linux 4.1.195 issue
5 years 3 months ago #215231 by crowloy
linux 4.1.195 issue was created by crowloy
I installed 4.1.195 kernel from source with the latest rtai patch. configuring linuxcnc for uspace due to not being able to use the rtai since I have a 7i92 board, I find that I get ALOT of watchdog error's on the 7i92 to the point of being absolutely useless. linux is set for low-latency desktop on a I5 processor. Is anyone else seeing this?
5 years 3 months ago #215232 by PCW
Replied by PCW on topic linux 4.1.195 issue
The "Low Latency Desktop" is not real time, you need to select
"Fully Preemptable Kernel"
5 years 3 months ago #215239 by crowloy
Replied by crowloy on topic linux 4.1.195 issue
that doesn't appear to be an option though.
No Forced Premption (Server)
Voluntary Kernel Premption (Desktop)
Preemptable Kernel (Low-Latency Desktop)
These are the only options available.
5 years 3 months ago #215255 by PCW
That suggests that you did not apply the real time patches
Is there any reason you are not using the latest LinuxCNC (2.8.2) ISO?
5 years 3 months ago #215269 by crowloy
I applied the rtai 5.3 patches to a bare 4.1.195 kernel. Then did the make oldcconfig and make menuconfig to enable an option for rtai. i wasn't aware I needed to install the rt patch on top of all of this.
As for the 2.8.2 iso, I started with linux mint 19, installed pathpilot 2.0 on it. I have since upgraded that to 2.7 I believe. I run linuxcnc 2.8.2 on a separate account with qtplasmac for my plasma table. Pathpilot is used for my milling machine. I need to look into setting up qtdragon, as I can't stand the look of gmocappy or axis.
5 years 3 months ago #215274 by PCW
Yes, you need to apply the Preempt-rt patches that match the exact kernel you are using. 4.1.195 doesn't have such patches so I would probably choose the latest of the 4 series kernels with a RT patch = linux-4.19.196
Building the kernel would be something like this:
cd ~
sudo apt-get update
sudo apt-get install build-essential bin86 libssl-dev bc libelf-dev bison flex libqt4-dev libncurses5-dev pkg-config
mkdir rtlinux
cd rtlinux
wget www.kernel.org/pub/linux/kernel/v4.x/linux-4.19.196.tar.xz
wget www.kernel.org/pub/linux/kernel/projects...19.196-rt83.patch.gz
tar -xpf linux-4.19.196.tar.xz
gunzip patch-4.19.196-rt83.patch.gz
cp patch-4.19.196-rt83.patch linux-4.19.196
cd linux-4.19.196
cat patch-4.19.196-rt83.patch | patch -p1
make xconfig
make -j4
sudo make modules_install
sudo make install
The following user(s) said Thank You: arvidb
Time to create page: 0.381 seconds
