545 X3.0745 Y-2.2044 N36550 X3.0709 Y-2.205 N36555 X3.0674 Y-2.206 N36560 X3.061 Y-2.2093 N36565 X3.053 Y-2.2157 N36570 X3.0455 Y-2.2225 N36575 X3.0315 Y-2.2373 N36580 X3.0192 Y-2.2518 N36585 X3.0073 Y-2.2667 N36590 X2.996 Y-2.2821 N36595 X2.9852 Y-2.2978 N36600 X2.9755 Y-2.3126 N36605 X2.9665 Y-2.3277 N36610 X2.9586 Y-2.3435 N36615 X2.9516 Y-2.3597 N36620 X2.9496 Y-2.3671 N36625 X2.9495 Y-2.3708 N36630 X2.95 Y-2.3746 N36635 X2.9518 Y-2.3775 N36640 X2.9532 Y-2.3784 N36645 X2.9548 Y-2.3789 N36650 X2.962 Y-2.3766 N36655 X2.969 Y-2.3737 N36660 X2.9821 Y-2.3661 N36665 X2.9965 Y-2.3521 N36670 X3.0102 Y-2.3375 N36675 X3.0231 Y-2.3221 N36680 X3.0354 Y-2.3062 N36685 X3.0477 Y-2.2892 N36690 X3.0535 Y-2.2805 N36695 X3.0589 Y-2.2717 N36700 X3.0639 Y-2.2625 N36705 X3.0685 Y-2.2531 N36710 X3.0768 Y-2.234 N36715 X3.0787 Y-2.2283 N36720 X3.0801 Y-2.2226 N36725 X3.0805 Y-2.2168 N36730 X3.0801 Y-2.2109 N36735 X3.0793 Y-2.2086 N36740 X3.0782 Y-2.2067 N36745 Z0.1606 N36750 G0 Z0.2 N36755 X2.8608 Y-2.0669 N36760 Z0.1606 N36765 G1 Z-0.0394 F13.123 N36770 X2.8512 F39.37 N36775 X2.833 Y-2.0688 N36780 X2.8241 Y-2.0704 N36785 X2.8156 Y-2.0729 N36790 X2.8075 Y-2.0765 N36795 X2.7997 Y-2.0809 N36800 X2.7846 Y-2.0913 N36805 X2.77 Y-2.1073 N36810 X2.7634 Y-2.1156 N36815 X2.7575 Y-2.1245 N36820 X2.7524 Y-2.1338 N36825 X2.7479 Y-2.1436 N36830 X2.7399 Y-2.1637 N36835 X2.6452 Y-2.4421 N36840 X2.6281 N36845 X2.4221 Y-2.1037 N36850 X2.3469 Y-2.3248 N36855 X2.343 Y-2.3372 N36860 X2.3397 Y-2.3497 N36865 X2.3379 Y-2.3624 N36870 X2.3371 Y-2.3754 N36875 X2.3387 Y-2.3842 N36880 X2.3399 Y-2.3884 N36885 X2.3416 Y-2.3924 N36890 X2.3438 Y-2.3961 N36895 X2.3465 Y-2.3996 N36900 X2.3527 Y-2.4061 N36905 X2.3594 Y-2.4094 N36910 X2.3663 Y-2.4119 N36915 X2.3735 Y-2.4134 N36920 X2.3809 Y-2.4145 N36925 X2.3988 Y-2.4164 N36930 X2.4169 Y-2.4173 N36935 X2.4097 Y-2.4382 N36940 X2.1994 N36945 X2.2065 Y-2.4174 N36950 X2.2208 Y-2.4163 N36955 X2.235 Y-2.4145 N36960 X2.2489 Y-2.4112 N36965 X2.2626 Y-2.407 N36970 X2.2724 Y-2.4022 N36975 X2.2817 Y-2.3966 N36980 X2.2899 Y-2.3896 N36985 X2.2976 Y-2.3818 N36990 X2.3047 Y-2.3721 N36995 X2.311 Y-2.3619 N37000 X2.316 Y-2.3511 N37005 X2.3204 Y-2.3398 N37010 X2.3938 Y-2.1241 N37015 X2.396 Y-2.1165 N37020 X2.3974 Y-2.1089 N37025 X2.3973 Y-2.1011 N37030 X2.3962 Y-2.0933 N37035 X2.3934 Y-2.0872 N37040 X2.3898 Y-2.0818 N37045 X2.3848 Y-2.0775 N37050 X2.3791 Y-2.0739 N37055 X2.3704 Y-2.0706 N37060 X2.3615 Y-2.0683 N37065 X2.3523 Y-2.0672 N37070 X2.343 Y-2.0669 N37075 X2.3325 N37080 X2.3397 Y-2.0457 N37085 X2.5009 N37090 X2.6646 Y-2.3205 N37095 X2.7187 Y-2.1616 N37100 X2.7223 Y-2.1494 N37105 X2.7251 Y-2.137 N37110 X2.7258 Y-2.1307 N37115 X2.7261 Y-2.1244 N37120 X2.726 Y-2.1116 N37125 X2.7238 Y-2.102 N37130 X2.7223 Y-2.0974 N37135 X2.7204 Y-2.093 N37140 X2.7178 Y-2.0891 N37145 X2.7147 Y-2.0853 N37150 X2.7077 Y-2.0784 N37155 X2.7005 Y-2.0738 N37160 X2.6925 Y-2.0708 N37165 X2.6768 Y-2.068 N37170 X2.6608 Y-2.0665 N37175 X2.6679 Y-2.0457 N37180 X2.868 N37185 X2.8608 Y-2.0669 N37190 Z0.1606 N37195 G0 Z0.2 N37200 X2.2226 Y-2.048 N37205 Z0.1606 N37210 G1 Z-0.0394 F13.123 N37215 X2.1657 Y-2.2236 F39.37 N37220 X2.1467 N37225 X2.147 Y-2.1984 N37230 X2.1458 Y-2.1731 N37235 X2.1436 Y-2.159 N37240 X2.1398 Y-2.1451 N37245 X2.1318 Y-2.127 N37250 X2.1272 Y-2.1184 N37255 X2.1219 Y-2.1103 N37260 X2.1157 Y-2.1028 N37265 X2.1088 Y-2.0959 N37270 X2.0938 Y-2.083 N37275 X2.0765 Y-2.0736 N37280 X2.0677 Y-2.0696 N37285 X2.0586 Y-2.0664 N37290 X2.0493 Y-2.0641 N37295 X2.0396 Y-2.0627 N37300 X2.02 Y-2.0611 N37305 X2.0086 Y-2.0618 N37310 X1.9973 Y-2.0632 N37315 X1.9862 Y-2.0657 N37320 X1.9752 Y-2.0689 N37325 X1.9644 Y-2.0729 N37330 X1.9539 Y-2.0775 N37335 X1.9439 Y-2.0832 N37340 X1.9342 Y-2.0895 N37345 X1.9192 Y-2.1027 N37350 X1.912 Y-2.1097 N37355 X1.9053 Y-2.117 N37360 X1.8991 Y-2.1247 N37365 X1.8933 Y-2.1328 N37370 X1.8823 Y-2.1496 N37375 X1.8694 Y-2.1741 N37380 X1.8632 Y-2.1865 N37385 X1.8575 Y-2.1991 N37390 X1.8473 Y-2.2248 N37395 X1.8379 Y-2.2508 N37400 X1.832 Y-2.2694 N37405 X1.8268 Y-2.2883 N37410 X1.8231 Y-2.304 N37415 X1.8202 Y-2.3199 N37420 X1.8185 Y-2.3336 N37425 X1.8176 Y-2.3474 N37430 Y-2.3589 N37435 X1.819 Y-2.3703 N37440 X1.823 Y-2.3819 N37445 X1.8258 Y-2.3873 N37450 X1.829 Y-2.3926 N37455 X1.8329 Y-2.3977 N37460 X1.8372 Y-2.4024 N37465 X1.842 Y-2.4065 N37470 X1.8471 Y-2.4103 N37475 X1.8532 Y-2.4138 N37480 X1.8595 Y-2.417 N37485 X1.8661 Y-2.4194 N37490 X1.8729 Y-2.4214 N37495 X1.8887 Y-2.4241 N37500 X1.9048 Y-2.4249 N37505 X1.9166 Y-2.4244 N37510 X1.9284 Y-2.4234 N37515 X1.94 Y-2.4215 N37520 X1.9516 Y-2.4192 N37525 X1.9628 Y-2.4162 N37530 X1.9737 Y-2.4128 N37535 X1.9844 Y-2.4084 N37540 X1.9948 Y-2.4036 N37545 X2.0071 Y-2.3949 N37550 X2.0127 Y-2.3902 N37555 X2.0178 Y-2.385 N37560 X2.0221 Y-2.3792 N37565 X2.0258 Y-2.3729 N37570 X2.0323 Y-2.3594 N37575 X2.039 Y-2.3398 N37580 X2.0417 Y-2.3263 N37585 X2.0428 Y-2.3198 N37590 X2.0435 Y-2.3135 N37595 X2.0437 Y-2.3076 N37600 X2.0432 Y-2.3021 N37605 X2.042 Y-2.2971 N37610 X2.0399 Y-2.2928 N37615 X2.0369 Y-2.2891 N37620 X2.0329 Y-2.286 N37625 X2.0281 Y-2.2835 N37630 X2.0227 Y-2.2814 N37635 X2.0167 Y-2.2798 N37640 X2.0103 Y-2.2783 N37645 X1.9969 Y-2.2759 N37650 X1.9583 N37655 X1.9655 Y-2.2548 N37660 X2.2378 N37665 X2.2306 Y-2.2759 N37670 X2.216 N37675 X2.2018 Y-2.2769 N37680 X2.1949 Y-2.2778 N37685 X2.1881 Y-2.2793 N37690 X2.1815 Y-2.2816 N37695 X2.1751 Y-2.2845 N37700 X2.1627 Y-2.2914 N37705 X2.1522 Y-2.3017 N37710 X2.1474 Y-2.3072 N37715 X2.1432 Y-2.3131 N37720 X2.1395 Y-2.3194 N37725 X2.1364 Y-2.326 N37730 X2.1309 Y-2.3398 N37735 X2.0985 Y-2.4349 N37740 X2.0803 N37745 X2.0769 Y-2.4304 N37750 X2.0732 Y-2.4262 N37755 X2.0689 Y-2.4225 N37760 X2.0643 Y-2.4193 N37765 X2.0596 Y-2.4176 N37770 X2.0548 Y-2.4165 N37775 X2.0449 Y-2.4158 N37780 X2.034 Y-2.4163 N37785 X2.0233 Y-2.418 N37790 X2.0077 Y-2.4223 N37795 X1.9924 Y-2.4277 N37800 X1.966 Y-2.4357 N37805 X1.9392 Y-2.4422 N37810 X1.9279 Y-2.4439 N37815 X1.9166 Y-2.4452 N37820 X1.8938 Y-2.446 N37825 X1.8716 Y-2.4451 N37830 X1.8606 Y-2.4442 N37835 X1.8497 Y-2.4427 N37840 X1.839 Y-2.4405 N37845 X1.8283 Y-2.4378 N37850 X1.8071 Y-2.4313 N37855 X1.7903 Y-2.4234 N37860 X1.7822 Y-2.419 N37865 X1.7745 Y-2.4141 N37870 X1.7672 Y-2.4085 N37875 X1.7604 Y-2.4024 N37880 X1.7474 Y-2.3891 N37885 X1.7374 Y-2.3744 N37890 X1.733 Y-2.3668 N37895 X1.7293 Y-2.3589 N37900 X1.7263 Y-2.3506 N37905 X1.7239 Y-2.3421 N37910 X1.7203 Y-2.3247 N37915 X1.7195 Y-2.3044 N37920 X1.7197 Y-2.2943 N37925 X1.7206 Y-2.2842 N37930 X1.7222 Y-2.2743 N37935 X1.7245 Y-2.2644 N37940 X1.73 Y-2.2448 N37945 X1.7351 Y-2.2316 N37950 X1.7407 Y-2.2186 N37955 X1.7472 Y-2.2061 N37960 X1.7542 Y-2.1938 N37965 X1.7621 Y-2.1815 N37970 X1.7706 Y-2.1696 N37975 X1.7797 Y-2.1582 N37980 X1.7893 Y-2.1471 N37985 X1.8 Y-2.1362 N37990 X1.8111 Y-2.1257 N37995 X1.8227 Y-2.1158 N38000 X1.8347 Y-2.1062 N38005 X1.8492 Y-2.0961 N38010 X1.864 Y-2.0866 N38015 X1.8794 Y-2.0779 N38020 X1.8952 Y-2.0698 N38025 X1.9106 Y-2.063 N38030 X1.9262 Y-2.0568 N38035 X1.9422 Y-2.0516 N38040 X1.9584 Y-2.0469 N38045 X1.9735 Y-2.0436 N38050 X1.9887 Y-2.0409 N38055 X2.004 Y-2.0395 N38060 X2.0194 Y-2.0388 N38065 X2.0332 Y-2.0393 N38070 X2.0469 Y-2.0406 N38075 X2.0604 Y-2.043 N38080 X2.0739 Y-2.0462 N38085 X2.0876 Y-2.051 N38090 X2.101 Y-2.0564 N38095 X2.1139 Y-2.0629 N38100 X2.1266 Y-2.0699 N38105 X2.1331 Y-2.0739 N38110 X2.1398 Y-2.0773 N38115 X2.1468 Y-2.0798 N38120 X2.1542 Y-2.0816 N38125 X2.1593 Y-2.0808 N38130 X2.1642 Y-2.0794 N38135 X2.1688 Y-2.0772 N38140 X2.1732 Y-2.0746 N38145 X2.1813 Y-2.0685 N38150 X2.1891 Y-2.062 N38155 X2.2038 Y-2.048 N38160 X2.2226 N38165 Z0.1606 N38170 G0 Z0.2 N38175 X1.7271 Y-2.0457 N38180 Z0.1606 N38185 G1 Z-0.0394 F13.123 N38190 X1.7199 Y-2.0669 F39.37 N38195 X1.7034 N38200 X1.6893 Y-2.0678 N38205 X1.6823 Y-2.0687 N38210 X1.6756 Y-2.0702 N38215 X1.669 Y-2.0724 N38220 X1.6627 Y-2.0753 N38225 X1.6503 Y-2.0822 N38230 X1.6398 Y-2.0926 N38235 X1.635 Y-2.0981 N38240 X1.6308 Y-2.104 N38245 X1.6272 Y-2.1103 N38250 X1.624 Y-2.1169 N38255 X1.6185 Y-2.1307 N38260 X1.543 Y-2.3527 N38265 X1.5392 Y-2.3649 N38270 X1.5378 Y-2.371 N38275 X1.5371 Y-2.377 N38280 X1.5373 Y-2.3831 N38285 X1.5383 Y-2.3891 N38290 X1.5419 Y-2.4011 N38295 X1.551 Y-2.4087 N38300 X1.5559 Y-2.4118 N38305 X1.5611 Y-2.414 N38310 X1.5667 Y-2.4154 N38315 X1.5725 Y-2.4161 N38320 X1.5845 Y-2.4165 N38325 X1.601 N38330 X1.5936 Y-2.4382 N38335 X1.3421 N38340 X1.3495 Y-2.4165 N38345 X1.3657 N38350 X1.38 Y-2.4156 N38355 X1.387 Y-2.4147 N38360 X1.3938 Y-2.4132 N38365 X1.4004 Y-2.4109 N38370 X1.4068 Y-2.408 N38375 X1.4193 Y-2.4011 N38380 X1.4299 Y-2.3905 N38385 X1.4348 Y-2.3849 N38390 X1.439 Y-2.379 N38395 X1.4427 Y-2.3726 N38400 X1.4459 Y-2.3659 N38405 X1.4514 Y-2.3519 N38410 X1.4639 Y-2.3256 N38415 X1.4691 Y-2.3131 N38420 X1.4739 Y-2.3004 N38425 X1.4862 Y-2.2641 N38430 X1.4976 Y-2.2292 N38435 X1.5085 Y-2.1943 N38440 X1.5188 Y-2.1592 N38445 X1.5285 Y-2.1238 N38450 X1.5315 Y-2.1101 N38455 X1.5321 Y-2.1031 N38460 X1.5323 Y-2.096 N38465 X1.5317 Y-2.0918 N38470 X1.5305 Y-2.0877 N38475 X1.5285 Y-2.084 N38480 X1.526 Y-2.0805 N38485 X1.5169 Y-2.0738 N38490 X1.5121 Y-2.0711 N38495 X1.507 Y-2.0691 N38500 X1.5016 Y-2.0679 N38505 X1.4961 Y-2.0673 N38510 X1.4846 Y-2.0669 N38515 X1.4684 N38520 X1.4756 Y-2.0457 N38525 X1.7271 N38530 Z0.1606 N38535 G0 Z0.2 N38540 X1.3005 Y-2.376 N38545 Z0.1606 N38550 G1 Z-0.0394 F13.123 N38555 X1.2911 Y-2.386 F39.37 N38560 X1.2807 Y-2.395 N38565 X1.2698 Y-2.4036 N38570 X1.2556 Y-2.4131 N38575 X1.2483 Y-2.4176 N38580 X1.2408 Y-2.4217 N38585 X1.2331 Y-2.4253 N38590 X1.2252 Y-2.4286 N38595 X1.209 Y-2.4345 N38600 X1.191 Y-2.4391 N38605 X1.1819 Y-2.4411 N38610 X1.1728 Y-2.4426 N38615 X1.1543 Y-2.4444 N38620 X1.1357 Y-2.4452 N38625 X1.1233 Y-2.4449 N38630 X1.1109 Y-2.444 N38635 X1.0987 Y-2.4422 N38640 X1.0865 Y-2.4398 N38645 X1.0739 Y-2.436 N38650 X1.0615 Y-2.4315 N38655 X1.0495 Y-2.4262 N38660 X1.0377 Y-2.4204 N38665 X1.0224 Y-2.414 N38670 X1.0068 Y-2.4084 N38675 X0.9974 Y-2.4062 N38680 X0.9877 Y-2.4054 N38685 X0.9792 Y-2.4061 N38690 X0.9709 Y-2.4077 N38695 X0.963 Y-2.4107 N38700 X0.9554 Y-2.4145 N38705 X0.9473 Y-2.4208 N38710 X0.9399 Y-2.4278 N38715 X0.9338 Y-2.4359 N38720 X0.9283 Y-2.4446 N38725 X0.9085 N38730 X0.9723 Y-2.2571 N38735 X0.9925 N38740 X0.9893 Y-2.2794 N38745 X0.9885 Y-2.2904 N38750 X0.9887 Y-2.3014 N38755 X0.9902 Y-2.3123 N38760 X0.9928 Y-2.323 N38765 X1. Y-2.3443 N38770 X1.0072 Y-2.3557 N38775 X1.0152 Y-2.3664 N38780 X1.0245 Y-2.3761 N38785 X1.0346 Y-2.3851 N38790 X1.0466 Y-2.3939 N38795 X1.0591 Y-2.4018 N38800 X1.0724 Y-2.4084 N38805 X1.0862 Y-2.4142 N38810 X1.1003 Y-2.4186 N38815 X1.1145 Y-2.4219 N38820 X1.1291 Y-2.4237 N38825 X1.1438 Y-2.4246 N38830 X1.1563 Y-2.424 N38835 X1.1686 Y-2.4226 N38840 X1.1808 Y-2.4198 N38845 X1.1928 Y-2.4163 N38850 X1.2034 Y-2.412 N38855 X1.2137 Y-2.407 N38860 X1.2233 Y-2.4008 N38865 X1.2324 Y-2.3938 N38870 X1.2394 Y-2.3868 N38875 X1.2456 Y-2.3793 N38880 X1.2505 Y-2.3708 N38885 X1.2545 Y-2.3618 N38890 X1.2564 Y-2.3532 N38895 X1.2569 Y-2.3489 N38900 X1.2568 Y-2.3447 N38905 X1.256 Y-2.3406 N38910 X1.2546 Y-2.3365 N38915 X1.2509 Y-2.3285 N38920 X1.2444 Y-2.3213 N38925 X1.2366 Y-2.3156 N38930 X1.2237 Y-2.3087 N38935 X1.2102 Y-2.3031 N38940 X1.1869 Y-2.295 N38945 X1.1632 Y-2.2877 N38950 X1.1384 Y-2.2803 N38955 X1.1188 Y-2.2745 N38960 X1.0992 Y-2.2683 N38965 X1.0799 Y-2.2613 N38970 X1.0609 Y-2.2537 N38975 X1.0505 Y-2.2494 N38980 X1.0404 Y-2.2446 N38985 X1.0308 Y-2.2389 N38990 X1.0215 Y-2.2326 N38995 X1.0156 Y-2.2269 N39000 X1.0103 Y-2.2209 N39005 X1.0061 Y-2.214 N39010 X1.0025 Y-2.2067 N39015 X0.9988 Y-2.1936 N39020 X0.9975 Y-2.1871 N39025 X0.997 Y-2.1806 N39030 X0.9973 Y-2.174 N39035 X0.9984 Y-2.1674 N39040 X1.0016 Y-2.1542 N39045 X1.009 Y-2.1374 N39050 X1.0131 Y-2.1294 N39055 X1.0179 Y-2.1216 N39060 X1.0232 Y-2.1144 N39065 X1.0291 Y-2.1074 N39070 X1.0418 Y-2.0942 N39075 X1.0576 Y-2.0815 N39080 X1.0658 Y-2.0756 N39085 X1.0742 Y-2.0701 N39090 X1.083 Y-2.0653 N39095 X1.0921 Y-2.0609 N39100 X1.1107 Y-2.0529 N39105 X1.1309 Y-2.0467 N39110 X1.141 Y-2.0441 N39115 X1.1513 Y-2.0419 N39120 X1.1616 Y-2.0404 N39125 X1.1721 Y-2.0394 N39130 X1.1931 Y-2.0382 N39135 X1.2088 Y-2.0394 N39140 X1.2243 Y-2.041 N39145 X1.2396 Y-2.0434 N39150 X1.2546 Y-2.047 N39155 X1.2691 Y-2.052 N39160 X1.2832 Y-2.0583 N39165 X1.2972 Y-2.0654 N39170 X1.311 Y-2.0729 N39175 X1.3175 Y-2.0767 N39180 X1.3241 Y-2.0801 N39185 X1.3311 Y-2.0827 N39190 X1.3384 Y-2.0846 N39195 X1.3502 Y-2.0801 N39200 X1.3556 Y-2.0772 N39205 X1.3603 Y-2.0735 N39210 X1.3646 Y-2.069 N39215 X1.3684 Y-2.0641 N39220 X1.3754 Y-2.0533 N39225 X1.395 N39230 X1.3468 Y-2.1949 N39235 X1.3275 N39240 X1.3266 Y-2.1755 N39245 X1.3257 Y-2.1658 N39250 X1.3244 Y-2.1562 N39255 X1.3224 Y-2.1468 N39260 X1.3198 Y-2.1374 N39265 X1.3136 Y-2.119 N39270 X1.308 Y-2.1102 N39275 X1.3016 Y-2.102 N39280 X1.2942 Y-2.0947 N39285 X1.286 Y-2.0881 N39290 X1.2755 Y-2.0814 N39295 X1.2646 Y-2.0754 N39300 X1.2531 Y-2.0707 N39305 X1.2412 Y-2.0666 N39310 X1.2275 Y-2.0633 N39315 X1.2137 Y-2.0607 N39320 X1.1997 Y-2.0594 N39325 X1.1856 Y-2.0588 N39330 X1.1754 Y-2.0592 N39335 X1.1653 Y-2.0602 N39340 X1.1553 Y-2.0622 N39345 X1.1454 Y-2.0647 N39350 X1.1364 Y-2.0681 N39355 X1.1277 Y-2.0719 N39360 X1.1194 Y-2.0767 N39365 X1.1114 Y-2.082 N39370 X1.1015 Y-2.0904 N39375 X1.0926 Y-2.0998 N39380 X1.0863 Y-2.1087 N39385 X1.0816 Y-2.1186 N39390 X1.0799 Y-2.1266 N39395 X1.0796 Y-2.1305 N39400 X1.0797 Y-2.1344 N39405 X1.0806 Y-2.1382 N39410 X1.082 Y-2.1419 N39415 X1.0857 Y-2.1491 N39420 X1.0917 Y-2.1551 N39425 X1.0988 Y-2.1598 N39430 X1.1123 Y-2.1664 N39435 X1.1264 Y-2.1716 N39440 X1.1516 Y-2.1792 N39445 X1.177 Y-2.1862 N39450 X1.1831 Y-2.1881 N39455 X1.1892 Y-2.1897 N39460 X1.1946 Y-2.1928 N39465 X1.2209 Y-2.1986 N39470 X1.2392 Y-2.2038 N39475 X1.2574 Y-2.2096 N39480 X1.2752 Y-2.2163 N39485 X1.2927 Y-2.2236 N39490 X1.3028 Y-2.2297 N39495 X1.3076 Y-2.233 N39500 X1.3121 Y-2.2366 N39505 X1.3162 Y-2.2406 N39510 X1.3201 Y-2.2449 N39515 X1.3274 Y-2.2541 N39520 X1.3314 Y-2.2612 N39525 X1.3347 Y-2.2687 N39530 X1.3367 Y-2.2765 N39535 X1.338 Y-2.2847 N39540 X1.3381 Y-2.2947 N39545 X1.3374 Y-2.3045 N39550 X1.3354 Y-2.3142 N39555 X1.3326 Y-2.3238 N39560 X1.328 Y-2.3349 N39565 X1.3228 Y-2.3456 N39570 X1.3164 Y-2.3557 N39575 X1.3095 Y-2.3655 N39580 X1.3005 Y-2.376 N39585 Z0.1606 N39590 G0 Z0.2 N39595 X0.9642 Y-2.0457 N39600 Z0.1606 N39605 G1 Z-0.0394 F13.123 N39610 X0.9102 Y-2.2044 F39.37 N39615 X0.8919 N39620 X0.893 Y-2.1739 N39625 X0.8927 Y-2.1587 N39630 X0.8918 Y-2.1434 N39635 X0.8902 Y-2.1341 N39640 X0.888 Y-2.1249 N39645 X0.8848 Y-2.116 N39650 X0.8811 Y-2.1072 N39655 X0.8767 Y-2.0995 N39660 X0.8716 Y-2.0923 N39665 X0.8653 Y-2.0862 N39670 X0.8582 Y-2.0808 N39675 X0.8394 Y-2.0745 N39680 X0.8299 Y-2.0718 N39685 X0.8203 Y-2.0698 N39690 X0.8106 Y-2.0684 N39695 X0.8007 Y-2.0676 N39700 X0.7808 Y-2.0669 N39705 X0.7116 N39710 X0.6538 Y-2.237 N39715 X0.6681 N39720 X0.6794 Y-2.2354 N39725 X0.6904 Y-2.2335 N39730 X0.7012 Y-2.2308 N39735 X0.7113 Y-2.2268 N39740 X0.7209 Y-2.2215 N39745 X0.73 Y-2.2152 N39750 X0.7474 Y-2.2007 N39755 X0.7571 Y-2.1902 N39760 X0.7662 Y-2.1793 N39765 X0.7744 Y-2.1676 N39770 X0.782 Y-2.1555 N39775 X0.7925 Y-2.136 N39780 X0.802 Y-2.1161 N39785 X0.8224 N39790 X0.7335 Y-2.3774 N39795 X0.7132 N39800 X0.7167 Y-2.3565 N39805 X0.7192 Y-2.3353 N39810 X0.7199 Y-2.3212 N39815 X0.719 Y-2.3072 N39820 X0.7164 Y-2.296 N39825 X0.7124 Y-2.2853 N39830 X0.7072 Y-2.2786 N39835 X0.7017 Y-2.2724 N39840 X0.6958 Y-2.2671 N39845 X0.6925 Y-2.2649 N39850 X0.6891 Y-2.263 N39855 X0.6817 Y-2.2604 N39860 X0.6737 Y-2.2589 N39865 X0.6653 Y-2.258 N39870 X0.6568 Y-2.2576 N39875 X0.6468 N39880 X0.5925 Y-2.4171 N39885 X0.6495 N39890 X0.6747 Y-2.4162 N39895 X0.6873 Y-2.4149 N39900 X0.6998 Y-2.4132 N39905 X0.7107 Y-2.411 N39910 X0.7215 Y-2.4085 N39915 X0.7321 Y-2.4051 N39920 X0.7426 Y-2.4014 N39925 X0.7527 Y-2.3968 N39930 X0.7626 Y-2.3919 N39935 X0.7722 Y-2.3864 N39940 X0.7816 Y-2.3805 N39945 X0.7978 Y-2.3686 N39950 X0.8056 Y-2.3623 N39955 X0.8131 Y-2.3557 N39960 X0.8203 Y-2.3487 N39965 X0.8271 Y-2.3413 N39970 X0.8401 Y-2.326 N39975 X0.8596 Y-2.2986 N39980 X0.8778 Y-2.2702 N39985 X0.8979 N39990 X0.8408 Y-2.4382 N39995 X0.4146 N40000 X0.421 Y-2.4171 N40005 X0.4369 N40010 X0.4518 Y-2.4147 N40015 X0.4662 Y-2.4116 N40020 X0.473 Y-2.4096 N40025 X0.4795 Y-2.4071 N40030 X0.4855 Y-2.404 N40035 X0.4911 Y-2.4003 N40040 X0.4962 Y-2.3959 N40045 X0.5008 Y-2.3909 N40050 X0.505 Y-2.3853 N40055 X0.5089 Y-2.3793 N40060 X0.516 Y-2.3664 N40065 X0.5226 Y-2.3527 N40070 X0.5981 Y-2.1307 N40075 X0.6019 Y-2.1185 N40080 X0.6033 Y-2.1125 N40085 X0.604 Y-2.1064 N40090 X0.6038 Y-2.1003 N40095 X0.6028 Y-2.0943 N40100 X0.5992 Y-2.0823 N40105 X0.5899 Y-2.0746 N40110 X0.585 Y-2.0716 N40115 X0.5797 Y-2.0694 N40120 X0.5741 Y-2.068 N40125 X0.5682 Y-2.0673 N40130 X0.556 Y-2.0669 N40135 X0.5401 N40140 X0.5473 Y-2.0457 N40145 X0.9642 N40150 Z0.1606 N40155 G0 Z0.2 N40160 X0.4169 Y-2.1252 N40165 Z0.1606 N40170 G1 Z-0.0394 F13.123 N40175 X0.4207 Y-2.1329 F39.37 N40180 X0.424 Y-2.1408 N40185 X0.4265 Y-2.1489 N40190 X0.4285 Y-2.1573 N40195 X0.4315 Y-2.1743 N40200 X0.432 Y-2.1929 N40205 X0.4318 Y-2.2022 N40210 X0.431 Y-2.2114 N40215 X0.4295 Y-2.2205 N40220 X0.4275 Y-2.2296 N40225 X0.4225 Y-2.2476 N40230 X0.4141 Y-2.2681 N40235 X0.4095 Y-2.2781 N40240 X0.4044 Y-2.2878 N40245 X0.3987 Y-2.2972 N40250 X0.3925 Y-2.3064 N40255 X0.3793 Y-2.3241 N40260 X0.3636 Y-2.3412 N40265 X0.3555 Y-2.3494 N40270 X0.347 Y-2.3573 N40275 X0.3382 Y-2.3646 N40280 X0.329 Y-2.3716 N40285 X0.3101 Y-2.385 N40290 X0.2892 Y-2.397 N40295 X0.2785 Y-2.4026 N40300 X0.2677 Y-2.4078 N40305 X0.2567 Y-2.4125 N40310 X0.2454 Y-2.4167 N40315 X0.2226 Y-2.4244 N40320 X0.1987 Y-2.4302 N40325 X0.1867 Y-2.4327 N40330 X0.1746 Y-2.4348 N40335 X0.1624 Y-2.4362 N40340 X0.1502 Y-2.4371 N40345 X0.1256 Y-2.4382 N40350 X-0.1509 N40355 X-0.1435 Y-2.4165 N40360 X-0.1241 N40365 X-0.1098 Y-2.4156 N40370 X-0.1028 Y-2.4147 N40375 X-0.096 Y-2.4132 N40380 X-0.0894 Y-2.4109 N40385 X-0.083 Y-2.408 N40390 X-0.0705 Y-2.4011 N40395 X-0.06 Y-2.3907 N40400 X-0.0552 Y-2.3852 N40405 X-0.0509 Y-2.3794 N40410 X-0.0473 Y-2.3731 N40415 X-0.0441 Y-2.3665 N40420 X-0.0386 Y-2.3527 N40425 X0.0369 Y-2.1307 N40430 X0.0407 Y-2.1185 N40435 X0.0421 Y-2.1125 N40440 X0.0428 Y-2.1064 N40445 X0.0427 Y-2.1003 N40450 X0.0416 Y-2.0943 N40455 X0.038 Y-2.0823 N40460 X0.0288 Y-2.0746 N40465 X0.0238 Y-2.0716 N40470 X0.0186 Y-2.0694 N40475 X0.0129 Y-2.068 N40480 X0.007 Y-2.0673 N40485 X-0.0051 Y-2.0669 N40490 X-0.0246 N40495 X-0.0174 Y-2.0457 N40500 X0.2411 N40505 X0.2677 Y-2.0466 N40510 X0.2809 Y-2.0475 N40515 X0.294 Y-2.049 N40520 X0.307 Y-2.0513 N40525 X0.3198 Y-2.0543 N40530 X0.3454 Y-2.0616 N40535 X0.3638 Y-2.0702 N40540 X0.3726 Y-2.0751 N40545 X0.3809 Y-2.0807 N40550 X0.3884 Y-2.0872 N40555 X0.3954 Y-2.0945 N40560 X0.4083 Y-2.1102 N40565 X0.4169 Y-2.1252 N40570 Z0.1606 N40575 G0 Z0.2 N40580 X0.1386 Y-2.1019 N40585 Z0.1606 N40590 G1 Z-0.0394 F13.123 N40595 X0.0316 Y-2.4165 F39.37 N40600 X0.0994 N40605 X0.1261 Y-2.4158 N40610 X0.1394 Y-2.4146 N40615 X0.1527 Y-2.4131 N40620 X0.1631 Y-2.4111 N40625 X0.1734 Y-2.4088 N40630 X0.1834 Y-2.4056 N40635 X0.1933 Y-2.402 N40640 X0.2022 Y-2.3978 N40645 X0.2109 Y-2.3931 N40650 X0.2191 Y-2.3878 N40655 X0.2271 Y-2.382 N40660 X0.2424 Y-2.3674 N40665 X0.2571 Y-2.3524 N40670 X0.2708 Y-2.3366 N40675 X0.2771 Y-2.3284 N40680 X0.2829 Y-2.3199 N40685 X0.2883 Y-2.311 N40690 X0.2932 Y-2.3019 N40695 X0.3023 Y-2.283 N40700 X0.3104 Y-2.2635 N40705 X0.318 Y-2.2438 N40710 X0.3225 Y-2.2295 N40715 X0.3265 Y-2.2151 N40720 X0.3297 Y-2.2004 N40725 X0.3323 Y-2.1857 N40730 X0.3336 Y-2.1737 N40735 X0.3343 Y-2.1617 N40740 X0.3339 Y-2.1498 N40745 X0.3328 Y-2.1378 N40750 X0.3306 Y-2.1273 N40755 X0.3277 Y-2.117 N40760 X0.3237 Y-2.1071 N40765 X0.3192 Y-2.0974 N40770 X0.3089 Y-2.0888 N40775 X0.2976 Y-2.0816 N40780 X0.2895 Y-2.0777 N40785 X0.2812 Y-2.0745 N40790 X0.2726 Y-2.0722 N40795 X0.2638 Y-2.0704 N40800 X0.2512 Y-2.0688 N40805 X0.2387 Y-2.0676 N40810 X0.2134 Y-2.0669 N40815 X0.1505 N40820 X0.1386 Y-2.1019 N40825 Z0.1606 N40830 G0 Z0.2 N40835 X-0.2851 Y-2.1743 N40840 Z0.1606 N40845 G1 Z-0.0394 F13.123 N40850 X-0.2922 Y-2.1952 F39.37 N40855 X-0.3093 Y-2.1966 N40860 X-0.3262 Y-2.1996 N40865 X-0.3401 Y-2.2045 N40870 X-0.3534 Y-2.211 N40875 X-0.3685 Y-2.2201 N40880 X-0.3826 Y-2.2309 N40885 X-0.4014 Y-2.2486 N40890 X-0.4194 Y-2.2674 N40895 X-0.438 Y-2.2871 N40900 X-0.4573 Y-2.3064 N40905 X-0.4748 Y-2.3225 N40910 X-0.4932 Y-2.3376 N40915 X-0.4863 Y-2.3481 N40920 X-0.4788 Y-2.3582 N40925 X-0.4704 Y-2.3674 N40930 X-0.4612 Y-2.3761 N40935 X-0.4534 Y-2.3813 N40940 X-0.4493 Y-2.3835 N40945 X-0.4451 Y-2.3854 N40950 X-0.4408 Y-2.3867 N40955 X-0.4362 Y-2.3876 N40960 X-0.4269 Y-2.3886 N40965 X-0.4201 Y-2.3879 N40970 X-0.4135 Y-2.3866 N40975 X-0.4071 Y-2.3842 N40980 X-0.4009 Y-2.3813 N40985 X-0.3942 Y-2.3774 N40990 X-0.3878 Y-2.3731 N40995 X-0.3818 Y-2.3682 N41000 X-0.3762 Y-2.3629 N41005 X-0.3648 Y-2.3499 N41010 X-0.355 Y-2.3358 N41015 X-0.3438 Y-2.3135 N41020 X-0.3341 Y-2.2906 N41025 X-0.3134 N41030 X-0.3201 Y-2.3066 N41035 X-0.3271 Y-2.3224 N41040 X-0.335 Y-2.3379 N41045 X-0.3435 Y-2.353 N41050 X-0.3512 Y-2.3639 N41055 X-0.3594 Y-2.3743 N41060 X-0.3684 Y-2.3841 N41065 X-0.378 Y-2.3934 N41070 X-0.3919 Y-2.4049 N41075 X-0.399 Y-2.4103 N41080 X-0.4064 Y-2.4154 N41085 X-0.4141 Y-2.42 N41090 X-0.422 Y-2.4243 N41095 X-0.4382 Y-2.4322 N41100 X-0.4539 Y-2.4379 N41105 X-0.4618 Y-2.4403 N41110 X-0.4698 Y-2.4423 N41115 X-0.478 Y-2.4438 N41120 X-0.4862 Y-2.4448 N41125 X-0.5029 Y-2.446 N41130 X-0.5154 Y-2.4454 N41135 X-0.5276 Y-2.4439 N41140 X-0.5336 Y-2.4424 N41145 X-0.5395 Y-2.4405 N41150 X-0.5511 Y-2.4359 N41155 X-0.5623 Y-2.4286 N41160 X-0.5727 Y-2.4205 N41165 X-0.5822 Y-2.4113 N41170 X-0.5911 Y-2.4014 N41175 X-0.6115 Y-2.4112 N41180 X-0.6323 Y-2.4202 N41185 X-0.6536 Y-2.4278 N41190 X-0.6752 Y-2.4345 N41195 X-0.6954 Y-2.4391 N41200 X-0.7158 Y-2.4427 N41205 X-0.7364 Y-2.4446 N41210 X-0.7571 Y-2.4455 N41215 X-0.7735 Y-2.445 N41220 X-0.7899 Y-2.4437 N41225 X-0.8061 Y-2.4411 N41230 X-0.8221 Y-2.4377 N41235 X-0.8342 Y-2.434 N41240 X-0.8458 Y-2.4293 N41245 X-0.8513 Y-2.4263 N41250 X-0.8566 Y-2.4229 N41255 X-0.8667 Y-2.4154 N41260 X-0.8723 Y-2.4084 N41265 X-0.8774 Y-2.4013 N41270 X-0.8814 Y-2.3939 N41275 X-0.8829 Y-2.3901 N41280 X-0.8839 Y-2.3862 N41285 X-0.8845 Y-2.3822 N41290 X-0.8846 Y-2.3781 N41295 X-0.8839 Y-2.3696 N41300 X-0.8823 Y-2.3609 N41305 X-0.8802 Y-2.3521 N41310 X-0.8722 Y-2.3355 N41315 X-0.8676 Y-2.3277 N41320 X-0.8623 Y-2.3205 N41325 X-0.8561 Y-2.314 N41330 X-0.8493 Y-2.308 N41335 X-0.8344 Y-2.297 N41340 X-0.825 Y-2.2879 N41345 X-0.8152 Y-2.2795 N41350 X-0.8046 Y-2.2719 N41355 X-0.7935 Y-2.265 N41360 X-0.7722 Y-2.2548 N41365 X-0.7502 Y-2.2459 N41370 X-0.7187 Y-2.235 N41375 X-0.6868 Y-2.2251 N41380 X-0.6636 Y-2.2186 N41385 X-0.6644 Y-2.2017 N41390 Y-2.1933 N41395 X-0.6639 Y-2.1849 N41400 X-0.6627 Y-2.1767 N41405 X-0.661 Y-2.1684 N41410 X-0.6566 Y-2.1521 N41415 X-0.6504 Y-2.1366 N41420 X-0.6469 Y-2.1291 N41425 X-0.6431 Y-2.1217 N41430 X-0.6388 Y-2.1147 N41435 X-0.6342 Y-2.1078 N41440 X-0.6243 Y-2.0944 N41445 X-0.6133 Y-2.0825 N41450 X-0.6077 Y-2.0769 N41455 X-0.6017 Y-2.0715 N41460 X-0.5954 Y-2.0666 N41465 X-0.5888 Y-2.062 N41470 X-0.5752 Y-2.0533 N41475 X-0.5621 Y-2.0471 N41480 X-0.5554 Y-2.0445 N41485 X-0.5486 Y-2.0422 N41490 X-0.5416 Y-2.0406 N41495 X-0.5345 Y-2.0396 N41500 X-0.5201 Y-2.0382 N41505 X-0.5056 Y-2.0395 N41510 X-0.4987 Y-2.0409 N41515 X-0.4922 Y-2.0432 N41520 X-0.4863 Y-2.0466 N41525 X-0.481 Y-2.051 N41530 X-0.4711 Y-2.0615 N41535 X-0.4658 Y-2.0759 N41540 X-0.464 Y-2.0831 N41545 X-0.4633 Y-2.0904 N41550 X-0.4637 Y-2.0978 N41555 X-0.4649 Y-2.1052 N41560 X-0.4689 Y-2.1201 N41565 X-0.4726 Y-2.1295 N41570 X-0.477 Y-2.1385 N41575 X-0.4823 Y-2.1469 N41580 X-0.4882 Y-2.1551 N41585 X-0.4954 Y-2.1629 N41590 X-0.503 Y-2.1701 N41595 X-0.5114 Y-2.1766 N41600 X-0.5201 Y-2.1826 N41605 X-0.5305 Y-2.1885 N41610 X-0.5411 Y-2.1938 N41615 X-0.5521 Y-2.1983 N41620 X-0.5634 Y-2.2022 N41625 X-0.5551 Y-2.2126 N41630 X-0.5403 Y-2.2454 N41635 X-0.5243 Y-2.2775 N41640 X-0.5022 Y-2.3236 N41645 X-0.477 Y-2.3001 N41650 X-0.465 Y-2.2878 N41655 X-0.4532 Y-2.2752 N41660 X-0.4459 Y-2.2664 N41665 X-0.4392 Y-2.2572 N41670 X-0.4336 Y-2.2473 N41675 X-0.4289 Y-2.2369 N41680 X-0.4269 Y-2.2289 N41685 X-0.4264 Y-2.225 N41690 X-0.4265 Y-2.2212 N41695 X-0.4273 Y-2.2175 N41700 X-0.4288 Y-2.2139 N41705 X-0.4328 Y-2.2068 N41710 X-0.441 Y-2.2013 N41715 X-0.4452 Y-2.1991 N41720 X-0.4496 Y-2.1975 N41725 X-0.4543 Y-2.1964 N41730 X-0.4591 Y-2.1959 N41735 X-0.469 Y-2.1955 N41740 X-0.4887 N41745 X-0.4816 Y-2.1743 N41750 X-0.2851 N41755 Z0.1606 N41760 G0 Z0.2 N41765 X-0.682 Y-2.2435 N41770 Z0.1606 N41775 G1 Z-0.0394 F13.123 N41780 X-0.7011 Y-2.2512 F39.37 N41785 X-0.7181 Y-2.2594 N41790 X-0.7346 Y-2.2687 N41795 X-0.7458 Y-2.2785 N41800 X-0.7509 Y-2.2838 N41805 X-0.7555 Y-2.2895 N41810 X-0.7594 Y-2.2956 N41815 X-0.7628 Y-2.3021 N41820 X-0.7687 Y-2.3158 N41825 X-0.7723 Y-2.3289 N41830 X-0.7741 Y-2.3423 N41835 X-0.7742 Y-2.3547 N41840 X-0.7725 Y-2.367 N41845 X-0.7689 Y-2.3778 N41850 X-0.7635 Y-2.3878 N41855 X-0.7572 Y-2.3943 N41860 X-0.7506 Y-2.4003 N41865 X-0.7437 Y-2.4055 N41870 X-0.7362 Y-2.4094 N41875 X-0.7281 Y-2.412 N41880 X-0.7195 Y-2.4135 N41885 X-0.7014 Y-2.4148 N41890 X-0.6912 Y-2.4144 N41895 X-0.681 Y-2.4135 N41900 X-0.671 Y-2.4117 N41905 X-0.661 Y-2.4094 N41910 X-0.6473 Y-2.405 N41915 X-0.6337 Y-2.4003 N41920 X-0.6072 Y-2.3892 N41925 X-0.5986 Y-2.3869 N41930 X-0.6111 Y-2.3694 N41935 X-0.6169 Y-2.3605 N41940 X-0.6224 Y-2.3513 N41945 X-0.632 Y-2.3322 N41950 X-0.6408 Y-2.3127 N41955 X-0.6487 Y-2.2923 N41960 X-0.6557 Y-2.2716 N41965 X-0.66 Y-2.2542 N41970 X-0.6627 Y-2.2364 N41975 X-0.682 Y-2.2435 N41980 Z0.1606 N41985 G0 Z0.2 N41990 X-0.5681 Y-2.186 N41995 Z0.1606 N42000 G1 Z-0.0394 F13.123 N42005 X-0.5594 Y-2.1821 F39.37 N42010 X-0.5508 Y-2.1777 N42015 X-0.5428 Y-2.1726 N42020 X-0.535 Y-2.1669 N42025 X-0.5294 Y-2.1615 N42030 X-0.5245 Y-2.1557 N42035 X-0.5207 Y-2.149 N42040 X-0.5175 Y-2.1419 N42045 X-0.5155 Y-2.1344 N42050 X-0.514 Y-2.1268 N42055 X-0.5126 Y-2.1114 N42060 Y-2.1035 N42065 X-0.5131 Y-2.0956 N42070 X-0.5144 Y-2.0879 N42075 X-0.5164 Y-2.0803 N42080 X-0.5199 Y-2.0726 N42085 X-0.522 Y-2.0692 N42090 X-0.5246 Y-2.0664 N42095 X-0.5277 Y-2.0644 N42100 X-0.5314 Y-2.0629 N42105 X-0.5395 Y-2.0611 N42110 X-0.5467 Y-2.062 N42115 X-0.5536 Y-2.0638 N42120 X-0.5599 Y-2.0671 N42125 X-0.566 Y-2.0711 N42130 X-0.5717 Y-2.0761 N42135 X-0.5768 Y-2.0817 N42140 X-0.5807 Y-2.0881 N42145 X-0.5839 Y-2.0951 N42150 X-0.5856 Y-2.1022 N42155 X-0.5867 Y-2.1094 N42160 X-0.5866 Y-2.1166 N42165 X-0.5859 Y-2.1239 N42170 X-0.5834 Y-2.1359 N42175 X-0.5804 Y-2.1478 N42180 X-0.5728 Y-2.1711 N42185 X-0.5681 Y-2.186 N42190 Z0.1606 N42195 G0 Z0.2 N42200 X-1.0242 Y-2.0533 N42205 Z0.1606 N42210 G1 Z-0.0394 F13.123 N42215 X-1.0724 Y-2.1949 F39.37 N42220 X-1.0918 N42225 X-1.0927 Y-2.1755 N42230 X-1.0935 Y-2.1658 N42235 X-1.0948 Y-2.1562 N42240 X-1.0968 Y-2.1468 N42245 X-1.0994 Y-2.1374 N42250 X-1.1056 Y-2.119 N42255 X-1.1112 Y-2.1102 N42260 X-1.1176 Y-2.102 N42265 X-1.125 Y-2.0947 N42270 X-1.1332 Y-2.0881 N42275 X-1.1437 Y-2.0814 N42280 X-1.1547 Y-2.0754 N42285 X-1.1662 Y-2.0707 N42290 X-1.178 Y-2.0666 N42295 X-1.1917 Y-2.0633 N42300 X-1.2055 Y-2.0607 N42305 X-1.2195 Y-2.0594 N42310 X-1.2336 Y-2.0588 N42315 X-1.2438 Y-2.0592 N42320 X-1.2539 Y-2.0602 N42325 X-1.2639 Y-2.0622 N42330 X-1.2738 Y-2.0647 N42335 X-1.2828 Y-2.0681 N42340 X-1.2915 Y-2.0719 N42345 X-1.2998 Y-2.0767 N42350 X-1.3078 Y-2.082 N42355 X-1.3178 Y-2.0904 N42360 X-1.3266 Y-2.0998 N42365 X-1.3329 Y-2.1087 N42370 X-1.3376 Y-2.1186 N42375 X-1.3393 Y-2.1266 N42380 X-1.3397 Y-2.1305 N42385 X-1.3395 Y-2.1344 N42390 X-1.3386 Y-2.1382 N42395 X-1.3372 Y-2.1419 N42400 X-1.3335 Y-2.1491 N42405 X-1.3275 Y-2.1551 N42410 X-1.3204 Y-2.1598 N42415 X-1.3069 Y-2.1664 N42420 X-1.2928 Y-2.1716 N42425 X-1.2676 Y-2.1792 N42430 X-1.2422 Y-2.1862 N42435 X-1.2361 Y-2.1881 N42440 X-1.23 Y-2.1897 N42445 X-1.2246 Y-2.1928 N42450 X-1.1983 Y-2.1986 N42455 X-1.18 Y-2.2038 N42460 X-1.1619 Y-2.2096 N42465 X-1.1441 Y-2.2163 N42470 X-1.1265 Y-2.2236 N42475 X-1.1164 Y-2.2297 N42480 X-1.1116 Y-2.233 N42485 X-1.1071 Y-2.2366 N42490 X-1.103 Y-2.2406 N42495 X-1.0991 Y-2.2449 N42500 X-1.0918 Y-2.2541 N42505 X-1.0878 Y-2.2612 N42510 X-1.0845 Y-2.2687 N42515 X-1.0825 Y-2.2765 N42520 X-1.0812 Y-2.2847 N42525 X-1.0811 Y-2.2947 N42530 X-1.0818 Y-2.3045 N42535 X-1.0838 Y-2.3142 N42540 X-1.0866 Y-2.3238 N42545 X-1.0912 Y-2.3349 N42550 X-1.0964 Y-2.3456 N42555 X-1.1028 Y-2.3557 N42560 X-1.1097 Y-2.3655 N42565 X-1.1187 Y-2.376 N42570 X-1.1282 Y-2.386 N42575 X-1.1385 Y-2.395 N42580 X-1.1494 Y-2.4036 N42585 X-1.1636 Y-2.4131 N42590 X-1.1709 Y-2.4176 N42595 X-1.1784 Y-2.4217 N42600 X-1.1861 Y-2.4253 N42605 X-1.194 Y-2.4286 N42610 X-1.2102 Y-2.4345 N42615 X-1.2282 Y-2.4391 N42620 X-1.2373 Y-2.4411 N42625 X-1.2464 Y-2.4426 N42630 X-1.2649 Y-2.4444 N42635 X-1.2835 Y-2.4452 N42640 X-1.2959 Y-2.4449 N42645 X-1.3083 Y-2.444 N42650 X-1.3205 Y-2.4422 N42655 X-1.3327 Y-2.4398 N42660 X-1.3453 Y-2.436 N42665 X-1.3577 Y-2.4315 N42670 X-1.3697 Y-2.4262 N42675 X-1.3815 Y-2.4204 N42680 X-1.3968 Y-2.414 N42685 X-1.4124 Y-2.4084 N42690 X-1.4219 Y-2.4062 N42695 X-1.4315 Y-2.4054 N42700 X-1.44 Y-2.4061 N42705 X-1.4483 Y-2.4077 N42710 X-1.4562 Y-2.4107 N42715 X-1.4638 Y-2.4145 N42720 X-1.4719 Y-2.4208 N42725 X-1.4793 Y-2.4278 N42730 X-1.4854 Y-2.4359 N42735 X-1.4909 Y-2.4446 N42740 X-1.5107 N42745 X-1.4469 Y-2.2571 N42750 X-1.4267 N42755 X-1.4299 Y-2.2794 N42760 X-1.4307 Y-2.2904 N42765 X-1.4305 Y-2.3014 N42770 X-1.429 Y-2.3123 N42775 X-1.4264 Y-2.323 N42780 X-1.4192 Y-2.3443 N42785 X-1.412 Y-2.3557 N42790 X-1.404 Y-2.3664 N42795 X-1.3947 Y-2.3761 N42800 X-1.3846 Y-2.3851 N42805 X-1.3726 Y-2.3939 N42810 X-1.3601 Y-2.4018 N42815 X-1.3468 Y-2.4084 N42820 X-1.333 Y-2.4142 N42825 X-1.319 Y-2.4186 N42830 X-1.3047 Y-2.4219 N42835 X-1.2901 Y-2.4237 N42840 X-1.2754 Y-2.4246 N42845 X-1.2629 Y-2.424 N42850 X-1.2506 Y-2.4226 N42855 X-1.2384 Y-2.4198 N42860 X-1.2264 Y-2.4163 N42865 X-1.2158 Y-2.412 N42870 X-1.2055 Y-2.407 N42875 X-1.196 Y-2.4008 N42880 X-1.1868 Y-2.3938 N42885 X-1.1798 Y-2.3868 N42890 X-1.1736 Y-2.3793 N42895 X-1.1687 Y-2.3708 N42900 X-1.1647 Y-2.3618 N42905 X-1.1628 Y-2.3532 N42910 X-1.1623 Y-2.3489 N42915 X-1.1624 Y-2.3447 N42920 X-1.1632 Y-2.3406 N42925 X-1.1646 Y-2.3365 N42930 X-1.1683 Y-2.3285 N42935 X-1.1748 Y-2.3213 N42940 X-1.1826 Y-2.3156 N42945 X-1.1955 Y-2.3087 N42950 X-1.209 Y-2.3031 N42955 X-1.2324 Y-2.295 N42960 X-1.256 Y-2.2877 N42965 X-1.2808 Y-2.2803 N42970 X-1.3005 Y-2.2745 N42975 X-1.32 Y-2.2683 N42980 X-1.3393 Y-2.2613 N42985 X-1.3583 Y-2.2537 N42990 X-1.3687 Y-2.2494 N42995 X-1.3788 Y-2.2446 N43000 X-1.3885 Y-2.2389 N43005 X-1.3977 Y-2.2326 N43010 X-1.4036 Y-2.2269 N43015 X-1.4089 Y-2.2209 N43020 X-1.4131 Y-2.214 N43025 X-1.4167 Y-2.2067 N43030 X-1.4204 Y-2.1936 N43035 X-1.4217 Y-2.1871 N43040 X-1.4222 Y-2.1806 N43045 X-1.4219 Y-2.174 N43050 X-1.4209 Y-2.1674 N43055 X-1.4177 Y-2.1542 N43060 X-1.4102 Y-2.1374 N43065 X-1.4061 Y-2.1294 N43070 X-1.4014 Y-2.1216 N43075 X-1.396 Y-2.1144 N43080 X-1.3901 Y-2.1074 N43085 X-1.3774 Y-2.0942 N43090 X-1.3616 Y-2.0815 N43095 X-1.3534 Y-2.0756 N43100 X-1.345 Y-2.0701 N43105 X-1.3362 Y-2.0653 N43110 X-1.3271 Y-2.0609 N43115 X-1.3085 Y-2.0529 N43120 X-1.2883 Y-2.0467 N43125 X-1.2782 Y-2.0441 N43130 X-1.2679 Y-2.0419 N43135 X-1.2576 Y-2.0404 N43140 X-1.2471 Y-2.0394 N43145 X-1.2261 Y-2.0382 N43150 X-1.2104 Y-2.0394 N43155 X-1.1949 Y-2.041 N43160 X-1.1796 Y-2.0434 N43165 X-1.1646 Y-2.047 N43170 X-1.1501 Y-2.052 N43175 X-1.136 Y-2.0583 N43180 X-1.1221 Y-2.0654 N43185 X-1.1083 Y-2.0729 N43190 X-1.1017 Y-2.0767 N43195 X-1.0951 Y-2.0801 N43200 X-1.0881 Y-2.0827 N43205 X-1.0808 Y-2.0846 N43210 X-1.069 Y-2.0801 N43215 X-1.0636 Y-2.0772 N43220 X-1.0589 Y-2.0735 N43225 X-1.0546 Y-2.069 N43230 X-1.0508 Y-2.0641 N43235 X-1.0438 Y-2.0533 N43240 X-1.0242 N43245 Z0.1606 N43250 G0 Z0.2 N43255 X-0.5045 Y2.3698 N43260 Z0.1606 N43265 G1 Z-0.0394 F13.123 N43270 X-0.5212 Y2.3723 F39.37 N43275 X-0.5376 Y2.3755 N43280 X-0.5538 Y2.3796 N43285 X-0.5696 Y2.3847 N43290 X-0.5851 Y2.3908 N43295 X-0.6004 Y2.3978 N43300 X-0.6154 Y2.4055 N43305 X-0.6302 Y2.4138 N43310 X-0.6448 Y2.4226 N43315 X-0.6739 Y2.4409 N43320 X-0.6952 Y2.4649 N43325 X-0.7055 Y2.4771 N43330 X-0.7154 Y2.4894 N43335 X-0.7248 Y2.5021 N43340 X-0.7335 Y2.515 N43345 X-0.7414 Y2.5284 N43350 X-0.7484 Y2.5422 N43355 X-0.7544 Y2.5564 N43360 X-0.7596 Y2.5711 N43365 X-0.7641 Y2.5861 N43370 X-0.768 Y2.6014 N43375 X-0.7746 Y2.6327 N43380 X-0.7801 Y2.6644 N43385 X-0.6083 Y2.6811 N43390 X-0.6043 Y2.6632 N43395 X-0.5999 Y2.6455 N43400 X-0.5945 Y2.6284 N43405 X-0.5913 Y2.62 N43410 X-0.5877 Y2.6119 N43415 X-0.5836 Y2.604 N43420 X-0.5791 Y2.5964 N43425 X-0.5688 Y2.5818 N43430 X-0.5573 Y2.5677 N43435 X-0.5453 Y2.554 N43440 X-0.5307 Y2.5445 N43445 X-0.516 Y2.5357 N43450 X-0.5008 Y2.528 N43455 X-0.4931 Y2.5248 N43460 X-0.4851 Y2.5221 N43465 X-0.477 Y2.5199 N43470 X-0.4687 Y2.5181 N43475 X-0.4519 Y2.5157 N43480 X-0.4346 Y2.5143 N43485 X-0.4173 Y2.5134 N43490 X-0.4 Y2.5139 N43495 X-0.3829 Y2.515 N43500 X-0.366 Y2.5169 N43505 X-0.3577 Y2.5184 N43510 X-0.3496 Y2.5203 N43515 X-0.3416 Y2.5227 N43520 X-0.3337 Y2.5256 N43525 X-0.3184 Y2.5326 N43530 X-0.3034 Y2.5407 N43535 X-0.2886 Y2.5495 N43540 X-0.2796 Y2.5583 N43545 X-0.2711 Y2.5673 N43550 X-0.2634 Y2.5767 N43555 X-0.2601 Y2.5816 N43560 X-0.2571 Y2.5868 N43565 X-0.2546 Y2.5922 N43570 X-0.2525 Y2.5977 N43575 X-0.2493 Y2.6094 N43580 X-0.2471 Y2.6216 N43585 X-0.2454 Y2.634 N43590 X-0.2467 Y2.6483 N43595 X-0.2478 Y2.6553 N43600 X-0.2497 Y2.662 N43605 X-0.2524 Y2.6685 N43610 X-0.2557 Y2.6747 N43615 X-0.2636 Y2.6868 N43620 X-0.2777 Y2.6991 N43625 X-0.2851 Y2.7048 N43630 X-0.2928 Y2.7098 N43635 X-0.3011 Y2.7141 N43640 X-0.3096 Y2.7179 N43645 X-0.3271 Y2.7247 N43650 X-0.3623 Y2.7351 N43655 X-0.3975 Y2.7449 N43660 X-0.4686 Y2.7629 N43665 X-0.4953 Y2.7697 N43670 X-0.5218 Y2.7771 N43675 X-0.5479 Y2.7853 N43680 X-0.5607 Y2.7899 N43685 X-0.5734 Y2.7949 N43690 X-0.5858 Y2.8004 N43695 X-0.598 Y2.8064 N43700 X-0.61 Y2.8128 N43705 X-0.6218 Y2.8197 N43710 X-0.645 Y2.8342 N43715 X-0.6679 Y2.8494 N43720 X-0.6852 Y2.8682 N43725 X-0.7016 Y2.8873 N43730 X-0.7091 Y2.8972 N43735 X-0.7161 Y2.9073 N43740 X-0.7224 Y2.9177 N43745 X-0.7279 Y2.9285 N43750 X-0.7325 Y2.9397 N43755 X-0.7363 Y2.9513 N43760 X-0.7394 Y2.9632 N43765 X-0.7419 Y2.9753 N43770 X-0.7457 Y3.0002 N43775 X-0.7485 Y3.0255 N43780 X-0.7472 Y3.0422 N43785 X-0.7454 Y3.0587 N43790 X-0.7428 Y3.0749 N43795 X-0.741 Y3.0829 N43800 X-0.7389 Y3.0908 N43805 X-0.7333 Y3.1062 N43810 X-0.7265 Y3.1212 N43815 X-0.7188 Y3.1359 N43820 X-0.7106 Y3.1505 N43825 X-0.6995 Y3.1647 N43830 X-0.688 Y3.1784 N43835 X-0.6759 Y3.1914 N43840 X-0.6695 Y3.1974 N43845 X-0.6628 Y3.2031 N43850 X-0.6558 Y3.2084 N43855 X-0.6485 Y3.2134 N43860 X-0.6333 Y3.2226 N43865 X-0.6175 Y3.2311 N43870 X-0.6014 Y3.2392 N43875 X-0.5805 Y3.2462 N43880 X-0.5595 Y3.2529 N43885 X-0.5383 Y3.2586 N43890 X-0.5169 Y3.263 N43895 X-0.4952 Y3.266 N43900 X-0.4733 Y3.2679 N43905 X-0.4292 Y3.2696 N43910 X-0.3957 Y3.2685 N43915 X-0.3626 Y3.2664 N43920 X-0.3462 Y3.2647 N43925 X-0.33 Y3.2624 N43930 X-0.314 Y3.2594 N43935 X-0.2983 Y3.2556 N43940 X-0.2829 Y3.2509 N43945 X-0.2677 Y3.2451 N43950 X-0.2529 Y3.2385 N43955 X-0.2383 Y3.2312 N43960 X-0.2238 Y3.2232 N43965 X-0.2096 Y3.2149 N43970 X-0.1812 Y3.1974 N43975 X-0.1625 Y3.1769 N43980 X-0.1535 Y3.1664 N43985 X-0.1449 Y3.1559 N43990 X-0.1367 Y3.145 N43995 X-0.1292 Y3.1339 N44000 X-0.1225 Y3.1225 N44005 X-0.1166 Y3.1106 N44010 X-0.1116 Y3.0983 N44015 X-0.1075 Y3.0857 N44020 X-0.1041 Y3.0726 N44025 X-0.1013 Y3.0594 N44030 X-0.0971 Y3.0322 N44035 X-0.0938 Y3.0046 N44040 X-0.2704 Y2.9968 N44045 X-0.2733 Y3.0106 N44050 X-0.2766 Y3.0242 N44055 X-0.2806 Y3.0374 N44060 X-0.2858 Y3.05 N44065 X-0.2889 Y3.056 N44070 X-0.2925 Y3.0618 N44075 X-0.3006 Y3.0729 N44080 X-0.3096 Y3.0835 N44085 X-0.3191 Y3.0938 N44090 X-0.3321 Y3.1011 N44095 X-0.3452 Y3.1078 N44100 X-0.3586 Y3.1136 N44105 X-0.3654 Y3.1159 N44110 X-0.3724 Y3.1178 N44115 X-0.3867 Y3.1206 N44120 X-0.4012 Y3.1222 N44125 X-0.4161 Y3.123 N44130 X-0.431 Y3.1234 N44135 X-0.447 Y3.1228 N44140 X-0.4629 Y3.1218 N44145 X-0.4786 Y3.12 N44150 X-0.4939 Y3.117 N44155 X-0.5014 Y3.1149 N44160 X-0.5088 Y3.1124 N44165 X-0.5233 Y3.1064 N44170 X-0.5375 Y3.0993 N44175 X-0.5516 Y3.0917 N44180 X-0.5633 Y3.0806 N44185 X-0.5684 Y3.0746 N44190 X-0.5725 Y3.0682 N44195 X-0.5754 Y3.0611 N44200 X-0.5774 Y3.0535 N44205 X-0.5796 Y3.0374 N44210 X-0.5773 Y3.0221 N44215 X-0.5754 Y3.0147 N44220 X-0.5727 Y3.0079 N44225 X-0.5688 Y3.0015 N44230 X-0.5641 Y2.9955 N44235 X-0.5533 Y2.9843 N44240 X-0.5342 Y2.974 N44245 X-0.5149 Y2.9642 N44250 X-0.4952 Y2.9553 N44255 X-0.475 Y2.9477 N44260 X-0.4544 Y2.9413 N44265 X-0.4334 Y2.9357 N44270 X-0.391 Y2.9258 N44275 X-0.3421 Y2.9137 N44280 X-0.3178 Y2.9071 N44285 X-0.2938 Y2.8999 N44290 X-0.27 Y2.8917 N44295 X-0.2466 Y2.8826 N44300 X-0.2003 Y2.8629 N44305 X-0.186 Y2.8541 N44310 X-0.172 Y2.8451 N44315 X-0.1585 Y2.8355 N44320 X-0.1459 Y2.825 N44325 X-0.1343 Y2.8133 N44330 X-0.1236 Y2.8007 N44335 X-0.1135 Y2.7875 N44340 X-0.1036 Y2.7739 N44345 X-0.0956 Y2.7574 N44350 X-0.088 Y2.7409 N44355 X-0.0815 Y2.724 N44360 X-0.0787 Y2.7154 N44365 X-0.0764 Y2.7068 N44370 X-0.0729 Y2.6891 N44375 X-0.0708 Y2.6711 N44380 X-0.0695 Y2.6529 N44385 X-0.0687 Y2.6346 N44390 X-0.0701 Y2.6158 N44395 X-0.0721 Y2.5972 N44400 X-0.075 Y2.579 N44405 X-0.0769 Y2.57 N44410 X-0.0793 Y2.5611 N44415 X-0.0822 Y2.5524 N44420 X-0.0854 Y2.5437 N44425 X-0.093 Y2.5268 N44430 X-0.1015 Y2.5102 N44435 X-0.1105 Y2.4937 N44440 X-0.1224 Y2.4781 N44445 X-0.1347 Y2.4629 N44450 X-0.1478 Y2.4486 N44455 X-0.1547 Y2.4419 N44460 X-0.1619 Y2.4357 N44465 X-0.1695 Y2.4298 N44470 X-0.1773 Y2.4243 N44475 X-0.1939 Y2.4142 N44480 X-0.2111 Y2.4049 N44485 X-0.2286 Y2.3961 N44490 X-0.2518 Y2.3886 N44495 X-0.2751 Y2.3816 N44500 X-0.2985 Y2.3755 N44505 X-0.3103 Y2.3729 N44510 X-0.3222 Y2.3708 N44515 X-0.3462 Y2.3677 N44520 X-0.3703 Y2.3659 N44525 X-0.3947 Y2.3648 N44530 X-0.419 Y2.3642 N44535 X-0.4535 Y2.3656 N44540 X-0.4877 Y2.368 N44545 X-0.5045 Y2.3698 N44550 Z0.1606 N44555 G0 Z0.2 N44560 X0.0746 Y2.6672 N44565 Z0.1606 N44570 G1 Z-0.0394 F13.123 N44575 Y3.2547 F39.37 N44580 X0.2512 N44585 Y2.3797 N44590 X0.0746 N44595 Y2.6672 N44600 Z0.1606 N44605 G0 Z0.2 N44610 X0.4404 Y2.5871 N44615 Z0.1606 N44620 G1 Z-0.0394 F13.123 N44625 X0.4291 Y2.6151 F39.37 N44630 X0.4185 Y2.6433 N44635 X0.4136 Y2.6575 N44640 X0.4091 Y2.6718 N44645 X0.405 Y2.6862 N44650 X0.4015 Y2.7007 N44655 X0.3987 Y2.7153 N44660 X0.3963 Y2.7301 N44665 X0.3929 Y2.7599 N44670 X0.3907 Y2.79 N44675 X0.3891 Y2.8202 N44680 X0.3907 Y2.8519 N44685 X0.393 Y2.8834 N44690 X0.3947 Y2.8991 N44695 X0.3967 Y2.9146 N44700 X0.3993 Y2.93 N44705 X0.4025 Y2.9453 N44710 X0.4064 Y2.9604 N44715 X0.4109 Y2.9754 N44720 X0.4159 Y2.9902 N44725 X0.4215 Y3.0049 N44730 X0.4336 Y3.0341 N44735 X0.4464 Y3.0631 N44740 X0.4627 Y3.0882 N44745 X0.4796 Y3.1128 N44750 X0.4885 Y3.1246 N44755 X0.4977 Y3.1361 N44760 X0.5074 Y3.1471 N44765 X0.5176 Y3.1576 N44770 X0.5284 Y3.1674 N44775 X0.5397 Y3.1768 N44780 X0.5514 Y3.1857 N44785 X0.5635 Y3.1942 N44790 X0.5885 Y3.2104 N44795 X0.6141 Y3.226 N44800 X0.6393 Y3.2362 N44805 X0.6646 Y3.2457 N44810 X0.6773 Y3.25 N44815 X0.6902 Y3.254 N44820 X0.7031 Y3.2574 N44825 X0.7162 Y3.2603 N44830 X0.7293 Y3.2627 N44835 X0.7426 Y3.2646 N44840 X0.7694 Y3.2672 N44845 X0.7965 Y3.2687 N44850 X0.8236 Y3.2696 N44855 X0.8575 Y3.2684 N44860 X0.8912 Y3.2662 N44865 X0.9078 Y3.2646 N44870 X0.9243 Y3.2624 N44875 X0.9406 Y3.2595 N44880 X0.9567 Y3.2559 N44885 X0.9726 Y3.2513 N44890 X0.9881 Y3.2459 N44895 X1.0035 Y3.2397 N44900 X1.0187 Y3.2328 N44905 X1.0337 Y3.2254 N44910 X1.0486 Y3.2176 N44915 X1.0782 Y3.2013 N44920 X1.0994 Y3.1817 N44925 X1.1198 Y3.1617 N44930 X1.1294 Y3.1513 N44935 X1.1385 Y3.1406 N44940 X1.147 Y3.1295 N44945 X1.1547 Y3.1179 N44950 X1.1616 Y3.1058 N44955 X1.1679 Y3.0933 N44960 X1.1735 Y3.0804 N44965 X1.1786 Y3.0672 N44970 X1.1877 Y3.04 N44975 X1.1961 Y3.0124 N44980 X1.0206 Y2.9795 N44985 X1.0151 Y2.9944 N44990 X1.0091 Y3.0091 N44995 X1.0024 Y3.0231 N45000 X0.9986 Y3.0299 N45005 X0.9945 Y3.0364 N45010 X0.99 Y3.0426 N45015 X0.9851 Y3.0486 N45020 X0.9744 Y3.06 N45025 X0.9629 Y3.0708 N45030 X0.951 Y3.0813 N45035 X0.9363 Y3.0898 N45040 X0.9214 Y3.0978 N45045 X0.9061 Y3.1048 N45050 X0.8984 Y3.1077 N45055 X0.8904 Y3.1102 N45060 X0.8824 Y3.1123 N45065 X0.8742 Y3.1139 N45070 X0.8576 Y3.1163 N45075 X0.8407 Y3.1177 N45080 X0.8236 Y3.1186 N45085 X0.7977 Y3.1166 N45090 X0.7721 Y3.1138 N45095 X0.7595 Y3.1117 N45100 X0.7472 Y3.1091 N45105 X0.7352 Y3.1058 N45110 X0.7234 Y3.1018 N45115 X0.7121 Y3.0968 N45120 X0.7011 Y3.091 N45125 X0.6903 Y3.0845 N45130 X0.6799 Y3.0774 N45135 X0.6595 Y3.0618 N45140 X0.6395 Y3.0452 N45145 X0.6231 Y3.0206 N45150 X0.6152 Y3.0082 N45155 X0.6078 Y2.9956 N45160 X0.6009 Y2.9829 N45165 X0.5946 Y2.9699 N45170 X0.5892 Y2.9567 N45175 X0.5847 Y2.9432 N45180 X0.5811 Y2.9293 N45185 X0.5782 Y2.9152 N45190 X0.576 Y2.9009 N45195 X0.5744 Y2.8864 N45200 X0.5723 Y2.857 N45205 X0.5711 Y2.8273 N45210 X0.5722 Y2.7957 N45215 X0.5742 Y2.7644 N45220 X0.5759 Y2.7489 N45225 X0.578 Y2.7336 N45230 X0.5809 Y2.7186 N45235 X0.5845 Y2.7037 N45240 X0.5891 Y2.6892 N45245 X0.5946 Y2.675 N45250 X0.6009 Y2.661 N45255 X0.608 Y2.6473 N45260 X0.6156 Y2.6337 N45265 X0.6236 Y2.6203 N45270 X0.6404 Y2.5937 N45275 X0.6598 Y2.5764 N45280 X0.6796 Y2.5602 N45285 X0.6898 Y2.5527 N45290 X0.7003 Y2.5458 N45295 X0.7111 Y2.5397 N45300 X0.7223 Y2.5344 N45305 X0.7338 Y2.5301 N45310 X0.7457 Y2.5265 N45315 X0.758 Y2.5236 N45320 X0.7704 Y2.5214 N45325 X0.7959 Y2.5181 N45330 X0.8218 Y2.5158 N45335 X0.8504 Y2.5176 N45340 X0.8645 Y2.5191 N45345 X0.8785 Y2.5214 N45350 X0.8923 Y2.5246 N45355 X0.906 Y2.5285 N45360 X0.9331 Y2.5376 N45365 X0.9584 Y2.5484 N45370 X0.9708 Y2.5542 N45375 X0.983 Y2.5605 N45380 X0.9948 Y2.5674 N45385 X1.0063 Y2.5748 N45390 X1.0289 Y2.5904 N45395 Y2.7014 N45400 X0.8266 N45405 Y2.8488 N45410 X1.2074 N45415 Y2.5003 N45420 X1.1891 Y2.4855 N45425 X1.1705 Y2.4711 N45430 X1.1515 Y2.4575 N45435 X1.1417 Y2.4511 N45440 X1.1317 Y2.4451 N45445 X1.1111 Y2.4341 N45450 X1.0899 Y2.424 N45455 X1.0465 Y2.4057 N45460 X1.0206 Y2.3969 N45465 X0.9945 Y2.3886 N45470 X0.9683 Y2.3812 N45475 X0.9551 Y2.378 N45480 X0.9418 Y2.3752 N45485 X0.9284 Y2.3729 N45490 X0.9149 Y2.371 N45495 X0.8878 Y2.3681 N45500 X0.8605 Y2.3662 N45505 X0.8332 Y2.3648 N45510 X0.8019 Y2.3663 N45515 X0.7707 Y2.3686 N45520 X0.7553 Y2.3702 N45525 X0.7399 Y2.3722 N45530 X0.7247 Y2.3748 N45535 X0.7097 Y2.378 N45540 X0.6948 Y2.3818 N45545 X0.68 Y2.3864 N45550 X0.6655 Y2.3915 N45555 X0.651 Y2.3971 N45560 X0.6223 Y2.4094 N45565 X0.5938 Y2.4224 N45570 X0.5699 Y2.4385 N45575 X0.5466 Y2.4552 N45580 X0.5353 Y2.464 N45585 X0.5244 Y2.4731 N45590 X0.514 Y2.4826 N45595 X0.5042 Y2.4926 N45600 X0.4949 Y2.5032 N45605 X0.4861 Y2.5143 N45610 X0.4778 Y2.5258 N45615 X0.4699 Y2.5376 N45620 X0.4549 Y2.5621 N45625 X0.4404 Y2.5871 N45630 Z0.1606 N45635 G0 Z0.2 N45640 X1.3721 Y2.7047 N45645 Z0.1606 N45650 G1 Z-0.0394 F13.123 N45655 Y3.2547 F39.37 N45660 X1.544 N45665 X1.9021 Y2.6704 N45670 Y3.2547 N45675 X2.0663 N45680 Y2.3797 N45685 X1.889 N45690 X1.5363 Y2.9503 N45695 Y2.3797 N45700 X1.3721 N45705 Y2.7047 N45710 Z0.1606 N45715 G0 Z0.2 N45720 X1.4779 Y3.7335 N45725 Z0.1606 N45730 G1 Z-0.0394 F13.123 N45735 X1.4564 Y3.7355 F39.37 N45740 X1.435 Y3.738 N45745 X1.414 Y3.7413 N45750 X1.3933 Y3.7455 N45755 X1.3731 Y3.7508 N45760 X1.3533 Y3.7574 N45765 X1.3437 Y3.7612 N45770 X1.3341 Y3.7654 N45775 X1.3155 Y3.7748 N45780 X1.2974 Y3.7854 N45785 X1.2796 Y3.797 N45790 X1.2622 Y3.8094 N45795 X1.245 Y3.8224 N45800 X1.211 Y3.8495 N45805 X1.1844 Y3.886 N45810 X1.1715 Y3.9044 N45815 X1.1594 Y3.9231 N45820 X1.148 Y3.9421 N45825 X1.1376 Y3.9614 N45830 X1.1285 Y3.9812 N45835 X1.1208 Y4.0015 N45840 X1.1145 Y4.0224 N45845 X1.1095 Y4.0437 N45850 X1.1056 Y4.0654 N45855 X1.1025 Y4.0874 N45860 X1.1002 Y4.1097 N45865 X1.0984 Y4.1322 N45870 X1.0958 Y4.1774 N45875 X1.0966 Y4.2063 N45880 X1.098 Y4.235 N45885 X1.1003 Y4.2635 N45890 X1.1021 Y4.2777 N45895 X1.1042 Y4.2918 N45900 X1.1069 Y4.3058 N45905 X1.1101 Y4.3197 N45910 X1.1176 Y4.3473 N45915 X1.1264 Y4.3746 N45920 X1.1358 Y4.4019 N45925 X1.1525 Y4.4343 N45930 X1.1615 Y4.4502 N45935 X1.1712 Y4.4655 N45940 X1.1818 Y4.4802 N45945 X1.1932 Y4.4943 N45950 X1.2172 Y4.5218 N45955 X1.2428 Y4.5455 N45960 X1.256 Y4.5567 N45965 X1.2698 Y4.567 N45970 X1.2843 Y4.5764 N45975 X1.2993 Y4.5849 N45980 X1.3304 Y4.6006 N45985 X1.3533 Y4.6085 N45990 X1.3763 Y4.6159 N45995 X1.3994 Y4.6224 N46000 X1.4111 Y4.6251 N46005 X1.4229 Y4.6274 N46010 X1.4466 Y4.6309 N46015 X1.4706 Y4.633 N46020 X1.4947 Y4.6343 N46025 X1.519 Y4.6352 N46030 X1.5623 Y4.632 N46035 X1.5838 Y4.63 N46040 X1.6051 Y4.6274 N46045 X1.6261 Y4.624 N46050 X1.6468 Y4.6198 N46055 X1.6669 Y4.6144 N46060 X1.6866 Y4.6078 N46065 X1.7057 Y4.5997 N46070 X1.7243 Y4.5902 N46075 X1.7424 Y4.5795 N46080 X1.7601 Y4.5679 N46085 X1.7774 Y4.5554 N46090 X1.7946 Y4.5424 N46095 X1.8284 Y4.5153 N46100 X1.8554 Y4.4781 N46105 X1.8683 Y4.4593 N46110 X1.8807 Y4.4403 N46115 X1.8922 Y4.421 N46120 X1.9026 Y4.4013 N46125 X1.9118 Y4.3811 N46130 X1.9159 Y4.3709 N46135 X1.9196 Y4.3605 N46140 X1.9259 Y4.3393 N46145 X1.9309 Y4.3176 N46150 X1.9348 Y4.2956 N46155 X1.9379 Y4.2731 N46160 X1.9402 Y4.2505 N46165 X1.9419 Y4.2276 N46170 X1.9445 Y4.1816 N46175 X1.9419 Y4.1359 N46180 X1.9402 Y4.1132 N46185 X1.9379 Y4.0907 N46190 X1.9349 Y4.0685 N46195 X1.931 Y4.0465 N46200 X1.926 Y4.025 N46205 X1.9197 Y4.0039 N46210 X1.916 Y3.9936 N46215 X1.912 Y3.9834 N46220 X1.9029 Y3.9634 N46225 X1.8925 Y3.9438 N46230 X1.8811 Y3.9246 N46235 X1.8689 Y3.9057 N46240 X1.856 Y3.887 N46245 X1.8293 Y3.8501 N46250 X1.7957 Y3.823 N46255 X1.7786 Y3.81 N46260 X1.7613 Y3.7976 N46265 X1.7438 Y3.7859 N46270 X1.7258 Y3.7753 N46275 X1.7073 Y3.7658 N46280 X1.6883 Y3.7578 N46285 X1.6687 Y3.7511 N46290 X1.6486 Y3.7458 N46295 X1.6281 Y3.7416 N46300 X1.6071 Y3.7382 N46305 X1.586 Y3.7356 N46310 X1.5645 Y3.7336 N46315 X1.5214 Y3.7304 N46320 X1.4779 Y3.7335 N46325 Z0.1606 N46330 G0 Z0.2 N46335 X0.9441 Y4.2193 N46340 Z0.1606 N46345 G1 Z-0.0394 F13.123 N46350 X0.829 Y3.7453 F39.37 N46355 X0.6416 N46360 X0.4673 Y4.3995 N46365 X0.2936 Y3.7453 N46370 X0.102 N46375 X-0.1069 Y4.6203 N46380 X0.074 N46385 X0.2059 Y4.0193 N46390 X0.3658 Y4.6203 N46395 X0.5759 N46400 X0.7293 Y4.0091 N46405 X0.8636 Y4.6203 N46410 X1.0415 N46415 X0.9441 Y4.2193 N46420 Z0.1606 N46425 G0 Z0.2 N46430 X-0.5116 Y3.7453 N46435 Z0.1606 N46440 G1 Z-0.0394 F13.123 N46445 X-1.1771 F39.37 N46450 Y4.6203 N46455 X-0.5283 N46460 Y4.4723 N46465 X-1.0004 N46470 Y4.2783 N46475 X-0.5611 N46480 Y4.1309 N46485 X-1.0004 N46490 Y3.8927 N46495 X-0.5116 N46500 Y3.7453 N46505 Z0.1606 N46510 G0 Z0.2 N46515 X1.2827 Y4.1076 N46520 Z0.1606 N46525 G1 Z-0.0394 F13.123 N46530 X1.2849 Y4.0929 F39.37 N46535 X1.2878 Y4.0783 N46540 X1.2914 Y4.064 N46545 X1.296 Y4.05 N46550 X1.3014 Y4.0363 N46555 X1.3077 Y4.0229 N46560 X1.3146 Y4.0096 N46565 X1.3221 Y3.9966 N46570 X1.33 Y3.9837 N46575 X1.3465 Y3.9581 N46580 X1.3651 Y3.9413 N46585 X1.3841 Y3.9255 N46590 X1.3939 Y3.9182 N46595 X1.404 Y3.9115 N46600 X1.4143 Y3.9055 N46605 X1.425 Y3.9003 N46610 X1.4361 Y3.8959 N46615 X1.4475 Y3.8924 N46620 X1.4593 Y3.8895 N46625 X1.4713 Y3.8872 N46630 X1.4958 Y3.8839 N46635 X1.5208 Y3.8814 N46640 X1.5456 Y3.8838 N46645 X1.57 Y3.8871 N46650 X1.5819 Y3.8894 N46655 X1.5936 Y3.8922 N46660 X1.605 Y3.8957 N46665 X1.616 Y3.9 N46670 X1.6267 Y3.9052 N46675 X1.637 Y3.9112 N46680 X1.647 Y3.9178 N46685 X1.6567 Y3.9251 N46690 X1.6756 Y3.9408 N46695 X1.6941 Y3.9575 N46700 X1.7105 Y3.9835 N46705 X1.7184 Y3.9966 N46710 X1.7258 Y4.0099 N46715 X1.7327 Y4.0233 N46720 X1.7389 Y4.0369 N46725 X1.7443 Y4.0508 N46730 X1.7488 Y4.065 N46735 X1.7524 Y4.0795 N46740 X1.7551 Y4.0943 N46745 X1.7573 Y4.1092 N46750 X1.7589 Y4.1243 N46755 X1.7608 Y4.1549 N46760 X1.7619 Y4.1858 N46765 X1.7609 Y4.2161 N46770 X1.759 Y4.2462 N46775 X1.7575 Y4.2611 N46780 X1.7554 Y4.2757 N46785 X1.7527 Y4.2902 N46790 X1.7493 Y4.3044 N46795 X1.7449 Y4.3184 N46800 X1.7397 Y4.3321 N46805 X1.7336 Y4.3455 N46810 X1.7269 Y4.3587 N46815 X1.7196 Y4.3717 N46820 X1.712 Y4.3846 N46825 X1.6959 Y4.4102 N46830 X1.6771 Y4.4267 N46835 X1.658 Y4.4422 N46840 X1.6481 Y4.4494 N46845 X1.638 Y4.4559 N46850 X1.6275 Y4.4617 N46855 X1.6167 Y4.4668 N46860 X1.6056 Y4.4709 N46865 X1.5941 Y4.4743 N46870 X1.5823 Y4.4769 N46875 X1.5703 Y4.4791 N46880 X1.5457 Y4.4821 N46885 X1.5208 Y4.4842 N46890 X1.4957 Y4.482 N46895 X1.4709 Y4.4789 N46900 X1.4589 Y4.4767 N46905 X1.447 Y4.474 N46910 X1.4355 Y4.4706 N46915 X1.4242 Y4.4664 N46920 X1.4134 Y4.4613 N46925 X1.4029 Y4.4554 N46930 X1.3927 Y4.4488 N46935 X1.3828 Y4.4417 N46940 X1.3636 Y4.4259 N46945 X1.3447 Y4.4093 N46950 X1.3285 Y4.3836 N46955 X1.3207 Y4.3706 N46960 X1.3133 Y4.3575 N46965 X1.3065 Y4.3442 N46970 X1.3004 Y4.3307 N46975 X1.2951 Y4.317 N46980 X1.2907 Y4.3029 N46985 X1.2872 Y4.2886 N46990 X1.2844 Y4.274 N46995 X1.2823 Y4.2592 N47000 X1.2808 Y4.2443 N47005 X1.2789 Y4.214 N47010 X1.2778 Y4.1834 N47015 X1.279 Y4.1528 N47020 X1.2811 Y4.1226 N47025 X1.2827 Y4.1076 N47030 Z0.1606 N47035 G0 Z0.2 N47040 X2.083 Y4.1828 N47045 Z0.1606 N47050 G1 Z-0.0394 F13.123 N47055 Y4.6203 F39.37 N47060 X2.4548 N47065 X2.5065 Y4.6198 N47070 X2.5322 Y4.6187 N47075 X2.5578 Y4.6167 N47080 X2.5832 Y4.6133 N47085 X2.6085 Y4.6085 N47090 X2.6336 Y4.6029 N47095 X2.6587 Y4.5967 N47100 X2.674 Y4.5894 N47105 X2.689 Y4.5817 N47110 X2.7033 Y4.5731 N47115 X2.7101 Y4.5685 N47120 X2.7166 Y4.5634 N47125 X2.7228 Y4.558 N47130 X2.7287 Y4.5522 N47135 X2.7398 Y4.5397 N47140 X2.7503 Y4.5265 N47145 X2.7604 Y4.5129 N47150 X2.7689 Y4.4967 N47155 X2.7769 Y4.4804 N47160 X2.7839 Y4.4637 N47165 X2.7869 Y4.4553 N47170 X2.7895 Y4.4467 N47175 X2.7917 Y4.438 N47180 X2.7934 Y4.4293 N47185 X2.7959 Y4.4114 N47190 X2.7975 Y4.3933 N47195 X2.7986 Y4.375 N47200 X2.797 Y4.3526 N47205 X2.7947 Y4.3305 N47210 X2.7931 Y4.3196 N47215 X2.791 Y4.3089 N47220 X2.7884 Y4.2983 N47225 X2.7852 Y4.288 N47230 X2.7813 Y4.278 N47235 X2.7767 Y4.2681 N47240 X2.7716 Y4.2585 N47245 X2.766 Y4.2491 N47250 X2.7537 Y4.2306 N47255 X2.7407 Y4.2124 N47260 X2.7219 Y4.1965 N47265 X2.7027 Y4.1815 N47270 X2.6928 Y4.1744 N47275 X2.6827 Y4.1679 N47280 X2.6723 Y4.162 N47285 X2.6616 Y4.1567 N47290 X2.6505 Y4.1521 N47295 X2.6392 Y4.1481 N47300 X2.6276 Y4.1446 N47305 X2.6159 Y4.1415 N47310 X2.5919 Y4.1361 N47315 X2.5676 Y4.1315 N47320 X2.5931 Y4.1155 N47325 X2.6056 Y4.1071 N47330 X2.6176 Y4.0982 N47335 X2.6293 Y4.0888 N47340 X2.6405 Y4.0788 N47345 X2.6623 Y4.0581 N47350 X2.6896 Y4.0242 N47355 X2.7029 Y4.0069 N47360 X2.7156 Y3.9892 N47365 X2.7278 Y3.9712 N47370 X2.7397 Y3.953 N47375 X2.7628 Y3.916 N47380 X2.8697 Y3.7453 N47385 X2.6584 N47390 X2.5306 Y3.9357 N47395 X2.5087 Y3.9688 N47400 X2.4861 Y4.0015 N47405 X2.4744 Y4.0175 N47410 X2.4623 Y4.0333 N47415 X2.4375 Y4.0643 N47420 X2.4257 Y4.0756 N47425 X2.4196 Y4.0809 N47430 X2.4131 Y4.0857 N47435 X2.4063 Y4.09 N47440 X2.3992 Y4.0939 N47445 X2.3844 Y4.1007 N47450 X2.3625 Y4.1057 N47455 X2.3515 Y4.1076 N47460 X2.3404 Y4.1091 N47465 X2.3292 Y4.1099 N47470 X2.318 Y4.1104 N47475 X2.2955 Y4.1106 N47480 X2.2597 N47485 Y3.7453 N47490 X2.083 N47495 Y4.1828 N47500 Z0.1606 N47505 G0 Z0.2 N47510 X2.2597 Y4.2502 N47515 Z0.1606 N47520 G1 Z-0.0394 F13.123 N47525 X2.3904 F39.37 N47530 X2.4303 Y4.25 N47535 X2.4503 Y4.2503 N47540 X2.4701 Y4.2511 N47545 X2.49 Y4.2526 N47550 X2.5097 Y4.2549 N47555 X2.5491 Y4.261 N47560 X2.5637 Y4.2674 N47565 X2.5706 Y4.2711 N47570 X2.577 Y4.2754 N47575 X2.5829 Y4.2804 N47580 X2.5884 Y4.2859 N47585 X2.5987 Y4.298 N47590 X2.6067 Y4.3134 N47595 X2.61 Y4.3213 N47600 X2.6126 Y4.3294 N47605 X2.6144 Y4.3378 N47610 X2.6155 Y4.3463 N47615 X2.6166 Y4.3637 N47620 X2.6151 Y4.383 N47625 X2.6137 Y4.3924 N47630 X2.6114 Y4.4016 N47635 X2.6079 Y4.4103 N47640 X2.6035 Y4.4187 N47645 X2.593 Y4.435 N47650 X2.5786 Y4.4477 N47655 X2.5709 Y4.4533 N47660 X2.5629 Y4.458 N47665 X2.5542 Y4.4618 N47670 X2.5452 Y4.4647 N47675 X2.5265 Y4.4693 N47680 X2.4943 Y4.4711 N47685 X2.462 Y4.4721 N47690 X2.3975 Y4.4723 N47695 X2.2597 N47700 Y4.2502 N47705 Z0.1606 N47710 G0 Z0.2 N47715 X2.9675 Y4.2453 N47720 Z0.1606 N47725 G1 Z-0.0394 F13.123 N47730 Y4.6203 F39.37 N47735 X3.1442 N47740 Y4.2318 N47745 X3.5011 Y4.6203 N47750 X3.7387 N47755 X3.4092 Y4.2795 N47760 X3.7566 Y3.7453 N47765 X3.528 N47770 X3.2875 Y4.1559 N47775 X3.1442 Y4.0097 N47780 Y3.7453 N47785 X2.9675 N47790 Y4.2453 N47795 Z0.1606 N47800 G0 Z0.2 N47805 X3.8172 Y3.9594 N47810 Z0.1606 N47815 G1 Z-0.0394 F13.123 N47820 X3.8153 Y3.967 F39.37 N47825 X3.8087 Y3.9983 N47830 X3.8032 Y4.03 N47835 X3.975 Y4.0467 N47840 X3.979 Y4.0288 N47845 X3.9834 Y4.0111 N47850 X3.9888 Y3.994 N47855 X3.992 Y3.9856 N47860 X3.9956 Y3.9775 N47865 X3.9996 Y3.9696 N47870 X4.0042 Y3.962 N47875 X4.0145 Y3.9474 N47880 X4.026 Y3.9333 N47885 X4.038 Y3.9196 N47890 X4.0526 Y3.9102 N47895 X4.0673 Y3.9013 N47900 X4.0825 Y3.8936 N47905 X4.0902 Y3.8904 N47910 X4.0982 Y3.8877 N47915 X4.1063 Y3.8855 N47920 X4.1146 Y3.8838 N47925 X4.1315 Y3.8813 N47930 X4.1487 Y3.8799 N47935 X4.1661 Y3.879 N47940 X4.1833 Y3.8796 N47945 X4.2004 Y3.8806 N47950 X4.2173 Y3.8826 N47955 X4.2256 Y3.884 N47960 X4.2337 Y3.8859 N47965 X4.2417 Y3.8883 N47970 X4.2496 Y3.8912 N47975 X4.2649 Y3.8982 N47980 X4.2799 Y3.9064 N47985 X4.2947 Y3.9151 N47990 X4.3037 Y3.9239 N47995 X4.3122 Y3.9329 N48000 X4.3198 Y3.9423 N48005 X4.3232 Y3.9473 N48010 X4.3262 Y3.9524 N48015 X4.3287 Y3.9578 N48020 X4.3308 Y3.9633 N48025 X4.334 Y3.975 N48030 X4.3362 Y3.9872 N48035 X4.338 Y3.9996 N48040 X4.3367 Y4.0139 N48045 X4.3355 Y4.0209 N48050 X4.3336 Y4.0276 N48055 X4.3309 Y4.0341 N48060 X4.3276 Y4.0404 N48065 X4.3197 Y4.0524 N48070 X4.3056 Y4.0648 N48075 X4.2983 Y4.0704 N48080 X4.2905 Y4.0754 N48085 X4.2822 Y4.0797 N48090 X4.2737 Y4.0835 N48095 X4.2562 Y4.0903 N48100 X4.2211 Y4.1007 N48105 X4.1857 Y4.1106 N48110 X4.1147 Y4.1285 N48115 X4.088 Y4.1354 N48120 X4.0615 Y4.1427 N48125 X4.0354 Y4.1509 N48130 X4.0226 Y4.1556 N48135 X4.0099 Y4.1606 N48140 X3.9975 Y4.166 N48145 X3.9853 Y4.172 N48150 X3.9733 Y4.1784 N48155 X3.9615 Y4.1853 N48160 X3.9383 Y4.1998 N48165 X3.9154 Y4.215 N48170 X3.8981 Y4.2338 N48175 X3.8817 Y4.2529 N48180 X3.8742 Y4.2628 N48185 X3.8672 Y4.2729 N48190 X3.8609 Y4.2833 N48195 X3.8554 Y4.2941 N48200 X3.8508 Y4.3053 N48205 X3.847 Y4.3169 N48210 X3.8439 Y4.3288 N48215 X3.8414 Y4.3409 N48220 X3.8376 Y4.3658 N48225 X3.8348 Y4.3911 N48230 X3.8361 Y4.4078 N48235 X3.8379 Y4.4243 N48240 X3.8405 Y4.4406 N48245 X3.8423 Y4.4485 N48250 X3.8445 Y4.4564 N48255 X3.85 Y4.4718 N48260 X3.8569 Y4.4868 N48265 X3.8646 Y4.5015 N48270 X3.8727 Y4.5161 N48275 X3.8838 Y4.5303 N48280 X3.8953 Y4.544 N48285 X3.9074 Y4.557 N48290 X3.9139 Y4.563 N48295 X3.9206 Y4.5687 N48300 X3.9275 Y4.5741 N48305 X3.9348 Y4.5791 N48310 X3.95 Y4.5883 N48315 X3.9658 Y4.5967 N48320 X3.9819 Y4.6048 N48325 X4.0028 Y4.6119 N48330 X4.0239 Y4.6185 N48335 X4.045 Y4.6242 N48340 X4.0664 Y4.6287 N48345 X4.0881 Y4.6317 N48350 X4.11 Y4.6335 N48355 X4.1541 Y4.6352 N48360 X4.1876 Y4.6341 N48365 X4.2207 Y4.632 N48370 X4.2371 Y4.6303 N48375 X4.2533 Y4.628 N48380 X4.2693 Y4.625 N48385 X4.285 Y4.6213 N48390 X4.3005 Y4.6165 N48395 X4.3156 Y4.6107 N48400 X4.3304 Y4.6041 N48405 X4.345 Y4.5968 N48410 X4.3594 Y4.5889 N48415 X4.3737 Y4.5805 N48420 X4.4021 Y4.563 N48425 X4.4208 Y4.5425 N48430 X4.4298 Y4.532 N48435 X4.4384 Y4.5215 N48440 X4.4466 Y4.5107 N48445 X4.4541 Y4.4996 N48450 X4.4609 Y4.4881 N48455 X4.4667 Y4.4762 N48460 X4.4717 Y4.4639 N48465 X4.4758 Y4.4513 N48470 X4.4792 Y4.4383 N48475 X4.482 Y4.425 N48480 X4.4862 Y4.3978 N48485 X4.4895 Y4.3702 N48490 X4.3129 Y4.3625 N48495 X4.31 Y4.3763 N48500 X4.3067 Y4.3899 N48505 X4.3027 Y4.4031 N48510 X4.2975 Y4.4157 N48515 X4.2944 Y4.4217 N48520 X4.2908 Y4.4275 N48525 X4.2827 Y4.4385 N48530 X4.2737 Y4.4491 N48535 X4.2642 Y4.4594 N48540 X4.2513 Y4.4667 N48545 X4.2381 Y4.4734 N48550 X4.2247 Y4.4792 N48555 X4.2179 Y4.4815 N48560 X4.2109 Y4.4835 N48565 X4.1967 Y4.4862 N48570 X4.182 Y4.4878 N48575 X4.1672 Y4.4886 N48580 X4.1523 Y4.489 N48585 X4.1363 Y4.4884 N48590 X4.1204 Y4.4874 N48595 X4.1047 Y4.4857 N48600 X4.0894 Y4.4826 N48605 X4.0819 Y4.4806 N48610 X4.0745 Y4.478 N48615 X4.06 Y4.472 N48620 X4.0458 Y4.4649 N48625 X4.0318 Y4.4574 N48630 X4.02 Y4.4463 N48635 X4.0149 Y4.4403 N48640 X4.0108 Y4.4338 N48645 X4.0079 Y4.4267 N48650 X4.0059 Y4.4191 N48655 X4.0037 Y4.4031 N48660 X4.006 Y4.3877 N48665 X4.0079 Y4.3804 N48670 X4.0106 Y4.3735 N48675 X4.0145 Y4.3671 N48680 X4.0192 Y4.3611 N48685 X4.03 Y4.3499 N48690 X4.0491 Y4.3396 N48695 X4.0684 Y4.3298 N48700 X4.0881 Y4.3209 N48705 X4.1083 Y4.3133 N48710 X4.1289 Y4.3069 N48715 X4.1499 Y4.3013 N48720 X4.1923 Y4.2915 N48725 X4.2412 Y4.2794 N48730 X4.2655 Y4.2728 N48735 X4.2895 Y4.2655 N48740 X4.3133 Y4.2573 N48745 X4.3367 Y4.2482 N48750 X4.383 Y4.2285 N48755 X4.3973 Y4.2198 N48760 X4.4113 Y4.2107 N48765 X4.4248 Y4.2011 N48770 X4.4374 Y4.1906 N48775 X4.449 Y4.1789 N48780 X4.4597 Y4.1663 N48785 X4.4698 Y4.1531 N48790 X4.4797 Y4.1395 N48795 X4.4877 Y4.1231 N48800 X4.4953 Y4.1065 N48805 X4.5018 Y4.0896 N48810 X4.5046 Y4.0811 N48815 X4.5069 Y4.0724 N48820 X4.5104 Y4.0547 N48825 X4.5125 Y4.0367 N48830 X4.5138 Y4.0185 N48835 X4.5146 Y4.0002 N48840 X4.5132 Y3.9815 N48845 X4.5112 Y3.9629 N48850 X4.5083 Y3.9446 N48855 X4.5064 Y3.9356 N48860 X4.504 Y3.9267 N48865 X4.5011 Y3.918 N48870 X4.4979 Y3.9094 N48875 X4.4903 Y3.8924 N48880 X4.4818 Y3.8758 N48885 X4.4728 Y3.8593 N48890 X4.4609 Y3.8437 N48895 X4.4486 Y3.8285 N48900 X4.4356 Y3.8142 N48905 X4.4287 Y3.8076 N48910 X4.4214 Y3.8013 N48915 X4.4139 Y3.7954 N48920 X4.406 Y3.7899 N48925 X4.3894 Y3.7798 N48930 X4.3722 Y3.7705 N48935 X4.3546 Y3.7617 N48940 X4.3315 Y3.7542 N48945 X4.3082 Y3.7472 N48950 X4.2848 Y3.7411 N48955 X4.273 Y3.7386 N48960 X4.2611 Y3.7364 N48965 X4.2371 Y3.7334 N48970 X4.213 Y3.7315 N48975 X4.1887 Y3.7304 N48980 X4.1643 Y3.7298 N48985 X4.1298 Y3.7312 N48990 X4.0956 Y3.7336 N48995 X4.0788 Y3.7355 N49000 X4.0621 Y3.7379 N49005 X4.0457 Y3.7412 N49010 X4.0295 Y3.7453 N49015 X4.0137 Y3.7503 N49020 X3.9981 Y3.7564 N49025 X3.9829 Y3.7634 N49030 X3.968 Y3.7711 N49035 X3.9531 Y3.7794 N49040 X3.9385 Y3.7882 N49045 X3.9094 Y3.8065 N49050 X3.8881 Y3.8305 N49055 X3.8778 Y3.8427 N49060 X3.8679 Y3.855 N49065 X3.8585 Y3.8677 N49070 X3.8498 Y3.8806 N49075 X3.8419 Y3.894 N49080 X3.8349 Y3.9078 N49085 X3.8289 Y3.9221 N49090 X3.8237 Y3.9367 N49095 X3.8192 Y3.9517 N49100 X3.8172 Y3.9594 N49105 Z0.1606 N49110 G0 Z0.2 N49115 X4.9676 Y3.9852 N49120 Z0.1606 N49125 G1 Z-0.0394 F13.123 N49130 X4.9693 Y4.0057 F39.37 N49135 X4.9715 Y4.0259 N49140 X4.975 Y4.0458 N49145 X4.9773 Y4.0555 N49150 X4.9802 Y4.0651 N49155 X4.9835 Y4.0744 N49160 X4.9875 Y4.0836 N49165 X4.9966 Y4.1016 N49170 X5.0069 Y4.1192 N49175 X5.0178 Y4.1365 N49180 X5.0339 Y4.1544 N49185 X5.0504 Y4.1719 N49190 X5.0676 Y4.1884 N49195 X5.0765 Y4.1962 N49200 X5.0858 Y4.2036 N49205 X5.0954 Y4.2106 N49210 X5.1052 Y4.2174 N49215 X5.1255 Y4.23 N49220 X5.1464 Y4.2418 N49225 X5.1676 Y4.2532 N49230 X5.1485 Y4.2771 N49235 X5.1393 Y4.2893 N49240 X5.1306 Y4.3017 N49245 X5.1224 Y4.3145 N49250 X5.1147 Y4.3276 N49255 X5.1001 Y4.3544 N49260 X5.091 Y4.3763 N49265 X5.087 Y4.3874 N49270 X5.0837 Y4.3987 N49275 X5.0813 Y4.4102 N49280 X5.0796 Y4.4218 N49285 X5.0774 Y4.4454 N49290 X5.0797 Y4.4649 N49295 X5.0828 Y4.4841 N49300 X5.0848 Y4.4934 N49305 X5.0872 Y4.5025 N49310 X5.0902 Y4.5113 N49315 X5.0939 Y4.5199 N49320 X5.0982 Y4.5281 N49325 X5.1032 Y4.5361 N49330 X5.1087 Y4.5438 N49335 X5.1146 Y4.5513 N49340 X5.1275 Y4.5658 N49345 X5.141 Y4.58 N49350 X5.1617 Y4.5931 N49355 X5.1826 Y4.6054 N49360 X5.1932 Y4.6109 N49365 X5.204 Y4.616 N49370 X5.215 Y4.6204 N49375 X5.2263 Y4.624 N49380 X5.2378 Y4.627 N49385 X5.2495 Y4.6293 N49390 X5.2613 Y4.6311 N49395 X5.2733 Y4.6324 N49400 X5.2976 Y4.6342 N49405 X5.3222 Y4.6352 N49410 X5.3464 Y4.634 N49415 X5.3704 Y4.632 N49420 X5.3822 Y4.6306 N49425 X5.3938 Y4.6286 N49430 X5.4053 Y4.6261 N49435 X5.4165 Y4.623 N49440 X5.4275 Y4.6191 N49445 X5.4383 Y4.6145 N49450 X5.4488 Y4.6093 N49455 X5.4591 Y4.6035 N49460 X5.4794 Y4.5909 N49465 X5.4994 Y4.5773 N49470 X5.5131 Y4.5622 N49475 X5.5261 Y4.5468 N49480 X5.5322 Y4.5389 N49485 X5.5377 Y4.5307 N49490 X5.5427 Y4.5223 N49495 X5.547 Y4.5137 N49500 X5.5507 Y4.5046 N49505 X5.5537 Y4.4954 N49510 X5.5561 Y4.4858 N49515 X5.5581 Y4.4761 N49520 X5.5611 Y4.4561 N49525 X5.5633 Y4.4359 N49530 X5.5606 Y4.409 N49535 X5.5584 Y4.3959 N49540 X5.5551 Y4.3831 N49545 X5.5504 Y4.3707 N49550 X5.5448 Y4.3586 N49555 X5.5317 Y4.335 N49560 X5.5178 Y4.3191 N49565 X5.5036 Y4.3035 N49570 X5.4889 Y4.2887 N49575 X5.4732 Y4.2748 N49580 X5.4566 Y4.262 N49585 X5.4394 Y4.2499 N49590 X5.4039 Y4.227 N49595 X5.5257 Y4.0664 N49600 X5.5372 Y4.0905 N49605 X5.5426 Y4.1027 N49610 X5.5474 Y4.115 N49615 X5.5517 Y4.1276 N49620 X5.5556 Y4.1404 N49625 X5.5627 Y4.1661 N49630 X5.7143 Y4.1315 N49635 X5.7057 Y4.1016 N49640 X5.6965 Y4.0719 N49645 X5.6862 Y4.0426 N49650 X5.6749 Y4.0136 N49655 X5.6672 Y3.9973 N49660 X5.6588 Y3.9814 N49665 X5.6493 Y3.9661 N49670 X5.6391 Y3.9512 N49675 X5.6565 Y3.936 N49680 X5.6744 Y3.9212 N49685 X5.6928 Y3.9072 N49690 X5.7116 Y3.8936 N49695 X5.7275 Y3.8825 N49700 X5.7436 Y3.8717 N49705 X5.7601 Y3.8617 N49710 X5.777 Y3.8521 N49715 X5.6755 Y3.7226 N49720 X5.6371 Y3.744 N49725 X5.6184 Y3.7553 N49730 X5.6002 Y3.7674 N49735 X5.5826 Y3.7805 N49740 X5.5656 Y3.7942 N49745 X5.5323 Y3.8229 N49750 X5.5063 Y3.8017 N49755 X5.4929 Y3.7917 N49760 X5.4791 Y3.7824 N49765 X5.4648 Y3.7741 N49770 X5.4499 Y3.7664 N49775 X5.4194 Y3.7525 N49780 X5.3847 Y3.7423 N49785 X5.3672 Y3.738 N49790 X5.3495 Y3.7347 N49795 X5.3317 Y3.7325 N49800 X5.3136 Y3.7311 N49805 X5.2774 Y3.7298 N49810 X5.2429 Y3.7317 N49815 X5.2258 Y3.733 N49820 X5.2088 Y3.7347 N49825 X5.1921 Y3.7371 N49830 X5.1757 Y3.7401 N49835 X5.1596 Y3.7441 N49840 X5.1439 Y3.749 N49845 X5.1287 Y3.7551 N49850 X5.1139 Y3.7624 N49855 X5.0996 Y3.7707 N49860 X5.0856 Y3.7799 N49865 X5.0718 Y3.7898 N49870 X5.0583 Y3.8001 N49875 X5.0315 Y3.8217 N49880 X5.0178 Y3.8399 N49885 X5.0048 Y3.8584 N49890 X4.9988 Y3.8679 N49895 X4.9932 Y3.8775 N49900 X4.9882 Y3.8873 N49905 X4.9839 Y3.8974 N49910 X4.9802 Y3.9077 N49915 X4.9772 Y3.9183 N49920 X4.9748 Y3.9292 N49925 X4.9728 Y3.9402 N49930 X4.9698 Y3.9626 N49935 X4.9676 Y3.9852 N49940 Z0.1606 N49945 G0 Z0.2 N49950 X5.4254 Y3.9351 N49955 Z0.1606 N49960 G1 Z-0.0394 F13.123 N49965 X5.2547 Y4.1458 F39.37 N49970 X5.2301 Y4.1318 N49975 X5.2183 Y4.1242 N49980 X5.207 Y4.1159 N49985 X5.1965 Y4.1067 N49990 X5.1867 Y4.0967 N49995 X5.1682 Y4.0754 N50000 X5.1565 Y4.0558 N50005 X5.1515 Y4.0458 N50010 X5.1473 Y4.0355 N50015 X5.1442 Y4.0248 N50020 X5.1421 Y4.0138 N50025 X5.1395 Y3.9912 N50030 X5.1406 Y3.9787 N50035 X5.142 Y3.9665 N50040 X5.1443 Y3.9545 N50045 X5.1459 Y3.9487 N50050 X5.1479 Y3.9431 N50055 X5.1503 Y3.9376 N50060 X5.1531 Y3.9323 N50065 X5.1597 Y3.9221 N50070 X5.1671 Y3.9123 N50075 X5.175 Y3.9026 N50080 X5.1856 Y3.8947 N50085 X5.1964 Y3.8874 N50090 X5.2075 Y3.8809 N50095 X5.2132 Y3.8782 N50100 X5.2191 Y3.8759 N50105 X5.2313 Y3.8725 N50110 X5.2441 Y3.8704 N50115 X5.257 Y3.8691 N50120 X5.2702 Y3.8683 N50125 X5.2897 Y3.8695 N50130 X5.2994 Y3.8705 N50135 X5.3089 Y3.8722 N50140 X5.3183 Y3.8744 N50145 X5.3276 Y3.8772 N50150 X5.3461 Y3.8838 N50155 X5.3672 Y3.8946 N50160 X5.3775 Y3.9004 N50165 X5.3876 Y3.9066 N50170 X5.3973 Y3.9133 N50175 X5.4068 Y3.9204 N50180 X5.4254 Y3.9351 N50185 Z0.1606 N50190 G0 Z0.2 N50195 X5.3204 Y4.3278 N50200 Z0.1606 N50205 G1 Z-0.0394 F13.123 N50210 X5.3657 Y4.3625 F39.37 N50215 X5.3752 Y4.3702 N50220 X5.3843 Y4.3781 N50225 X5.3926 Y4.3865 N50230 X5.3998 Y4.3955 N50235 X5.4029 Y4.4004 N50240 X5.4056 Y4.4054 N50245 X5.4098 Y4.4163 N50250 X5.4131 Y4.4277 N50255 X5.4159 Y4.4394 N50260 X5.4139 Y4.455 N50265 X5.4122 Y4.4624 N50270 X5.4097 Y4.4695 N50275 X5.4062 Y4.4761 N50280 X5.4018 Y4.4824 N50285 X5.3917 Y4.4944 N50290 X5.377 Y4.5045 N50295 X5.3693 Y4.5088 N50300 X5.3613 Y4.5121 N50305 X5.3529 Y4.5143 N50310 X5.3443 Y4.5157 N50315 X5.3263 Y4.517 N50320 X5.3094 Y4.5159 N50325 X5.3011 Y4.5148 N50330 X5.2931 Y4.5128 N50335 X5.2854 Y4.5099 N50340 X5.278 Y4.5061 N50345 X5.2637 Y4.497 N50350 X5.2544 Y4.4872 N50355 X5.2504 Y4.482 N50360 X5.2471 Y4.4764 N50365 X5.2447 Y4.4704 N50370 X5.243 Y4.4641 N50375 X5.241 Y4.4508 N50380 X5.2432 Y4.4402 N50385 X5.2459 Y4.4298 N50390 X5.2492 Y4.4197 N50395 X5.2536 Y4.4102 N50400 X5.2591 Y4.4011 N50405 X5.2654 Y4.3924 N50410 X5.2792 Y4.3756 N50415 X5.3204 Y4.3278 N50420 Z0.1606 N50425 G0 Z0.2 N50430 X5.376 Y-2.0457 N50435 Z0.1606 N50440 G1 Z-0.0394 F13.123 N50445 X5.6474 F39.37 N50450 X5.6403 Y-2.0669 N50455 X5.6069 N50460 X5.5927 Y-2.0678 N50465 X5.5857 Y-2.0687 N50470 X5.579 Y-2.0702 N50475 X5.5724 Y-2.0724 N50480 X5.5661 Y-2.0753 N50485 X5.5537 Y-2.0822 N50490 X5.5432 Y-2.0926 N50495 X5.5384 Y-2.0981 N50500 X5.5342 Y-2.104 N50505 X5.5306 Y-2.1103 N50510 X5.5274 Y-2.1169 N50515 X5.522 Y-2.1307 N50520 X5.4245 Y-2.4171 N50525 X5.5175 N50530 X5.5322 Y-2.416 N50535 X5.5394 Y-2.4151 N50540 X5.5466 Y-2.4138 N50545 X5.5536 Y-2.412 N50550 X5.5606 Y-2.4097 N50555 X5.5744 Y-2.4047 N50560 X5.5889 Y-2.3976 N50565 X5.6028 Y-2.3897 N50570 X5.6159 Y-2.3806 N50575 X5.6286 Y-2.3707 N50580 X5.6439 Y-2.3566 N50585 X5.6586 Y-2.342 N50590 X5.673 Y-2.3256 N50595 X5.6863 Y-2.3083 N50600 X5.7035 Y-2.2836 N50605 X5.7198 Y-2.2584 N50610 X5.74 N50615 X5.6788 Y-2.4382 N50620 X5.2428 N50625 X5.2492 Y-2.4171 N50630 X5.2689 N50635 X5.2839 Y-2.4147 N50640 X5.2982 Y-2.4116 N50645 X5.305 Y-2.4096 N50650 X5.3115 Y-2.4071 N50655 X5.3176 Y-2.404 N50660 X5.3231 Y-2.4003 N50665 X5.3282 Y-2.3959 N50670 X5.3328 Y-2.3909 N50675 X5.337 Y-2.3853 N50680 X5.3409 Y-2.3793 N50685 X5.348 Y-2.3664 N50690 X5.3546 Y-2.3527 N50695 X5.4301 Y-2.1307 N50700 X5.4328 Y-2.1172 N50705 X5.4339 Y-2.1107 N50710 X5.4346 Y-2.1045 N50715 X5.4347 Y-2.0985 N50720 X5.4343 Y-2.0931 N50725 X5.4331 Y-2.0881 N50730 X5.431 Y-2.0837 N50735 X5.428 Y-2.08 N50740 X5.424 Y-2.077 N50745 X5.4192 Y-2.0745 N50750 X5.4137 Y-2.0724 N50755 X5.4078 Y-2.0707 N50760 X5.4014 Y-2.0693 N50765 X5.388 Y-2.0669 N50770 X5.3688 N50775 X5.376 Y-2.0457 N50780 Z0.1606 N50785 G0 Z0.2 N50790 X5.7895 Y-2.3754 N50795 Z0.1606 N50800 G1 Z-0.0394 F13.123 N50805 X5.793 Y-2.3712 F39.37 N50810 X5.7969 Y-2.3673 N50815 X5.8054 Y-2.3598 N50820 X5.8144 Y-2.3538 N50825 X5.8192 Y-2.3511 N50830 X5.824 Y-2.3489 N50835 X5.8291 Y-2.3473 N50840 X5.8343 Y-2.3461 N50845 X5.8452 Y-2.3447 N50850 X5.8543 Y-2.3456 N50855 X5.8587 Y-2.3465 N50860 X5.8629 Y-2.3479 N50865 X5.8667 Y-2.35 N50870 X5.8702 Y-2.3527 N50875 X5.8768 Y-2.3592 N50880 X5.8806 Y-2.3678 N50885 X5.882 Y-2.3722 N50890 X5.8827 Y-2.3766 N50895 X5.8826 Y-2.3811 N50900 X5.882 Y-2.3857 N50905 X5.8797 Y-2.3949 N50910 X5.8748 Y-2.4053 N50915 X5.872 Y-2.4102 N50920 X5.8689 Y-2.4148 N50925 X5.8652 Y-2.419 N50930 X5.8612 Y-2.423 N50935 X5.8525 Y-2.4304 N50940 X5.8432 Y-2.4364 N50945 X5.8384 Y-2.439 N50950 X5.8335 Y-2.4411 N50955 X5.8283 Y-2.4427 N50960 X5.823 Y-2.4438 N50965 X5.812 Y-2.4452 N50970 X5.8031 Y-2.4442 N50975 X5.7989 Y-2.4433 N50980 X5.7949 Y-2.4418 N50985 X5.7913 Y-2.4396 N50990 X5.788 Y-2.4368 N50995 X5.7818 Y-2.4303 N51000 X5.7781 Y-2.4217 N51005 X5.7768 Y-2.4174 N51010 X5.7761 Y-2.413 N51015 Y-2.4086 N51020 X5.7767 Y-2.4041 N51025 X5.7789 Y-2.3949 N51030 X5.7837 Y-2.3848 N51035 X5.7864 Y-2.38 N51040 X5.7895 Y-2.3754 N51045 Z0.1606 N51050 G0 Z0.2 N51055 X6.0256 Y-2.3175 N51060 Z0.1606 N51065 G1 Z-0.0394 F13.123 N51070 X6.0243 Y-2.3047 F39.37 N51075 X6.0241 Y-2.2919 N51080 X6.0254 Y-2.2792 N51085 X6.0278 Y-2.2665 N51090 X6.0344 Y-2.2411 N51095 X6.0413 Y-2.2241 N51100 X6.0491 Y-2.2075 N51105 X6.0584 Y-2.1917 N51110 X6.0685 Y-2.1763 N51115 X6.0811 Y-2.1602 N51120 X6.0944 Y-2.1447 N51125 X6.1089 Y-2.1303 N51130 X6.124 Y-2.1164 N51135 X6.1393 Y-2.1043 N51140 X6.1552 Y-2.093 N51145 X6.1634 Y-2.0879 N51150 X6.172 Y-2.0832 N51155 X6.1894 Y-2.0744 N51160 X6.2182 Y-2.0597 N51165 X6.2329 Y-2.0533 N51170 X6.2479 Y-2.048 N51175 X6.2633 Y-2.0441 N51180 X6.2791 Y-2.0415 N51185 X6.2951 Y-2.0397 N51190 X6.3113 Y-2.0382 N51195 X6.3299 Y-2.0391 N51200 X6.3483 Y-2.0418 N51205 X6.3564 Y-2.0438 N51210 X6.3643 Y-2.0463 N51215 X6.3719 Y-2.0496 N51220 X6.3793 Y-2.0533 N51225 X6.3865 Y-2.0579 N51230 X6.3934 Y-2.0629 N51235 X6.4062 Y-2.0742 N51240 X6.4105 Y-2.078 N51245 X6.415 Y-2.0814 N51250 X6.42 Y-2.0837 N51255 X6.4254 Y-2.0853 N51260 X6.4423 Y-2.0784 N51265 X6.4503 Y-2.0742 N51270 X6.4578 Y-2.0692 N51275 X6.465 Y-2.0636 N51280 X6.4718 Y-2.0575 N51285 X6.485 Y-2.0446 N51290 X6.503 N51295 X6.445 Y-2.2392 N51300 X6.4257 N51305 X6.4274 Y-2.2211 N51310 X6.4283 Y-2.203 N51315 X6.4276 Y-2.1895 N51320 X6.4258 Y-2.1762 N51325 X6.4225 Y-2.1596 N51330 X6.4205 Y-2.1515 N51335 X6.4181 Y-2.1435 N51340 X6.4152 Y-2.1357 N51345 X6.4118 Y-2.128 N51350 X6.4043 Y-2.113 N51355 X6.3961 Y-2.1009 N51360 X6.3916 Y-2.0952 N51365 X6.3868 Y-2.0899 N51370 X6.3815 Y-2.085 N51375 X6.3759 Y-2.0806 N51380 X6.3639 Y-2.0722 N51385 X6.3508 Y-2.0662 N51390 X6.3441 Y-2.0637 N51395 X6.3373 Y-2.0616 N51400 X6.3303 Y-2.0602 N51405 X6.3232 Y-2.0593 N51410 X6.3088 Y-2.0583 N51415 X6.2915 Y-2.0597 N51420 X6.2831 Y-2.061 N51425 X6.2748 Y-2.0629 N51430 X6.2668 Y-2.0657 N51435 X6.259 Y-2.0692 N51440 X6.2437 Y-2.0774 N51445 X6.2278 Y-2.0904 N51450 X6.2202 Y-2.0973 N51455 X6.2132 Y-2.1047 N51460 X6.2067 Y-2.1126 N51465 X6.2007 Y-2.1209 N51470 X6.1893 Y-2.1381 N51475 X6.1753 Y-2.164 N51480 X6.1687 Y-2.1772 N51485 X6.1625 Y-2.1905 N51490 X6.1568 Y-2.2041 N51495 X6.1515 Y-2.2178 N51500 X6.1415 Y-2.2455 N51505 X6.131 Y-2.2788 N51510 X6.1267 Y-2.2956 N51515 X6.1227 Y-2.3126 N51520 X6.1206 Y-2.3245 N51525 X6.1189 Y-2.3366 N51530 X6.1184 Y-2.3486 N51535 X6.1185 Y-2.3608 N51540 X6.1198 Y-2.3702 N51545 X6.1217 Y-2.3793 N51550 X6.1248 Y-2.3882 N51555 X6.1285 Y-2.3969 N51560 X6.1348 Y-2.4031 N51565 X6.1416 Y-2.4085 N51570 X6.1492 Y-2.4129 N51575 X6.1571 Y-2.4167 N51580 X6.1682 Y-2.4204 N51585 X6.1795 Y-2.4231 N51590 X6.191 Y-2.4244 N51595 X6.2027 Y-2.4249 N51600 X6.2152 Y-2.4244 N51605 X6.2276 Y-2.4233 N51610 X6.2399 Y-2.4212 N51615 X6.2521 Y-2.4186 N51620 X6.2646 Y-2.4148 N51625 X6.2769 Y-2.4106 N51630 X6.2889 Y-2.4054 N51635 X6.3006 Y-2.3997 N51640 X6.3127 Y-2.3929 N51645 X6.3244 Y-2.3856 N51650 X6.3357 Y-2.3776 N51655 X6.3467 Y-2.3692 N51660 X6.3635 Y-2.3542 N51665 X6.3791 Y-2.3379 N51670 X6.3963 Y-2.3159 N51675 X6.4122 Y-2.2929 N51680 X6.4317 N51685 X6.4244 Y-2.3055 N51690 X6.4169 Y-2.3178 N51695 X6.4087 Y-2.3298 N51700 X6.4 Y-2.3414 N51705 X6.3843 Y-2.3586 N51710 X6.3673 Y-2.3746 N51715 X6.3474 Y-2.3895 N51720 X6.3272 Y-2.4037 N51725 X6.3169 Y-2.4103 N51730 X6.3065 Y-2.4164 N51735 X6.2957 Y-2.422 N51740 X6.2848 Y-2.4269 N51745 X6.2735 Y-2.431 N51750 X6.262 Y-2.4345 N51755 X6.2502 Y-2.4373 N51760 X6.2383 Y-2.4397 N51765 X6.2139 Y-2.4433 N51770 X6.1892 Y-2.446 N51775 X6.1622 Y-2.4442 N51780 X6.1489 Y-2.4425 N51785 X6.136 Y-2.4397 N51790 X6.1234 Y-2.4357 N51795 X6.1111 Y-2.4305 N51800 X6.087 Y-2.4183 N51805 X6.0682 Y-2.403 N51810 X6.0596 Y-2.3948 N51815 X6.0519 Y-2.3859 N51820 X6.0454 Y-2.3761 N51825 X6.0398 Y-2.3655 N51830 X6.0303 Y-2.3433 N51835 X6.0277 Y-2.3304 N51840 X6.0256 Y-2.3175 N51845 Z0.1606 N51850 G0 Z0.2 N51855 X6.5107 Y-2.2909 N51860 Z0.1606 N51865 G1 Z-0.0394 F13.123 N51870 X6.5114 Y-2.2811 F39.37 N51875 X6.5129 Y-2.2712 N51880 X6.515 Y-2.2615 N51885 X6.5204 Y-2.2421 N51890 X6.5328 Y-2.214 N51895 X6.5397 Y-2.2004 N51900 X6.5475 Y-2.1874 N51905 X6.5563 Y-2.175 N51910 X6.566 Y-2.1632 N51915 X6.5867 Y-2.1404 N51920 X6.6118 Y-2.1183 N51925 X6.6248 Y-2.1078 N51930 X6.6383 Y-2.098 N51935 X6.6524 Y-2.0891 N51940 X6.6669 Y-2.081 N51945 X6.6969 Y-2.0658 N51950 X6.727 Y-2.0544 N51955 X6.7422 Y-2.0495 N51960 X6.7576 Y-2.0455 N51965 X6.7733 Y-2.0426 N51970 X6.7892 Y-2.0406 N51975 X6.8213 Y-2.0382 N51980 X6.8454 Y-2.0393 N51985 X6.8574 Y-2.0404 N51990 X6.8692 Y-2.0421 N51995 X6.8809 Y-2.0447 N52000 X6.8924 Y-2.048 N52005 X6.9153 Y-2.0558 N52010 X6.9333 Y-2.0655 N52015 X6.9419 Y-2.0708 N52020 X6.9499 Y-2.0768 N52025 X6.9573 Y-2.0836 N52030 X6.9641 Y-2.091 N52035 X6.9769 Y-2.1069 N52040 X6.9851 Y-2.1219 N52045 X6.9888 Y-2.1296 N52050 X6.9919 Y-2.1375 N52055 X6.9943 Y-2.1456 N52060 X6.9961 Y-2.1539 N52065 X6.999 Y-2.1708 N52070 X6.9994 Y-2.1891 N52075 X6.9992 Y-2.1982 N52080 X6.9984 Y-2.2073 N52085 X6.9969 Y-2.2162 N52090 X6.9949 Y-2.2251 N52095 X6.99 Y-2.2428 N52100 X6.9777 Y-2.2709 N52105 X6.9708 Y-2.2845 N52110 X6.963 Y-2.2976 N52115 X6.9543 Y-2.31 N52120 X6.9446 Y-2.3219 N52125 X6.924 Y-2.3447 N52130 X6.8989 Y-2.3667 N52135 X6.886 Y-2.3771 N52140 X6.8726 Y-2.3867 N52145 X6.8585 Y-2.3955 N52150 X6.844 Y-2.4035 N52155 X6.8141 Y-2.4184 N52160 X6.7835 Y-2.4296 N52165 X6.768 Y-2.4345 N52170 X6.7523 Y-2.4385 N52175 X6.7363 Y-2.4413 N52180 X6.7202 Y-2.4432 N52185 X6.6876 Y-2.4455 N52190 X6.6656 Y-2.4445 N52195 X6.6546 Y-2.4435 N52200 X6.6438 Y-2.442 N52205 X6.6331 Y-2.4398 N52210 X6.6225 Y-2.4369 N52215 X6.6015 Y-2.4302 N52220 X6.5844 Y-2.4219 N52225 X6.5762 Y-2.4173 N52230 X6.5683 Y-2.4122 N52235 X6.561 Y-2.4065 N52240 X6.554 Y-2.4002 N52245 X6.5407 Y-2.3867 N52250 X6.5304 Y-2.3716 N52255 X6.5257 Y-2.3639 N52260 X6.5218 Y-2.3558 N52265 X6.5186 Y-2.3474 N52270 X6.516 Y-2.3388 N52275 X6.5119 Y-2.321 N52280 X6.5107 Y-2.3009 N52285 Y-2.2909 N52290 Z0.1606 N52295 G0 Z0.2 N52300 X6.8211 Y-2.0594 N52305 Z0.1606 N52310 G1 Z-0.0394 F13.123 N52315 X6.8091 Y-2.0601 F39.37 N52320 X6.7972 Y-2.0615 N52325 X6.7855 Y-2.0641 N52330 X6.7739 Y-2.0675 N52335 X6.7625 Y-2.0721 N52340 X6.7515 Y-2.0774 N52345 X6.741 Y-2.0837 N52350 X6.7309 Y-2.0907 N52355 X6.7201 Y-2.0998 N52360 X6.7096 Y-2.1093 N52365 X6.6999 Y-2.1195 N52370 X6.6905 Y-2.1301 N52375 X6.6811 Y-2.1423 N52380 X6.6721 Y-2.1549 N52385 X6.6639 Y-2.1679 N52390 X6.6561 Y-2.1813 N52395 X6.6486 Y-2.1963 N52400 X6.6415 Y-2.2115 N52405 X6.6353 Y-2.227 N52410 X6.6295 Y-2.2428 N52415 X6.6238 Y-2.2612 N52420 X6.6189 Y-2.2799 N52425 X6.6154 Y-2.2988 N52430 X6.613 Y-2.318 N52435 X6.6125 Y-2.3326 N52440 X6.6131 Y-2.3471 N52445 X6.6141 Y-2.3542 N52450 X6.6156 Y-2.3614 N52455 X6.6193 Y-2.3755 N52460 X6.6241 Y-2.3862 N52465 X6.6268 Y-2.3912 N52470 X6.63 Y-2.396 N52475 X6.6336 Y-2.4004 N52480 X6.6377 Y-2.4044 N52485 X6.6467 Y-2.4119 N52490 X6.6578 Y-2.4174 N52495 X6.6635 Y-2.4198 N52500 X6.6693 Y-2.4216 N52505 X6.6752 Y-2.4228 N52510 X6.6813 Y-2.4236 N52515 X6.6938 Y-2.4243 N52520 X6.7134 Y-2.4224 N52525 X6.7231 Y-2.4209 N52530 X6.7325 Y-2.4186 N52535 X6.7417 Y-2.4153 N52540 X6.7507 Y-2.4114 N52545 X6.7682 Y-2.4023 N52550 X6.7869 Y-2.3888 N52555 X6.7958 Y-2.3816 N52560 X6.8043 Y-2.3739 N52565 X6.8122 Y-2.3656 N52570 X6.8196 Y-2.3569 N52575 X6.8339 Y-2.3388 N52580 X6.8487 Y-2.3151 N52585 X6.8557 Y-2.3031 N52590 X6.8622 Y-2.2908 N52595 X6.868 Y-2.2782 N52600 X6.8733 Y-2.2654 N52605 X6.8832 Y-2.2393 N52610 X6.8885 Y-2.2221 N52615 X6.893 Y-2.2048 N52620 X6.8961 Y-2.1872 N52625 X6.8984 Y-2.1695 N52630 X6.899 Y-2.1552 N52635 X6.8986 Y-2.141 N52640 X6.8977 Y-2.134 N52645 X6.8965 Y-2.127 N52650 X6.8932 Y-2.1131 N52655 X6.8888 Y-2.1023 N52660 X6.8862 Y-2.0971 N52665 X6.8833 Y-2.0922 N52670 X6.8798 Y-2.0876 N52675 X6.876 Y-2.0832 N52680 X6.8676 Y-2.0751 N52685 X6.8628 Y-2.0716 N52690 X6.8577 Y-2.0685 N52695 X6.8468 Y-2.0638 N52700 X6.8405 Y-2.062 N52705 X6.8342 Y-2.0605 N52710 X6.8277 Y-2.0597 N52715 X6.8211 Y-2.0594 N52720 Z0.1606 N52725 G0 Z0.2 N52730 X7.0996 Y-2.0669 N52735 Z0.1606 N52740 G1 Z-0.0394 F13.123 N52745 X7.1069 Y-2.0457 F39.37 N52750 X7.2754 N52755 X7.3161 Y-2.3376 N52760 X7.5544 Y-2.0457 N52765 X7.7143 N52770 X7.707 Y-2.0669 N52775 X7.6873 N52780 X7.6731 Y-2.0678 N52785 X7.6661 Y-2.0687 N52790 X7.6593 Y-2.0703 N52795 X7.6528 Y-2.0725 N52800 X7.6464 Y-2.0754 N52805 X7.634 Y-2.0823 N52810 X7.6235 Y-2.0927 N52815 X7.6187 Y-2.0982 N52820 X7.6144 Y-2.104 N52825 X7.6108 Y-2.1103 N52830 X7.6076 Y-2.1169 N52835 X7.6021 Y-2.1307 N52840 X7.5266 Y-2.3527 N52845 X7.5228 Y-2.3649 N52850 X7.5215 Y-2.3709 N52855 X7.5208 Y-2.377 N52860 X7.5209 Y-2.383 N52865 X7.522 Y-2.389 N52870 X7.5257 Y-2.401 N52875 X7.5348 Y-2.4087 N52880 X7.5397 Y-2.4117 N52885 X7.5449 Y-2.414 N52890 X7.5505 Y-2.4154 N52895 X7.5563 Y-2.4161 N52900 X7.5684 Y-2.4165 N52905 X7.5881 N52910 X7.5807 Y-2.4382 N52915 X7.3227 N52920 X7.3301 Y-2.4165 N52925 X7.352 N52930 X7.3663 Y-2.4156 N52935 X7.3732 Y-2.4147 N52940 X7.38 Y-2.4131 N52945 X7.3866 Y-2.4109 N52950 X7.393 Y-2.408 N52955 X7.4054 Y-2.4011 N52960 X7.4159 Y-2.3907 N52965 X7.4207 Y-2.3852 N52970 X7.425 Y-2.3794 N52975 X7.4286 Y-2.3731 N52980 X7.4317 Y-2.3665 N52985 X7.4372 Y-2.3527 N52990 X7.5236 Y-2.0988 N52995 X7.5318 N53000 X7.2525 Y-2.4382 N53005 X7.236 N53010 X7.1854 Y-2.0999 N53015 X7.1937 N53020 X7.1119 Y-2.3404 N53025 X7.1089 Y-2.3505 N53030 X7.1067 Y-2.3606 N53035 X7.1063 Y-2.3657 N53040 Y-2.3709 N53045 X7.107 Y-2.3813 N53050 X7.1096 Y-2.389 N53055 X7.1113 Y-2.3927 N53060 X7.1133 Y-2.396 N53065 X7.1158 Y-2.399 N53070 X7.1187 Y-2.4018 N53075 X7.1252 Y-2.4068 N53080 X7.1361 Y-2.4113 N53085 X7.1417 Y-2.4132 N53090 X7.1474 Y-2.4146 N53095 X7.1591 Y-2.4162 N53100 X7.1711 Y-2.4168 N53105 X7.1638 Y-2.4382 N53110 X6.9733 N53115 X6.9807 Y-2.4165 N53120 X6.9901 N53125 X7.0065 Y-2.415 N53130 X7.0144 Y-2.4137 N53135 X7.0222 Y-2.4117 N53140 X7.0296 Y-2.4088 N53145 X7.0368 Y-2.4051 N53150 X7.0508 Y-2.3966 N53155 X7.0631 Y-2.385 N53160 X7.0689 Y-2.3788 N53165 X7.0739 Y-2.3722 N53170 X7.0783 Y-2.3652 N53175 X7.0821 Y-2.3577 N53180 X7.0887 Y-2.3421 N53185 X7.1606 Y-2.1307 N53190 X7.1644 Y-2.1185 N53195 X7.1658 Y-2.1125 N53200 X7.1665 Y-2.1064 N53205 X7.1664 Y-2.1003 N53210 X7.1654 Y-2.0943 N53215 X7.1618 Y-2.0823 N53220 X7.1525 Y-2.0746 N53225 X7.1476 Y-2.0716 N53230 X7.1423 Y-2.0694 N53235 X7.1367 Y-2.068 N53240 X7.1308 Y-2.0673 N53245 X7.1186 Y-2.0669 N53250 X7.0996 N53255 Z0.1606 N53260 G0 Z0.2 N53265 X-4.5839 Y4.0915 N53270 Z0.1606 N53275 G1 Z-0.0394 F13.123 N53280 X-4.7045 Y4.4162 F39.37 N53285 X-4.8227 Y4.0915 N53290 X-4.5839 N53295 Z0.1606 N53300 G0 Z0.6 N53305 M5 N53310 G54 G0 Z0. N53315 M30 %
Last edit: 1 year 1 month ago by andypugh.
1 year 1 month ago #334355 by andypugh
Replied by andypugh on topic Program cnc linux
I tried to up load a jpg file but it kept saying didn't load.
You need to "attach" the file with the "attachments" button then "include" it into the post.
Time to create page: 0.354 seconds
